Results 1 to 3 of 3
    135 x 12m to 10mm step-down axle in Australia?
    I have a wheelset with a Stan's 3.30/ ZTR HD 12 x 135 rear hub that I need to fit to an Anthem X 29er which has 135 x QR/10mm rear dropouts.
    I've found two options:
    1. QR end caps from Stan's. I can't source these in Australia, or even find any overseas right now.
    2. Find an axle with a step-down so it's 12mm through the hub then 10mm at the dropouts.
    Here's a few suitable products.135×12 Rear Conversion Axle | SUNRinglé and Azonic Momentum Axle 12mm X 135mm at Price Point
    So my question is, does anyone happen to know where I might find one of these step-down style axles in Australia, ideally in Brisbane?
    Thanks!!!
    This is the hub I have (ZH19): ZTR Hub Info
    Do you know anyone who can turn you up a couple of endcaps?
    Where did you get the wheelset from? I'm guessing OS - so that's probably where you're going to have to go to get parts. It'll likely be quicker than trying to get a local shop to order them in anyway.
    Quote Originally Posted by cowpat View Post
    Unfortunately no. Yeah I guess I'll just bite the bullet and order from the UK or US.
