Page 5 of 26 FirstFirst 12345678915 ... LastLast
Results 401 to 500 of 2512
Thread: 2013 Spitfire
  1. #401
    Reputation: Dogboy's Avatar
    Quote Originally Posted by hiawatha-de View Post
    Is that scale reading 7.15 lbs? Can't tell if that's the current time or weight? Is that a veggie scale or what?
    I read it as 7lbs15.3oz.
  2. #402
    I just got off of a Yeti SB 66 and the frame weights were actually pretty similar to the Spitfire. My frame was a small and weighed in at 7.5lbs with quick release drop outs, about a 100g heavier with the threw axle. I preferred the stiffness and efficiency of the Yeti over some lighter options, I think stiffness is hard to quantify numerically but makes a significant difference in ride quality especially landing off camber etc. I think the most important thing for a bike is Fit i.e. geometry. The Yeti just had too slack a seat angle climb comfortably on for a long time. I am excited about the Spity because it is stiff with spot on geometry. Mine should be here next week.
  3. #403
    weight
    Quote Originally Posted by Dogboy View Post
    That makes more sense. Just 7/10 shy of 8lbs.
    Weight is kinda of a big deal for a bike in this category. One of the reasons I bought the V1 Spitfire was because of the relatively low weight. I climb the spitfire more than I descend and use it as an XC bike as I'm constantly pedaling all the time. In these situations weight can be an issue as your plugging along rather than ripping along. (The spitfire does rip on the flats, however it is obvious that one can feel a little loss in momentum on the uphill due to the extra weight and the slight pedal feedback that occurred).
    With that said I have a fully dedicated XC bike that is much lighter and faster (trek Superfly 100 29'er), but I was always pulling out the Spitfire for everyday riding as the fun factor was more overall. The climbing was always good with the V1 cause I got the weight pretty low and the descents and trail carving were just way to much fun and made up for its sluggishness on the ups.
    If anything the extra weight will make you a stronger rider in terms of pedaling and endurance. I'm still gonna run my V2 as an XC bike so it will be interesting to see the difference with the added weight which I'm sure will be primarily noticeable on the ascents. The extra weight will probably be noticeable at first and then quickly disappear once I get accustomed.
    I'm hoping the extra weight isn't so noticeable that it takes the fun out of pedaling the bike. Kinda like my wildcard did when I tried to XC the thing. Not fun at all.
  4. #404
    Reputation: savo's Avatar
    A simple guess is that a 650b wheel would not fit in the rear with the 26'' dropouts... but maybe it does. Would someone try?
  5. #405
    Hard funkinī Kraut
    Reputation: NoStyle's Avatar
    May 2005
    Quote Originally Posted by FM View Post
    What argument?
    Don't get me wrong, light bikes are great if there are no compromises taken getting there.
    The spitfire has adjustable drop-outs, those will add weight compared to the simpler designs used by other brands.
    Transition lists the covert as 7.68lb with shock, no adjustable drop-outs. The carbon version is 6.8lbs & $2800. Those are reasonable weights IMO ...
    ... I just don't see much point in getting hung up over <1lb of frame weight, you are getting extra durability, stiffness and adjustability with it. Frame weight doesn't tell you much about how the bike will actually ride.
    Plus: Banshee builds Bikes that are meant to be ridden hard, real hard if you are willing or able to. This inevitably means something more Flesh/Material to achieve the Durability and Stiffness that is needed for this Purpose => a bit more Frame-Weight than average.
    But how much more? Compared to what? What Features included? Prize? Turner 5 Spot? TR Bandit? SC Blur? Liteville 301? Canyon Nerve AM? Intense Trazer? Spezi Stumpjumper? Devinci Dixon? Nicolai Helius AC? Trek Fuel EX/Remedy? any other Aluminum-Frame with 5/5,5" Travel ... ?
  6. #406
    Quote Originally Posted by meekkho View Post
    Hi
    Is that a medium or a small?
    it's a medium (i'm pretty sure)
    this one i think is a large:
  7. #407
    Yeah that's a large.
    And NoStyle, no bike company makes bikes that aren't made to be ridden hard. That's a crazy argument.. "Ok here is your new Blur LT, now don't go to fast, ride anything off camber, or do any jumps" said no one ever. In this day and age 6lb bikes can be ripped on for years. This isn't 2005 when bikes were breaking all over the place if they weighed less than 8lb, this is 2012 where you can have a 170mm freeride bike weighing in under 30lb, or a 210mm DH bike weighing in at 33 and under.
