Page 11 of 26 FirstFirst ... 78910111213141521 ... LastLast
Results 1,001 to 1,100 of 2522
Thread: 2013 Spitfire
  1. #1001
    May 2005
    Quote Originally Posted by jlf.ski.bike.sail View Post
    lets see a nice pic of the blue spitty!
    Oh yeah, I want to see that also. Probably would have gotten that if available last year.
    2013 Banshee Spitfire V2 650b
  2. #1002
    spinner
    Reputation: Pinky's Avatar
    Quote Originally Posted by inkisink View Post
    Teaser
    Thank you sir ! That pic will get me through the next 2 weeks while I await the arrival of my frame
  3. #1003
    Mr. Knowitall
    Reputation: hssp's Avatar
    Re: 2013 Spitfire
    Monday! I do not have too much of photography equipment thingys or good Internet where I am now... Frame in couch is mandatory, and it will come.
  4. #1004
    Reputation: RollingRevolution's Avatar
    Oct 2011
    2014 Spitfire
    Finished the build. Still to trim brake lines a bit, trim excess steerer and setup the suspension. Maiden ride tomorrow.
  5. #1005
    Jun 2013
    Very nice! Is it just me or does the 2014 look a little bit skinnier, particularly the top tube? I know some weight has been shaved off so was it off the tubing or am I just talking bs
  6. #1006
    Hard funkin´ Kraut
    Reputation: NoStyle's Avatar
    May 2005
    Hmmm ... By the Look Tubing seems to be the same. Questionable were Weight has been shaved off, and how much ...
  7. #1007
    Reputation: jazzanova's Avatar
    Re: 2013 Spitfire
    Very nice.
    Which saddle is that?
  8. #1008
    Mr. Knowitall
    Re: 2013 Spitfire
    Quote Originally Posted by NoStyle View Post
    The rear has been tuned a bit i know. Less welding.
  9. #1009
    Mar 2011
    Quote Originally Posted by jazzanova View Post
    Very nice.
    Looks like a Chromag Trail Master LTD
  10. #1010
    Oct 2011
    Tis indeed a Trailmaster LTD.
    Regarding weight, I have no idea if there is any difference from the 2013. Changes I know of are stealth routing, bottle cage bosses, and on the strut (for want of a better word) completing the triangle between seat stay and chain stay there is one less weld. I doubt any of this saves any significant weight.
    Truth be told I was worried about this being a bit of a porker. And it is. But as others have said time and time again it doesn't feel heavy when riding. And if that weight is what contributes towards the solid feel, stiff rear end and all round build quality then its very welcome. Also the bulk of the weight is low down which keeps a nice low centre of gravity.
    Two rides in and I can already start to see why there is so much love for Banshees. It climbs as well as any bike I've had, but its the descents which stand out for me. I've never felt more confident.
    I bought mine blind. No chance for a test. Never even seen one in real life. I'm very happy to say the bet has paid off, big time.
  11. #1011
    That's one hot ride!
    One day I'll have one of my own but the V1 does me fine at the mo.
    Are the bottle cage bosses under the downtube?
  12. #1012
    Sep 2013
    Here is my 2013 Spitfire:
    raw, large, Lyrik Solo Air RC2 DH 160mm, X.9, XT brakes, Kindshox LEV 150mm, Hope Pro2/Flow, Highroller 2 & Ardent 2.4" each.
    14.7kg - amazing ride :-)
    2013 Spitfire-img_p9193864.jpg2013 Spitfire-img_p9193745.jpg2013 Spitfire-img_p9193777.jpg
    Nice greetings from Austria
  13. #1013
    Mr. Knowitall
    Finally! My '14 blue size L frame has arrived, I have instagrammed it well tucked in on the couch. And I have weighed it... Heavy machinery, so hope it is worth the extra ballast. To transport it home, I had to take the frame apart, and the front triangle is fairly light, and all the weight is in the rear (no shock). A carbon rear triangle is high up on my wishlist for this bike.
