Page 25 of 25 FirstFirst ... 152122232425
Results 2,401 to 2,489 of 2489
Thread: 2013 Spitfire
  1. #2401
    MTB B'dos
    Reputation: LyNx's Avatar
    Good advice from CoolDaddy, I'll add hopefully something helpful...
    I'm 6'2.25", 35.25" inseam and I ride a Large Phantom (it's Reach is 5mm shorter than the L Spitfire) and I run a 65mm stem and 785mm bar, have arms that match my inseam, I also own a Prime XL with a 474mm Reach and I used to run it with the same bar/stem combo as I have on the L Phantom, it always felt hard to control on the faster stuff, but short stems and wide bars were still fairly new to me and I thought I was "short enough" with the 65mm.
    2 years after getting the Prime I got the Large Phantom for something a bit more "XC" with the intent to go with a 75mm stem, which I rode for a bit, but ultimately went down to the 65mm and it's been great. I've accumulated enough parts so rebuilt the Prime, this time with a 40mm stem and voila, my high speed problems were gone and handling in tight stuff was much easier, actually, honestly I had no more trouble than on the L Phantom, I cleared every tight spot on my fav trail I know like the back of my hand, no problems, actually the longer WB made it easier to stall the bike when I needed in the tight stuff and readjust and move again.
    I'd say if you want to run a really short stem, go for the XL, you should prob end up on a 35-40mm with a 785mm bar, unless you're very flexible, then maybe a 50mm and if you go with the Large you'll end up on a 60-70mm stem, so think on that. Also will note I like to be about 2.5-3cm behind KOPS, so use a setback post with the steep STAs of the Phantom and Prime, if you happen to pedal closer to KOPS, most definitely look at the XL as your cockpit will definitely be shorter on a straight post - my only gripe with both frames is the super steep STA.
    Quote Originally Posted by richulr View Post
    What do you guys think is the height requirement for an extra large? It seems bikes are getting much longer these days. Bikes like the 5010 and the Troy now have longer top tubes then a large Spitfire. It seems I've seen all different heights riding large and extra large Spitfires on here. I'm a hair under 6'2" with no shoes and am wondering if I should look at an extra large. Also have a 34" inseam for pants and weigh around 250lbs. Which size should I be looking at?
  2. #2402
    Plenty of room; I run a 125 KS Lev, with over an inch seat post extension still visible so I could run a 150 dropper if I wanted. Btw I measure 28.5" from center bb to seat rail with seat post fully extended on my set-up.
    Does the longer seat tube on the xl still leave you with enough room for a dropper post? Can you still get behind the seat without much trouble.
    I'll look at the Rune too.
  3. #2403
    Well I jumped in and now own a Spitfire from the Jenson specials. I went for the XL and can't wait for it to arrive to check the sizing. They even threw in a KS Lev to sweeten the deal. Always wanted a Banshee.
    I see some people are running 650b wheels in 26" dropouts. Any more opinions on this? Can you really tell that much of a difference with the shorter chain stays? Anyone know if a nobby nic will fit in the 26" dropouts. It's an upgrade I'd consider.
  4. #2404
    Hard funkin´ Kraut
    Reputation: NoStyle's Avatar
    May 2005
    From my experience 10mm longer or shorter chain-stays make for a noticeable difference, same as a 10mm higher or lower bb.
    I´m running 650b wheels in the 26" dropouts. Did some experimentation from the start with both dropouts and liked the nimble and playful feel of the shorter dropouts more, so I kept it this way. But tire-clearance is then limited to max. 2.3.
    Best thing to do is: Get both and find out for yourself if you like the short stays, as longer chain-stays can have some advantages when it comes to very steep climbings or high-speed-stability in gnarly terrain. Plus you´re flexible with tire-sizings like 26+ or B+ ...
  5. #2405
    Feb 2012
    Nice! Post up some photos when you get it. I've been considering the complete XL Spitfire from Jenson as well, at 6'1" I owned a large V2 Rune and it fit slightly on the small side for me. Fantastic price on Jenson, almost worth the gamble on size. How did you get them to throw in a dropper?
  6. #2406
    Re: 650b versus 26" dropouts.