    But I am tired of beating the dead horse, the Spitfire is heavy for it's category, bottom line. Does it make it worse? Probably not. Does the heavy weight make it better? Probably not. Sure the bike as whole is better than many, but even then that's personal preference, just like wanting a light bike.
  8. #408
    Quote Originally Posted by savo View Post
    i think keith mentioned he designed the frame for tonnes of tire/mud clearance, so if you ran a pinner tire you could fit a 650 wheel in with 26" dropouts and keep the backend super short. oh but maybe he was talking about the rune...
  9. #409
    FM
    FM is offline
    Reputation: FM's Avatar
    Apr 2003
    Quote Originally Posted by Dlongb13 View Post
    Maybe save 1/4lb with a quick release fork?!
  10. #410
    May 2005
    Quote Originally Posted by boomforeal View Post
    Yes he mentioned it about the Spitty after I questioned all the clearance I saw in a previous picture.
    I am very curious about this as well to see what size if any 650B wheel/tire combo will fit the 26" dropouts. Hopefully someone will give it a shot for kicks and giggles.
    2013 Banshee Spitfire V2 650b
  11. #411
    7 lbs 15. 3 oz.....Just under 8 lbs
  12. #412
    Just checked UPS, bike sat in Portland for 3 days! Will be here Tuesday non. All parts cleaned prepped and ready to go.
  13. #413
    Reputation: hrdude's Avatar
    Feb 2006
    Quote Originally Posted by skidad View Post
    Nevermind, +2
  14. #414
    But so would the front...
  15. #415
    Got my frame and parts ready to build but have to admit I'm having second thoughts about frame size.
    I have a medium and I am 175cm (5'9") tall.
    I think I am ok with most of the numbers, but the reach is 1 3/4" (44.5mm) longer than my med Rune. That seems HUGH. I've been liking a 70mm stem on the Rune, and was going to go to a 60mm on the spity but that is not nearly enough. Not sure how the bike would climb technical single track with a 50mm, but that still seem too long of reach. The WB is quite long too.
    I'm not sure how accurate my rune reach is as I measured it with a level and tape measure. Came out to 381mm. Reach on med Spity in 427mm
    Should I get a small? Any opinions?.....Keith?
  16. #416
    Quote Originally Posted by Nescafe View Post
    If you stick with the medium frame you'd definitely benefit from droping to a 50mm stem (the V2 frames are designed to work better with shorter stems). The reach number shouldn't really be considered on its own. In seated position, the top tube of the V1 and V2 are the same (presuming same parts), but the reach is longer because I have steepened the seat tube on the V2.
    At 5'9" you may benefit from being on a small frame if you generally prefer the feeling of smaller frames, you are close to borderline on sizes, although for all day rides I would still put you on a medium with shorter stem.
    The new frames have a more agressive geometry that helps with weight distribution, so climbing with a short stem is not going to be an issue. Switching to the more forward position may take a couple of rides to get used to, but once you do you'll feel more comfortable at speed and have better front wheel traction.
    Banshee Bikes Designer
    www.bansheebikes.com
    Banshee Blog
  17. #417
    I'm 5'10 and originally had a 70 mm stem on my V1 spitfire. I could have even gone to a 60mm which would have probably helped to liven up the front end. The wheelbase is much longer on the spitfire and helps with climbing. The low front end and seat angle help, too.
    I believe anything over 50mm might hinder maneuverability of the front end on the spitfire because the wheelbase is plenty long (just a guess).
    I'm actually gonna run a 40mm stem on my new V2 due to the slight geo changes and I'm suspecting it will not have any effect on it's climbing potential, but rather make it more lively.
  18. #418
    Oh yeah, forgot to say my V1 was a medium and my V2 is gonna be a medium.
    I had trouble with sizing between a medium and large when the V1 spitfire came out in 2010. I went with Keith's advice and went with the medium. He was right with his suggestions.
    What stem length do you suggest running on the V2 spitfire, Keith?
  19. #419
    Stem length is a personal thing, and depends on arm length, riding style, frame size etc, but generally I wouldn't recommend going over 60mm for the V2 frames. Personally when I went from a large spitfire V1 (I'm just over 6'2" and have fairly long arms) with 70mm stem. I went to a large V2 and currently have a 60mm stem with same bars, and I'm considering going to 50mm stem just to make things a touch more lively, as I don't feel I need a 60mm stem to stay comfortable and certainly not to keep the front end down as I have no issues with that.... only you can choose what is best for you.
    Banshee Blog
  20. #420
    Thanks for your reply's and insight Keith.
