Results 1 to 10 of 10
Thread: Stan's in AZ
    Low speed, High Drag
    Reputation: kevhogaz's Avatar
    Stan's in AZ
    I just converted my 26" bike over to tubeless, and I have a couple of questions.
    How often do I add the sealant?
    How much sealnt do I add? A full scoop, or just up to the line on the scoop?
    "Yabut"
    Reputation: MyBike'sBroken's Avatar
    This time of year, the liquid works for a couple months, no problem. But when it heats up, you need to add more about once a month. "Normal" size tires (2.0, 2.1) I use just one scoop. With big tires, I put in two scoops. It works great, you'll love it.
    ~Aaron~
    "I like the night life. I like to boogie."
    ____________
    www.CosmicRaces.com
    A "full" scoop? As in fill the scoop to the top?
    "Yabut"
    Quote Originally Posted by kevhogaz
    Sure, right to the top. It's not rocket science. You just want to make sure there is enough to coat the entire inside surface of the tire.
    ~Aaron~
    ____________
    www.CosmicRaces.com
    Thanks, man. I didn't think it could be that difficult, I just tend to over-analyze things, a bit.
    What, who, me?
    Bring it by on the way home...
    and i'll walk you thru it step by step. Just don't cough on me, i don't want the 2 month flu
    "shoo shoo retarded flu!"
    Mike
    AKA shitbird
    Reputation: eabos's Avatar
    Jun 2005
    Quote Originally Posted by pool_monkey
    Gary the retard.....love that guy!
    JRA
    Mike
    Mike, I already got the tires mounted up, and aired up. I just needed to know how much, and how often to put in the sealant.
    You don't have to worry about catching my "flu", it's my allergies that are kickin' my a$$. Hopefully I'll be squared away, before it gets to hot to ride.
    I hope you heard Gary the retard when Richard Christie came in on his B-day, and played the retarded flu, live. Now that was funny. Almost as funny as when Sal told him he was smart, and then told he wasn't after failing the last test.
    NardoSS
    Guest
    If you garage your bike then you'll have to add fluid 2x as often due to the temperature increase. When your tires have been sitting for a min or two, shake the tire up and down or side to side to hear for a splash. When it sounds low, open it up and take a look at how much was inside and judge from the sound going forward.
    AKA shitbird
    Jun 2005
    It makes me happy to know I'm not the only Stern fan here .
    JRA