    Anyway, I have some vitals for the number nerds.
    Weight shock: 553g
    Weight bike incl shock, dropouts, axle and seatclamp: 3890g(!)
    I have only instagrammed it, so here goes:
    Instagram
  14. #1014
    Reputation: jon123's Avatar
    Whoa. Did I read that correctly?? Nearly 8.6 pounds. Yikes.
  15. #1015
    Mr. Knowitall
    I will double ceck, but this scale is usually spot on
  16. #1016
    I must admit, I also nearly choked at that.
    Really hoping your scales are f*cked, because that sounds faaaaar too heavy!
  17. #1017
    The weights are listed as (which may or may not be completely wrong):
    Ison Distribution
    So for frame only at 2948 (let's assume that's a medium) + 553 = a frame / shock at £3501.
    If the frame wasn't listed with an axle, or any mounting hardware and seat collar, it's not that much of a stretch to say that your measurement is probably spot on for a Large.
    That's a bit shocking, especially given Alu bikes like the Santa Cruz Bronson are coming in at around 7lbs with CTD shock
  18. #1018
    Hard funkin´ Kraut
    May 2005
    The Spitfire weights around +/- 3200 Gramms with Shock-Bolts, Clamp, complete Dropout-Set, depending on Color and Size. Plus Shock separately to add.
    Jep - heavier than average, but you should buy a Bike because of it´s given Features like Suspension-Layout or Geometry, not Frameweight ...
    Truth is that the Spitfire is a lot more towards the 150/160 mm Travel Enduro/AM-Bikes with slightly reduced Travel than towards the average Trailbike. Like it or not, but the Spitty´s Frameweight is contributed to all the Adjustability and Dropout-System. Like inkisink has already said - all Linkages are around the BB, so this Weight is low in the Frame and not noticable when riding.
  19. #1019
    Mr. Knowitall
    It's aout the same as my previous SB66 with Vivid Air. And that ended up being a bit on the bulky side...
  20. #1020
    May 2005
    My 2013 large Raw frame with Fox CTD shock, 12x142 dropouts, Banshee QR post clamp, installed head set cups and NO axle was 8.2lbs.
    Bike pedals great and never feel heavy or sluggish to me. It's about 31lbs as I have it.
  21. #1021
    Sorry, but that's just contentious.
    No one said otherwise, however this is not a budget old school bike. With the money we spend, we can expect great geometry, suspension and decent frame weight - no reason to not sacrifice any of the above. That said, I'm not cancelling my order, but it's a bit annoying that I need to pick my components more carefully than I'd have wanted to.
    "Not noticeable when riding" - this is just something everyone says with a heavy bike.
  22. #1022
    Hard funkin´ Kraut
    May 2005
    "Not noticeable when riding" - please go demoride one and report if it feels heavy anyway. This has absolutely nothing to do with "I´m on a heavy Bike", so I have to find Reasons to justify ...
  23. #1023
    I have ridden one as a demo bike and again, I reiterate, I'm still having one.
    It does ride great and doesn;t feel heavy...but it would have been an even better climber, were it lighter.
  24. #1024
    FM
    FM is offline
    Reputation: FM's Avatar
    Apr 2003
    Well… wait though, what do you get for the extra weight? Is it just heft or does it actually benefit the ride?
    I think we can all agree it would be idiotic to not ask that question….
    • The adjustable geometry drop-outs are a rare feature you don’t see on the lighter frames. No doubt they add significant weight. The 4 fasteners alone are probably an ounce each- but it’s awesome how beefy they are, no worries about stripping or coming loose. And you can run different wheelsizes on the same frame.
    • Then there’s the linkage system and how it mounts to the frame. Mounting the shock to the downtube requires a thicker walled DT, which adds weight compared to a top-tube mounted suspension design. I learned this after many of my friends broke their frames made by another brand, which uses the DT-mounted shock lay-out. They all got heavier warranty frames. Mounting the shock to the downtube reduces the rotation at the shock eyelets though.
