Results 1 to 8 of 8
Thread: New Rotor
    Reputation: chipolopolo's Avatar
    Dec 2008
    New Rotor
    looking for a bit of advice, I just recieved new rotors (R&F) for Elixer brakes. The old rotors were way under spec. I need to spread the pads a significant amount.
    Any "trade craft" secrets so as not to screw things up.?
    any help would really be appreciated.
    Steve
    Drinkin the S-Works Kool-aid
    Reputation: woahey's Avatar
    The secret to mountain biking is pretty simple. The slower you go the more likely it is you’ll crash.
    - Julie Furtado
    Reputation: tysonnemb's Avatar
    I always just used a regular screwdriver, put in between pads, and twist until fully spread.
    No Clue Crew
    Apr 2005
    Big flathead screwdriver or a Pedro's tire lever will work.
    bland
    Reputation: m77ranger's Avatar
    Jan 2009
    If you want to be super pro you can put a piece of thin cardboard between the screwdriver and pads so you don't mar the pads.
    Meatbomb
    Reputation: Phillbo's Avatar
    Use Easy E's mom if you want max spread.
    My other ride is your mom
    Reputation: Maadjurguer's Avatar
    I never found that "marring" the pads did anything bad....just get all monkey on it and pry those effers open with any non-greesy flat implement you have and call it good...
    Dec 2008
    Thanks for the responses,
    I was looking for a "non-purpose built" tool method. I have used screwdrivers in the past with mixed results. Tonights results were good!!! I put the old pads on to pry against.
    I'm a pro at breaking things that were not broken when I started. A plumbing job at home is, EVERY time, three trips to Home Depot.
    Thanks all,
    Steve
  1. Replies: 9
    Last Post: 04-01-2012, 12:18 PM
  2. Replies: 9
    Last Post: 12-29-2011, 05:47 PM
  3. Replies: 1
    Last Post: 12-05-2011, 02:41 AM
  4. Replies: 39
    Last Post: 05-25-2011, 06:14 PM
  5. Need rotor advice from Marta SL/storm rotor users
    By Shuteye in forum Brake Time
    Last Post: 02-14-2011, 02:58 PM
