Page 8 of 26 FirstFirst ... 45678910111218 ... LastLast
Results 701 to 800 of 2522
Thread: 2013 Spitfire
  1. #701
    such a great bike for this type of terrain
  2. #702
    Reputation: JustMtnB44's Avatar
    I finally got my upgrade Spitfire V2 put together last week and got a ride in over the weekend. I am really happy with it so far. The frame fits me perfectly and everything went together with no issues. I definitely notice some of the improvements over the V1, mostly how much smoother the suspension action is and the increased lateral stiffness.
    Parts list (mostly taken from my V1):
    RS Revelation Team
    Easton Havoc wheels
    Conti Trail King 2.4F/2.2R
    SLX crankset
    X.9 rear derailleur, X.0 shifter
    MRP Lopes SL chain guide
    Candy 2 pedals
    Syncros stem
    Easton Havoc bars
    Banshee seatpost and collar (will be replaced once I get another dropper post)
    I bought the 650b dropouts as well and a DT Swiss M1700 wheelset, just need a 650b fork and then I will try that out. I am debating between the new RS Pike or Xfusion Sweep; I would like to get the Sweep, if it is in fact available soon.
  3. #703
    May 2005
    You can fit a 2.3" 650B Neo Moto in the Revelation fork. It would at least get you started while waiting for the new offerings to appear.
    2013 Banshee Spitfire V2 650b
  4. #704
    I already have 650b sets of Nevegal 2.35 and Hans Dampf 2.35 so I don't want to buy any more tires. Also the M1700 wheels have a 15mm front hub and the Revelation is 20mm. I'm also not a fan of using improperly matched parts, so I can wait for a real 650b fork.
  5. #705
    Reputation: saruti's Avatar
    hi guys
    I've ordered a 2014 spitfire frame. blue, medium, 142x12.
    I want to start ordering parts for the bike...
    what seat post do I need if I want a KS LEV? what size? length?
    what size BB? regular or press fit?
    any more info can help
    thanks
  6. #706
    Quote Originally Posted by saruti View Post
    hi guys
    thanks
    Did you consider looking at the website? All of that info is on there.
    Spitfire | Banshee Bikes: DH Race, Freeride, All Mountain, Trail, Slopestyle, DJ/Street/4x, Aggressive Trail, Cross Country
  7. #707
    JustMtn, sure I checked
    but I cant understand if the BB is regular 73 with treaded or press fit...
    and the question about the seat post, I know its 30.9.
    but, what length do I need? 300? 400? with 100mm of travel? or 125mm of travel?
  8. #708
    Hard funkin´ Kraut
    Reputation: NoStyle's Avatar
    May 2005
    The BB is a regular ENG/BSA 73 mm, no Press-Fit.
    Towards your Seatpost: Isn´t this a Question of personal Preference? Hard to tell if 100 mm, 125 mm or maybe 150 mm Travel-Adjust would work for you. This too could have Influence for your prefered Length ...
  9. #709
    NoStyle, thanks
    about the seat post, I know that I want 100mm of travel. but willa 400mm KS lev post will work with the seat tube? will it be too long? or does the seat tube is not long enough ?
    thanks
  10. #710
    Hard funkin´ Kraut
    May 2005
    Huh, hard to tell ...
    Look at my Spitfire in Post 704. It´s a large Size Frame with a Thomson Elite Post 42 cm, Saddle put down as much as possible. I can´t measure right now but I think there´s 10-12 cm Post left outside the Seattube. For my personal Liking 40 cm would be to long, especially when going 125 or 150 mm Travel-Adjust ...
    Is it too long for you? Maybe yes ... and if I were you I would take the Benefit of more Travel than 100 mm ...
  11. #711
    thanks NoStyle
    you have a nice bike :-)
    I think I'll go for the 125mm travel seat post.
    and maybe it will be best to wait with it till I get the frame and measure things.
    thanks
  12. #712
    Hard funkin´ Kraut
    May 2005
    ... maybe it will be best to wait with it till I get the frame and measure things.