    I started with running the 26" dropouts when I converted to 650b wheels, now I'm using 650b dropouts. I prefer them as the bike seems to climb a little easier (more leverage and less front wheel wandering), tall riders might benefit from this more than shorter ones. Didn't feel the bike is less nimble and wheelies are still easy on this bike (although I've never been any good at those in general).
  7. #2407
    When I placed my order there was no picture on the site. I ordered the anodized black 2014 Spitfire .The next day I go online to check something on the specs, and now there is a picture but it's the black and white. I called to ask which I was getting . They said the black and white. I said I ordered the 2014 black which should be the black on black. I really wanted that color and the 2013 model won't work for me since it doesn't have stealth routing like the 14, and I need to put my reverb on it. They did some checking and saw they made a mistake in how they had it listed .They threw in the dropper post to make up for it.
    Amazing customer service from Jenson. They really made up for the mistake. I will definitely send more business to these guys .
  8. #2408
    I thought about going with the Prime, but the shock and fork are better on the Spitfire, and the Prime is about $250 more. And I like the black more than the raw . I think I'll be happy with the Spitfire.
  9. #2409
    If it ever dies I'll get a V3 but damn what a fun bike!!!!
  10. #2410
    Big Test Icycles
    Reputation: Hangtime's Avatar
    Has anyone used Silk Graphics decals on your Spitfire. I searched but didn't find much.
  11. #2411
    Reputation: hartwerks's Avatar
    Oct 2011
    Quote Originally Posted by Hangtime View Post
    I've got the Slik Graphics package, but decided to use it to highlight graphics a bit, rather than completely replace them.
  12. #2412
    Jun 2005
    That Spitfire life. What and awesome bike.
  13. #2413
    Mar 2012
    Got a new shock last week... ooooh baby!
  14. #2414
    Quote Originally Posted by SupervillainX View Post
    You know we need a ride report. CS version? Looks awesome man.
    Seriously....that ride report?
  15. #2415
    Mar 2012
    Quote Originally Posted by Lithified View Post
    Yup CS. I don't think the standard one comes in 200x57? Anyway...
    Shock feels great. But I can't give an accurate review yet as I'm still tuning.
    Got a shuttle day to attend tomorrow, so I'll be fiddling then! I set it to the base tune of the Air CS with a tad more HSC, since the coil is linear, vs. the progressive nature of an air shock.
    Pops off stuff beautifully, feels super plush. My only gripe was that it's a bit chattery through rock gardens. I read I should knock the LSR down a tad, so I'll try that first.
  16. #2416
    Nov 2007
    To any of you running a bos kirk rear shock on your spitfire. What tune do you have? Is it KI03 or KI04?
    Do any of you know what is the difference? Does the 04 have more compression and/or rebound or is it the other way around?
    Sent from my X98 Air II(HG8N) using Tapatalk
  17. #2417
    time for some winter maintenance
  18. #2418
    Feb 2012
    Thought I should contribute to the bike porn.
    Sent from my SM-N910G using Tapatalk
  19. #2419
    Reputation: ddraz's Avatar
    Aug 2014
    18mnths later still loving this bike...
  20. #2420
    Nov 2007
    Quote Originally Posted by algian View Post
    This is just an update for anyone that is interested in trying BOS kirk rear shock.
    I have had a reply from Jungle products in the uk and also Mad elk cycles in Ireland.
    They both confirmed that KI04 is a firmer tune (compared to KI03).
    KI03 is M rebound M compression
    KI04 is H rebound M compression
    I am running a shock with KI03 and the rebound tune is more than ok for my weight (75kg without gear).
    By the way Kirk is much better than ccdb cs. Huge improvement in small bump compliance and no spikes! Very happy with the change. And 180gr lighter.
    Highly recommended
  21. #2421
    Going on a year in April with this thing. No intentions of changing directions any time soon!
  22. #2422
    Looking to improve my Banshee for trail riding. What is trail riding here in Switzerland ? I think, and hope, this is exactly the same as everywhere in the world, ride up, ride down, ride up, ride down, ride .... everywhere having fun and maintaining or improving fitness.
    My Spitfire is a 2013 model. Or 2014, I'm not sure and it doesn't matter. It is now equipped with a CCDB air (not CS). And if my build is not the lightest, and like all Banshee riders i'm not a weight weenie, i'd like to make a gain in weight and pedaling efficiency. So my question, what do you have for a shock ? I'm thinking of a CCDB Inline CS, but what's about the Monarch. A guy from Banshee told me that I need to fin a low compression, middle rebound.
