Results 1 to 51 of 51
    EDR
    Reputation: eatdrinkride's Avatar
    Jun 2005
    National stair step pics?
    Anyone have a pic or better yet a video of cleaning the stair step(s) when heading down National towards Pima? The section I am referring to is where 95% of all riders I've seen just stop and walk up the left side. The stair step is a rock that juts out towards the trail (and you are already climbing a bit), it's maybe a 18'' lift to get your front tire up then you must get your rear up, and then pedal real hard to continue up. There is an alternative line to the left that are basically 5 or 6 stair steps, this section is very difficult to navigate but doesn't have the ' Oh, crap" factor, so many try it that way.
    I've seen several people make this section look easy, including Azmtncycler and his crew. Most don't even bother trying though.
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    I confess that I don't usually even bother with that section. It takes a bit of effort and you can get your right foot wedged under that dang rock on the right just when you think you've got it...Phooey
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
    Quote Originally Posted by kenbentit
    I have gotten where I can do it on the right , but depending on how hard I was riding the rest of the ride wheather or not I will have the power left to do it at the ending of a hard , ---it takes a good hard charge and push for me in middle 2 or granny 4 and most of the time I just don't have any power left that late in my ride.
    I have been working on doing the stairs on the left , I have come close to making it but not quite , ----it seems to take less energy for me to do it on the left , --its just I have not quite gotten it right all the way
    No Clue Crew
    Apr 2005
    Bah, that's one of the toughest obstacles on that trail. I know a couple of guys can make the left line. You have to run up the first couple of steps then cut right. I don't have enough gas to pop up on the right line and can make the succession of steps on the left. I generally give it a couple tries, make it halfway, then gracefully walk the rest.
    EDR
    Jun 2005
    Ya, that's what makes that way so difficult, I've never made it that way. In fact for the last year I've only been attempting the right line.
    Anyway today was one of those days where everything just felt perfect. On the way up I told my buddy I was going to ride the spine at the waterfall. I've rolled up to that countless times and chickened out every time. Now, I've done the far left line several times and I've done the far right line down the shoot countless times. Both line are much more technical than the spine........but the spine has that pucker factor that has just been in my head. Today I rolled up to it and rode right down without thinking about it. It was an absolute breeze compared to the other two lines. Once I made that I told my buddy to let me ahead b/c "I'm going to ride the up the stair step". I hit that step and pulled the rear up and just kept going........I made is easily and was stoked Then I went back to show him how easy it was and I failed miserably
    Anyhow I turned 40 this year and had pretty much figured I have hit my apex, as far as technical riding goes. It just felt great to conquer two obstacles that I had pretty much given up on, in one day nonetheless! Today was definitely a 'passion' day for me!
    Next up...........the trail gap near Hidden Valley. I've ridden up to that sevaral times but the penalty for failure is scary.
    Anyhow when I cleaned the stair step my buddy said "Mother Fvcker"!...it was a good day
    Reputation: tmarkos's Avatar
    Nice job EDR Never to late to step it up.
    trail "cleaner"
    good job EDR!!
    It's always major stokage when you can clean something that's had your number for so long.. I think its time you come out for a Boo Crew ride this fall/winter.
    vmb
    vmb is offline
    Technique for that step
    That is a tricky spot - I can't tell you how many people I've seen case the edge of that rock and pinch flat (present company included).
    I have finally figured it out and can now clear it most of the time (used to be ~ 5-10% of the time, now ~90% of the time).
    The technique that works best is to loft the front wheel as far over and past the rock as possible (just pull a nice wheelie and stick with it) and just as your front tire comes down,
    lift the rear wheel as best you can using your clipless peddles.
    Once on top of the rock, peddle in a controled fashion as to not lose traction.
    I have never used flats, so can't talk to what techique to use there.
    What I know doesn't work is to hit it with speed with the expectation that momentum will carry you over (that's usually when the pinch flats happen). It's all in the technique....
