Results 1 to 85 of 85
Thread: Tubeless
    Click Click Click
    Reputation: dirtbyte's Avatar
    Tubeless
    Just wondering who rides tubeless out here and what you think of it. I just ordered new tires (Geax Saguaro foldable) and have the Giant S-XC rims (29er).
    Just wondering if it is worth the hassle. I ride about 3 times a week and in the past year I have had about 5 pinch flats (running the thin slime tubes). No flats due to thorns and I have ridden over many cholla balls. Usually run pretty low pressure (~30 in back and ~28 in front - I weigh 140).
    Been doing a bit of research, and I am really on the fence (leaning towards going for it).
    Just looking for any advice, thoughts, etc before I make the final decision. Probably have a couple of months left on my current tires before I put the new ones on and make the final decision.
    Reputation: boomvader's Avatar
    Nov 2006
    Hi Dennis,
    Not sure if your wheels will work with a Stan's kit or not. If so, that might be the way to go. Otherwise, maybe look to upgrade your rims and go tubeless at that time.
    I run tubeless on both of my bikes and would not go back to tubes. However, both of my wheelsets are UST and with the exception of adding more Stan's every 2-3 months, have been hassle free for me.
    Hope this helps, Dennis. :-)
    -boom
    Click Click Click
    Thanks, I checked the STANS site and my rims are listed as compatible (Flow Kit). I also checked the Giant forumn here (they are Giant brand rims) and others have successfully converted them using the STANS kit.
    Thinking I am going to go for it. Now I just need to find a deal on that kit
    Reputation: Eazy_E's Avatar
    I'm interested in tubeless. I usually run about 40-45PSI, or else I pinch flat a lot. I get LOL for traction like that. I think for bigger or heavier riders, tubeless really shines.
    Reputation: stevland's Avatar
    I think it makes sense to go tubeless IF you're willing to accept there's still maintenance involved and more work to get them set up anytime you need to change tires, break a spoke, etc. I think it can be frustrating the first time you set them up as well, you've been warned.
    I just set up a similar wheelset tubeless (P-XC's). Make sure you get the correct kit. Double check the NoTubes website, but I'm fairly certain they'll only work with the Flow 29er kit. There are other options out there, but you'll probably save yourself a few bucks going with the kit to start.
    I had the same wheels on my HT and I set mine up tubeless with NO problems And I'm in AZ also.. My LBS set mine up with Stan's tape, sealant, and valves.....that's it. It worked awesome and I used a Geax Saguaro for my rear when I did it. I was able to run lower pressures easier and had fantastic gripping and control.
    My vote is to do it.
    I ride with tools
    Reputation: Jim Beam's Avatar
    Quote Originally Posted by mtbdennis View Post
    I've run tubeless on both of my bikes for many years and I would never go back. There's a small learning curve to get set up, but then all you need to do is "juice 'em up" every coupla months.
    I ride mainly singlespeed, and I usually have only 20 psi in the rear, which gives me a little shock absorption but more importantly, amazing traction when climbing.
    EDR
    Reputation: eatdrinkride's Avatar
    Jun 2005
    Tubeless is awesome for out here with one caveat for me...UST tires and UST rims. I've done the ghetto thing and after using true UST tire/rim combo I'll never mess with ghetto again. UST is just too simple in comparison and although it limits your rim/tire selections there is still a lot out there....and lots of tubeless ready tires that have a UST bead.
    Click Click Click
    Quote Originally Posted by eatdrinkride View Post
    Well, I do not have 5-6 hundred bucks to throw at a new wheelset right now. So would you recommend NOT doing the STANS NoTubes conversion on my existing wheelset and just stick with tubes? If so, why?
    Basically, I understand it is going to be a little tricky getting it setup (I enjoy projects like this), and I understand that it takes a little maintenance (adding more stans every few months), and if I have a major issue (sidewall tear / etc) I may have to stick in a tube and wrap duct tape around my tire, LOL. If I am prepared for all of that, it seems like it is worth it to go tubeless with my existing wheels.