    • The Bronson & solo have a spar on only one side of the swing arm, Banshee has spars on both sides with cross-bracing, who knows if that actually saves weight or adds flex, but it’s a difference.
    • Last… all the carbon bikes have reset our standards for frame weights, but lets not forget the cost!
    last... weight seems like a big deal on paper. But realistically we all carry 1lbs of car&house keys and empty beer cans in our packs. Better places to shave weight.
    No doubt light bikes are fun, and I personally would really like to see lighter carbon versions of the KS-link banshee bikes (not holding my breath though).
  25. #1025
    Fair points you raise.
    Just for reference, I was comparing the Spitfire to the the Aluminium Bronson.
    Personally, having the option of running both 650b and 26", I don't think benefits a single user for the most part (who runs both wheel sizes on the same bike anyways).
    I also don't are for adjustable geo - but I'm sure I'm in the minority there.
  26. #1026
    FM
    FM is offline
    Apr 2003
    Quote Originally Posted by supercow View Post
    Oh yes. Mainly I was getting at.... ~8+lbs didn't seem so heavy a few years back when the lightest durable 5" frames were ~7+lbs. Carbon has changed our standards now that 5-6lb frames are available in that travel range!
  27. #1027
    Hard funkin´ Kraut
    May 2005
    Well, things turned out for me that the 650B Wheel amazes me more than I thought it could. My initial Plan was to switch Wheels = light 650Bs for Traildays and burly 26" for the Park/DHs. Now I stick with the 650Bs, but I´m happy that I can change if I want. Only very few other Brands offer a Feature like this. Add the Possibility to have adjustable Geometry at the same Time, to fix the one you like, is a Feature that no other Brand has. The interchangeable Dropout-System is simply genius. If this weights 200 Gramms more than fixed Dropouts than yes, I´m fine. And if ribbed Chain/Seatstays add another 100 Gramms for the exceptional Rear-Stiffness than yes, I´m fine again.
    Other Brands maybe do use higher/lighter Alumium and have more excessive Manufacturing, Hydroforming etc. to shave off Weight from Tubing. But all this comes to significantly higher Prices versus the Weightsavings and often Frameflex you mostly get for it. Plus the Majority of other Brands don´t offer Features Banshee has - some more Frameweight is the Pay-Off for a great Money/Value-Ratio you get with Banshee ...
  28. #1028
    Aug 2013
    No it's not a budget old school bike but I do still see it on the cheaper side considering whats out their. I had narrowed my selection down to the alu SB66, Banshee Spitfire and Carbon Bronson. I picked the Spitfire because it was a full $1000 cheaper and comes with a CCDB (I am from Australia).
    I don't mind the weight as long as it goes into strength and stiffness then you get 2 big thumbs up from me.
  29. #1029
    Quote Originally Posted by steeeze View Post
    So you compared it to one of the most overpriced brands around and the one of the most expensive carbon bikes around, then came to the conclusion that it's one of the lower priced bikes around ... right.
  30. #1030
    Hard funkin´ Kraut
    May 2005
    It´s important to compare Aluminum-Frames, of course. I don´t know for the rest of the World, but Specialized Enduros, Santa Cruz Bronsons/Nomads, Trek Slash/Remedy, Liteville 301/601 - the List goes on - are between 200 and 500 Euros more expensive than Banshee in their Alu-Frame-Offerings in Germany. That´s a lot of Money - for how much Weightsaving on Frame-Only ... ?
    I´m sure Banshee could save more Weight on their Frames, but maybe with a Compromise of Durability, Stiffness and mostly higher Cost due to more expensive Materials/Alloys or Tooling ...
  31. #1031
    When i 1st got the frame i worry about the weight too. I got it build up near 15kg.
