Results 1 to 28 of 28
    bland
    Reputation: m77ranger's Avatar
    Jan 2009
    New question here. Tire help. (fast response plz)
    My instagram told me it was cold and i want to have the right setup for the new AZ cold we got (global warming my b*tt.) I know that you should fill your petrol tank when its cold because cold gas is more dense than hot gas and you get more bang for your bux. I know that air is gas so its more dense in my tires right now. Is there some equation for how much more air I need to put in my tires?
    I'm running a 2.5 minion up front and a two four ardent in back both tubeless STANS
    Make it quick nerds I'm going for a ride as soon as my hydration bladder thaws out.
    Reputation: Casual Observer's Avatar
    Quote Originally Posted by m77ranger View Post
    ROUND!!!!!!
    (Sorry, I didn't read your post, but saw you wanted a fast response. Good luck with your search.)
    Nobody gives a s#$t you singlespeed.
    SamuraiBunnyGuy
    Reputation: longhairmike's Avatar
    a full gas tank leaves less room for condensation to form on the tank walls which ultimately ends up as water being injected into your engine
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    28/front - 24/rear....go ride!
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    Reputation: tysonnemb's Avatar
    Make sure you make the switch from summer air to winter air. I won't make THAT mistake again...
    “Think of bicycles as rideable art that can just about save the world.”
-Grant Petersen
    bland
    Jan 2009
    Quote Originally Posted by Zachariah View Post
    I should have made it clear, I ride a 26er. I don't fall for trick marketing.
    How much further ???
    Reputation: Douger-1's Avatar
    I dont get it ....
    “Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did." Mark Twain
    Reputation: shiggy's Avatar
    Dec 1998
    Then use 26psi f&r, desert and winter specific air.
    mtbtires.com
    Reputation: RajunCajun44's Avatar
    You should run the same psi whether its cold or warm, I think what you are referring to is that as the temperture drops, so does your pressure (for the same amount of air).... I think the natural drop is something like 1psi per 10 degrees F.
    Goodyear Corporate | Newsroom | News Releases | As Temperature Drops, So Does Tire Inflation
    SCRUBDUNKER
    Reputation: razardica's Avatar
    Just put 40 in both and let your suspension smooth the ride out.
    Reputation: cstem's Avatar
    more importantly, you should ensure that you have the proper air for your tire. If it was made in Taiwan, you need a Taiwan floor pump. Contrary to popular belief, Italian pumps cannot make Taiwanese air. For that matter, Italians are pretty much known not to work period.
    Vassago Cycles, Shadetree Bikes, Flat Tire Bikes, Galfer Brakes USA
    bland
    Jan 2009
    Thanks for the help. I didn't really understand a most of it so I'll just go to the shop and do what ever they say.
    pV=nRT
    Reputation: metalaficionado's Avatar
    do nothing.
    less expansion at colder temps will give you more traction in the snow/ice, plus the rubber is less compliant in the cold so it should flex less.
    pulled this out of my ass 2 seconds ago
    Dec 1998
    Quote Originally Posted by metalaficionado View Post
    do nothing.
    Smart ass.
    mtbtires.com
    Si vales, valeo.
    Reputation: Warshade's Avatar
    If it's all the same to you, then I must recommend NOT (I repeat, DO NOT do this!) putting the Clearance Summer Air in your tires, as I once did this, and when I was riding I got a ticket from the park ranger saying that it was a fire hazard. He let me off easy by only taking my bike, gear and all the money in my wallet, but he said next time he would even kick me in the jimmy!! Consider yourself warned!!
    But on a more serious note, if it were me, I would just do it, because you never know when they might tell you otherwise, and that would be terrible! Remember??
    "An inconvenience is an adventure wrongly considered." G.K. Chesterton
    Reputation: GR1822's Avatar
    Quote Originally Posted by MtbAZ44 View Post
    *Sigh*
    There's one in every group. İ
    Quote Originally Posted by GR1822 View Post
    *Sigh*
    I have a feeling this thread is a farse.. and I am the idiot for not knowing that...
    Yeah, LBS air is the best. That online stuff could be a blem and not have a warranty. Besides, is that online store gonna help when some of your precious air escapes?
    Reputation: chipolopolo's Avatar
    Dec 2008
    On a similar note, does anyone else have this issue. You flat, put in a tube, fill it with a Co2. Next day, flat. Fill with air compressor, fine??? Happens VERY frequently on my road bike.
    Drinkin the S-Works Kool-aid
    Reputation: az3075's Avatar
    You guys still use air and CO2? I've switched to methane long ago. If you have a leak, you'll know.
    Quote Originally Posted by az3075 View Post
    I fill with it hydrogen, with the buoyancy your tires float over the rocks and I can bunny hop downed trees.
    Reputation: AZ Stumpy's Avatar
    Nov 2008
    A mix of 78% Nitrogen and 21% Oxygen works best in the winter. I can get it free through work, too.
    Si vales, valeo.
    Re: Tire help. (fast response plz)
    Quote Originally Posted by AZ Stumpy View Post
    Depends on the humidity...
    Sent from my HTC One using Tapatalk
    10% of particulate if you live in Phoenix, good for plugging smaller leaks.
    Meatbomb
    Reputation: Phillbo's Avatar
    I have a lovely bunch of coconuts
    You have to fill your winter pumps with air from the first Haboob Haboob - Wikipedia, the free encyclopedia (you may need two dedicated pumps for this) It is critical to have right mix of dirt and organic matter and valley fever spores. The valley fever feeds on the organic matter and combined with the other non organic Haboob material creates the perfect tubeless seal without any Stans required.
    Si vales, valeo.
    Quote Originally Posted by Old ROMPer View Post
    I believe that you've been severely misinformed. Anyone with even a lick of sense knows that winter pumps aren't compatible with haboob air. What you need is a summer-to-winter conversion tank, or a summer pump & a winter pump, (but this method is definitely lacking in consistency when compared to the conversion tank method). Using only a winter pump, (even if you are using two of them), will only net you a result of a trip to the hospital.
  1. Front tire and steering response
    By Montster in forum Fat bikes
    Last Post: 01-01-2013, 12:02 PM
  2. How can I tell if my tire is a fast roller?
    By Cycling Cyco in forum Wheels and Tires
    Last Post: 09-16-2012, 10:27 AM
  3. What makes a tire fast?
    By fixgeardan in forum Wheels and Tires
    Last Post: 04-18-2012, 11:38 AM
  4. Max. Tire width on Response?
    By Joey47 in forum Diamondback
    Last Post: 09-02-2011, 12:30 PM
  5. Fast Cheq 40 Fat Tire set-ups - let's see em...
    By single speed kid in forum Minnesota, Wisconsin
    Last Post: 02-08-2011, 05:08 PM
