Results 1 to 15 of 15
Thread: Tires for Sand?
    Don't believe the Hype...
    Reputation: luckybastard's Avatar
    Tires for Sand?
    Does anyone have any recs for a good sand tire? I found a spot real close to my house that has some potential but a lot of sandy areas.
    Made with real bits of Panther, so you know it's good...
    www.krackedskulls.com
    use promo code "lucky" for 5% off
    Reputation: matt1976's Avatar
    I'm here for the OT
    Shifted
    that's not a tire, that's a river raft!
    Are you looking to rail sandy corners or for more of a straight line over sand a lot?
    back at it
    2014 Trek Stache 7.
    Victim of Saddle Rage
    Reputation: cannonballtrail's Avatar
    Sep 2004
    Geax saguaros aren't half bad as long as it's not a beach
    " the surest sign that intelligent life exists elsewhere in the universe is that none of it has tried to contact us." C&H
    Is there a particular tire that's good for riding on cloudy days, but only between the hours of 2 and 2:15pm on Wednesdays?
    Eroding into the trail
    Reputation: DustyBones's Avatar
    Jun 2010
    Quote Originally Posted by AZspeeding
    Yes.
    May be good till 2:30 PM though!
    Conditions exist!
    Big B's Trails
    Reputation: ImaFred's Avatar
    Maybe you could find a setup like the ohvs buff in front paddles in the rear...
    I dig dirt!
    Reputation: twowheelsdown2002's Avatar
    Look for tires with lots of prominent side knobs for the front tire.
    I don't mean tall knobs, but you want a continuous line of knobs, just the opposite of a mud tire. Mud tires have lots of big gaps on the side knobs to let mud escape, but you want to trap sand.
    I had a tri-razor tire on my moto for the Oregon dunes. It had a middle line, and 2 very prominent lines of rubber that splayed outwards at an angle, trapping sand in the middle and allowing the tire to get up onto the sand.
    On the rear, look for paddle style blocks with enough space to dig in.
    Shifted
    Quote Originally Posted by cannonballtrail
    Maybe as a rear tire but otherwise a horrendous front tire (from experience). Side knobs are worthless unless maybe you are using a 40mm wide rim. A few rides on DC proved that point to me. Had the 2.2" on 23mm rims (OD, not terrible small). Sold that tire 40 miles later. Thats likely a very good light sand over hardpack tire, rear only.
    I've learned that railing sandy corners is more about finese and ballance than having the perfect tires. Practice makes ummm not as many hard crashes ??? I washed out on a sandy corner yesterday. Just a little too much weight on the front with the amount of lean and bam, washout Rollin Front 2.4" Specy Purgatory Control on 35mm rims at 32psi with a Serfas Krest 2.1 on a WTB trail 27mm wide rim at 38PSI. Good enough traction but when my technique gets sloppy, the tires can only help so much.. .
    back at it
    2014 Trek Stache 7.
    Shifted
    Quote Originally Posted by twowheelsdown2002
    Makes sense
    When I was looking at this Wicked Will tire, I was thinking along those lines b/c the side knobs are pretty continuous
    http://www.universalcycles.com/shopp...6&category=624
    A more DH type tire for sandy areas may would be a Specy Clutch Front and maybe a Chunder on the rear b/c of the large center paddle type knob http://www.specialized.com/us/en/bc/...jsp?spid=57837
    http://www.specialized.com/us/en/bc/...jsp?spid=56711
    back at it
    2014 Trek Stache 7.
    Quote Originally Posted by berny2435
    Makes sense
    Those look like some good choices.
    A wide rim to square the tire profile out a bit more, and low pressure as well, would both help.
    High Desert MTBer
    Reputation: rockerc's Avatar
    Sand? I try and avoid it if possible, and I would rather buy my tires more specifically for the places I enjoy riding more: rocks and high trails. So far I have managed to ride little sand around Tucson, and if I encounter any, I will get off and push if the weight-back-pedal-like-f**k approach doesn't work. If I want a beach cruiser I will get a Pugsly, but I don't think that's ever gonna happen...
    bland
    Reputation: m77ranger's Avatar
    Jan 2009
    Serfas Krest 2.1
    How do you like that tire? It looks like a nevagal rip-off for half the price. Does it perform? Does it last?
    Shifted
    Quote Originally Posted by m77ranger
    Just started using it actually. DC was my first ride on it. Not a terribly soft tire so it should last. I replaced a wire bead light weight Maxis Ignitor that was just getting destroyed ride to ride. With only one ride on it, it for sure beats the Ignitor for traction at DC. Especially on the little steep uphill washes.
    I wouldn't consider it a Nevagal rip-off at all. Completely different tire. More knobs and should be faster rolling Haven't ridden a Nevagal on my 29r before. It measures a 2.1 on a WTB trail rim. Their website http://www.serfas.com/product_details.asp?ID=559
    They don't feel like 880grams like the site says. one dudes comment at 740 feels about right but I didn't weigh it before I mounted it.
    back at it
    2014 Trek Stache 7.
    bland
    Jan 2009
    Thanks for the info.
