Results 1 to 6 of 6
    Reputation: CrankyMonkey's Avatar
    Which shop has a good selection of single speed parts?
    I'm converting my 29er to a single speed and I need a 32t chain ring and a set of single ring chain ring bolts. Any recommendations on a shop with a good selection of single speed parts?
    (I've got everything else I need.)
    Reputation: Casual Observer's Avatar
    Quote Originally Posted by CrankyMonkey
    Pretty much any LBS will have the bolts (just ask for BMX bolts). I can't comment on the chain ring, as I was not aware there were SS-specific chain rings.
    Nobody gives a s#$t you singlespeed.
    SS chain rings are not ramped... I could probably get by with the one I have.
    Reputation: EZSHUM_331's Avatar
    I've been SS on a non SS chain ring for ever with no issues. Most middle chain rings are 32t standard anyway. When I built my SS I just used what I had, 12 months later and over a 1000 miles and still going strong.
    Reputation: tamen00's Avatar
    Most shops should have what you need, however a couple of recommendations...
    Do not get aluminum BMX chainring bolts - get the steel cheap ones. Less creaking and way less chance of breaking one, especially with the 4 bolt cranks
    Also, get a SS specific chainring - especially if you are using a chain tensioner like a surly or whatever. The teeth are longer and will hold the chain better than a geared ring. Recommendation is the regular old Salsa non-ramped chainring - 20 bucks, pretty much last forever (I get about 2 years out of them) and are strong. Swiss American, Slippery pig, and Rage should all have the ring
    Reputation: AZ_AlanS's Avatar
    Nov 2006
    The Pig. If you are coming out for the night ride you can call them and ask Eric to bring them out to the park.
