Results 1 to 20 of 20
    Rear Tire Recommendations
    I am looking for a rear tire that will be good in the Arizona desert conditions. I am currently running the Maxxis Ignitor in both the front and the hear. I have noticed that when climbing in does not have good hook up and I lose all momentum when going uphill because my tire just spins. Does any one have any suggestions for a good rear tire?
    How much further ???
    Reputation: Douger-1's Avatar
    I run a Maxxis Crossmark 2.25 LUST in the rear running at 28 psi. Ive had good luck with it. I will also say technique has a big part in spinning out. Are you hammering out of the saddle in a low gear?
    “Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did." Mark Twain
    Feb 2010
    I have tried several and my favorite by far is Maxxis Larsen TT LUST UST 26x2.00. I get around 500 miles out of it. I also hear that Kenda Small Block Eight work well in AZ...but I have never tried one.
    Ahhh the pain....
    Reputation: Raybum's Avatar
    Tons of posts on this here in the AZ forum. The search function is your friend!
    my faves for rear tire...(for SS)
    Geax Saguaro
    Michelin Wild Racer
    WTB Nano (just don't expect alot of life out of it, but rolls great and is light)
    lots of other good ones that I haven't tired yet.
    ┌∩┐(◣_◢)┌∩┐
    http://onegear-ray.blogspot.com/
    Reputation: Tankerblade's Avatar
    Im running some out dated Bontrager Jones ACX tires...has some GREAT traction in my limited experience...
    K3N
    K3N is offline
    Certified slacker
    Reputation: K3N's Avatar
    Aug 2010
    I have Specialized purgatory tires, they're quite knobby. I think they have some awsome traction compared to the Maxxis aspen that was on before. But also tubless so I'm sure that has something to do with it also.
    Reputation: dunerinaz's Avatar
    Quote Originally Posted by K3N View Post
    I'm also running a purgatory in the rear tubeless. Actually I'm experimenting running the purgatory in the front and rear. Both are 2.4's. So far they've actually been impressive, even in the front. Rear has mad traction running 30 psi.
    Quote Originally Posted by Raybum View Post
    Geax Saguaro
    Michelin Wild Racer
    Not a place a usually shop but nashbar has a tubeless version of these on sale for $30. I bought two today.
    First post. I'm new up in this b!tch.
    Reputation: AzFlapjack's Avatar
    Kenda Small Block 8. I also really like the new Maxxis IKON as a rear tire.
    Reputation: mtnbiketodd's Avatar
    You did not mention what part of AZ you ride in or what trail you are on. I mostly ride Natty at South Mtn and on that trail I can run bald as long as I keep my weight back over the rear end. I road out at Red Mtn and there was a couple of spot my weight back bald tire would not hook up.
    So remember to get your butt over the rear and see if that solves the problem.
    I mostly ride in the deems hill area and thunderbird park. When I climb I am on the saddle most of the times and occasionly will stand up to get through a technical section.
    Reputation: Britishnate's Avatar
    I am riding these
    http://bontrager.com/model/08039
    Bontrager XR4 Kevlar bead. I have a 2.2 in the rear and a 2.35 in the front. Nice gripy tires for the AZ conditions.
    You can pick them up at Trek west phoenix.
    WTB Velociraptor! the best! FTW
    I'm running Kenda Small Block 8's and really like them. Also like the Continental Race Kings although the sidewall is a bit thin.
    CST Caballero wire bead: Cheap, hook up well (for me), run fine ghetto tubeless, strong sidewalls
    Machacaman
    Reputation: jrpogge5's Avatar
    Jan 2009
    I am running my second set of Spec Purgatory's UST and they are sweet. The bead sets with a hand pump and they are bulletproof. Spec has a pretty good policy on their tires as well.
    MachacaMan
    PMP,TAN,LAUNDRY
    Reputation: azdog's Avatar
    Minion DHR if you are riding the more techy trails. High roller if you ride the smoother stuff.
    Bender to AZDog: I'm not the best person to give advice on not riding!
    dirt visionary
    Reputation: clockwork's Avatar
    +1 for minion. the exo version comes to mind for all mountain type stuff.
    IMO Highroller or the likes if your aggressive with the corning.
    Life should NOT be a journey to the grave with the intention of
    arriving safely in an attractive and well preserved body.
    skilldest©
    Reputation: _dragon's Avatar
    Jun 2010
    Quote Originally Posted by jrpogge5 View Post
    After going through 3 different Spec tires on a few light rides (Jan-Feb) I had 2 sidewall tears (rear) and 1 that burped constantly (front). Due to the generous return policy I thought I "settled" for the Spec Purgatory Grid UST 2.4 front/back. Pain in the butt to get on the rim, once on, same here, bead set very easily. I was wondering how long they would last but so far they have been just fine. May just be me but my rear tire gets wore down really fast (not much of a skidder either) compared to my front.
    Reputation: schenker's Avatar
    Quote Originally Posted by Britishnate View Post
    I am riding these
    x2 on the XR4 in the back, but I use an FR3 up front and I'm pretty happy with it.
  1. Rear tire recommendations needed
    By DFYFZX in forum 29er Bikes
    Last Post: 05-23-2010, 06:53 AM
  2. 26 rear tire recommendations with 650B front?
    By gthcarolina in forum 27.5
    Last Post: 07-15-2009, 07:54 AM
  3. Fast rolling rear DH tire recommendations.
    By 4 Jaw Chuck in forum Downhill - Freeride
    Last Post: 03-22-2009, 06:17 AM
  4. 2.3 or bigger ust rear tire recommendations
    By ccwaskier in forum Wheels and Tires
    Last Post: 08-10-2007, 11:28 PM
  5. Replies: 5
    Last Post: 05-24-2006, 06:19 AM