    Help !
  23. #2423
    If you are a fan of the DBair, then I think the inline CS would be a great upgrade for you, drops a chunk of weight (although not lightest shock on the market) gives CS feature which I think is great, and keeps all adjustibility you are used to.
    However, if you don't use all the damping adjustents, then it is worth considering a simpler shock like the monarch which would save more weight, as long as you get the right base tune.
    Banshee Bikes Designer
    www.bansheebikes.com
    Banshee Blog
  24. #2424
    I'm very happy with my CCDB and I love this adjustability. And secondly it is very very difficult to find an RS Monarch with the correct tune, which is low compression, medium rebound (if you can confirm?).
    So I will maybe go for the CCDB Inline CS.
    Here a pic of my loved Spitty :
  25. #2425
    Quote Originally Posted by Samos View Post
    That's a beautiful bike!!! Always loved the red. FWIW, I've had a DB inline for about a year on my 2015 Spitty and won't be changing anytime soon. Love it.
  26. #2426
    Thanks. At this time of the year, here in Switzerland, I'm enjoying some xc'ish riding. Because from home I can see the snow on the hills. By night, searching for some to short single tracks.
    I'll go with the CCDB Inline CS. First because I miss a CS or platform, second because I will save some weight.
  27. #2427
    2013 Spitfire
    I'm wondering now if I should hangs my frame for a longer one. I'm 1.70 in meters. Mine is a 2014 in S size. As you can see in the picture posted a few days ago, my saddle is very high. It's almost at the limit of insertion.. I choose a small because I had some upper back/neck/shoulder problems. I'm feeling far better now and feel a little bit on the short side. Maybe one factor is also at I'm riding more XC-stuff in the last months. Sunday it was 50km for 900m +/- and a lot of easy roads, fire roads, nothing very technical.
    Do we already know something about the next year Banshee bikes ?
  28. #2428
    To confirm the shock tune that we spec on the spitfire is:
    200x57 RT3 M L S 320 HV This tune should fit the average weight banshee rider well.
    Banshee Blog
  29. #2429
    Eating my words here. Had my inline sh!t the bed and Cane Creek hooked me up with a great deal on a DBAir CS. 3 rides in, a bit of fine tuning and holy moly the thing is dialed. Love it!!!!! Many steps above my Inline. Opens up the Spitty, man what a great bike!!!!
  30. #2430
    Nov 2006
    Guys,
    Anyone had real experience with both 2014-15 and 2016 Spitfires? Are the geo changes noticeable at all in 650b mode?
  31. #2431
    Feb 2012
    My spitty just got treated to some pikes! Looks much better than with the white x-fusion sweeps it used to have on there. Loving the stealth look.
  32. #2432
    Jun 2014
    Quote Originally Posted by thedrizzle View Post
    Looks familiar this one..
    Just wanted to bump my post count past yours.
  33. #2433
  34. #2434
    I forgot to post a pic' of mine with the new 27.5 wheels here!
    Envoyé de mon iPhone à l'aide de Tapatalk
  35. #2435
    Keith, what are our chances of possible running the new metric shocks on the old 2014-2015 spitfires? i was on the market for a frame change to the rune but this new standard kind of put me on hold, also what is the chances of actually having a usable bottle cage mount on the new spitfires for us riders in the tropics,
  36. #2436
    Quote Originally Posted by zuman View Post
    No chance I'm afraid... the metric shock bodies are WAY longer than the standard shocks so you would end up with very steep angles and high BB's if you even managed to fit one in a frame, which is highly doubtful.
    Banshee Blog
  37. #2437
    That's a pity!
    I'll just have to wait on Christmas day for your redesigned spitty then,
    the spitty being the perfect one bike for most of my local trail riding but was really considering getting the rune in the hopes that it will give me the boost to ride more real downhill tracks, with the plan to swap out the shocks when the metric ones comes out.
    any way thanks for answering my inquiry.
    you don't have to reply to this, as i know you are very busy redesigning my next banshee bike!