    I am about to pull the trigger and go for the Stans conversion.
    Thanks for all the input guys! As usual you all provide great information!
    EazyE - I used to ride 40+ psi with tubes. I now ride 32psi tubeless. Any lower and the side wall wiggle in hard cornering freaks me out. also I have pinch flatted tires running lower pressure non UST tires. I weigh in at 250 on the bike, and I'm currently looking for some wider tires (2.3+) to see how they work.
    Dennis - If 5 flats a year is bothering you, then do it. Your running fairly low pressure with tubes, so the only real reason to switch is to try it out and reduce the number of flats. As for the stands kit, if you follow the steps, you should have no problems. 1 recommendation: Put the new tires on with tubes first and maybe ride a few times to stretch the rubber. It will make mounting them easier when you go tubeless.
    You can always use tubes with removable cores and add either Stans or Slime if you're concerned with thorns. If you want to run lower pressure (ahhh, better traction and comfort) then tubeless is the way to go.
    Do yourself the favor and buy the syringe for $10 so you don't have to break the rim/tire seal every time you want to add sealant. Also, if your garage is really hot, your sealant will dry much faster in your wheels...hence the syringe ease. Or you can just put the wheels or bike indoors.
    Yes, worth the trouble. To fill the tire quickly to get a nice seal I use a compressor, but co2 works as well. Also, if you only have a pump, remove the valve core and you can get more air in to get that initial seal. Good luck.
    Reputation: Casual Observer's Avatar
    SO had her Giant rims converted using the Stans Kit, and no issues.
    Nobody gives a s#$t you singlespeed.
    How much further ???
    Reputation: Douger-1's Avatar
    I have not gotten a single flat in the 3 years since I have gone tubeless. Thats what I think of it.
    “Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did." Mark Twain
    Click Click Click
    Quote Originally Posted by 2wheelsarefun View Post
    Thanks. Yeah, the 5 times I flatted it was a pain. Most recently I was really in the zone bombing downhill and it was hot as hell out, and changing out a tube sucked. Plus the cost, the slime tubes are around 12-15 bucks a pop (usually just toss them after a pinch flat, I guess I could have patched and re-used them, but it is hard to pack them in my camelback after they have been used.
    I have decided to go for it. Thanks everyone for the feedback, exactly what I was looking for.
    I ride with tools
    Quote Originally Posted by AZspeeding View Post
    Stan's dries out way too fast. Since I switched to home-brew I've been able to go twice as long before needing to add more sealant.
    I love bike!
    Reputation: dsittman's Avatar
    I run tubeless on a couple bikes and would never go back to tubes. I like the added grip you get running lower pressure without the worry of flats.
    Only time I've had an issue in like 4 years is when I didn't refresh the stan's sealant in one of my tires, got a flat, and had to pop in a tube to get home...but that was due to my laziness.
    Most tubeless setups are not too difficult especially if you have access to an air compressor. I've gotten a couple tires set up with just a floor pump but I think I was a bit lucky as I've not had success 4-5 setups later. One time I even took both my tires to a Discount Tire, tipped the guy $5, and had them use their compressor to pop the beads on. They actually thought it was pretty cool that you could have a tubeless bike tire.
    Black and Sticky
    Reputation: Bituman's Avatar
    x10 on running tubeless, go for it. I started MTB over 10 years ago and tubeless is all I've ever run. Except for the tube I carry for emergencies, my MTB's have never seen a tube. Started out with UST setup on my old SC Superlight. Now all my MTB's are tubeless with Stans rims. I'm 160 lbs incl. water/gear and run 28 psi F/R. Seems like every year I go a little lower. Good advice on getting the syringe to squirt the Stan's spooge into the tire thru the valve stem. Just keep adding every couple months and once a year clean out the latex boogers. I'm such an advocate of tubeless that by happenstance, this week I'm converting my road bike to tubeless. (Alpha 340 Team Wheelset 2012) All my roadie friends think I'm nuts. We'll see...