    Thank you!
    I think it´s the best you can do. Getting the Seat up enough for proper Position is important. But for me Standover-Clearancein steep techy Terrain is really important, maybe for you too.
  13. #713
    May 2010
    I use a 380mm reverb with a 125 mm drop, I have a medium frame and have 31inch inseam. I have more than enough post inserted in the seatube and when the seat is at its lowest it is completely out of the road... Hope this helps.
  14. #714
    thanks guys
  15. #715
    Dab-O-Matic
    Reputation: Simplemind's Avatar
    RE: Seatpost length: I would add up the heights of the BB and seat tube and compare that with what you are currently riding. That should give you a rough approximation.
  16. #716
    Hard funkin´ Kraut
    May 2005
  17. #717
    Quote Originally Posted by zoro View Post
    Can someone point me out to a chainguide that will fit proper on the V2 Spitty? My SRS+ looks wonky on it even in the wide position.
    From what I gathered, Straitline seems good and Gamut also? E13 is a no go, no for a clean install at least.
    Please don't tell me to buy a clutch rear D and ditch the chainguide.
    Attachment 782962
    +1, I'm trying to fit a Gamut P30 and its not looking promising... This is about the only position it will fit and while I haven't checked whether the tensioner will work in all the gears and travel (as my rear hub has not yet arrived) the top guide appears to be too low/right in the chain path. It doesn't appear that a small amount of dremelling will solve the problem.
    JustMtnB44's setup with the mrp lopes guide looks to fit well. What chainring are you running and was any grinding required to fit the lopes guide? If I'm honest I'm not sure I need a full on bash guard on this bike, I went with the gamut setup because it works well on my DH bike.
    Any advise is appreciated.
  18. #718
    Reputation: hartwerks's Avatar
    Oct 2011
    2013 Spitfire
    For what it's worth, I could not get my Straitline Silent Guide (32 tooth specific) to fit on my medium frame.
  19. #719
    Quote Originally Posted by Aweather View Post
    Here is another picture of my setup. I am running a 32T chainring and did not do any grinding or trimming of the Lopes guide. The guide is rotated all the way to one side; it basically only fits in one position. There is probably 3mm of clearance between the chainstay and guide.
    I had an E13 XCX on my V1 Spitfire, but sometimes the chain would drop off the bottom of the chainring and get stuck between the chainring and ISCG tabs. The Lopes guide basically just adds the lower roller to prevent this. However, now the chain is very close to the chainstay and rattles against it. I need to wrap it in tape or a tube or something to keep it quiet.
    Attached Thumbnails Attached Thumbnails 2013 Spitfire-spitfire-chain-guide.jpg
  20. #720
    Quote Originally Posted by hartwerks View Post
    It fits on my large frame but rotated all the way to one side
  21. #721
    Aug 2005
    Hey dudes,
    So it looks like I'm going to be getting a V2 frame to replace my V1 frame. I need some advice on what size to pick.
    I am 5'7/5'8 and I am currently using a Medium frame. Are the V1 and V2 mediums sizes the same? Is the reach longer? I think the V1 medium is at about the maximum reach I can handle when my seat is up all the way for climbing. Going downhill the bike feels perfect.
    Would you suggest to go with another medium frame? I had trouble finding a seat post long enough for the V1 frame, to get proper leg extension when climbing. Switching to a dropper post (KS 900r) fixed that.
    Any advice from someone my height would be greatly appreciated.
    Oh and are the bottom headtube sizes different?
  22. #722
    May 2010
    I'm 5'8 and ride a medium, my last bike was a small meta4x with a top tube of 559. I was really concerned about the long reach of the spitfire v2 but I decided to go for it anyway and it fits perfectly. I would go for medium but its your choice.