    Some of the trails I ride are slow speed tight twisty "black diamond" so a smaller bike might be better, but
    a short stem as you recommend (on these bikes) on a small would make the cockpit too small for seated pedaling for me. If I went with a small I would need a new dropper post as well as mine would be short. I hope with this geometry that the WB wont feel as long as it is on the trails I like to ride. Thanks again, looking forward to get her built up today.
  21. #421
    Sled of Lead.
    Reputation: Lead-Sled's Avatar
    Ok, I went to the local bike shop and found a frame. So I weighed it.
    Size medium raw/clear coat comes in at 8.00 lbs exactly with 12x142 dropouts and axle.
    My black frame I ordered still hasn't arrived yet.
  22. #422
    My black one is sitting at ups. I'll have it Tuesday.
  23. #423
    Hard funkinī Kraut
    May 2005
    8.00 lbs??? Pffff ... thatīs way to heavy, man ...
  24. #424
    Here is my large spitfire I just built up last night. Super stoked on this bike!
  25. #425
    ...and i am now officially rethinking my decision to switch to a red frame. but all the colors look good, seems like you can't go wrong. sharp bike joe!
    edit: i was supposed to pick up my frame on friday but showed up late to lights out and locked doors... damn had all the parts laid out and beers on ice to build it this weekend! won't be able to make another pickup run until thursday afternoon, trying to convince my wife to play courier on her lunch break tomorrow
  26. #426
    So glad I got black
  27. #427
    So it begins...
  28. #428
    Reputation: JustMtnB44's Avatar
    I'm getting super jealous seeing all these new frames...I just want to get my new Spitfire on order, but I still haven't heard back from Trident regarding actually ordering my upgrade deal.
  29. #429
    My V2 arrived with all the parts ready to swap from the V1, but can't ride until after board exams in 2.5 weeks.
    Keith: I have a suggestion. You probably have a few experts/pros riding the V2 with intentions of giving professional ride reports, but have you ever considered shipping one out to Pinkbike's Brad Walton? He has reviewed many bikes and rips without a doubt. Plus, his ride reports on Pinkbike are very technical, well-thought out, exhaustive, and articulate.
    Banshee would benefit from his impressions, I believe. Just a suggestion. Reason I mention it is because his ride reports are well-respected. I could give mine, but they would include words like cool, fun, so-so, awesome.....
    Looking forward to the first ride on my V2. Anyone feel free to chime in on their ride. They should be trickling in by now. Unless your snowed in.
  30. #430
    Reputation: Haus Boss's Avatar
    Jun 2010
    Looks like Brad already got his hands on a Rune V2.
    Mountain Biking Photos - Pinkbike
  31. #431
    So frames come with all the 12x142 dropouts right? Including 650b ones?
  32. #432
    Reputation: MartinS's Avatar
    No, you choose your dropouts when you order the frame. Extra dropouts are available for around $70-ish I beleive.
  33. #433
    OK..... I am no expert or pro but do have a dozen years of north shore riding, the last 3 on my Rune for AM and consider myself an advanced rider.
    Rode the last 4 days on my medium spity v2 and defiantly feel the extra inch of WB over my v1 Rune as well as the added reach when out of the saddle.
    Im 5'9" with a 30" inseam.
    Had 70mm stem and 28" bars on the med rune
    Have 60mm and 29.5 on the med spitfire.
    Same 160 Lyrik u turn coil
    As many are coming off a Rune like me I will make some comparisons as I see them.
    On the 22/32 fire road climbs I cant say I notice much difference.
    On the short climbs on the trails I've been riding out of the saddle it feels as good or maybe better than the Rune.
    The suspension feels awesome. Much better than I thought. The fox CTD soaks up the chunder and the feels just as good landing hits. My isx6 shock on the Rune needed service and it wasn't quite getting full travel. The v2 Spitfire suspension feels much better.
    The Spitfire is a little tougher to manual, and on slow speed pops I have to lean back a little more.
    In the air it feels good.
    On the trail, I have to really lean forward. I have been getting faster every ride but I'm still having a hard time finding the sweet spot to get the proper traction and braking in the tighter corners.
    Most of the trails I ride are Twisty with lots of pops and I wonder if a small frame would have been better for me.
    If I was an inch or two taller the fit would be better. I am going 1.5" wider with the bars on this bike. I may try a 50mm stem to push me back a bit but that would hamper single track climbing.
    It seems like I'm shifting my weight back (to pop off things) and forth (to trail ride) a lot more which isn't good.
    Once I get better at finding the sweet spot and start cornering better this bike will be an absolute blast, after all I've just had four days on it.