  38. #2438
    Reputation: JustMtnB44's Avatar
    My 2013 Spitfire with some 2016 upgrades
    Custom wheelset with Hadley Hubs and LB AM728 carbon rims
    Geax Goma 2.4 tires
    Easton Haven 35mm bars and stem
    Ergon Enduro grips
  39. #2439
    Reputation: RS VR6's Avatar
    Getting there, hopefully the last of my parts will be in by Friday.
    Attached Thumbnails Attached Thumbnails 2013 Spitfire-img_20160720_184901.jpg
  40. #2440
    18 months in this is the most fun bike I've ever owned. Two things I'd change....1. weight (duh), and 2. water bottle cage inside triangle. But those things aren't enough to really matter, so shred on.
    I have ridden the DH bike a bit lately and was surprised to get on this and have it feel a bit short. I imagine the 2016 geo changes will fix that fit issue for me. Wonder what 2017 will bring!?
  41. #2441
    Above tree line @ 12,600ft in the Rocky Mountains
  42. #2442
    Folks, i need help on compatible shock and tune for the spitfire, as there is a nice bargain for a fox float that came form a build bronson 2016 model, Measurement: 200 x 57 or 2.25 x 7.875 evo can
    free upload image
    i was thinking this would be a good back up for when i need to ship my ccdb air for servicing to another country.
    i hope keith's online, hehehe
    thnxz
  43. #2443
    2016, FLOAT DPS, F-S, K, 3pos-Adj Evol LV, 7.875, 2.250, CL, RM, Climb L
    Thats the shock tune we offered for 2016 after testing. Hope that helps. The brosnon has a very different shaped (almost opposite) leverage curve shape, so tune may well not be compatible as is.
    Banshee Blog
  44. #2444
    Thanks Keith, can't wait for the new spitfire to be released into the wild.
  45. #2445
    Col de Seron, Swiss Alps this morning. Nice views, perfect bike but to less flow for my taste.
    Envoyé de mon iPhone en utilisant Tapatalk
  46. #2446
    One more red bike
    I updated my 2013 Spitfire with a bike skills course, best money I spent ever! After that I "had" to get new brakes, Guide RSC's and a new saddle.
    Love it but I am really looking forward to the new bike as it might be time to change frame.
  47. #2447
    Feb 2014
    Over 2.5 years and 2000 miles of fun! Love this bike. Just treated it to a 170mm Reverb Stealth.
    I've taken to riding it in the high/steep setting on my very tight twisty rooty local singletrack, and then going low/slack when heading to gnarlier places (swapping the bars from 740 to 800mm at the same time). It's on 27.5 wheels but I changed to the 26 dropouts earlier this year.
    Spot the difference.
  48. #2448
    Apr 2015
    Hi all,
    My Spitfire (2015) came with a DBInline, love it, when it works......
    It has been fixed under warranty once, and now after 50h it needs fixing again, hopefully just air can this time, most likely air stuck in the wrong chamber, running at max half stroke, adding air did nothing much.
    What are you running, are the DBAir better and more reliable or any other suggestions?
  49. #2449
    Feb 2014
    My DBair-CS has been very reliable. Serviced once in almost three years, always works great.
    From what I've read about the Inline, attempting to miniaturise the DB damper in the Inline led to extremely demanding tolerances on assembly, hence something as tiny as a fragment of a human hair or a near microscopic scratch can lead to premature failure.
  50. #2450
    Feb 2014
    Spitfire update! 160mm Pike shortened to 150mm and Works -2 deg headset fitted.
    Geometry calculated as (and measurements confirm, which is nice), in low/slack setting:
    HA: 64.1 deg
    SA: 74.1 deg
    Reach: 425mm
    BB height: 335mm
    Wheelbase: 1175mm
    Chainstay: 431mm
  51. #2451
    Hard funkin´ Kraut
    May 2005
    Nice!
    Unfortunately I can´t travel my BOS Deville from 160 to 150mm. If I could I would go with a -1 or -1,5 deg angleset as well. So far keeping it with -0,5 or -1 deg ...
  52. #2452
    Why are you guys going with shorter forks and angle sets? #ignorant
  53. #2453
    Feb 2014
    Lower BB, longer reach, longer wheelbase, steeper seat angle, slacker head angle. Apart from the slacker head angle, the changes are just like on the 2016 version. I'm also running 26" dropouts with 27.5" wheels for shorter chainstays.
  54. #2454
    Very nice! That sounds like a great idea.