    Now after 1 month of riding. I feel the bike climb much better then my lighter weight AM hardtail. Tons of traction at rear wheel on tech slippery uphill section.
    It just keep going as long as you put the power down. Love the feel!
  32. #1032
    Oct 2011
    5 rides out on mine now. Each time I've pulled it down from the rack I thought to myself "damn that's a heavy piece of kit".
    Then I start riding and that thought quickly evaporates and doesn't cross my mind again until it goes back on the rack.
  33. #1033
    I purchased and rode my Spitty V2 all summer with a relatively selective but affordable build and found that it felt stiffer and more efficient than some lighter offerings (i.e. Giant, Trek, Yeti) that I had ridden before. With the type of aluminum tubing they use this is the first bike I have not dented the down tube in a long time. Though I do occasionally think a lighter bike would be beneficial, I have been hard pressed to find a bike that is lighter with geometry and fit that are is ideal as my banshee. This will be the first bike in five years I ride for more than a season, because I like it that much.
  34. #1034
    I was wondering if anyone had replaced their pivot bearings yet? What size they are, so I can grab some enduro MAX bearings.
  35. #1035
    Jun 2013
    I don't own one yet but I believe its 4 x 6001 2RS and 4 x 608 2RS. Very easy to source. Its listed earlier on in this thread.
    im interested in this as well as ease of replacement and bearing life are a big deal to me, coming off a 575 that had play after about 4 months of light riding. I could do with knowing if there is a banshee bearing kit available as I don't know how replaceable the pivot pins are for example?
    re the weight debate - is the 2014 spitty still approx. a pound heavier than the 2014rune? this was why I chose the spitty over the rune but it seems its like comparing the weight of a battleship to an aircraft carrier, on paper at least
  36. #1036
    Mr. Knowitall
    I hope the Spitty is LIGHTER than the Rune...
  37. #1037
    Hard funkin´ Kraut
    May 2005
    Why should the Spitfire - a Trailbike - with a slimmer Front-Triangle-Tubing, shorter Shock and less Rear-Travel, be heavier than the Rune - a AM-Bike?
  38. #1038
    Jun 2013
    Don't worry I meant 'lighter'! Haha. Im not that misinformed
  39. #1039
    FM
    FM is offline
    Apr 2003
    In case it helps I replaced the bearings in my Prime already, over the summer- I was trying to track down a creak that ended up being my dropper post.
    All the bearings were available off enduroseals.com and were pretty inexpensive. The bearinsg I pulled out were like new, alignment was good, fit was perfect (much improved compared to my proto). The axles showed no signs of wear at all, so unless there's a "mechanical accident" I don't think those would ever need to be replaced.
    I made a $3 bearing puller/press using some 8mm threaded rod, fender washers and nuts. Presses them in perfectly square without loading the races. To remove the bearings, I just added a socket to this tool, which had an ID larger than the bearings OD. Remove washers from the opposite side, and when tightening the nut will pull the bearing out of the frame and up into the socket. Smooth and easy! The only thing to note is that you must do the upper swingarm link bearings idependantly- if you run the press tool through both sides, it could potentially bend the link.
    Make sure to use a torque wrench on the axles.
  40. #1040
    Hard funkin´ Kraut
    May 2005
    Quote Originally Posted by fingerbanger View Post
    hahaha, I thought so already ...
  41. #1041
    Quote Originally Posted by eightyfive View Post
    Holy crap man, does your seat have lead railings?!
    That's close to my DH bike weight.
  42. #1042
    Reputation: crazyape's Avatar
    Nov 2013
    did someone want to see a blue 'un?
    can't comment on how it rides as i've not had chance yet but not sure it matters when it looks this pretty ;o)
    my large frame weighs 7 1/4 lbs with 135 dropouts and the fox shock. i'm quite happy with this. i always considered a heckler as a bit of a bench mark for a tough aluminium all mountain bike at 6 1/2 lb. for an extra 3/4 lb i get 3 extra sets of bearings, a lot of adjustability and hopefully a back wheel that follows the front!
    full thing weighs just a fraction over 30 lbs without much weenie-ing.
    seems a shame to get it mucky...