    Bob
    "Some people follow their dreams, others hunt them down and beat them mercilessly into submission." - Neil Kendall
    Reputation: armourbl's Avatar
    May 2012
    Quote Originally Posted by Jim Beam View Post
    Home brew? Recipe?
    ben
    I ride with tools
    Quote Originally Posted by Bituman View Post
    Bob
    Can we all pitch in to buy Bituman some chimichangas? Dude's gonna float away...
    Jun 2012
    I did the exact conversion on my Giant SXC's using the Stan's Flow kit with no problem. The tape fits perfect in the channel of the wheel.It was fairly quick and painless. I ran over a stick with a thorn and it stuck to my tire, making about a dozen revolutions. I stopped, pulled the stick off and spun the tire.. Leak stopped. I like the tubeless a lot!
    Click Click Click
    Quote Originally Posted by Slowness View Post
    Thanks I am going for it. New tires are here. Should have pulled the trigger yesterday, amazon had a Stans NoTubes Flow kit in stock with free shipping, today sold out (with free shipping, guess I should quit being such a cheapskate).
    Black and Sticky
    Hey I'm having a great big greasy breakfast burro RIGHT NOW, and yesterday a chicken fried steak. No chance of floating away!
    No Clue Crew
    Reputation: big0mike's Avatar
    Jun 2010
    Quote Originally Posted by armourbl View Post
    Home brew? Recipe?
    My recipe:
    http://forums.mtbr.com/newreply.php?p=9462081
    The full thread:
    Best Tubeless Brew?
    You won't regret it. There's always the chance that it'll be a bear getting a tire sealed but brand new tires help. And if you have to fight it you'll appreciate the next time when your next set seal right up
    Nov 2006
    I found it helpful to ride the bike after setting them up in order for the Stan's to move around and seal, etc. You may need to add some air within the next day or so, but I think that is somewhat normal. Maybe others can chime in on this...
    -boom
    Si vales, valeo.
    Reputation: Warshade's Avatar
    Quote Originally Posted by boomvader View Post
    That's what I typically do as well. I've had the Stan's kit on 3 of my bikes now for about 5 years, and it's always been good to me! That being said, at least with my particular wheel/tire combo, it was hard as heck to get a tire off the rim, (or even break the bead for that matter)!
    "An inconvenience is an adventure wrongly considered." G.K. Chesterton
    No Clue Crew
    Jun 2010
    I don't buy it but if you watch Stan in his videos he will tell you NOT to ride a tire until it fully seals. Mine have always sealed before I rode but I wouldn't hesitate to ride a tire that only lost the tiniest of air.
    I like bikes
    Reputation: ghglenn's Avatar
    Going tubeless is easy, and worth every penny. I wish I had done it years ago. I recommend it to anyone who rides a bike.
    Reputation: 5bravobravo's Avatar
    tubeless is way less hassle than tubes..
    Just be sure to carry a tube with you just in case you slice a tire wide open and cannot seal it.
    Sometimes our trails can be down right nasty on tires.
    I've been running tubeless for many years on a whole fleet of bikes and will never go back
    Check my pulse...
    Click Click Click
    Thanks guys, just waiting for a few parts to get here in the mail. I really should put a few more miles on my existing tires before I switch them out, but I don't think I can wait At least I will have a decent backup.
    Jun 2012
    + 1 for going tubeless.
    I just made the transition myself. It took me some time to decipher the tire codes, and figure out what would work with what. It took a phone call to Stan's before I learned that their rims are designed to work with any* tire and not just UST and tubeless ready. *Ironically their 29er rims will not work w\ WTB UST tires and the 26-inch WTB UST tires are a very tight fit on Stan's rims.
    Another shock was how heavy UST tires are. One of my objectives going tubeless was to save weight. I wound up picking up a used Stan's Arches wheel set and mounting WTB Bronson race (2.3) front and rear. Using an air compressor I had zero issues getting the tire to seal and saved a couple hundred grams/ tire vs. a UST model.
