Page 1 of 2 1 2 LastLast
Results 1 to 25 of 50
    Reputation: targnik's Avatar
    Jan 2014
    What just happened!?
    Was talking (on ph) to a guy at a local lbs in my town, re getting a derailleur tune and a new chain.
    I asked him cost/price - he replied $40-ish for chain and $20 for tune + time = around $70.
    I say 'sweet' I'll bring bike in this arvo...
    I bring in bike and now I'm looking at $210!?
    Bike needs a deluxe service apparently... headsets a little off, rear bearing has a little lift, rear cassette might need replacing!
    Holy sh*t!!
    Bike is a year old and has had two services in that time, last being just before xmas both basic services I would say...
    Now to tell the wife
    Opinions are like A-holes... everybody
    has one & they're usually full of...??
    to err is human... to face plant is frickin hilarious!!
    Jun 2013
    Yeah when an lbs tried to pull that number on me, I kindly declined the service saying that I'd think about it and never visited that lbs again. Just like any mechanic whether it be car/bike/appliance, there are good ones and there are bad ones.
    Reputation: Kiwiplague's Avatar
    Sounds like a bike shop that doesn't want you as a customer any more! Did they actually do all the work without discussing it with you first? If so, I'd be just a little mad at them for not even having the courtesy to talk to you first about what (allegedly) needed doing.
    I don't crash, I just have slightly uncontrolled dismounts!
    Yeah, we have some like that at one of the places around here. I asked about a syringe to refill/measure my fork fluid and they try to sell me a $50+ brake bleed kit. I couldn't help giggling and the guy says, "well, it comes with other stuff". I didn't bother to explain that I already have a bleed kit and don't want to mix brake/fork fluid for a syringe that should cost all of $5-10 retail. It's no wonder some shops don't make it.
    High Gravity Haze
    Reputation: Spec7's Avatar
    May 2000
    This is where you can really save yourself a lot of money and headache by learning to do this stuff yourself. A simple chain replacement should not warrant a derailleur tune unless you already needed the tune.
    Once you learn to do it yourself, then you'll know what parts you need and you'll be able to ride more since you won't be waiting for the bike to get finished at the shop.
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    Is this the LBS you bought the bike from?
    FBI tested, NSA approved!
    Reputation: Forster's Avatar
    Sep 2013
    Quote Originally Posted by targnik View Post
    Not sure what rear bearing you're talking about, but if you bought this bike from this shop and they have an lifetime adjustment policy (most have something similar) the Der adjustment and headset should be free, so you're looking at labor for the chain replacement. If you're chain is worn the real question is how worn. It would be hard for me to imagine that your cassette is worn out in a year unless it was neglected, used very hard or an ultra-light performance cassette. I'm 212# and replace my chains pretty frequently and still get 5-6K out of my chainrings and cassettes. I think the general answer you'll get here is learn how to do the basics yourself (cassettes take two tools to change, the tools can be purchased cheaply and the job takes less than 5 minutes, chains take one tool and two minutes, Der adjustments are quick, you have a multi-tool with the right stuff on it already and you can youtube the process or download the manufactures .) I wouldn't get too steeped in anti-LBS setiment, they gotta make a living too and they may be right about the cassette, but that's easy to check yourself and a worn cassette will affect shifting and riding as much as a worn chain.
    The most expensive bike in the world is still cheaper than the cheapest open heart surgery.
    Just hitting the other side of the coin. Sounds to me like the OP asked about a service over the phone, and then more was found when he brought the bike into the shop. In all the shops I have worked in, bikes are inspected as they come through the door. It is unclear in the original post if the price quoted was before or after service was provided.
    While I think some folks are very capable of fixing their own bikes, many are not, and I would go so far as saying the vast majority of LBS customers ride way past the point that adjustments will fix the problem. $200 parts&labor for a bike that has been ridden hard and put away wet doesn't seem that extreme to me. On the other hand, if the last service was in December, and the bike hasn't been ridden, then the OP is likely being taken for a ride (or the previous mechanic just did the basic tune, and failed to check all the other systems)
    As someone mention, it saves time and money when you can wrench your own bike. It really isn't rocket science
    Land of the 230+
    Sep 2013
    Of the dozen or so bikes I've built and owned throughout my life, none have, nor shall they ever see the inside of a bike shop.
