Results 1 to 21 of 21
    unrooted
    Reputation: unrooted's Avatar
    142x12 Axle Replacement
    I just got my new prime frame this week and already I've jacked up the allen hole on my axle. Does anyone know if there is an aftermarket axle that fits the prime? Are all 142x12 axles the same threading???
    195 lbs-6'4" Banshee Prime XL
    Ride Mammoth, Tahoe & Vegas
    PLEASE GIVE ME NEGATIVE REP!
    Reputation: Haus Boss's Avatar
    Jun 2010
    Maxle 142x12 should work.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by unrooted View Post
    There are THREE (3) different threads used for 142/12 TAs.
    mtbtires.com
    Jun 2010
    Maxle : yes
    Dt Rws : no
    Syntace : no
    unrooted
    Is shimano and maxle the same?
    Mar 2013
    so i was just informed that the maxle 142x12 is being discontinued?
    what are the current options for replacement axles for the banshee rune now?
    unrooted
    I ended up buying one from fanatik bike for $40!
    unrooted
    You should call and make sure they have it in stock, but here ya go:
    Banshee 12x142mm Bolt-On Axle - Fanatik Bike Co. - Bellingham Wa
    They pulled one out of a rear end kit for me when I bought a new one-drinking and wrenching go well together, to a point!
    Reputation: Dogboy's Avatar
    Quote Originally Posted by 84532 View Post
    Bad information. If a shop told you that I'd fire them.
    Jan 2009
    the maxle is no being discontinued, they did change it to a Maxle lite ( a little version of the orginal Maxle ) a while ago. I did check my distributor and seems to be on back order till about mid march.
    unrooted
    I would much prefer the Banshee thru-axle over the Maxle lite-there are a lot of people *****ing about how easily they break, plus the Banshee axle is lighter and more likely to stay in place.
    Jan 2009
    agreed, the banshee axle is better if you dont mind using tools to take the wheel off.
    Mar 2013
    my problem with the stock banshee axle is that the nut that screws into the axle would stick really bad and i stripped it out trying to remove it, even though i had it greased really well and was super careful not to overtorque.
    i installed a maxle but i'm keeping the stock axle in my pack as a backup. maybe replace the stripped out nut with a torx one.
    Gear Whore
    Reputation: mudpuppy's Avatar
    Yeah, I have stripped mine too. You can order a new one from Trident from what I understand...I just keep on using it and just tighten it as much as I can. That bolt is made of butter.
    I would love Banshee to make a Ti one like on the Legend...pretty sure I remember Keith telling me the hardware would be like on the Legend...but that was WAY before production.
    Reputation: dirtrider76's Avatar
    Sep 2012
    Mine is starting to get messed up now. It been a PITA to get out the past 2 times. I have a spare but a Ti one would be pimp and likely hold up better.
    I like to fart when I'm in front of you on a climb
    unrooted
    I broke my axle today, wonder if Keith designed it to break to save the frame, or if the threads just end In the wrong place. Now I know what I'll be carrying in my pack from now on. Long fukking walk down the hill today.
    Sep 2012
    I broke 1 of those, broke in the threads but right at the edge of the drop out. I posted a picture on here and was told it was from being over torqued. I lol'ed and got a maxle and no issues since.
    unrooted
    Dirtrider: Do you know which maxle you bought?
    I think I broke mine because my rear shock broke and I didn't notice, probably because my bike felt super stable which I attribute to the decreased bottom bracket height/slacker headtube. The root I hit that broke my axle was only 2-3" tall, but ran at about a 30 degree angle to the trail, so it twisted my rear wheel. At least that's my theory.
    Too bad they don't offer a solid aluminum or just a ti axle.
    The axle I broke was one I had already replaced because I had stripped the allen hole in my stock one, but the stock one seems to be a much thicker wall gauge than the replacement. . .
    Sep 2012
    12x142 maxle lite, I've had no issues since. I broke mine when my back tire clipped a log sticking out the end of a berm. I've hit stuff harder since with no issue. That said I'd buy a TI one if it was offered.
    FYI I do carry a replacement axle. It's a stock Banshhe axle from my other set of drop outs.
    unrooted
    This one: Rockshox Maxle Light Rear Skewer > Components > Wheels, Tires and Tubes > Quick Releases | Jenson USA
    Or this one:
    Amazon.com : RockShox Maxle Lite 142 x 12mm Black Fork : Sports & Outdoors
    Nevermind, in the reviews it states that the amazon one pictured isn't the correct one, it now has the same OD for the full length.
    Sep 2012
    Mine is the one pictured above, the image in the Amazon link is the Trek ABP version.
  1. 142x12 Hub, Axle won't fit through?
    By FlyingIrish in forum Wheels and Tires
    Last Post: 05-07-2016, 10:06 PM
  2. Bob trailer to 142x12 axle ?
    By becik in forum Bikepacking and Bike Expedition
    Last Post: 08-14-2015, 06:44 AM
  3. Rear axle mismatch 142x12?
    By RezaKalimantan in forum General Discussion
    Last Post: 07-25-2014, 10:47 PM
  4. 142x12 axle vs CK fun bolts
    By jet fixer in forum Wheels and Tires
    Last Post: 02-27-2013, 08:56 PM
  5. Droputs for through axle 142x12
    By febikes in forum Frame Building
    Last Post: 01-08-2013, 11:34 PM
Members who have read this thread: 4