    Reputation: blue109's Avatar
    was up there for the first time earlier this week....and yea, i walked it. that climb is not flat pedal friendly :P
    Thats great EDR , its so great to hit something new and have it work for you , That thing is tricky , --( and if your not tubeless you will pince flat if you catch it wrong )
    every once in awhile I will go through it with ease, ----but not to often , its generally an energy burnner .
    I do not know why that left line is just in my head , its really not that bad,-- I ride with acoupple guys that make it real easy .
    Reputation: JrockFeltaz's Avatar
    Quote Originally Posted by eatdrinkride
    Never focus on the penalty. Only visualize yourself clearing the gap. Practice on a single and get comfortable with the speed and distance needed to clear the distance. Follow somebody the first time.
    Pivotal figure
    Jan 2003
    Riding it with flats is pretty similar but you obviously can't pull the bike up quite the same way. Getting over the step isn't so hard, it's getting thru that narrow spot right above it. Takes a fair amount of effort and precise timing. I walked it quite easily again today
    EDR
    Jun 2005
    Hey thanks for the stokage everyone.
    I really didn't intend to start a thread about me but hey, sometimes it's ok to pat yourself on the back, haha. I was just so stoked I wanted to photoshop my head onto some pics of someone cleaning that climb so I could send a "friendly" email reminder to my buddy. See, we have been friends since 7th grade or so and we started biking together in '04. Since then we have had a pretty good competition thing going on so any chance I can get to rub it in a bit, I'll take He's had the one-up on me for a while now as he has been dropping down the spine, while I have been chicken-shiite. Friday totally turned the tables on him and I just know it bugs the crap out of him
    Friday was just weird. Everything about being on the bike felt just right. It's a feeling I've had a few times before but not often. Basically it's being in "The Zone" I guess, I also dropped off, rather than rolling off, two sections I've never done that on before. I noticed that I didn't think about any of the obstacles, I just hit them. That's a hard place to get to, but I hope it comes again soon.
    AZmtncycler: Let me know when you have a slow-poke along so I'll have someone to keep me company, lol.
    Crazed Country Rebel
    Reputation: iheartbicycles's Avatar
    Anyone have a pic or better yet a video of cleaning the stair step(s) when heading down National towards Pima? The section I am referring to is where 95% of all riders I've seen just stop and walk up the left side. The stair step is a rock that juts out towards the trail (and you are already climbing a bit), it's maybe a 18'' lift to get your front tire up then you must get your rear up, and then peddle real hard to continue up. There is an alternative line to the left that are basically 5 or 6 stair steps, this section is very difficult to navigate but doesn't have the ' Oh, crap" factor, so many try it that way.
    I can't remember any part of that trail that wasn't rideable. Post a pic of the section and I'll post one of me or my peeps riding it.
    Stupid, but sometimes witty. Occasionally brilliant. Slow and fat though.
    Mike Vandeman Sucks Dong
    EDR
    Jun 2005
    I know I don't have a pic. I'll search around. I did a group ride a year or more ago with 8 or 10 people. Durtgurl was there, and Sam I think and a few others I've ridden with before. Anyhow, someone on a 29ers taco'd his rim when rather than dropping down that step, like most people do, he chose (and I did that day also) to take the right hand line (heading up natty) down the stair steps. Anyway Sam or Kathleen caught it on video. I'll have to look for it.
    Quote Originally Posted by iheartbicycles
    Sweet, got any pics or vid of you climbing the waterfall? I'd love to see that.
    Quote Originally Posted by tmarkos
    Being that I am not a local, I don't know these terms. Post a pic of the spot. I think we cleaned everything on that trail, up and down - can't remember anything too difficult.
    Here's a few pics for starters. Not bragging - it was a great trail and it was very technical. Would love to ride it again.
    EDR
    Jun 2005
    tmarkos is referring to climbing up the lower section of the Waterfall, which is pictured below. Typically it's talked about in two sections, the upper and the lower which is what you beginning to ride down. I think calling it difficult to climb is an understatement. I've personally only witnessed one guy climb UP the lower waterfall.