  55. #2455
    Hard funkin´ Kraut
    May 2005
    Quote Originally Posted by threehats View Post
    Aiiiiight Sir - so do I.
    Plus: It´s not about the quantity of travel, but the quality of it.
  56. #2456
    Just finished upgrading my Spitfire.
  57. #2457
    Whats the frame weight on a 2016 spitfire now?
  58. #2458
    Jun 2005
    Love this bike.
  59. #2459
    Apr 2015
    Quote Originally Posted by kazlx View Post
    Love this bike.
    Hi, what tune do you run on your rear shock?
    My DbInline is crap (hooping for warranty, but do not look good), looking to replace, but CCDB Air is quite expensive, the RS RC3 seems more affordable
  60. #2460
    Reputation: Andrewslice's Avatar
    Nov 2015
    Quote Originally Posted by CastorTroll View Post
    You need a M/L tune for the spitty. But without debonair can, i had a DA M/L tune and it felt much too slow and unsensitiv and gone too fast through its travel. So i filled the aircan with spacers and the shock was more crappy than before
  61. #2461
    Apr 2015
    Quote Originally Posted by Andrewslice View Post
    Thanks for the info.
    We are talking about this one, just to be sure https://www.sram.com/rockshox/products/monarch-plus-rc3
    I have not, so far, found it without debonair (is it really an option?) and all I see has M/M.
    To add another question, is CCDB Air worth the money? And is it that much better and more reliable then DbInline, I kind of lost my trust for CC there.
    In the meantime I run with a RS Monarch R HV :-D
  62. #2462
    Apr 2015
    has anyone ridden a spitfire and a Transition scout? how do they compare? I currently have a Scout but I want to change it to possibly get a new spitfire. I really like how playfull and agile the scout feels but want something a little more forgiving on bigger hits. Thanks.
  63. #2463
    Apr 2015
    Hi,
    How do I calculate spring rate?
    Anything more needed for selecting a spring?
    I'm about 80 kg without gear
    Bike: Spitfire
    Is Rockshox and Cane Creek calculated in the same way?
  64. #2464
    Spring Calculator - TF Tuned
    This spring calculator gives a pretty accurate starting point... as far as this calculator is concerned you can consider the KS link to be close to 'single pivot / DW'. Make sure you use weight as you wuld be when riding with gear on + pack etc. I'd guess a 450lbs spring was a good starting point for RS, 400 for cane creek. I would definitely advise testing a cheap steel spring to get weight right before considering investing in a lighter option.
    Banshee Blog
  65. #2465
    Off the back...
    Reputation: pinkrobe's Avatar
    I use the CCDBA on my DH and AM bikes. Do the recommended annual maintenance and they'll last for years. I have seen a few issues with the DBInline among the local crew, but the CCDBA looks to be pretty bombproof.
    @pinkrobeyyc
    #pinkrobeyyc
  66. #2466
    Apr 2015
    Quote Originally Posted by builttoride View Post
    Thanks a lot for quick response!
    Any serious concerns against RS vivid compared to CCDB, coil versions?
  67. #2467
    Finally "done" with the Spitfire. Weighs in at 30.5lbs.
  68. #2468
    Apr 2015
    Additional question.
    For Spitfire it is medium rebound, low compression, is that for all RS shocks?
    That is both for Vivid R2C and Monarch RC3.
    And is so, I can not find a retailer that stocks that for 200/57, in Europe, any suggestions?
    Edit: aftermarket tune is apparently MM, but can be altered but bike shop.
  69. #2469
    Sep 2013
    New '16 frame. Thanks Dirt Merchant.
  70. #2470
    I went this morning for a small, 20 km, ride over the clouds. Apart from a rear tyre which lost some air on a rock strike and slowed me a bit...
    The Spitfire is a so great trail bike, no matter what you ride, it's at home !
  71. #2471
    Aug 2005
    4500km on my Spitfire frame now. Still going strong and just finished a week of riding in Pisgah, North Carolina.
    The only thing I'm not keen on is the rear shock. But meh, it feels good once you start getting the speed up in the rough stuff.
  72. #2472
    Only 2'500 in mine so far, but also not so keen on my rear shock (CCDB air), which is lacking a platform I think.
    For the rest, it's just an awesome bike, the best I've ever owned.