    I used Stan's formula for determining tire pressure: body weight / 7 = X. X -1 = front. X + 2 = rear. I generally ride pretty agressive and was super scetched on my first ride when I could feel the tire folding in hard corners. It turns out that both gauges I used to check my tires were off and I was about 10 psi under my target pressure. Tubeless tires are run at pressures so much lower than what I am used too - there is not much room for error and there is the potential for serious injury. Make sure your gauges are accurate!
    Good luck!
    Meatbomb
    Reputation: Phillbo's Avatar
    Quote Originally Posted by singletracmind View Post
    I've never seen that formula. It puts me at about 29psi front and 32psi rear. I've been running my tubeless at about 34psi in both... maybe I'll drop a couple pounds and see how it feels.
    Thanks !!
    Jun 2012
    Formula is just a starting point...
    After sorting out the tire gauge issue I still wasn't comfortable with the formula numbers. After 13-years of running on tubes around 45 psi I had some difficulty adjusting to the lower tubeless pressures. The lower pressures made me feel like I was riding on molasses during hard-packed climbes. I am 175 pounds and I am now running 31R/28F. A change from 24 to 27 psi may not sound like much but at these low numbers you are looking at a 12.5% change in pressure. This change has a pretty big impact on things like rolling-resistance and traction for any given tire. Making minor tweaks to suit tire types, rider style and trail conditions can influence how much you like tubeless.
    Here's a poll on issue:
    Ok. Had to remove the link because I have fewer than 10 posts. Search, "tubeless tire pressure and rider weight" if interested.
    Click Click Click
    Thanks... Here is the link to the poll: Tubeless Pressure, Rider Weight, Tire Size - POLL
    I had a real bad run of luck with my innertubes this weekend. Got a flat almost right out the the trailhead. Patched it, and it went flat again in under two miles. Swapped in the spare tube. It held air, but messing with the same tire twice is crap.
    I got a couple of Presta valves and a bottle of Stan's. My front tire actually inflated and held air. Hooray. I'm so happy. I was worried I was going to need an air compressor, but it pumped up great with a floor pump. Now, if the back will follow suit, I'll be really happy. No more tubes for me.
    Click Click Click
    Quote Originally Posted by Eazy_E View Post
    Sweet! I am starting my Ghetto (Gorilla tape) conversion tonight. Can't wait to test it out!
    Looks like the rear is going to take too. It was a little more effort, but it pumped up. Had some pretty nice punctures in the rear too. Give it a shake of Stan's and it sealed right up.
    If you're going Gorilla tape, make sure you've either for a good compressor, or you cut the opening for the valve really clean. You're going to need a good blast of air to get the bead to pop initially.
    The WTB TCS rims I got on my Tallboy are pretty nice. They came taped from the factory. All I had to do was add a valve stem and pump it up.
    Click Click Click
    Thanks for the advice. I have an air compressor to get the blast of air. I am also going to inflate them with a tube and let it sit over night. To help push the tape down, and help seat the tire. Then after sitting for a day I am going to put in the stans and fill with the compressor. I also have Stans stems instead of the cut out of a tube method. Watched all the youtube videos and I think I am ready
    Also starting with new tires so not worried about existing punctures
    Glad to hear it worked for you!
    Hmmmmm.
    I checked on my front tire. It went from 50psi down to 20 in an hour. I guess that's normal at first as small leaks seal up slowly, right? I mounted it and gave it a few spins so hopefully the centrifugal force gets the sealant where it needs to be.
    Click Click Click
    Hmmmmm.
    Did you watch the video's on Stan's site? I think that is normal... He shows a procedure of using soapy water to seal the sidewalls / etc...
    Hmmmmm.
    Shake it side to side. Lay it flat on one side for 5 minutes, then flip it. You want the sealant to fill those tiny gaps and help seal the strip to the tire. Dennis is right about the soapy water, that will help you identify those gaps more readily when you see where the bubbles are coming from.
    Quote Originally Posted by stevland View Post
    + 1. I don't use soapy water. Instead, when I mount a tire for the first time, the first thing I do is slap the top of the tire to try and get the bead to seat. Then once I get it inflated, I shake side to side, and rotate. Then, I look for leaks, etc, and if I see any, I lay id down on it's side so the side with the leaks is facing the ground.
