Page 4 of 26 FirstFirst 1234567814 ... LastLast
Results 301 to 400 of 2512
Thread: 2013 Spitfire
  1. #301
    Quote Originally Posted by cave dweller View Post
    Measured ~328mm with Fox 36 in 140mm setting, spitfire in slackest setting, running Maxxis Minion 2.5 DHF DH casing tires (large volume)
    *Edit* Zero stack headset as well
    Thanks man
    Keith, can you tell me what the bb drop is with the 545 fork.
  2. #302
    Got my frame ordered! CCDB Air (and a Foxctd for local XC stuff) , DT Swiss M1700 650B wheelset, Fox 34 Float 650b dropped to 150, and XTR brakes all standing by! Waiting to decide if I want to go with the XTR drivetrain I have or if I wanna sell it and go XX1.
  3. #303
    Reputation: cave dweller's Avatar
    Feb 2005
    Quote Originally Posted by Nescafe View Post
    Thanks man
    Sorry, thought I read bb height.
    The drop (difference in bb to ground and rear axle to ground) is measured at ~14mm in slack setting.
  4. #304
    Does anyone know what company makes an 56mm ID external headset cup?
    I'm gonna run a 150mm RS Revelation and wanted to add some stack height to the lower cups, rather than the zero stack, to keep the BB height proper. So, far all I've seen for the 56mm option is zero stack height. Anyone know?
    Keith you mentioned Banshee was making some headsets. Are the lower cups zero stack only or is there some stack height options?
  5. #305
    May 2005
    Quote Originally Posted by hiawatha-de View Post
    I've not seen any 56mm external head set cups. The reason for the big 56 in the first place is to get away from the external cup.
    I'm willing to bet that Works Components might be able to make what your looking for. They make sweet angle sets and can do custom stuff so drop em an e-mail.
    Works Components - Angle Headsets to fit Most Frame Types & CNC Bicycle Components Proudly Made in the UK
    2013 Banshee Spitfire V2 650b
  6. #306
    Does the frame come with a headset? I thought I read that it did.
  7. #307
    Reputation: MartinS's Avatar
    Qbert mentioned in the Prime build forum that Cane Creek does an external 56 lower cup for their angleset HS. It is a pricey solution, but it is a solution....
  8. #308
    Quote Originally Posted by Dlongb13 View Post
    No they don't.
  9. #309
    Thanks.
  10. #310
    Thanks man
    BB drop (If using same rim and tire front and rear):
    -8mm in high position.
    -2mm in neutral position.
    4mm in low position.
    Remember that tire choice will affect BB height almost as much as fork choice.
    Banshee Bikes Designer
    www.bansheebikes.com
    Banshee Blog
  11. #311
    Sov
    Sov is offline
    What sizes are people ordering? I'm 5'7 and have a medium on order but am second guessing myself a little as I suspect I'm in between sizes.
    I currently have a small '11 Trance with a 70mm stem and measured reach of 395mm = 465mm total. I find it to be a bit short (but this could be a ride feel thing as it has a short wheelbase and steep head angle)
    The medium Spitfire is 428mm reach and I would like to run a 50mm stem = 478mm in total, so a touch longer than the Trance which should be good in theory.
    My V1 Rune was a medium with a 70mm stem and felt great, but with 379mm reach the total = 449mm, so quite a bit shorter than the small Trance and waaaay shorter than the V2 Spitty.
    I guess I am wondering if I should change my order to a small given that the Spitfires tend to run a bit longer than equivalent trail bikes (Blur TRC, SB66, 5 Spot)
    Thoughts anyone? Small or Medium?
  12. #312
    Hard funkin´ Kraut
    Reputation: NoStyle's Avatar
    May 2005
  13. #313
    The pics are but everything else, specs, geo, ect, are for the old model still.
  14. #314
    Quote Originally Posted by NVman View Post
    Hiawatha-de we just received our first shipment of Spitfires yesterday. That is why no one waiting for a Spitfire upgrade has go it yet. We have been really busy with handling people upgrades and have been working on getting people with Runes sorted out first since we had the inventory. Each case takes a fair amount of time since there have been many questions about sizing, drop out options, shocks, people changing colors and sizes at the last minute, etc. Please be patient. You will get taken care of.
    I'm one of those patient people, but it would be nice to get at least a confirmation email that an upgrade request was received. I submitted mine on Dec 17th and have gotten nothing. Makes me wonder if it was really received, regardless of the website stating that the request was submitted successfully...