    Just my observations, your results may vary.
  34. #434
    Quote Originally Posted by Haus Boss View Post
    interesting
    this is interesting too. planning the same transition (rune to a spitfire) in the same locale - but i don't think i'm going to have any fit issues. you don't seem blown away...
  35. #435
    Reputation: cave dweller's Avatar
    Feb 2005
    Maybe try increasing the head angle with the flip chips into the upper position to give a 67 degree head angle to match the V1 (Rune V1 had 67 deg head angle).
    You have also put a 10mm shorter stem on which will also move your weight back. Maybe try putting the 70mm stem onto the spitfire and see how it goes.
  36. #436
    Reputation: NCBigHit's Avatar
    Are you saying that you feel your weight is too far back or that you need to move your weight back when you're airing off of bumps in the trail? One thing that strikes me is that if you shorten your stem and widen your bars, it's kind of a wash. Add that to the fact that the consensus seems to be that the V2's are a bit longer than the V1's and it may be that you are too far forward compared to what you're used to. This would make it feel like you need to get back all the time. If it were me I'd try a shorter stem if anything. Steepening the HA a bit will also make manualing a little easier and would shorten the wheelbase. Just a thought....my frame hasn't arrived but I'll post my thoughts when it's ready (going large V1 spitty to V2).
  37. #437
    Reputation: filbike's Avatar
    Quote Originally Posted by joemosq View Post
    can I ask you what's your height and if is 650ed?
    in case you are 6',1- 6',2 and 34-35" inseam, how do you feel it?
  38. #438
    I would definitely try going with a shorter stem. Even down to 30 mm if you have to. Maybe try some riser bars or increased stack height, too. I think finding the sweet spot on the spitfire involves messing with the front end,
  39. #439
    The new breed of Banshee's are definitely designed around shorter stem length to help create a more fun ride without sacrificing weight distribution. If going from a V1 spitfire to a V2 spitfire of same size, I'd suggest you shorten stem by 10-20mm (depending on personal peferance, and assuming bar length remains the same, if bars go wider then take another 5-10mm off stem length).
    Banshee Blog
  40. #440
    I'll add a little more info to my post above.
    I've been riding between the steep and middle settings. Don't really want to go too slack. Middle feels better.
    Saddle is full forward on the rails with the 60mm stem and feels comfortable climbing.
    I have taken the 45mm stem off my DH bike to try for the next ride. I hope I will not have to move back and forth as much now
    Some of the rides I do, have extended technical singletrack climbs, and I question how this will be with a short stem which seems necessary for me.
  41. #441
    3050 grams outta the box - medium black frame only, no shock/hardware, no dropouts, no seatpost. With the shock/hardware and x12 dropouts added, its just over 3400 grams.
  42. #442
    5 days 5 rides on the new bike.
    After a week and a half of unusualy great winter conditions in Vancouver, we are back to the rain.
    On days like this I usually do trail work instead of ride, but, new bike........you know!
    One ride in sloppy conditions does not warrant a review, but I will say the shorter stem feels way better(for me). Much easier to get the front up and less weight shifting back and forth.
    Also, I remember the feeling of going from a single pivot bike to a VPP years ago and how each pedal stroke felt like it propeled you forward. I get a little of that feeling with the KS link over the v1 Rune.
  43. #443
    Does anyone have any 650b dropouts they would be willing to sell. Trident is out, banshee is out. Four week lead time. I need these dropouts!!
  44. #444
    We have them... but we are in Europe !!
  45. #445
    Check shipping to 45205 in Ohio. Seriously. I picked up some 650b Enve wheels and now I can't run them!
  46. #446
    Mar 2011
    I put my order in for a Frame/650b Drop outs a week and a half ago or so.
    Red, L,
    Just ordered my CC DBair from Cane Creek
    XX1,
    Arch EX on DT 240s, Sapim CX Ray
    Trail XO brakes
    enve bars, thompson, etc etc
  47. #447
    May 2005
    Quote Originally Posted by phallski View Post
    Red, L,
    XX1,
    Trail XO brakes
    Sounds nice and a lightweight build/objective? What fork you gonna use?
  48. #448
    Mar 2011
    Full build spec is as follows, Going with a 150 RCT3 Revelation. I'm planning around 28 lbs complete, including a chainguide, dropper, and Shimano DX SPD's. This will be a one bike quiver for me, riding in the Salt Lake/Park City area, so I want it strong for shuttles/riding lifts at DV, but also light enough to climb 4-5k/day.
