    Hud is offline
    Singletrack minded
    Reputation: Hud's Avatar
    disc brake adapter question
    My frame has an IS standard rear caliper mount, and my Formula RX's are post mount. CRC don't have Formula adapters but will a Shimano one do? Shouldn't be any different??
    Hoping to clarify this before Patchy's CRC order goes through tonight...
    The twenty-nine inch wheel.
    Reputation: I Like Dirt's Avatar
    I would think the bolts should not be a problem however there may be less clearance on the shimano ones for caliper clearance.
    You may be able to fix this with a file or dremel - not expensive so I gues it's worth the chance
    I'm going to need a shimano one soon (160mm) so if it doesn't work for you I'll buy it from you- how's that for a good solution?
    Scott is a tool.
    Reputation: waldog's Avatar
    it should be fine, Shimano adapters are all the same as the other brands, with the exception of their front 185mm jobbies.
    I like to ride my bicycle
    Reputation: JohnŠ's Avatar
    Thanks for that fellers. (This is Hud on John's login) ILD I will certainly take you up on that offer if there is an issue thanks. It's only about $7 anyway. (whole lot better than $25 from the LBS...)
    French car fan? Head straight to