  23. #723
    Aug 2005
    Thanks for the response monkeyninja. I think I'm with you on the medium suggestion. I wouldn't want to get the small and have it too small or get it and find out the seat tube is way too short.
    How long is the stem on yours?
  24. #724
    May 2010
    50mm stem 740mm bars
  25. #725
    Sov
    Sov is offline
    I'm 5'7, 31" inseam. I think that I am in between sizes.
    I originally had a small Spitfire with a 50mm stem and it felt great. I had the front triangle replaced and upsized to a medium and it also felt great with a 50mm stem.
    The reach was noticeably longer initially but still comfortable. I have since put on a 45mm stem.
    The V2 reach is 23mm longer than the V1. I think the V1 was designed around a 70mm stem, whereas the V2 was designed around a 50mm stem.
    At 5'8, I'd pick a medium but it depends on how you want to set your bike up and what trails you ride.
    What stem length do you run on your V1 and what length do you intend to run on the V2?
    Do you ride tight trails or would you prefer the stability of a longer bike?
    You might find that the offset head on your KS dropper might stretch you out too much - a medium with 50mm stem and straight seatpost would be the way to go imho.
    Regarding headtubes... the V1 and V2 are different - both are 44mm top cup but the V1 is a 49.6mm bottom cup and the V2 is 56mm.
  26. #726
    Aug 2005
    I think I have about the same measurements as you Sov. I'm 5'7 and around a 30/31" inseam.
    On my V1 Spitfire I've always used a 50mm stem. Who makes the 45mm stem? I plan on swapping over all the current parts to the new frame, stem included (minus the shock and lower headset cup).
    I guess it shouldn't be a big problem if the reach is only 23mm longer on the V2.
    This is my only bike, so picking between tight trails or higher speed ones is sort of a moot point. I ride everything on this bike and pretty much through myself down the hills on it as if it were my downhill bike.
    I guess if it comes down to it with the medium frame, I can always scoot my seat forward a bit and swap out the stem for a 40mm or 45mm one.
  27. #727
    Now I have finally put my V2 together, what an awesome bike!
    I really like the CCDB Air and how every small adjustment is noticeable
    The settings is 4 clicks of LSC and 3 clicks of LSR as I read in this thread, thanks for posting useful settings, works great!
    As it is now with a 150 mm Revelation and the internal headset-cup it is a bit low, so I cannot run it in the lowest setting too much rock on my trails...
    I plan on using a external lower cup for even more awesomness in the future.
    Weight is appr 13 kg with pedals according to my probably inaccurate scale
  28. #728
    how do I choose the proper dropper seat post length?
    I want to order the KS LEV
    In 125mm /5” travel
    In the KS site, I see they have it in: 385mm / 125mm
    Does the 385mm size is with the 125mm travel or without?...
    Saruti, 385 should be the seatpost in the longest setting, i.e. the shortest will be 385-125 = 260 mm
  30. #730
    thanks
    any one here 170m high with Medium frame using the KS ?
    what length do you use?
    thanks
  31. #731
    Note: useful length is 260 to 385 mm minus the insert length of course
  32. #732
    Aug 2005
    What tunes on the shocks are supposed to be run on this frame?
    2012 Fox Float rp23 kashima 7.875 X 2.25 - Pinkbike
    Would that shock work out?
  33. #733
    looks like you are holding a bolt of lightning
  34. #734
    Attached Thumbnails Attached Thumbnails 2013 Spitfire-img_20130515_211046.jpg
  35. #735
    I had the same issue same guide, i cut a bit off the bottom curve of the boomerang vertically to just clear the bottom slider left side screws. Then i slotted out the bottom isg mount on the guide to clock it further anticlockwise but then the right hand allen screw doesnt align so i only use two screws to mount it. (hope that makes sense)
    I was really annoyed as i didnt want to modify chain guide.
    Anyway it does work ok except the chain rubs the top guide when in the 32&36 rear gear. Not ideal, it still only just clears bottom chain stay and chain still slaps that area because it is only millimeters away.