    Frame Spitfire V2
    Shock CC DB Air
    Headset Cane Creen 110
    Fork Revelation449.28
    Stem Thomson X4
    Bar Enve DH
    Shifter XX1
    R.Derailleur XX1
    Chain XX1
    Cassette XX1
    Cranks XX1
    Bottom Bracket GXP
    Chainguide LG1
    Brakes x0 Trail
    Rotors HSX160/180
    Front Hub DT 240s 15mm CenterLock
    Rear Hub Dt240s 12x142 Centerlock
    Rims Arch EX
    Spokes Sapim CX-Ray
    Nipples Wheelsmith
    Tire F
    Tire R
    Post Lev
    Saddle Silverado Pro
    Grips Longneck
    Pedals DX
  49. #449
    Assembling mine now. Due to the non-availability of the 650B dropouts the build has changed a slight bit. Gonna be wicked. Pics up later tonight. Also, don't know if I am allowed to do this or not, but check my for sale stuff. I have some killer 650B DT Swiss wheels for sale in there that would be awesome on this bike. I just got lucky and scored some Enve 650B's so mine are for sale. Brand new.
  50. #450
    built up with all the parts from my rune:
    - bagged out xt/x9 drive train, still waiting for an s3 front derailleur
    - 36 float (damn this thing is heavy! soon to be swapped out for a revelation methinks)
    - xt/singletrack wheels with minion exo's (again, heavy as hell but they'll do. i've got some 650 drop outs ordered, and hopefully will be able to build myself a nice mid-size wheelset later this year)
    - new slx brakes, work wicked good
    - manitou isx-6 shock - having to pretty much relearn how to set this thing up, suspension acts much different from the rune's. range of adjustment is retarded
    probably weighs closer to 35 lbs than 30, but who cares
  51. #451
    May 2005
    Frame Spitfire V2
    Shock CC DB Air
    Stem Thomson X4
    Bar Enve DH
    Shifter XX1
    R.Derailleur XX1
    Chain XX1
    Cassette XX1
    Cranks XX1
    Bottom Bracket GXP
    Chainguide LG1
    Brakes x0 Trail
    Rotors HSX160/180
    Rims Arch EX
    Spokes Sapim CX-Ray
    Nipples Wheelsmith
    Tire F
    Tire R
    Post Lev
    Grips Longneck
    Pedals DX
    Very nice! I'll be watching for this.
    Is that a 28 hole Arch EX you plan to use? If not and a 32h you might consider the Pacenti TL28 rim which is wider, lighter, and eyeleted...and on sale right now for $59. Nice rim and I have the 650B version and live in the rocks of New England.
    BikeLugs.com
  52. #452
    Mar 2011
    32 hole here, 28 holes saves 8 g and looses 15% stiffness. kind of a no brainer. I work in the industry so can't really beat the arch EX's, and they are basically the same width as the best DH rim ever made, the Mavic 721=supreme tire profile.
    Where in New England? I grew up outside Boston and spent my formative riding years in VT
  53. #453
    All built up with 26 inch until the 650 dropouts come back into stock.
    Current build:
    Medium Spitfire in Black
    2013 Fox CTD read shock
    2012 RS Lyrik RC2DH freshly rebuilt and with new lowers
    Easton Haven Carbon wheels
    XTR Brakes
    XTR Rear Mech and shifter
    Point One Stem
    Enve DH Carbon Bars
    Race Face SixC Cranks
    CB Mallets
    Scwalbe Hans Dampf Trailstar 2.35 in front
    Schwalbe Nobby Nic Gatestar 2.25 in rear
    XTR Chain
    Cane Creek 40 headset
    Kind Shock LEV seatpost
    SDG Formula FX saddle
    Impressions:
    So far just ridden around the block a few times to see how it sprints, and I am very pleased. Compared to the Nomad this this really gets up and goes. Nomad had a very similar build on it too so it is a pretty decent quick comparison. And this thing manuals like crazy! I'm not very good at it, but on this bike for some reason I can, and for a while! Pretty stoked on how playful it feels. Hopefully I can get out monday for a frozen ride and really see how she rips.
    Oh and it came in at an even 29lb.
  54. #454
    Feb 2006
    Sounds like there may be no need to wait. Slap a 650 wheel in those 26" dropouts and let us know how she goes.
  55. #455
    Quote Originally Posted by hrdude View Post
    I can do that sunday or monday probably. My Enve 650B's are about 2 weeks out.
  56. #456
    Not as nice as some of your guys' build, but I cant wait to ride it!
  57. #457
    FM
    FM is offline
    Apr 2003
    coocoomike, what size is that& how tall are you? Looks good!