    I did the shake and lay on it's side thing. It feels like it's holding air better now.
    Shovel Ready
    Reputation: Cycle64's Avatar
    Flow rims and UST tires for years now. Only flats have been side wall cuts. Run a 60/40 mix of Stans and Flat Attack as my sealant. 2.4 front running 32PSI - 2.3 Rear 30PSI and I'm a very heavy rider.
    Easy, you need to add some PSI, as road bikes take 80psi or more.
    Currently at Mayo Clinic being tested for a kidney transplant. Donors welcome.
    I've been checking on them over the last couple of hours and they feel the same as when I left them. They're at 50ish PSI right now to help everything settle, but I'll probably start out at 35 and see how it works out. Right now, I call it a success. Can't wait for the sun to get low so I can try them out.
    May 2012
    Two questions:
    -- Schrader or Presta valves? Seems to me that using Schrader would be easier for adding Stans fluid later without having to break the bead on the tire. It would also be more friendly for checking tire pressure with a standard gauge. That being said, can Presta valve cores also be removed similar to Schrader?
    -- Anyone know if the rims on my 2012 Specialized Camber Comp are factory taped or not? I know I can take a peek myself, but would like to avoid taking tire off for now and order the things needed to go tubeless in the mean time.
    ben
    Two questions:
    ben
    The Presta valves that Stan's, WTB, and others sell have removable cores. Stan's also sells a little adapter hose that goes on the bottle and lets you squirt more fluid into the tire if you need to.
    Home Page
    Great resource. There's also a lot of videos on Youtube detailing various methods. Ghetto method with Gorilla tape is probably the best alternative method. Gorilla tape don't let go. Easier and cleaner version of the ghetto tubeless tire(Part 1 of 2) - YouTube
    Tried to see about the rim, but I didn't get much info.
    Jun 2012
    Probably overkill, but I bought the sealant injector thing and presta valve stem remover tool when I ordered sealant, tape and stems. I was able seat the tire (WTB Bronson Race 2.3) on the rim (Stan's ZTR Arch) with an air compressor -- first try without using soap or water. After seating the tire I, released all of the air and removed the valve stem (Stan's standard mountain presta stem). Using the injector, I dosed both tires, assembled the stems and inflated the tires to 30 psi. I shook both wheels and laid them on their sides like the Stan's video describes. I had zero issues with these tires holding air.
    I bought my wheel set used from the classified section on this site. One rim was wrapped with Stan's yellow tape and the other had Gorilla tape. The rims were a mess when they arrived, with latex sealant all over the place. After seeing the condition of the wheel set I decided to strip the tape, clean the rims and start from the beginning. The Stan's yellow tape came right off and didn't leave a deposit -- only the dried latex to deal with. The Gorilla tape was a pain in the ass to deal with because of the tape glue that was left on the rim. The extra effort involved to replace Gorilla tape vs. Stan's yellow tape is another thing to consider when you are deciding between the two.
    Well, my tires have held air all night, so they're a success.
    I tried riding with them last night. It wasn't the "OMGF" religious experience I was expecting the with the way some if you guys talk, but I've got no complaints. Trail chatter was less, traction was a little better, and I felt like it was a little easier going over baby heads and rocks at low speeds. I started out at 35 PSI and that still felt a little harsh so I let a little air out. Don't know where I finally settled at, I'll check later.
    And I agree with the guy who said a couple PSI makes all the difference. I let a little more air out of the front and it went from feeling fine, to a little squirrely just in a couple of PSI. More experimentation.
    Even though it's not the re-invention of the wheel I was expecting, there's no reason at all I can think of to go back to tubes. Tubeless for me, please.
    Registered Bike Offender
    Reputation: 1fast29er's Avatar
    Feb 2012
    Been tubless for 4 years. Love it. I rode a test bike a couple months ago with tubes. Forgot how much the tires bounce around in the rocky stuff with tubes due to the higher pressure. Such a huge difference. Tubless=less flats, smoother ride, better traction, and faster rolling. Every time I replace a tubless tire due to wear there are tons of cactus thorns sticking through it that would have been flats with a tube.