  43. #1043
    Aug 2013
    Wow the blue looks absolutely stunning! well done mate.
  44. #1044
    Reputation: NCBigHit's Avatar
    That's a beauty... Probably the only color I'd go for over my black one. If I can get down to a hair over 30 I'll be happy!
  45. #1045
    spinner
    The blue looks great with the black accessories I see you have run the rear der. cable between the upper link and the swingarm. Nice and tidy , there's no chance of it getting pinched in there I hope ?
    (I have nothing better to do than study in detail everyone elses builds while I wait for my Spitty frame haha)
  46. #1046
    The Blue is sooo pretty!
  47. #1047
    Hard funkin´ Kraut
    May 2005
    @ crazyape
    That is a very nice Spitfire!
    Although I wouldn´t run the Cables between the Link and the Brace but outside of it. I did this first too, and even when the Cables didn´t get pinched, there would be Cable-Rub and unnecessarily more Mud to catch in, so I got the Cable-Routing outside. Since then no "Problems" ...
  48. #1048
    Nov 2013
    thanks for the kind words people.
    pinky and no style - you don't miss much! i couldn't decide which way to run the cables. couldn't find any examples on here of people running them inside but i couldn't get them to pinch when cycling the suspension on the work stand so what it it came down to was any cable rub wouldn't be visible - what a tart! it does sound like i'll be rerouting them though...
    anyone try routing the final loop to the rear mech inside the frame?
  49. #1049
    Hard funkin´ Kraut
    May 2005
    No, I have all my Cables outside, because I don´t want to risk Rub, Mud or even Tire-Nobs to catch any of them. Same for the Rear-Derailleur - you need to have a big Bow to prevent the Cassette not eating up the Cable. Exception is the Front-Mech-Routing on mine, which takes a Bow and goes on the Downtube instead under it. The only Contribution of a "cleaner" Look.
  50. #1050
    Hi guys,
    can you tell me what comes with the 2014 frames besides the frame, flip chips and axle?
    I think the 2013 models came with seatpost and seatpost collar too - right?
    I didn't ask my dealer what has been inside - so i don't know it. It's Sunday and i don't wanna bug him with this today.
    What was inside of your 2014er Spitfire boxes if you ordered a frame kit?
    <a href="http://fotos.mtb-news.de/p/1510071"><img src="http://fstatic3.mtb-news.de/f/mr/2u/mr2uc5lk18sg/thumb_Spitfire-002.jpg?0"></a>
  51. #1051
    Oct 2011
    2013 Spitfire
    Mine came with seatpost clamp, dropout Kit with spare hanger, shock and stickers. No seatpost.
    Oh and it also seemed to include a lot smiles
  52. #1052
    Reputation: Haus Boss's Avatar
    Jun 2010
    Have the 2014s made their way down and into the States yet?
  53. #1053
    Oct 2013
    Quote Originally Posted by Haus Boss View Post
    Who cares? We have em in Sweden
  54. #1054
    Sep 2013
    Hi guys
    I have question, if I put Pike 650b 150mm (a2c 545)to spitty frame with 650b dropouts, HA will be 66 or 66,5? Or maybe I need a2c 555 to get HA 66/SA 73,5 with 650b wheels? It's not a problem, I'm just curious
  55. #1055
    Oct 2013
    A 650b pike in 150 mm got a listed a2c of 542 so it will be a touch steeper than the table. In the low setting it will be very close to 66HA and 73,5 SA.
  56. #1056
    I'd recommend sticking with the 150mm 650b pike. It works better with the frame geometry (giving you almost identical to geo chart (head angle will be about 0.1 degrees steeper and BB height about 1mm lower).