  15. #315
    Is the V2 spitfire bottom bracket press-fit or is it external outboard bearings like the V1?
  16. #316
    External outboard bearing... no creaky hard to change press fit bearings in these bikes.
    Banshee Blog
  17. #317
    just got my L black frame swapped for a red. a few details still to be worked out but its in the queue at trident for to be shipped out - stoked! (for the patient people: if it helps, email chain on this goes back to august 2011...)
    Attached Thumbnails Attached Thumbnails 2013 Spitfire-screen-shot-2013-01-10-10.29.17-am.jpg
  18. #318
    Quote Originally Posted by builttoride View Post
    Glad to see this standard hasn't changed in the frames.
  19. #319
    May 2005
    What shock is on that frame?
  20. #320
    Looks like a Manitou, maybe the Radium Pro. Manitou's air shocks are pretty nice, loved both of the ISX-6's Ive owned.
  21. #321
    Quote Originally Posted by skidad View Post
    ISX6 off his Rune?
  22. #322
    What are my fork options? Was looking to get the X-Fusion Slant RL2 DLA 27.5, and run it @ 160mm, but got word that it won't be avail till mid year. There's also the 2013 Fox 34 FLOAT 160 CTD, but I would need to choke on the $1,000 price tag. I think I want to keep it @ 160mm. Bilttoride, what are you guys using?
  23. #323
    some random manitou i imagine - that's not necessarily my frame, which i don't have yet, just an appetite whetting shot trident sent me during the correspondence
  24. #324
    Quote Originally Posted by bhaithcock View Post
    Are you running 27.5? I've heard that the X-Fusion Velvet's are 27.5 compatible and the price is good.
    ed: I meant the Vengeance, not the Velvet - brainfart...
  25. #325
    I'm running an X-fusion vengeance personally, Jon has a fox 34 27.5, and Dennis runs a 26" fox 34 as seen in the promo vid. It just depends what your priorities are, and how much you want to pay.
    While I've been told the vengeance works with 27.5, I don't think it would work very well in the thick mus we have here. I personally run my spitfire in 26".
    Banshee Blog
  26. #326
    [QUOTE=builttoride;10060159 While I've been told the vengeance works with 27.5, I don't think it would work very well in the thick mus we have here. I personally run my spitfire in 26".[/QUOTE]
    OK, I guess I'm asking this: If Banshee were offering built kits for these bikes, then what fork would Banshee be spec'ing the V2 with, in a 27.5 config?
  27. #327
    Fox 34 27.5 would probably be what our distributors would ask for.
    Banshee Blog
  28. #328
    10-4, thanks!
  29. #329
    Hard funkin´ Kraut
    May 2005
    For those who have Interest, Bernhard the german Banshee-Distributor gave me some Info about his Spitfire:
    He himself is 174 cm tall, with 78 cm Inseam and rides Sizes Medium. Stem-Length is 60 mm, Bars are 740 mm wide. He would suggest to go with Size Large for those who are 180 cm and taller, while another Rider with my Body-Measurements (181/85 cm) demorode it and felt pretty comfortable on Size Medium ... so should I, hopefully ...
    Weigth is 12,3 kg, BB-Heigth is 32,7 cm with the 150 Fox Float and ZS-Headset, slack Setting.
    His Impressions (in short Terms):
    - Rides great, feels/maneuvers directly
    - Rear-End is very stiff
    - Feels very planted/saturated on the Trail due to the low BB
    - Climbs "like a Goat" due to the steep Seatangle
    - He overall likes the Geometry very very much
    - Rear Suspension feels more than 14 cm Travel
    - Can be setup very plush without bottoming
    - When pedalling seated the Rear is neutral, with open/no Propedal
    - Out of the Saddle the Rear sags more, but not very much bobbing - at least less than other VPP-Designs
    - Can be easily tuned more firm due to the Fox CTD
    Hope it helps a little!
    Greetings
    NoStyle
  30. #330
    Awesome build, mine will be very similar except in 650B mode and with KS LEV dropper. Should be built by the end of the next week. Then it's mini winter vacation time to Pisgah NC.
  31. #331
    Reputation: hrdude's Avatar
    Feb 2006
    Greetings
    NoStyle
    Thanks NoStyle, great info, my order has been placed.
  32. #332
    Feb 2006
    Double post
  33. #333
    May 2005
    X2...thanks for getting that info NoStyle. Lots of positives but I especially like the "climbs like a goat" part.