  58. #458
    I'm 5'10" and it's a size Medium. Feels spot on.
  59. #459
    Feb 2006
    If anyone in the US needs a headset for their Banshee build, I've got a new one available for cheap. FSA 57 Orbit, ZS tapered 1.5-1.125. White & black, white headtube cups with black cap. Would look best on black or raw colored frames. Pm me.
  60. #460
    I'm tossing up between this, a orange five and a Cotic rocket. What I really want is a versatile trail bike that is capable of a bit of Australian downhilling (pretty tame) and general AM stuff.
    For the people who have one now, how playful/flickable is the bike compared to others you've ridden, is the wheelbase too long to get the bike unsettled/throw it around? And what is the suspension design like in regards to trail feed back? One thing I haven't liked about my duallys in the past is the steamroller effect they have (I ride lots of dirt jump bikes, and my main trail bike for the past year and a half has been a 650b hardtail).
    Sent from my Nexus S using Tapatalk 2
  61. #461
    Jan 2013
    Hello, first time here and first time Banshee owner. I've got the V2 spitfire, with the 12x142 650 drops. I'm a noob when it come to the 12x142 setup, so I'm a little confused by the axle that came with it? Is this the option to use, or are there others? I'm used to through-axle in the front. Just screw it in. Simple. The rear screws in, but from both sides. Is there one that operates more like the front, or is this setup just the way this rear through-axle works?
    Any recommendations for a dual ring chainguide or chainguide/bash.
    I had to remove my stinger after continually bending it. Never had a problem on the rune with it.
  63. #463
    what cranks will you be running?
  64. #464
    Fc-M770 xt is what I am using.
    The chain stays are a little lower on the V2's which left my stinger pretty low.
  65. #465
    E13 TRS dual. Hands down the best dual guide I have ever used. Very quiet. Is has rollers and not cogs. Don't get one with cogs, they are very loud.
  66. #466
    It looks like those come in an alloy or steel. With these v2 frames the roller part will have to be rotated forward and lower than the bash part of the guide. Hopefully the alloy one will do better than my stinger did?
  67. #467
    My xt cranks are 2011, the old 3 spider set-up. I think the 2012 and 2013 are only 2 spider so this chainguard, I believe, wouldn't apply if you have a 2 ring set up. Maybe it does, though.
    On mine, I use a gamut chainguard (minus the rollers) with the chain sandwiched between the black spire chainguard.
    Benefits: less resistance because no rollers and lightweight. Chain never falls off either.
    Blackspire - Blackguard | Blackspire
  68. #468
    i'm running an older set of xt cranks and can't get the granny bolts to stop rubbing the iscg5 mount stinger mounting bolts - even through they are recessed - without running an extra drive side bb spacer... again. sigh
  69. #469
    Feb 2005
    Running the E13 Hemi guide on the V2 spitfire and no problems so far. I had to trim a bit of the back plate away to rotate it higher but you are limited by position of the chain stay. I have been thinking of getting a new clutch derailleur and getting rid of the chain guide.
  70. #470
    I was wondering if my old XT cranks from my V1 were gonna fit on the V2. You could just grind the granny bolts if you're not using the granny ring. What's your plan? New cranks?
    It would be nice to have an extra $1200 for the XX1 and just forget about all this compatibility mess.However, I could barely come up with the money for my warranty upgrade to V2.
  71. #471
    ptd
    ptd is offline
    Oct 2012
    You can run the XX1 cranks on 10spd as long as you're using a clutch derailleur.
    No need to run XX1 shifter/rear derailleur/cassette.
    I think the XX1 spider is compatible with as XO? I've read XX1 are the same cranks as XO, just different spider and chainring? So if you had XO cranks, just need XX1 spider/chainring and clutch derailleur.
    Anyway, I've tried it out on my Rune (XX1 cranks and shadow+) because I couldn't believe it works, and hey-presto, no dropped chains!
  72. #472
    Dlong- What chain guide are you running on your V2? It looks like a ethirteen XCX. Are you just running a single ring up front?
  73. #473
    Yes the XCX. Single ring. Going XX1 soon hopefully. Really love 1x set ups. Was running 2x on my Nomad, tried a lot of dual guides, the TRS dual was leaps and bounds nicer than anything else I ran.
  74. #474
    Looks like Fox has a 140mm 27.5 coming out, with 32mm stanchions. Could this be a good marriage for the V2?
  75. #475
    There's no need for 2 rings up front, IMO. Been doing 1x8, 1x9, 1x10, and eventually 1x11 forever. Until then, if my old XT cranks aren't gonna fit then the XCX looks like the best alternative.