    Banshee Bikes Designer
    www.bansheebikes.com
    Banshee Blog
  57. #1057
    Sep 2013
    Thanks for your help, I bought 150mm 650b Pike about 5 minutes ago
  58. #1058
    ev.
    ev. is offline
    Nov 2013
    Hoping you guys can help me on sizing.
    I currently ride a Gen1 Santa cruz blur LT in a large, which has an ETT of 590mm, same as the medium spitfire. Currently using a 50mm stem with 750mm wide bar.
    Test rode a medium spitfire with a 45mm stem and 740mm bar the other day, and it definitely feels cramped comparatively.
    I'm really unsure whether I should go a large with 35mm stem, or medium with a slightly longer stem.
    For the record, i'm 182cm tall.
    All help appreciated
  59. #1059
    Sep 2013
    Quote Originally Posted by ev. View Post
    I am 182cm tall and run a L with 45mm stem and 760mm bar.
    Fits perfectly for me, maybe I'll try a 35mm stem for comparison.
  60. #1060
    Hard funkin´ Kraut
    May 2005
    I´m 180/181 cm tall and went with a medium Spitfire and 50 mm Stem first. Then switched Framesize to large, with a 35 mm Stem. I could even run a 50 mm Stem without being to stretched out.
    I think a large with a shorter Stem could fit you better when you felt cramped already on a medium.
  61. #1061
    Oct 2011
    180cm here. L Spitty, 760mm bars with 60mm stem (although the 12º sweep on my bars probably makes my stem equivalent to 50mm regarding hand position). Never been more comfortably.
  62. #1062
    Jun 2013
    anyone got any news on UK distribution? I'd been expecting my frame this week but looks like more delays. I've not had a trail ride since June so I feel like I've been out through injury again. Getting effed in the A. Should be renamed 'Mythic' again UPDATE - just had date fixed so panic over
  63. #1063
    Just a few pages back, I mentioned I was 5.9" (180cm ish) - and everyone was recommending a medium.
    Few pages later, same question comes up, and everyone's saying Large.
    :x
    For what it's worth, the Large felt great to me in terms of reach, but the seattube was too long. My seat was in the way, even slammed down with a Reverb.
    Care to share - I'm waiting on mine too?
  64. #1064
    Aug 2013
    5'9" is 175cm
  65. #1065
    5'9" is 175cm
    No.
    179.832
    But that really is splitting hairs mate. Even just 5mm, that's the difference in thickness between my Five ten freerider and the Karver shoes I have lol.
  66. #1066
    Aug 2013
    No.
    179.832
    No.
    Height Converter - cm to feet - inches to feet
    175cm.
    I am 180cm at 5'11" and ordered a Large.
  67. #1067
    Google > your site.
    My mac's converter agrees too.
    ANYWAY - back on topic - even if you were right, 5mm is bugger all.
  68. #1068
    Oct 2013
    LOL
    That why we euros actually use units that got a base of 10. 5.9 feet is not 5 feet and 9 inches since there goes 12 dumbass inches on a foot.
  69. #1069
    Aug 2013
    Google > your site.
    so you are 5.9' tall or 5'9"? I have never seen anybody use 5.9' as a measurement for height.
    I could be wrong but it's possible that people thought you meant 5'9" and that is why they recommended a medium because if you are 180cm then Large should be spot on.
  70. #1070
    Quote Originally Posted by Dystopism View Post
    LOL
    Best!
  71. #1071
    FM
    FM is offline
    Apr 2003
    LOL
    I have to point out that nearly all of us have 10 toes. How did we end up with 12 increments within a "foot"?
    Converting between fractions and decimals of imperial UoM makes matters even worse.
    As a citizen of the USA, I guarantee my child will grow up fluent in metric!
  72. #1072
    Jun 2013
    :x
    what ive been told is that Ison have now got the frames and my shop is getting there first drop either today or tomorrow. I reckon next week for me and then get it built up and riding next weekend fingers crossed
  73. #1073
    Cheers fingerbang.