    I recon the 34,36T guide would work ok?
  36. #736
    Reputation: highrustler's Avatar
    hi guys
    thanks
    Are 2014's available? When are you expecting to take delivery?
  37. #737
    the 2014 will arrive in August
  38. #738
    size....
    hi guys
    the more I think about it, it looks like maybe I'll be better ordering a small frame...
    it looks like the geo of the small spitfire is more like the medium MKIII I have now.
    I'm 1,70cm. and using short 40mm stem on my bike now.Name:  MKIII2007.png
Size:  23.5 KB2013 Spitfire-spitfire2013.png
    what do you think?
  39. #739
    Hard funkin´ Kraut
    May 2005
    Sizing is very much based on personal Preference ...
    I´m 180/181 cm Tall and switched from a M to a L Spitfire. M was really good, but the large is that little Tad better on long Days in the Saddle. I know some german Riders, all 172 or 173 cm Tall, all going with a medium Spitfire and shorter Stem.
    Depends on how you like to sit on the Bike, as the Reach (Standing on Pedals and Body moving over the Bike) changes on every single Obstacle ...
  40. #740
    Reputation: BillT's Avatar
    I built my v2 (warranty upgrade from a v1)up yesterday and got a 15 mile ride on it today. Overall, I'm really happy with the bike so far...I like the geometry, the bike feels better the fast you push it, and it just feels much, much smoother than my v1. Assuming the pivot wear issues are all sorted out with this new design, I can see hanging on to this bike for a long while.
  41. #741
    Wow... that is one of the nicest spitfires I have ever seen!
  42. #742
    nice
    what size?
  43. #743
    Thanks for the compliments! It is a medium and while it is a bit heavier than my old el guapo, it does seem to pedal like it weighs a bit less. I plan on getting on a scale soon to see exactly how much it weighs bit my guess in the 29 lb range.
  44. #744
    How tall are you?
    thanks
  45. #745
    Dec 2011
    Thats intrigue!
    could you please share som info on that?
    changes, colors, anything?
    How tall are you?
    thanks
    I'm 5'9/10 with a bit of a longer torso and shorter legs and medium fits great.
  47. #747
    Here is my freshly built, 650b spitfire. Two short rides on it over the weekend as a shakedown and I'm very happy with it. I can't wait to get up to some proper trails in a weeks time! I spoke to the Gamut guys and sorted out that their p30 vpp guide will work, it fits and is working well so far.
  48. #748
    When I got my V1 Spitfire I had been testing a >12 kg Transition Bandit for some weeks and my 13,5 kg Spitty just pedalled so much better it was hard to believe it was much heavier.
    I think people only know how well a Banshee pedals after trying one. Never tried the KS link though...
  49. #749
    2013 Spitfire-spitfire-2014.jpghere are the 2014 spitfires
  50. #750
    Dec 2011
    damn, no green again! and that blue is even worse than red, on my side..
    'll take red one, eek
  51. #751
    OT:
    where did you find this? Any more info on the 2014 Rune and Legend?
  52. #752
    2013 Spitfire-legend2014.jpg2013 Spitfire-rune2014.jpghere
  53. #753
    Hard funkin´ Kraut
    May 2005
    Uhhh yeah, I like that Stealth Black Ano - Damn!!!
    But I´m keeping my 2013er large Spitfire, as it does a great Job and is incredible Fun to ride. And of course - unfortunately money´s a Factor, too ...
    @ baramats, coocoomike, BillT and Aweather:
    Wow, you Guys do have some killer Spitfire-Builds.
    Good to see a nice Mix-Up of 26ers and 650Bs!
    @ Keith, Jay and Jon:
    Are these the new revised 142x12 Dropouts? Any Info when they will be available?
    Many Greetings
    NoStyle
  54. #754
    Dec 2011
    Quote Originally Posted by NoStyle View Post
    NoStyle
    What's wrong with current version?