    Are your cranks on your V2, dual ring with the granny ring removed?
    And, I guess I need to search, but what type derailleur is the V2? E-type? The banshee website says S3 type derailleur?
  76. #476
    Hard funkinī Kraut
    May 2005
    Quote Originally Posted by bhaithcock View Post
    Yes, it could. The Spitfire can take Forks from 140 to 160 mm Travel! Although Keith leans more towards going with more Travel up Front, 150 or 160 mm.
    Of course it depends on personal Preference, what and where youīll plan riding the Bike.
    Me, I got recommendations from Suspension-Experts to go with 34er or 35er Stanchions and more Travel.
    1.) I weight 90plus Kilos full geared -> more Need for a stiffer Fork and Wheelset.
    2.) My riding-style is somewhere between Allday-AM and downhill-orientated Enduro -> 160 mm Travel fits more to this Purpose and gives the right Geometry.
    If you think you donīt need more, this can be an Option.
  77. #477
    I went out and rode some big ole mountains and climbed some gnarly stuff this year so I really welcomed the granny ring after an hour of straight climbing. For my local trails I think 1x is perfectly fine.
    I am running the Race Face SixC cranks, which are 2x capable, but obviously I am running them with a single ring. And yes, you want the S3 type front derailleur. I am running the S3 XCX guide.
    Also did some part swapping tonight and came out with some good results.
    For starters, 650b wheels fit with ease on the 26 inch dropouts. I ended up putting the 34 on the front and with it lowered to 150. It feels much more like the trail bike I was looking for. Also put on the CCDB Air. I have been running one of these since they came out and I just love it, so seeing how it feels on this rig.
    With this set up is is 29lb 14oz. Have some Enve 650b wheels coming in to shave some weight.
  78. #478
    beater
    Reputation: evasive's Avatar
    Feb 2005
    That is a very nice looking bike.
  79. #479
    May 2005
    Dam, that is a great looking bike you have there They just look so nasty good in black.
    The 650B wheels fitting the 26" drops is really great news indeed. And I see you have the NN tires which in the 2.35" size is the tallest 650B tire that's available (are they the 2.35" or 2.25" which is not as tall)
    Now, can you please snap a few pics of the clearance at the seat stay brace, chain stay yoke and the vertical support spars (which I thought could be a potential issue with 650 tires using 26" drops). Also did you check to see if the tire hits the seatpost at full bottom out?
  80. #480
    I am running the 2.25 in the rear. I can fit a finger in between every space except for the middle one, but there is still 7mm or so of clearance. Plenty. I have seen clearance this tight on AM bikes with 2.4 or 2.5 26 in tires. There is still an inch or more of clearance at bottom out too. Would take pics but it is dark and flash makes it hard to see. I'll be riding in some muddy/sloppy conditions tomorrow so we will see but I am not worried about it at all. You could fit a 2.35 back there I bet, would be tight, but it would fit.
    I will still probably pick up the 650b dropouts when they are available though b/c For riding DH I will be running 2.4's for sure and would like the extra clearance. But for trail riding, this will suffice for sure.
  81. #481
    FM
    FM is offline
    Apr 2003
    +1, nice work on that build!
  82. #482
    sure! though you might have to remove some spokes from your rear wheel, to make sure the back end feels as noodly as the front
  83. #483
    May 2005
    There will be plenty of people who want the Spitty just as a ripping trail bike (like me a 55YO guy who doesn't leave the ground much) and lightweight build. A 140mm fork with 32mm stanchions is fine in that case...IMHO
  84. #484
    Hard funkinī Kraut
    May 2005
    @ Dlongb13:
    Awesome Bike man, much better looking now than with the Lyrik, which is a great Fork, no doubt.
    Interesting to hear the 650B-2.25 Schwalbes fit in the 26-Dropouts with plenty of about 7 mm Clearance. Want to go with Hans Dampf 2.25, so hopefully should fit in the 26ers too. My Spitfire is going to look the same way, some other Parts of course, with -1 or -1,5 Deg Angleset, black Flite and white BOS Deville (arrived today, yipee). My new 650B custom Wheelset (WTB Frequency i23, Tune Hubs) should arrive this Week, too, so I can start building. My Distributor told me yesterday that the CCDB-Air will come in late February, till then the Evolver has to prove itīs Quality again.
    So excited, but uff ... keeping patient is getting harder and harder ...