    Its a sad downward spiral, as fewer people support the LBS, they start to get panicky and start drumming up business which may not be absolutely necessary. Much like the questionable auto mechanic. I hate to ever suggest not to support the LBS, but unless you place a high amount of trust in them, you run the risk to get taken for a ride.
    • Carbon 650b - Epicon XC/Pacenti TL28/X9/X7
    • Motobecane 550HT - Axon/Easton XR/X7
    • 24" Sapient Cruiser
    • 20" Eastern BMX
    Sounds like a bunch of pretty vague stuff to me.
    What does 'headset is a little off' mean? Out of adjustment? That's a whole 2 minute fix if you're slow about it. Same with the 'rear bearing' - what rear bearing? Are they saying the hub has a little play?
    I dunno - I can't begin to see where a $210 price is coming from.
    Sinister Bikes
    Wraith Bicycles
    Sunday River Mtn Bike Park
    NEMBA
    Wachusett Brewing Co.
    Sep 2014
    I disagree with the post above entirely. Having been in the bike industry for over 25 years, this scenario is not uncommon, or unjustified. If you buy a bike and inadvertently fail to maintain the care of your chain, it can cause expedited wear of the cassette...an expensive item. So, take a $40 chain, a $75 cassette, throw in some labor to install these bits, and put that in with some other adjustments, and sure...$200 is easy. But....JUSTIFIED.
    No one said bikes are cheap.
    Quote Originally Posted by Quitou View Post
    My take after 25 years of learning how not to get suckered by "the industry" - bikes can be a lot cheaper than a lot of people make them out to be.
    There, I said it.
    As already mentioned - buy the parts and tools you need and stay the hell out of the shops if at all possible and you'll save tons. Bikes are simple machines, learn to work on yours.
    Sinister Bikes
    Wraith Bicycles
    NEMBA
    Reputation: Devastazione's Avatar
    Dec 2009
    Stay away from bike shops except for buying a bike ( unless you can buy Canyon) and for warranty claims. Get some tools and look on YouTube for tutorials.
    '15 Tarmac Sworks
    '15 Canyon Spectral 8.9
    Oh, I've GOT bike money
    Reputation: JACKL's Avatar
    As it happens, I do my own work. What I will say is that when working on my bike, I'm often surprised at how some things that should be simple end up taking 3 times as long as expected. It even takes up time to identify and order the correct parts.
    If the shop is being honest with you about what the bike needs, the charges don't sound unreasonable to me, keeping in mind they have to cover overhead and pay the mechanic. Not many people want to work for peanuts these days.
    Sep 2014
    I've never understood why people chide bike shops as such evil-doers ripping people off. It's a silly assertion and makes me wonder if people like slapheadmofo give away their professional services for free.
    Bike shops are no different from any other business that sells products and services. If you happen to be someone who needs their product, and/or their services, it seems only fair to pay them for it, right?
    I can work on my own motorcycle, but don't have the space or time, so I end up biting the bullet and having someone else do it, then paying them. That doesn't make THEM crooks, that makes ME in an unfortunately place to have to part with my money.
    To the OP - the charges you mention don't sound out of line, but as has been pointed out, if you knew how to do the work yourself, you could save some bucks. That only makes you a better mtb owner. It doesn't make the LBS any less necessary to a lot of people, or bad in any way.
    Sep 2014
    By the way, even after a lifetime working on my own bikes, I do find myself in a greater supply of money than time these days. Not that I'm flush with cash, but there are times when I'm more than happy to pay someone at a good shop to work on my bikes. More time for me to ride. To me...that's worth a few bucks here and there.