    Did not even buy the frame but ordered conversion kit for rear hub - just to be ready...
  55. #755
    Hard funkin´ Kraut
    May 2005
    Quote Originally Posted by Logoffski View Post
    Nothing really major - they work as they are. It has been discussed here
    Because of Riders Demand only the 142x12 Dropouts will become a Make-Over for all 2014 Primes, Runes and Spitfires, with Reliefs and Spacing due to the Syntace X-12-Standard ...
  56. #756
    Reputation: jlf.ski.bike.sail's Avatar
    my 2013 spitfire is being delivered tomorrow.....and now the 2014 comes out....haha.
    looks like they just cleaned up the welds. the rear linkage looks pretty much the same... any word on the new geo specs?
  57. #757
    Hard funkin´ Kraut
    May 2005
    These Pics are Renderings, just in another Color-Sheme than the Last-Year-Pics. Therefor no Welds.
    The only Things that changes are Color, more Shock-Options, and Reverb-Stealth-Ready. The Rest hopefully stays as amazing as it already is!
  58. #758
    Hi, anybody using Small size? How tall are you.. also if there's picture of the build, been looking but looks like they are all med, large sizes.. just want to check the seat tube length and proportion between S and M (visually)..
    Thanks..
  59. #759
    Sov
    Sov is offline
    I'm 5'7. Had a small, now on a medium - see my reply in post #729.
    Here's a pic of the complete small frame and another comparing a small vs a medium.
  60. #760
    @sov thanks for the pic, that is exactly what I was looking for
    Looks like there's enough space for dhx air in small frame, silly me of course because there's ccdb air option.
    Still not 100% sure about picking up an S or M, but I'm gonna use my old 50mm stem and 780 bar from my current am bike. I am 173cm with quite long hand span (177cm).
    Also anybody drilled 'stealth reverb' hole yet?
    Cheers..
  61. #761
    Hard funkin´ Kraut
    May 2005
    Quote Originally Posted by b15mo View Post
    ... Still not 100% sure about picking up an S or M, but I'm gonna use my old 50mm stem and 780 bar from my current am bike. I am 173cm with quite long hand span (177cm) ...
    From my positive Experience (switched from M to L) I can say maybe better go with the next larger Size. In your Case you might be better off with M and the 50 mm Stem or slightly shorter.
  62. #762
    Mar 2006
    Finally got the V2 buttoned up, wooh! Can't wait for the first ride, coming up in approx 1 hr.
    Specs:
    Frame: 2013 V2, Large
    Fork: Marzocchi 55CR, 170mm
    Wheels: Mavic Crossmax SX
    Drivetrain: SLX, 1x10
    Brakes: Avid Elixir
    Post: RS Reverb
  63. #763
    that is one good looking bike.. great components selection
  64. #764
    very cool, how is that marz 55cr, would love to hear a ride report on it.
  65. #765
    nice!
  66. #766
    Mar 2006
    After three rides I have to say I'm impressed, I like it even more than the V1. But without doubt, the fast flowy downhills are where this bike truly shines, she's a ripper! As I'm not a fancy fork-setting-sensitive kind of person I don't really have much to say about the 55 other than it's been great! Nice and simple to set up, very little bobbing on the uphills, nice and sensitive, seems to match the rear Fox nicely on the downhills. Would recommend! Although it apparently doesn't with a tapered steerer, which limits your headset choice slightly.
  67. #767
    Hard funkin´ Kraut
    May 2005
    Thundrbucket, would be nice to have a Side-Shot of your Bike. Looks amazing!