    Now I just need to sell my 2011 Jamis Dakar 650 B2 with less than 250 miles on it before I can order a new Spitty frame. The Dakar is really a sweet bike but I feel the Banshee is more what I'm after.
    Paid spam if anyone is interested 2011 Jamis Dakar 650 B2 - Buy and Sell and Review Mountain Bikes and Accessories
  34. #334
    Hard funkin´ Kraut
    May 2005
    If things go well my ordered Parts will hopefully arrive during the next week, so I can start building up mine - and give more Impressions, if wanted.
    Greetings
    NoStyle
  35. #335
    - Did Anyone try a 190mm shock in the New Spitfire?
    -is it worth running a db air in that travel range?
  36. #336
    Quote Originally Posted by kijan View Post
    Been using a DB air since they came out and it is totally worth it in any travel range!
    And does anyone have a frame weight yet?
  37. #337
    Did anyone already run a db air in the new spitty?
  38. #338
    May 2005
    Yes, someone please get one of these frames on a scale
  39. #339
    Feb 2006
    Banshee's site has it listed as 5.86 lbs. I'm assuming that's for a medium size but not sure if that includes shock or not.
  40. #340
    May 2005
    Quote Originally Posted by hrdude View Post
    Those specs are still for the old frame
  41. #341
    I Just weighed a medium Raw production V2 Spitfire, with the 142 drop outs and axel, derailer hanger, Fox CTD shock, and Banshee seat clamp and the weight was 8.09 lbs.
  42. #342
    Wow a whole lbs heavier than the old one...
  43. #343
    Try 2lb heavier.
    Holy crap. 8lb?!?! That is insane. Probably be a medium black ano for sale by the end of next week.
    When aluminum 160mm bikes are coming in under 7lb, a 140mm trail bike at 8lb is crazy. Sure hope that is wrong.
  44. #344
    May 2005
    Well....the red built up bike pictured above is "supposed" to be 27.1lbs which is a very respectable weight. Add XX1 and you could save maybe another pound. Ok, it doesn't have a dropper post or beefy forks so that would bring it closer to a 30lb weight I suppose. Not having owned a V1 Spitfire I'm not sure if that's good or bad but both my bikes now are around the 30lb mark so I'd be cool with that. Especially knowing the Banshee can take a beating.
    Still a few more frame weight checks would be nice and fully built bikes also. Patience I guess.
  45. #345
    Yeah the red one is light but like you said, fox 32 and a carbon post. And I am going 1x10 with full XTR b/c it is lighter than XX1. Wish I knew the weight of the wheels on the red one so I could do some math here.
    This is supposed to be my Enduro/Super D race bike, chose it over Carbon Divinci Dixon due to the 650B factor, just hoping I didn't make a bike mistake. I raced on a 30.5 lb Nomad last year and I don't want to be in that range again this year.
    Banshee really needs to update their website, that 5,86 number is incredibly misleading.
  46. #346
    Feb 2006
    8.09 That's slightly more than the Prime weights that have been posted. Was kind of expecting the Spitfire to be at least a pound less.
  47. #347
    Feb 2006
  48. #348
    May 2005
    Here's the build list from the red bike. Do some digging and you can figure out some weights. Frame is around 7.5lbs but by a scale I don't know.
    The weight is great, so are the Parts. Here´s an Overview the owner gave me:
    Rear Derailleur, Triggers, Brakes, Chain and Cassette: Shimano XTR
    Front Derailleur: Shimano XT
    Fork Fox 32 Float RLC
    Wheelset: DT 240 mit XM450TL Felgen und Messerspeichen
    Handlebars: Syntace Vector Carbon 740mm
    Stem: Syntace F109 60mm
    Headset: Pivot
    Handles: Pivot
    Seatpost: P6 carbon hiflex
    Saddle: Selle Italia SLR
    Tires: Kenda Nevegal
    Tubes: Kenda
    The owner of the red Spitfire stated around 3,4 kg Frameweight with Shock, Dropouts and Seatclamp.
  49. #349
    After the bushing issues I guess they are not taking any chances with frame breaking.
    We need a scale shot
  50. #350
    Wonder how many holes I can drill in the frame to shave weight.
  51. #351
    Headset: Pivot
    Handles: Pivot
    Tubes: Kenda
    Isn't the owner of the red bike a banshee dealer/distributer. Take it for what its worth.
