Results 1 to 6 of 6
    EDR
    Reputation: eatdrinkride's Avatar
    Jun 2005
    XT 22t steel chainring? Help needed.
    What steel chainring do I need to look at to replace a circa '08 XT 22t granny on a triple crank?
    I've done plenty of research so I thought this would be easy. Most say Deore or SLX so I went to Paragon to pick up a Deore but it won't work. My aluminum granny says SG-X 22-AA/AC and the problem I am having is my ring has countersunk (for lack of better word) chainring bolt holes. The ones I have found do not. The countersink is to accept the small spacer over each bolt hole.
    Any experience with this? I can just order the same ring no prob but I really would prefer a steel ring.
    I rode up mud flaps at Hawes yesterday using my middle ring only since my small ring has major chain suck. Yeah I know a lot of you do that all the time, but damn, I almost had a heart attack.!
    Reputation: SSdirt29's Avatar
    Dec 2011
    I dont deal with gears anymore but when i did webcyclery.com was the place to look for aftermarket stuff to replace shitmano. I havent checked bit i think their still around.
    Ahhh the pain....
    Reputation: Raybum's Avatar
    I've got a brand new shimano SG-X M9 S-22 that came off a LX set of cranks...it's steel, but the bolt holes are not countersunk.XT 22t steel chainring?  Help needed.-photo-17-.jpg
    ┌∩┐(◣_◢)┌∩┐
    http://onegear-ray.blogspot.com/
    EDR
    Jun 2005
    Re: XT 22t steel chainring? Help needed.
    Quote Originally Posted by Raybum View Post
    I've got a brand new shimano SG-X M9 S-22 that came off a LX set of cranks...it's steel, but the bolt holes are not countersunk.Click image for larger version.
    Thanks but think I need the countersunk option.
    Reputation: RajunCajun44's Avatar
    they have this in stock at the Phoenix REI
    Shimano XT M770 Chainring 64mm - 22 Teeth at REI.com
    if you zoom in, it says 22aa ac
    if it doesnt work, return it. But I think it will work. Replace it in the parking lot, try it out... Ive done that before...
    XT had alloy granny, slx had steel. Steel doesn't have countersunk holes, as it can be thinner for the same strength. I have not seen a countersunk steel granny. Measure the thickness of a steel ring and an alloy ring. I believe you will find the alloy thicker, hence the countersunk holes. Alloy Raceface rings work great, and are pretty cheap.
  1. Steel or aluminum chainring?
    By Blue Sugar in forum Singlespeed
    Last Post: 07-30-2013, 01:14 PM
  2. Steel or AL Chainring bolts?
    By mcoplea in forum Singlespeed
    Last Post: 04-10-2013, 05:09 PM
  3. Steel middle chainring in 34T or 36T (but not for singlespeed usage)?
    By PiroChu in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-30-2012, 02:21 PM
  4. Crank for 1x10 with steel 28T chainring?
    By Svend P in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-22-2012, 05:37 AM
  5. 1/8" stainless steel front chainring anyone?
    By mntn-biker in forum Urban/DJ/Park
    Last Post: 10-26-2011, 07:32 AM