  73. #2473
    Aug 2005
    Lets trade. haha
  74. #2474
    4 years old, still cleans up nicely.
    Installed new bearings, serviced shock and fork, tires, some purple bling = feels like a new bike :thumbs:
  75. #2475
    Reputation: mattyice's Avatar
    Dec 2015
    Quote Originally Posted by cooldaddy View Post
    Love the purple bars on the raw frame!
    Banshee Bikes
    Slaphead Legion
    Wachusett Brewery
  76. #2476
    Apr 2015
    Question:
    If given the option to run either CCDB Air CS or DB Coil IL CS, what's the best pick for trail riding? Not XC but still not DH, more like Swedish Enduro, that is a bit of all.
  77. #2477
    Question:
    I have ridden both. Replaced the DB Air CS after a year with a DB Coil Inline. My only regret is not doing it sooner!!! Man the coil just runs so nice on a Spitfire.
  78. #2478
    Sep 2013
    Question:
    Ignoring the brand/model of shock involved for a minute; just considering air vs coil on a bike like the Spitfire -
    - Ideally you have an overall suspension rate that is supple at the beginning stroke, ramps up to provide mid-stroke support, and ramps up more to provide bottom-out protection. You'd like the increase in support to feel as linear as possible when riding; humans are pretty sensitive to rate changes.
    - Coil springs increase in force in a linear fashion, for a 500lb/in spring every inch it's compressed it's force increases 500lbs.
    - Air springs increase in force in a non-linear fashion, generally the force is high at the beginning of travel, then both falls and then increases over the mid-stroke followed by a large increase at end stroke.
    - If you want the ideal suspension rate with an air-shock you design a linkage that negates those large changes in rates. The Spitfire does that, that's why air shocks feel really good on it. However a coil spring doesn't negate the rate changes. What you wind up getting is a suspension that is really supple at the beginning stroke, has a lot of mid-stroke support, and not as much end-stroke support. The last point is something you have to deal with to prevent harsh bottoming, usually by increasing the spring rate, which also increases that mid-stroke support even more. Whether or not you're good with that is up to you.
  79. #2479
    Apr 2015
    Quote Originally Posted by djjohnr View Post
    Really good info, cannot say I know that much about shocks, hence my question here. Your reasoning sounds sound, I'll do some reading about it. And thanks for taking the time to elaborate the matter.
  80. #2480
    Oct 2012
    FYI. Running 2.6 Rocket Ron on Flow MK3 and there is plenty of room in the rear. No review yet since haven't taken it out.
  81. #2481
    Dec 2016
    hello
    I have a Devinci Dixon 2011 frame and I wanna buy a Spitfire 2017 to replace it.
    Do you know if the spity is heavier than dixon?
    Feb 2010
    Hi, i am looking at a spitfire, or a transition scout. Which is the better climber and would be the better choice for big climbs and long days out. thanks
  83. #2483
    Dec 2016
    Quote Originally Posted by froutts View Post
    May be this will help you:
    Banshee Spitfire vs Transition Scout « Singletrack Forum
    It seems that Spitfire is better climber than Scout (KS >FSR), but for long days you will need to mount it with no-heavy components in order to contain the total weight of the bike.
    Remember that the anodized frame is 150-200 gr lighter than the raw one.
  84. #2484
    Are you sure the anodized frame is lighter than the raw frame ? The anodization don't destroy any material. This is just an oxidation of a thin layer on the surface. A raw frame and a anodized frame are lighter than painted frames for sure.
  85. #2485
    Dec 2016
    The designer wrote that in this forum, I will try to find those words
  86. #2486
    Dec 2016
    The raws are around 200g heavier than the ano frames.
    2013 Spitfire
    The raw is the heaviest (slightly) due to 2 clearcoat layers...
    2013 Spitfire
  87. #2487
    Ok, if they are clearcoated then it's normal ;-)
  88. #2488
    Some Spitfire fun. Yes that log is hanging by its own wedge in my wheel. Caught it mid air in a whip. Once in a lifetime wreck. Rode 20 miles after this. Only casualty was a single broken spoke/nipple.
  89. #2489
    Updated mine yesterday. The rear derailleur was crying and asking for help every gear change, so I decided to go for the new 1x11 XT. But with a Sunrace 11-46 cassette.