  52. #352
    Feb 2005
    Get the facts correct......
    Wow, some awesome non fact checking going on here
    The old Spitfire weight of 5,86lb's is without the shock.
    In this thread a 2010 (large) painted spitfire was measured as 7lbs 2oz including shock and hardware and 7oz in ano with shock. Spitfire Frame Weight.
    Dont forget the new frame has
    > 20mm more travel
    > Bearings (as opposed to plastic bushings)
    > 142mm x 12mm axle (as opposed to QR) - just the axle probably adds 100grams
    Finally, the clear coated raw frames are approx 150-200 grams heavier than the ano version and 50 grams heavier than the painted version (raw is the heaviest).
    The new spitfire in raw with bearing hardware, shock, axle kit at 8lbs seems about right.
  53. #353
    Thanks cave dweller for being reasonable.
    People who are *****ing about weight:
    - Compare apples to apples. You'll see it's a little heavier but not nearly as much as you're thinking. I bet it's less than one pound heavier for the frame itself, which is TOTALLY reasonable given the bearings and extra travel.
    - Stop making numbers the top priority if you plan to actually ride your bike. A slightly heavier, but stiffer and better built bike will be FASTER in most situations, last longer, be safer, etc etc. I agree that Banshee probably put a little more focus on durability over weight to save face and get the company image back on track, but if you want to drop a few hundred grams do it in your wheelset or something.
  54. #354
    Hard funkin´ Kraut
    May 2005
    @ LostBoyScout: There you go
    Well, I don´t have much Interest in Frameweigth or Weigth at all and I wanted to avoid spending extra Cash for a damn Scale, but I think it´s time to buy one and give some proper numbers
  55. #355
    May 2005
    Perhaps some could care less but IMO it's not unreasonable at all to want to know the weight of a newly re-designed frame. Go into any forum and it's one of the first things people question. I'm not complaining, just interested.
  56. #356
    Hard funkin´ Kraut
    May 2005
    @ skidad.
    I know you are not complaining at all!
    The curious thing is that most People in Forums ask for Weight first, instead of asking how it rides ... which should be way more important ...
    Well, I´m doing my best to get you some Numbers.
    Many Greetings
    NoStyle
  57. #357
    I agree that Banshee could have and should have got the approx weight out ASAP (a decent approximation could be made from the solid model but it's difficult to estimate the weight of the welds) and I agree weight is a factor.
    But because it's a black and white number as opposed to the subjective ride quality, folks online can tend to care far too much about weight. Which mtbr's are terrible for (not you specifically)
    I just looked up the Transition Bandit, which I consider to be a direct competitor, and it's 6.93lbs with shock published weight. The axle and bits attached to the Spitfire could be over 0.25 lbs themselves. So it's a little heavier, but it's also slacker and takes a bigger fork.
    The new Spitfire is a XC rider's bike, not a XC racer's bike.
  58. #358
    I thought the raw color would actually be slightly lighter than the painted models. I guess the gloss paint is pretty heavy, eh?
  59. #359
    The raw is the heaviest (slightly) due to 2 clearcoat layers... but you'd never notice the difference. Weight is mainly in the mind. If you want to ride faster, further, higher, longer and harder, then ride more. If you want to save weight, then go to the toilet before you ride.
    Its combined weight of bike and rider that matters for long days in the saddle, so 1kg weight difference is only 1% (roughly) weight difference (based on bike and kitted up rider weighing 100kg), but our frames more than make up for this with frame stiffness and pedal efficiency. These attributed will mean you can accelerate harder and hold your line better while loosing less energy to flex and wallowing suspension.
    I design our bikes to be ridden, and ridden hard, because that is what we know the vast majority of banshee customer want... don't listen to the marketeers from the big brands who switch to carbon to mainly increase their profit margins, and start counting grams too much. If you want to do that, and spend more time polishing your bike than riding it, then maybe you should start shaving your legs and buy a 'show bike'
    If you want to go mountain biking, then throw a leg over a new Banshee and the bike will do the talking, and what I've said here will make sense to you.
    Banshee Blog
  60. #360
    G_g
    G_g is offline
    Keith Scott: "I design our bikes to be ridden, and ridden hard, because that is what we know the vast majority of banshee customer want... don't listen to the marketeers from the big brands who switch to carbon to mainly increase their profit margins, and start counting grams too much. If you want to do that, and spend more time polishing your bike than riding it, then maybe you should start shaving your legs and buy a 'show bike'
    If you want to go mountain biking, then throw a leg over a new Banshee and the bike will do the talking, and what I've said here will make sense to you."