    That's great news, that means hopefully mine will be built up before this weekend then!
    Yay
  74. #1074
    Mr. Knowitall
    Quote Originally Posted by FM View Post
    24 thumbs up
  75. #1075
    LOL
    Christ, consider me schooled
    I also work in metric and was trying to work backwards ... failed miserably
  76. #1076
    Hard funkin´ Kraut
    May 2005
    No.
    179.832
    Hi Supercow,
    if you are 5'9" = 5 Feet, 9 Inches than you are 175,26 cm tall, not 179,83 cm. The Difference then is not 5 mm but 5 cm = almost 2 Inches!
    With this Numbers you should perfectly fit on a medium Spitfire. Stemlength probably from 30 to 50 mm. So all the Recommendations were just right!
    People with 5'11" (180 cm) or slightly taller can go with both Sizes medium or large, depending on personal Preference and a well choosen Stemlength to maximum 60 mm. But it seems like the majority of Riders prefer the Combination of a longer Frame with shorter Stem.
    Hope this helps!
  77. #1077
    Mr. Knowitall
    I am 185cm and considered an XL with short stem, but chickened out..
  78. #1078
    Hi Supercow,
    Yeap, I realised that this morning to my embarrassment :x
    Thanks though, do appreciate it.
    The reason I feel so anal (read: paranoid) about the "sizing up" thing, is because I prefer bike with a longer than normal reach. I also have mental scars still from my experience with the Intense Tracer 2 (50mm stem), which I couldn't hate more if I tried!
    I felt far too cramped and could not for the life of me feel comfy on the Medium, and I refuse to ride a stem longer than 50mm.
    In stark contrast, I borrowed a mate's 17" Orange five (50mm stem) and felt immediately at home, even though the bike was far too oversprung for me (my mates couldn't shake me off their tail down our local DH spot on it).
  79. #1079
    ps: F*ck me sideways, look at this build!
  80. #1080
    Hard funkin´ Kraut
    May 2005
    Quote Originally Posted by Wea22ther View Post
    I really hope they make dropouts to shorten the rear also.
    Hmmm ... for 26 Wheels the Spitfire´s Chainstays vary from 427 to 431 mm - which IS short. Ok, add 10 mm for 650B may not remain really short, but is still shorter than some others. Plus 650Bs do fit in the 26 Dropouts with Tires up to 2.3 ...
  81. #1081
    Hard funkin´ Kraut
    May 2005
    I can´t find the Reach of the Tracer 2 (26-Version), but the medium ETT is 584 mm and 610 mm on a large. 72 Deg effective Seatangle.
    The Orange Five has a ETT of 600 mm on a medium. Again no Reach, but a 74 Deg effective Seatangle which will make for a longer Reach for sure.
    A medium Spitfire is slightly shorter (10 mm) in ETT and possibly Reach compared to the Five. If it felt right than medium should fit pretty good. At 175 cm I would not recommend a large. Even with a 30 mm Stem it could be too long. To be absolutely sure take a Demoride if possible!
  82. #1082
    Reputation: jlf.ski.bike.sail's Avatar
    Selling my 2013 Spitfire V2 ano black medium!
    asking $3500 complete or $1500 for the frame (comes with a custom valved Fox Float CTD)
    check out the pinkbike link here: 2013 Banshee Spitfire V2 - medium - Pinkbike
    make an offer! i live in eastern wa, and would easily be able to hand deliver in washington or oregon.
    Looking forward to getting my 2014 spitfire!
  83. #1083
    Reputation: zoorlen's Avatar
    R: 2013 Spitfire
    If Batman had a bike... It would look like this. Awesome.
  84. #1084
    Aug 2013
    Oh my goodness! Excitement levels are reaching boiling point over here!