    "Grab life by the bars"
    SamuraiBunnyGuy
    Reputation: longhairmike's Avatar
    i installed my first tubeless tire yesterday (LBS did it last in October,, stans was now dry and i had a slow sidewall leak that would flat me daily)
    surprisingly I was able to get a seal without an air compressor or making a spooge mess all over the laundry room.
    it's a good feeling to finally get my feet wet into learning maintenance on a 21st century bike.
    Click Click Click
    Thanks for all the advice! Completed my gorilla tape semi getto tubeless conversion. Stock giant rims, folding non ust geax saguaro tires and Stan's presta stems with Stan's sealant. No issues at all. Probably because I over researched it and way over thought it. However, no way I could have done it without the air compressor. Just to see I tried the floor pump and no way I could have got them aired up. Took the compressor at 110 psi and soapy water on the tires. They sealed almost instantly and have been holding air at 40psi for an hour now.
    Only thing I noticed was a small leak when I wiggled the valve stem (probably expected). Wiggled a little and that magic Stan's sealant sealed them up.
    Can't wait to lower them down to about 28 psi and ride. Must admit I am a little nervous, so I will probably pack two tubes as backup for the first few rides.... Dork I know...
    Reputation: aztrail's Avatar
    Nicely done! Tubeless conversion and the new fork.... this has been a big week huh?
    Click Click Click
    Quote Originally Posted by aztrail View Post
    Yep. Can't wait to get it out on the trails tomorrow! Tires are holding strong this morning
    No Clue Crew
    Jun 2010
    I tried riding with them last night. It wasn't the "OMGF" religious experience I was expecting... I started out at 35 PSI...
    Same with me. I don't think you'll get much traction benefit at 35, though. Don't know where you wound up for pressure but most are running around 28ish. Some even claim 22? I've found I simply can't run much lower than 30. My rims get beat to sh|t if I do.
    Click Click Click
    Quote Originally Posted by big0mike View Post
    Not sure where I will come in on this... My wheels do feel lighter after the conversion. Even if I do not notice a big difference, I will enjoy not noticing that I am stopping to replace a tube all the time when I pinch flat.
    No Clue Crew
    Jun 2010
    Exactly. Having that "Oh My God I Can't Believe The Traction" moment would've been a bonus. Riding without flats is the payoff.
    From a riding perspective, you probably won't notice much. But do play around with the PSI until you find a nice pressure.
    Obviously one of the biggest benefits is the ability to run lower PSI without fear of pinch flats, and to not get flats in general. (The one disadvantage? When you do get a flat and need to put in a tube.)
    May 2012
    My Camber Comp 29er rims have red tape on them from the factory. I have some Stan's yellow tape. Should I remove the red factory tape first or just apply the yellow tape on top?
    ben
    Remove it.
    I finally went tubeless a couple of months ago. So far I have only converted the rear because I am running Kenda non-UST tires and they have a reputation for not playing well with sealants. I must say that I have had a "OMG" experience but I am also coming from running thorn liners as well. There was a definite increase in traction. I dropped roughly 180g of rotating mass on the rear wheel but some of that weight loss is attributed to the fact that my wheelset doesn't require tape for the conversion. I still run about the same air pressure. I weigh 185 with gear on a 26x2.1 tire and lowered my pressure down to 37psi from 39psi. I tried going down to 35psi but it felt a little squirrely and I also bent my rim. I got rid of the thorn liner on the front tire and now run a light tube with sealant. I am undecided on whether or not to convert the front as there are no issues with pinch flats and the weight penalty for going to a UST tire is kind of high.
    Just wanted to make two notes on here:
    1. I had a difficult time getting my non-tubeless tire to seal up. I followed the directions on the Stan's site and I added additional sealant initially but the tire kept losing a small amount of air. After riding for a couple of days I added another syringe of sealant and that stopped the air leakage.