    That, sir, shall be my new signature.
  61. #361
    Nov 2008
    Light wheels you can feel while riding. Light frames you can feel when you lift the bike onto the roof rack.
    I know which I care more about.
  62. #362
    Reputation: BillT's Avatar
    Once I get my new frame, I throw it on the scale and get a pic before building it up.
  63. #363
    Hard funkin´ Kraut
    May 2005
    Hahaha, yes! That´s exactly why I love Banshee, the Bikes and the People behind the Brand so much
  64. #364
    Reputation: Fakawi's Avatar
    Apr 2005
    check out my mate's Large raw v2 spitfire..
    More pics here on my site
    ((((((((( FAKAWI )))))))))))
  65. #365
    Hard funkin´ Kraut
    May 2005
    Show the Pics here! The Link doesn´t work ...
    Edit: Ah yeah! Great looking Spitty
  66. #366
    Reputation: Stratovolcano's Avatar
    Jan 2013
    Smile
    Hi from France (and sorry if everything is not clear...)!
    I have just registered to mtbr because i'm a proud owner of a brand new large black ano Spitfire.
    I see that some of you want to know more about this frame so here i am!
    The frame is just under 3.7kg ( under 8.15lbs) in Large size with provided seat collar (not really light), dropouts, derailleur hanger and 142*12 rear axle.
    Sorry no scale shot...
    The full bike weight is around 13.6kg (just under 30lbs) with the following specs:
    Frame: Large black ano Spitfire
    Wheelset: Ztr Arch on Hope pro evo 2 hubs
    Tires: Maxxis Advantage 2.25 and 2.10
    Transmission: Mainly XT, had to revise the e-type 3*10 front dérailleur but it fits!
    Fork: RS Revelation 150mm tapered 15mm axle and Fox CTD shock
    Brakes: Magura Louise Carbon
    Raceface Turbine handlebar and Thomson 50mm X4 Stem
    Seatpost and saddle: KS I950 and SDG Bel air
    Just had two small rides on it but i think this will be a trail eater.
    Yeah this frame is not the lightest but the rear is really stiff, that's impressive and more important for me!
    Coming from years of hardtails it's my first full suspension bike and i didn't want to buy a noodle/chewing-gum frame so i'm more than happy!
    As a new member, i can't post pictures but i'll do this ASAP!
  67. #367
    Reputation: NCBigHit's Avatar
    Just got word from Trident that my large black ano is shipping. Pretty damn excited.
  68. #368
    Mine just shipped too. Just got done cleaning and prepping the build kit parts in anticipation. Can't wait to see what the built weight is going to be. Really hoping it is sub 29lb.
    Just got my custom Fox 34 decals in the mail about 5 minutes ago along with the shock mounting hardware!
    Love to see my weight reaction got people a little fired up! Not saying weight is everything, but weight is important. I look forward to seeing how the weight feels when on the bike and how well the bike accelerates ( which is my biggest reason for wanting a lighter bike). I don't mind doing 30 miles on a 30lb machine or climbing 5k feet on one as long as when I get on the pedals it gets up and goes. Some 30lb bikes I have ridden in the past, like my nomad, didn't do that, others, were just fine. But if you have the chance to get out and ride a 26ish pound race built carbon AM machine, I suggest you do. This season I got a chance to put a Remedy 9.9 through it paces and it make me think of weight in a whole new light. That bike was FAST! As soon as you were on the pedals you were gone, I want that again.
    Either way, I am bikeless right now and it is incredibly depressing.
  69. #369
    No way I'll be under 33 pounds but my build is pretty burly. We'll see where it lands. I loved the way my old spitfire rode with basically the same build, so if I find the new bike to be as some of the others have reported, I won't care what it weighs...will be such a fun sled.