    Pretty much my exact build besides wheels and CCDBAcs. Hurry up frame!
  85. #1085
    Nov 2013
    Hey folks, what are your experiences with spitfire sizing?
    I've been torn between an XL and a L for a few weeks, I ordered an XL (was going to run a 35mm stem) to be told Ison (UK) wouldn't have them till early jan so opted for the L not sure if this was a mistake. Also had mixed opinions from shops I have spoken to, they often said they are fairly long bikes. I'm 6'2" (186cm).
    You guys got any thoughts?
  86. #1086
    Reputation: Calhoun's Avatar
    Nov 2008
    Gotta be SRAM employee, or at least a serious fan-boi
    Either way that is a sweet build
    "Mi amor Nuevo Miércoles!"
    -cabra cadabra
  87. #1087
    Jun 2013
    for ****s sake - its becoming a joke. we were told that 17th was the set in stone date. I've been spending a fortune on uplift days just to get some MTB done as I don't have a trail bike
  88. #1088
    Quote Originally Posted by Calhoun View Post
    Think it's someone at Fishers.
  89. #1089
    Jun 2013
    Quote Originally Posted by andrewbond View Post
    Im not currently a banshee owner (see above) but sorry to put you off ,Im 6'2 and a half and felt too cramped on a large rune. I have ape like arms though. Im getting an XL spitty which I know is a tiny bit longer than an XL rune. It might feel alright mate as having read this thread it would appear Im between sizes but I definitely felt large rune was too small. My inseam is disproportionately small for what its worth. I could have done with a demo on an XL but they're like rocking horse poo I believe. The only way to go is longer for me
  90. #1090
    Jun 2010
    Hate to say it, but this is pretty much a commonality across the industry and one you should pretty much expect when dealing with boutique manufacturers. A few weeks can easily turn into a month or two. You can always buy a Trek or Specialized!!! While I may not like it, I'm completely cool waiting for my 2014 to come in. All I've had for the past 4 weeks is a road bike since I sold the Rune.
  91. #1091
    We all knows this, but it doesn't make it less heartbreaking when you're so close, but yet so far.
    Was planning on riding this weekend until my balls fall off from frostbite, but now all I have to look forward to, is drinking myself into a stuper while sulking.
  92. #1092
    Jun 2013
    ...Im like this. Opening the banshee frame box will be like opening the lost ark of the covenant. Im expecting it to emit a shaft of light to blind me as I do it. God forbid its the wrong size/colour whatever.
    I blame David Cameron and UK customs and excise for dodgy shipping.
    And just in time for the UK winter! Its going to be trail centres for a while
  93. #1093
    Oct 2011
    2013 Spitfire
    It's worth the wait.
  94. #1094
    Hard funkin´ Kraut
    May 2005
    Yep!
    Ordered in July 2012, received Frame in December and thanks to non-availability of Parts could build up in February 2013. All this vanished after the first Ride
    Fortunately the Wait was not too bad as my Wildcard was ready to ride anytime ...
  95. #1095
    Reputation: theraggyone's Avatar
    Jun 2013
    Ison distribution and bikeactive have just announced on facebook that the first drop of 2014 frames has arrived and are available tomorrow in the uk .good news for those waiting for theres
    Sent from my GT-N7100 using Tapatalk
  96. #1096
    Quote Originally Posted by theraggyone View Post
    Not available tomorrow.
    The frames are only getting to Ison tomorrow, then out to the dealers, so we only get our hands on them next week.
    See the previous page in this discussion.
  97. #1097
    Jun 2010
    Great build minus the SRAM brakes!
  98. #1098
    Oct 2013
    And I have had mine for so long ...
  99. #1099
    Jun 2013
    UK debacle continues. just been told that no XLs were sent out in this batch, due to an admin cock up apparently, so i'll have to wait another couple of months. thanks banshee
  100. #1100
    Oh Jesus!
    I feel for you dude
Members who have read this thread: 49