    2. There was a question about Presta vs. Schrader... just wanted to point out that all Schrader valve cores are removable. You can buy the tool at any automotive store. They are also easier to remove on a Schrader than a Presta IMO.
    Killing it with close inspection.
    Click Click Click
    Had my first ride today tubeless... I too had the *OMG* experience. May be because I have a lower end bike and things like this make a big difference.
    1) Traction - Much improved. This may be due in part to new tires (geax saguaro). But I did not spin out in several places that I usually do. Seemed like I was climbing much faster.
    2) Chatter - much less chain slapping going on when bombing down hill. And I felt more in control at higher speeds.
    3) Squish. I ride a hard tail so some added suspension in the back, WAS noticed. I started at 25 psi (higher than the Stan's formula for my weight... I will lower it a few psi for my next ride)
    Who needs tubes? Not this guy!
    May 2012
    Installed my tubeless today. Did the Stan's route with yellow tape, valve stems and sealant.
    Some notes from my install experience...
    1. The red tape on my stock 2012 Specialized Camber Comp 29er is not tape, it is just a band that fits very very tightly. Removed this.
    2. Made the mistake of only applying one layer of yellow tape to my first wheel, which wasn't enough. Definately do two layers. One roll is enough for two layers on each 29 inch rim.
    3. Made the mistake of accidently cutting the yellow tape after it was applied with one of my tire levers. Good thing I only did one layer on the first attempt so I could recover from this.
    Points 2 and 3 resulted in a first failed attempt to get the wheel to seal. It was leaking out of spokes and the valve stem.
    4. Tried a trick that I think helped. I used a heat gun on the low setting to heat the rim and tape after it was applied to ensure it bonded well. Don't give it too much heat though, just enough to warm up the rim.
    5. Did one wheel with the floor pump, but then switched to my compressor. If you have a compressor, don't even waste your time with the floor pump. Used a Schrader to Presta valve converter so I could use the compressor.
    Both wheels were still holding 40 psi after an hour. Will check them again later and tomorrow.
    ben
    You do the thing where you lay them on their side on a bucket or trash can for a while and give them a shake every now and then?
    Click Click Click
    ben
    Nice!
    May 2012
    yep. did it a lot just to be sure before I put them on the bike.
    ben
    Jun 2012
    Check out the instructional videos on Stan's site before attempting a tubeless conversion:
    Help Center
    These help videos provide detailed instructions on everything from tape install to sealing a tire.
    I was working on my bike the other day when I heard something rolling around inside the tire. I popped the bead and saw a solidified wad of sealant inside.
    Ok. I've never uploaded photos before and I am attempting to get two attached to this message -- we'll see where they wind-up...
    The latex wad was a surprise because I've only been running tubeless for about two weeks. I had heard that this would happen but I was expecting to go 2-3 months before having to deal with it.
    The glom ball weighed-in at 2-grams.
    I set the bead and used the injector to add 7 ml (approx 1/4 ounce) of additional sealant.
    I can hear one rolling around in the rear tire as well.
  67. #67
    May 2012
    Does that happen from putting to much fuild in?
    ben
  68. #68
    Meatbomb
    Stan Boogers
  69. #69
    I think it's just a side effect of the dry climate. Supposedly, some home brews work better at not evaporating as fast. I've got a jug of Stan's I'm using, and once that's used up, I'll probably hit Hobby Lobby and make my own.
  70. #70
    Shred...it's the new drug
    Reputation: latedropbob's Avatar
    I've dealt with home brew and actually that makes huge boogers as compared to stans. one time I pulled out a lump as big as a childs fist. as much as I loved brewing my own...stans is just easier and works. I'll pay an extra buck or two for the convience. There are presta valves that you can buy that have removable cores so you can add more sealant. I've been running tubless on stans strips on one bike and on mavic 823 rims (so easy) and have not looked at a tube in a long time. I have punctured a few tires but stans usually fills it up for me to get home to patch the tire. Only issues I've had with is Stan's eating Kenda tires...not Maxxis
  71. #71
    Jun 2012
    So do you guys just leave the boogers in and top-up the sealant every now and then, using the injector and going through the hollow (core removed) stem?