    Large Ano Black Spitfire
    Fox Van 36RC2
    Crossmax XL wheels
    Old style XT brakes
    XT cranks
    e13 LG lite
    XO rear/X9 shifting
    Reverb
    Sunline stem
    ODI 750mm bars
    2.35 DHF front/2.25 Crossmark rear
  70. #370
    hey keith, how would a manitou isx-6 do on the new spitfire? i have one from my rune, absolutely love it.
    if you think it would suit, any recommended baseline settings or set up tips given the changes to the suspension design from the old vf4b to the ks link? i'm running the compression circuits pretty much full open, wondering if i can still get away with that
  71. #371
    My build will be:
    Fox 34 Talas converted to Float and dropped to 150mm (650B Variant)
    Fox CTD for XC and a DB Air for park days
    Full XTR Drivetrain set up 1x10 (until the DTswiss XX1 freehub comes back in stock, then XX1)
    XTR Trail Brakes and Rotors
    KindShock LEV Dropper
    SDG Formula FXR Saddle
    Thomson x4 50mm stem
    Cane Creek Angleset
    Easton Havoc Carbon Bars
    DT Swiss M1700 Spline 650B Wheelset
    Schwalbe Hans Dampf in front and Scwalbe Nobby Nic in the rear
    ODI SDG sig grips
    This bike is going to see a lot of miles this year.
  72. #372
    ^^^ That is one hell of a build. Can't wait til these frames start rolling in and we can see some pictures!
  73. #373
    Feb 2005
    Its mostly in the wheels. Cant compare XC race wheels/tires to AM wheels/tires.
    I can feel a huge difference in acceleration on the same bike, with the same wheels with same settings just by going from a Maxxis LUST tubeless tire to a Maxxis DH tubeless tire which adds around 250grams of rotating mass per tire. Nothing else has changed but the bike "feels" faster.
    Maybe consider going for the XR1450's if snappy acceleration is what you are after? Save 100 grams of rotating mass per wheel. It will make a difference but you loose some reliability and stiffness (obviously, but that is always the trade off)
  74. #374
    Both bikes had carbon Havens on them. Which if the spitfire builds heavy with the 650b wheels it will be getting my havens on it.
    After doing some math my build should be right around 28.5lb which should work for me. And that's real weights not claimed. Just spent an hour weighing everything haha!
  75. #375
    May 2005
    My build will be:
    Cane Creek Angleset
    ODI SDG sig grips
    That's gonna be a very nice build, especially with the XX1 when you get it. I'll be watching to see if you hit the goal weight of 28.5lbs. I'd be pretty dam happy with that running the Fox 34 and a dropper. Fox pisses me off as the Floats are white and the Talas black. I would want a Float but not in white and the GD thing is so pricey to begin with to go about swapping the internals.
    Why the Angle Set? (maybe you already have it but I would use a Works Components over the CC as it's a more sano setup IMO).
    I've got 650B NN on my Jamis front/back. Really tall and they roll nice and a little better than the Neo Moto 2.3's I also use. I think the HD front NN rear will be a fantastic combo. Also check out the new Vee Rubber Trail Taker 2.4 as a front possibility
  76. #376
    Already have it. Also have a 40 series if I don't feel the need for the Angle Set.
    I have been running Nobby Nics on my trail bike for the past year or so, love that tire. Just used the HD for the first time over the winter and it really impressed me up front, I just don't want a big ole 2.35 in the rear, so going with the smaller NN.
    Keep your eye out for the new Kenda Honey Badger. It will be available in this year. Awesome looking tire, saw it at Interbike this past year.
    After weighing all my XTR gear it is actually lighter than the XX1 set up so kinda not in a rush to get it. And I truly love XTR drivetrain gear, not sure if I wanna get rid of the most predictable, reliable, and precise equipment I have ever had on my rig. And Shimano has the double shift for dropping it down and getting up to speed, man I love that feature.
  77. #377
    Feb 2005
    If you can afford it high end carbon wheels are the way to go.
  78. #378
    Does anyone(kevin) know if Hope Tech has a headset for this bike? I'd like to keep a general theme going. Thanks
  79. #379
    Reputation: Dogboy's Avatar
    They do. Fourth headset from the left (Tapered/E2) on page 3 - http://www.hopetech.com/webtop/modul...ETS2011Web.pdf
  80. #380
    Feb 2005
    Yes, it is what I put on my 2013 spitfire
    Top Cup 1.1/8" - Integral 43.95mm (Hope Pick n Mix Headsets - Top Cup | Buy Online | ChainReactionCycles.com)
    Bottom Cup 1.5" - Integral 55.9mm (Hope Pick n Mix Headsets - Bottom Cup | Buy Online | ChainReactionCycles.com)
  81. #381
    Yeah, that looks good. Thanks, guys.
  82. #382
    Got the 650B wheels in. They look great as all DT wheels do. Came in at 1763 grams, a whopping 14 grams lighter than the claimed weight.