  68. #768
    Mar 2006
    Cheers guys, side shots coming up!2013 Spitfire-dsc_2503_copy.jpg2013 Spitfire-dsc_2507_copy.jpg
  69. #769
    Hard funkin´ Kraut
    May 2005
    Uhhh that´s hot !!! Thanks
  70. #770
    Reputation: theraggyone's Avatar
    Jun 2013
    Hi everyone new poster here.Wow some great looking examples . Ive just signed up to this forum after reading through this entire thread and deciding I should as found some really usefull info to help me with my current build. Im currently in the process of building my spitfire im just waiting on a couple of parts I should have it ready to ride by friday
    Will post more pictures when im finished
  71. #771
    Quote Originally Posted by Thundrbucket¨ View Post
    Cheers guys, side shots coming up!Click image for larger version.
ID:	804785Click image for larger version.
    Nice
  72. #772
    Wink
    Well, here's another RED Spitty :
    After 2 weeks comparing the geo chart with my 'slackened' oldie SX, and assembling my bro's rune v2, I decided to go with the S size. Rode it this morning aroung my home area and happy with the sizing. Can't wait for the weekend to ride it in proper trails..
    Components wise pretty standard :
    Fox DHX Air (from my SX) with 40mm Enduro Needle Bearing Kit
    Fox 32 150/120 (might switch to my 36 Float 160)
    780/38 fatbars (same as my DH bike for familiar feel) with 50mm Thomson X4
    5.1D/Hope 26" wheelset + Ardent EXOs (Might borrow and test my bro's WTB 650B wheels)
    Reverb Stealth (Custom seat tube hole, but very neat) + Salsa LipLock (just in case)
    Saint 165 Cranks + 32T + LG1+ set at Wide (will change to XT 785 dual but my wolftooth 30T still on the way)
    Zee RD, 11-36T, Saint Shifter, Etc.
    Yes, my S frame also doesn't have the front cable guide tab (just like some of you), and hopefully is being taken care by banshee dealer.
    Cheers and happy rides!
  73. #773
    Reputation: eurospek's Avatar
    Interesting front brake cable routing.
    konahonzo
  74. #774
    My setup for all of my bikes for few years now..
  75. #775
    Man that beast is low... o_O
  76. #776
    2 rides in and neither one of them felt like a test or shakedown ride. i was instantly comfortable on the bike and it sure rewards the rider's effort.
    Medium frame in slack mode Flip Chips
    650b drops
    Sun Ringle Black Flag Pros
    Fox 34 up front
    Maxxis Ardents
    Coming off of a Stumpjumper FSR 29, the Spitfire is way more playful. I've been riding for 25 years and finally feel like I've found the perfect bike. Great job, Banshee.
  77. #777
    Hard funkin´ Kraut
    May 2005
    ... Yes, my S frame also doesn't have the front cable guide tab (just like some of you), and hopefully is being taken care by banshee dealer ...
    Out of Curiosity: Turn a Page back and look at the other S-Size-Frames. They all don´t seem to have it ?!?!?
    Quote Originally Posted by moojo View Post
    ... and finally feel like I've found the perfect bike. Great job, Banshee ...
    Hell yes - that´s my Feeling too!
    Nice Spitfires - enjoy!!!
  78. #778
    Yes my dealer told me the black anodized one has the front cable tabs, and my red one doesn't. I don't mind (actually wish) if the lower downtube cable mounts that they forgot to weld, but the front upper one is very important. Still waiting for update. Can't mount cables properly, not a very good 1st impression for the QC, i hope it rides as well as 'all' the reviews.
    In this picture (hopefully) You can see the 'blank' upper front cable guide tab on my spitty :
    Our small rune v2 has the complete cable mount tabs :
  79. #779
    Hi b15mo, what is the exact spec of the Enduro needle bearing kit you using?
    NBKTREK40X10 or NBKRWC3988?
  80. #780
    Quote Originally Posted by eightyfive View Post
    hi b15mo, what is the exact spec of the enduro needle bearing kit you using?
    Nbktrek40x10 or nbkrwc3988?
    nbkrwc3988
  81. #781
    Jun 2013
    Cool-blue Rhythm
    Heres my red spitfire finished the build last night.cant wait for the week end to test it properly.well chuffed with it
  82. #782
    The Mountain Bike Life
    Reputation: mudpuppy's Avatar
    Looking good man! Red bikes are faster, it's science!