    @ bhaithcock:
    Boomforeal takes it the funny way , but seriously: Fork-Choice really depends on your Riding-Style and ... what I was told(!) ... your Weight. Same for the Wheelset. Initially planned the Arch EX Rims, for the weight-savings, and was recommended to go with Flow EX or WTB. Suggestions according the Fork went the same Route. Had the chance to testride a 150 mm Revelation, nice working Fork, but the lack of Stiffness overall felt uncomfortable, at least for me.
    Decide what you want to explore with the Bike in the Future ...
  85. #485
    And revelations are stiffer than 32's. If saving weight is a tip priority then go with the new Revs, they are pretty sick, and they make a 650b version in case you decide to go that route down the road.
    @Nostyle Thanks man! Sounds like you have a sweet build going as well!
  86. #486
    Oct 2011
    Is it predrilled for internal dropper posts?
  87. #487
    Hard funkinī Kraut
    May 2005
    @ Checkit:
    No it isnīt. Feel free to ask the Banshee-Guys if you are allowed to drill it when itīs done professionally.
    @ Dlongb13:
    Thank you man. I must confess that my Build is much over the initially planned Budget ... but well ... you know ...
    I honestly have to say that Iīm heavy in love with your Spitfire, and the beautiful red one from Strahan Loken.
  88. #488
    May 2010
    Big thanks to Keith for sorting this can't wait to ride it!
  89. #489
    Reputation: collectivedust's Avatar
    Oct 2010
    Just received my v2 this week and have started the build! The frame is absolutely stunning in ano black. Awesome work Keith (and the Banshee team)
    Could anyone please confirm whether an e.13 LG1 Trail guide will fit without touching the chain stays? Unfortunately my old e.13 LG1 would require a serious amount of further modification to fit.
  90. #490
    ^^^ Damn. If that's the case, this may be the thing that forces me to go 10 speed with clutch...
  91. #491
    Oct 2010
    Spitfire V2 Chain guide option - Superstar Plasma?
    I managed to find a good photo of the Superstar Plasma chain guide and traced it up in Illustrator to scale. Printed and cut it out and it looks like the boomerang will clear the chain stays. (No idea why the picture gets auto rotated)
  92. #492
    When are we getting the Spitfire V2 in the UK? Who is the new distributor and will there be any dealers?
  93. #493
    Quote Originally Posted by scarlet View Post
    Ison Distribution are bringing them in.
  94. #494
    Quote Originally Posted by Al2000 View Post
    Any idea when?
  95. #495
    Anyone rode the V2 with the CCDB Air? How does this shock perform on this travel range? Is it worth the extra weight?
  96. #496
    Hard funkinī Kraut
    May 2005
    Quote Originally Posted by kijan View Post
    If you are willing to wait some Time I can tell you how the CCDB is going to perform. Iīm building up my Spitfire tomorrow, with Evolver ISX-4 at first, as my CCDB should arrive end of February.
    In my honest Opinion you should be clear about what you want, or how much Adjustment-Possibilities you like. I have ordered the CCDB because I donīt want/need 3 different Compression-Settings. One Setting, dialed in with Time, should work for everything. This too is the Reason not to go with adjustable Forktravel anymore. Once set-up right the Bike hopefully performs very well in every Situation.
  97. #497
    Their shipment is leaving the factory tomorrow... should be through UK customs by end of the month.
    Banshee Blog
  98. #498
    I have one on mine, been using a DB Air since they came out. Depends on what kind of bike you want. If you want a super responsive trail bike, probably not for you. If you want a bike that can smash out DH runs all day, then yes, get the CC. I have ridden DB air on everything from a Session, to a Tallboy LTC and it is always effective no matter the travel. For my Spitfire I am choosing to run the DB air only when the terrain calls for it. My local trail are pretty new school and buff so the DB air really numbs them so I will be running a Fox CTD locally to get the most out of my trails.
    Don't get me wrong, the DB air is the greatest thing besides dropper posts and carbon wheels, but if you aren't riding on trails that demand it, it can dull the ride.
  99. #499
    May 2010
    Just about to finish my build off what is the best way to calculate the length of the chain I'm using xo short cage rear mech with 34x11-34 gearing.
    Put the chain on without closing it. Make sure the chain is in the largest chainring and largest cog. Pull the chain tight so that your derailleur hanger is pulled fairly far forward--because you have short cage, you probably need it on the tight side in your large gear so that it will still have enough tension when you're in the small cog. If in doubt leave it a little longer as you can always shorten it later. I usually do this so the two ends are overlapping beneath the chainstay. You should be able to see how much chain you need. Now pop out the extra links and close it with the powerlink (or pin if you're using shimano chain).