  72. #72
    No Clue Crew
    Jun 2010
    The tires I currently have on are wire bead and are EXTREMELY difficult to get on and off. I leave the boogers in until I change a tire. I'm about due for a set and am gonna get Butcher & Clutch SX casing which is folding. Should be easier to pop a bead and remove.
  73. #73
    May 2012
    Did a short ride at the White Tanks this morning. First ride on the new tubeless.
    I can't say I noticed a real difference in performance, but I think that is because I was running too much pressure. About half way through I let some air out of both tires and then noticed a difference. Tires seemed to conform better to the terrain and took some of the hit out of the bumps and edges.
    I pulled a cactus needle from the front tire that was about half an inch long. A little air escaped, but the fluid promptly sealed it right before my eyes. Very cool.
    How are you guys accurately measuring your tire pressure with Presta valves? I don't trust that my floor pump is accurate. When I started I used it to measure about 37psi. I checked the pressure again at the end of the ride to see how much I had let out and it read close to 25psi, which seems lot lower than it felt.
    ben
  74. #74
    Jun 2012
    The gauges on both of my floor pumps are off by > 10 psi.
    I use a Presta-Schrader adapter, then gauge my tires with a pencil style tire pressure gauge. My gauge measures 5-50 PSI in one-pound increments. This works well for me because:
    1. Accurate enough for my purposes.
    2. Cheap (especially when you already have one lying around)
    3. Doesn't take batteries
    4. Light-weight and compact
    5. After a little practice it is easy to gauge tire pressure without losing air.
  75. #75
    ben
    I use this. I don't know how accurate it is but it is fairly consistant. It reads higher than my cheap Bell pump gauge. It is also made in the USA but being a mechanical gauge I wouldn't carry it around in a hydration pack or let it drop on the ground.
  76. #76
    Meatbomb
    I just give my tires a squeeze and can tell if they are close to my desired psi. Close is good enough for me.
  77. #77
    May 2012
    Quote Originally Posted by FireLikeIYA View Post
    I ordered one of these off Ebay today. Thanks,
    ben
  78. #78
    May 2012
    Forgot to mention that I almost got to test my Tubeless against a rattle snake today.
    I was climbing a hill that tends to get me about mid way up everytime. Well, in typical fashion I got hung up on a rock and when I planted my foot there was about a 3-4 foot rattle snake about 3-4 feet away from me.
    I've never backed down a hill so fast in my life. He coiled up, shook his rattle and was poised to strike. He looked like he had just eaten recently, but he sat there defending his spot in the sun for a couple of minutes. I wish I had a camera with me as it would have been a fantasic photo.
    ben
  79. #79
    live long and huck
    Reputation: Optimus's Avatar
    ben
    Just think of that the next time you are climbing through there, that ought to give you the extra drive that you need to clear that rock, then you'll have the climb made.
    Low and slack.
  80. #80
    Good snakes are dead snakes, bro. Do the right thing next time.
  81. #81
    Meatbomb
    Sounds like he did the right thing, he backed away and left the snake alone. No reason to kill it.
  82. #82
    Agree!!
  83. #83
    What, so it can bite somebody else? Harmless snakes are harmless and I can leave them alone, but rattlers are not harmless, therefore, must be dealt with swiftly and harshly.
  84. #84
    May 2012
    I would never hurt a snake unless there were no choice -- such as protecting my family, which includes my dog.
    I was in his domain. He caught me off guard, but no so much that I was in danger. The only reason he would attack an adult human is if he was pestering the snake instead of leaving him a lone.
    Without these snakes we've have one hell of a rodent problem. As many times as I've ridden the White Tanks, this is the first snake I've seen. If I hadn't been so focused on cleaning that hill, I would have been looking far enough ahead to see him long before there was a chance of getting bit.
    ben
  85. #85
    ONCE AGAIN, AGREE!!!