    Beer Please! SuperModerator
    Reputation: Klurejr's Avatar
    Looks like the OP is from New Zealand, so i moved this here. It most certainly does not belong in the 27.5 forums. Also please do not work around the profanity filters, that can get you banned.
    Ride Bikes, Drink Craft Beer, Repeat.
    Service costs can add up. But doing this for a few years, I've never actually seen a cassette that actually got worn down with the exception of 200+mile/wk riders.
    Reputation: syl3's Avatar
    cassette should last 2 chains at least if not 3. unless you ran the chain waaay past the replacement point.
    anyone should know how to adjust a headset. it takes half a minute.
    you dont need a $40 chain, that sounds a bit much.
    Sep 2014
    Quote Originally Posted by bing! View Post
    There are many variables to cassette wear including the quality of the cassette itself. How well or poorly the chain was lubed, or even the conditions in which it was used. The decomposed granite dust where I live is very abrasive and neglect to clean the drivetrain regularly can accelerate wear.
    Even the user inputs during shifting can accelerate wear by increasing damage to the shift ramps and pins. Shifting regularly under load as an example.
    There's a lot that influences mechanical sympathy and that in turn impacts service life above everything else.
    Jan 2014
    Lots of comments ^^
    Chain is just at the needing replacement stage... which I had guessed as I've been dropping a few chains up front... $40-50NZD for a chain probably equates to $25 USD...
    The guy was spinning the wheels whilst holding stanchions and fork looking for play in those areas.
    They arrived at the conclusion that I needed a full service i.e. taking everything apart and giving things a good clean and lube.
    I do my own basic maintenance - lubing moving parts, truing tyres, fiddling with rear derailleur (not very good at it yet)...
    I'll pay it out this time and if there is a noticeable improvement in how it feels, I'll continue to return for major servicing - if there's no noticeable difference in ride... I'll go elsewhere.
    Cassette seems fine to my untrained eye (they won't replace it without contacting me first). Bike is probably due for the rest. But it begs the question... the first two services I paid for (other lbs) did they actually do anything?
    Will endeavour to receive some tutelage in tooling other than the basics.
    I don't think shops are evil or anything - got plenty of friends that own or work for shops and some that build and sell bikes too. I just think the prices are can run way high given how simple most of the work is (once you spend a little time figuring things out of course). Yeah, it's definitely more convenient, and for certain things like wheel building and some suspension work, etc, it can make more sense to deal with a pro, but for most regular maintenance, a couple tools, a rack of brew and the internet will get you through fine. And of course the added bonus that now you can fix your bike on the trail, which is the most likely place for things to go wrong.
    I don't give away my services for free, but I also don't do something that your average shmoe can take care of in the shed with a few specialized tools. As far as bike work, for what the OP needs done, I'd typically charge a tasty 6-pack.
    The exchange rate makes a big difference - I was thinking US $$.
    Sinister Bikes
    Wraith Bicycles
    NEMBA
    Jan 2014
    My Father-in-law is a mechanical whizz but he lives out of town... don't really know any tooleez in my area - which is a shame...
    Get Father-in-law to train me up I guess... I am mechanically challenged though ^^
    Reputation: Ben_M's Avatar
    I support my LBS and they normally do 'those little extra things' for free. What goes around comes around. Hell, last time I brought a bike I was asked to name my price .
    Hope it all ends up well for you.
  1. OMG!! What happened to...
    By Glide the Clyde in forum Off Camber (off topic)
    Last Post: 03-09-2015, 08:18 AM
  2. What Has Happened and Why?
    By Sand Rat in forum Fat bikes
    Last Post: 01-12-2013, 10:25 AM
  3. What happened?
    By telemike in forum Brake Time
    Last Post: 12-07-2011, 11:00 PM
  4. Look what happened to me ....
    By dstaks in forum Beginner's Corner
    Last Post: 07-15-2011, 09:14 PM
  5. What ever happened with that guy going from Cat 3 to Cat 1?
    By Okie Dokie in forum XC Racing and Training
    Last Post: 07-05-2011, 03:24 PM