    Also got the custom decals in for the 34 to match the black frame and graphics.
    Got the rest of the parts in as well, but these are the two I am most pumped about! Frame should be in Friday, Monday at the latest! Can't wait!
  83. #383
    May 2005
    Ah, foreplay...it's gonna be good!
  84. #384
    Gotta ask, where did you get the custom decals for the Fox?
  85. #385
    Medium, post clamp, 135 dropouts with hanger
  86. #386
    Quote Originally Posted by MartinS View Post
    Slik Graphics
    Took about a week to get here. Ends up being about 36 bucks with shipping.
  87. #387
    Ooomph. Wonder how much more the raw weighs.
  88. #388
    Feb 2006
    Looks like 7.95625 lbs with Fox shock which would make it 8.5+lbs with CC DBair. Really surprised this frame is the same weight as the Rune & Prime. Must have the same rear triangle & tubeset. I think it's 1-1.5 lbs too heavy to be competitive in this category. May have to sit on the sidelines a while longer, want similar 27.5 frame at 7 lbs or less.
  89. #389
    FM
    FM is offline
    Reputation: FM's Avatar
    Apr 2003
    <8lbs is totally reasonable, if it's anywhere near as stiff & quiet as my 9lb Prime prototype.
    Certainly plenty of other options available if you want something less stout.
  90. #390
    Reputation: Haus Boss's Avatar
    Jun 2010
    Smile
    Given that the Rune v2 is pretty much in the same class as the Chilcotin, I was hoping the new Spitty would be similar to the new Endorphin, which, according to Pinkbike weighs in at a very respectable 6.55 lb with float ctd shock. I imagine with the right build, the Spitty could probably be hucked and ridden nearly as hard as a Chili or Rune, where the Endorphin is more suited to less aggressive riding, at least on a regular basis.
  91. #391
  92. #392
    Hi
    Is that a medium or a small?
  93. #393
    The raws are around 200g heavier than the ano frames.
    Banshee Blog
  94. #394
    Quote Originally Posted by meekkho View Post
    Hi
    You mean the wheels?................there medium. lol
  95. #395
    Quote Originally Posted by FM View Post
    There are plenty of stout bikes under 7lb, that argument doesn't work. And we obviously don't want other bikes, we want the spitfire, we just are surprised by the weight given the competitions weight.
  96. #396
    Hard funkin´ Kraut
    May 2005
    Well, the pictured scale says: 7,1530 lbs (not 7.95625 lbs) = 3,5765 kg = 3576,5 Gramms, including Fox-Shock (!), Dropouts (QR), Clamp. Subtract the Shock and you will end up at around 3,2 kg for a Double Powdercoated Frame. Subtract the Coating and you will end up around 3 kg for Black-Anodized.
    Is it Carbon-Lightweight? No! Is it heavy? No, not really in my Opinion!
    Yes, Competitors offer plenty of stout Bikes under 7 lbs. Let´s hope you can shred them all as hard as the Spitfire, without ovalising Headtubes, breaking Chainstays or dented Downtubes by Rockfall, thru Years, jump Obstacles in Bikeparks, everywhere up and down ... and remember the Spitfire is just a little "Trailbike" ...
    We will see how troublefree the latest Carbon- or other lightweight "Trailbike"-Offerings will carry on the next two Seasons ...
  97. #397
    Considering how popular the Blurs and Nomads are I think they fare just fine. And that picture said 7lb 15oz.
  98. #398
    I meant the frame
  99. #399
    Nescafe
    Is that scale reading 7.15 lbs? Can't tell if that's the current time or weight? Is that a veggie scale or what?
  100. #400
    FM
    FM is offline
    Apr 2003
    Don't get me wrong, light bikes are great if there are no compromises taken getting there.
    The spitfire has adjustable drop-outs, those will add weight compared to the simpler designs used by other brands.
    Transition lists the covert as 7.68lb with shock, no adjustable drop-outs. The carbon version is 6.8lbs & $2800. Those are reasonable weights IMO.
    I just built up a Kona Honzo Hardtail, 6lbs for the frame. adjustable drop-outs.... no shock obviously! Rides great. And I don't have to worry about it!
    I just don't see much point in getting hung up over <1lb of frame weight, you are getting extra durability, stiffness and adjustability with it. Frame weight doesn't tell you much about how the bike will actually ride.