  83. #783
    May 2012
    Hi b15mo, may i know whats your height? And what u feel your small frame?
    M
  84. #784
    Quote Originally Posted by sorlo101 View Post
    M
    Hi Sorlo,
    I'm 173cm with 175cm arm span, the S with 780mm handlebar + 50mm stem feels great (for me)!
    Similar wheelbase from my previous AM bike (custom SX) that was even slacker (65HA) but the seattube was to steep for uphills, so I got this spitty.
    It may look small (because i'm quite fat hahaha) but I can balance my bike easily, i imagine if it's 25mm longer it will be too forward biased for my liking (also don't like 35mm stem as I found it harder to bunnyhop etc)
    Cheers!
  85. #785
    FM
    FM is offline
    Reputation: FM's Avatar
    Apr 2003
    Great pic b15mo!
    Bonus style points for coordinating shoelaces with frame color. (yeah me too)
  86. #786
    boring weight question- has anyone got a Spitty coming in sub 30 pounds?
  87. #787
    beater
    Reputation: evasive's Avatar
    Feb 2005
    Quote Originally Posted by mudpuppy View Post
    My rafting friends always say that red floats, too.
  88. #788
    Aug 2005
    Finally got mine finished up
  89. #789
    Quote Originally Posted by cunningstunts View Post
    No problem, mine is 28,66 lbs including flat pedals.But I do not use fancy heavy seatpost with that elevator function
    It's a Large frame in red, Revelation fork, CCDB Air. Pic in post #8 in page 29.
  90. #790
    Quote Originally Posted by baramats View Post
    That's superlite.. mine's 14.48 KG (almost 32 Lbs) with fox 32.
  91. #791
    Yes, It is probably incorrect, must find a better scale for reference weighting. But certain it is under 30 pounds. Single ring up front, light fork and wheelset, tubeless...
    I'll post an update when more correct numbers are in.
  92. #792
    Just info, plenty of clearance for 30T chainring :
    Hopefully the wide-narrow thingy works..
  93. #793
    Sep 2012
    If someone's looking for a chainguide, I've got a brand new Stratiline Silentguide 32t for sale. Price : 85 euros (shipping costs depend on location).
    Straitline SilentGuide - Pinkbike
    PM if interested
  94. #794
    OK, so it's a 2011 spitfire frame technically... but figured I'd post a riding shot from the weekend.2013 Spitfire-1015552_10151421320542413_1680573213_o.jpg
    There is definitely a little favourable tilt going on here from my photographer mate. haha
    Banshee Bikes Designer
    www.bansheebikes.com
    Banshee Blog
  95. #795
    Hard funkin´ Kraut
    May 2005
    Nice Keith ... and looks steep
  96. #796
    Steep enough that you need to commit... but scoped out some proper steep stuff on this little scout. Need to do a bit of trail building to make them ridable tho. If it happensI'll try to get photos.
    Banshee Blog
  97. #797
    Sep 2012
    First ride with the Spitfire today. Did a 30min climb. The bike climbs pretty well even at 14kg, no dropper post yet (waiting for my Thomson) and flat pedals. Really impressed by how it rides downhill. The rear triangle feels stiffer than the one of my DH bike (Lapierre Pendbox, ok....maybe not the stiffest on the market). With the DBair and the Deville the bike really feels like a mini-DH bike.
    Pics will follow. Just need to find a proper camera
  98. #798
    Sep 2012
    13.85kg as shown on the pictures.
    Enjoy
    Spitfire-V2-2013 Photo Album - Pinkbike
  99. #799
    Hard funkin´ Kraut
    May 2005
    Really nice Spitfire!
  100. #800
    @SuperQ.
    wow. the nicest one i've seen yet! what do you think of the BOS?
Members who have read this thread: 55