    Did you guys climb that or walk up like the rest of us?
    tmarkos is referring to climbing up the lower section of the Waterfall, which is pictured below. Typically it's talked about in two sections, the upper and the lower which is what you are riding down. I think calling it difficult to climb is an understatement. I've personally only witnessed one guy climb UP the lower waterfall.
    You're probably right. I don't remember cleaning it, and I probably would have had I done it.
    I need to ride that trail again!
    EDR
    Jun 2005
    Regardless, you guys must be good riders to clean most of National on your first and only visit. How far did you actually ride Natty? It goes on for miles and miles but many turn around at the parking on top (Buena Vista)
    Nice job!
    There are many different lines and many obsticles that it takes months and months to find and have someone show you whats up.
    If you do not ride national at least twice a week for a year ---you do not know and have not really ridden national.
    I have only seen 2 guys climb the waterfall, and I have only made it 1/2 way along with several others, ------Thats the beauty of somo is you can ride it for years and still find something way hard and new to do.
    So only going there acoupple of times whithout somebody that rides it all the time is not even scratching the surface.
    Somo has alot to offer every rider , and it will take years and years to ride all of it , Thats the greatest thing about Somo
    Reputation: Evil Patrick's Avatar
    Sep 2004
    Oh, everything on National is just too easy. I'd like to post the pics of me riding over the top
    of the people at the moment where they were cleaning everything, but I was going too fast
    for the cameras and my peeps were yawning.
    -- Evil Patrick
    Some of my Music
    My Videos
    The trail...shall set you free.
    lurker extraordinaire
    Reputation: AZDesertRat's Avatar
    Quote Originally Posted by kelstr
    This might be one of the guys you have seen do it, but here's a video of Ronnie climbing the waterfall. As if just getting up the waterfall isn't impressive enough, he has a cast on his arm!
    EDR
    Jun 2005
    Quote Originally Posted by AZDesertRat
    Impressive indeed but it seems the initial step looked way too easy. Either it was leveled out at that time or he is taking a little different line that I can't see. I was looking at it the other day and it just didn't look that easy, but video/pics have a way of doing that.
    If you're looking up at the waterfall, there's a rock on the right that kind of sticks out. A lot of people aim to go off that rock at the bottom. You probably know the rock if you ride out there a lot. Once in a while you'll see where someone will stick a cheater rock under there, but it usually gets knocked away after a while from people constantly hitting it on the way down, or someone else will just move it out of the way. Anyway, that's the rock that I usually see Ronnie go up. When he hits it right, he does make it look easy. I think what you're seeing here is just a case of video making everything look smoother than it is.
    I know he posts on here, and I told him that I was gonna post the video, so maybe he'll chime in and say something about it.
    Fly High!
    Reputation: RidingRiot's Avatar
    from SOMO on Vimeo.
    or go here for HD!!!
    "Its like Church to me, Like Church is, what it is for other people"
    sixsixtysix
    Guest
    Quote Originally Posted by RidingRiot
    from SOMO on Vimeo.
    Get back to work...
    Reputation: KavuRider's Avatar
    Sep 2004
    from SOMO on Vimeo.
    That video would be much better without the g@y NWD soundtrack...
    Fly High!
    Quote Originally Posted by KavuRider
    They pay the bills so, what ever freeride entertainment wants,,,,,,is good with me!
    Sep 2004
    Freeride Ent pays what bills?
    Seriously...ghay.
    Fly High!
    Seriously...ghay.
    the soundtrack bills! seriously.............dont hate cause you've never been in HD!
    Sep 2004
    Oh yes, that's my dream. To be in HD.
    I heard you don't ride anymore.
    Fly High!
    [QUOTE=KavuRider]Oh yes, that's my dream. To be in HD.
    This will be you in 6 more months
    But this will be you!
    " width="549">
    Sep 2004
    [QUOTE=RidingRiot]
    Yeah, so?
    Bask in my awesomeness.
    That video is still f***ing ghay.
    Reputation: cesslinger's Avatar
    OOOOOO.... don't forget to encourage the OP to do the trail gap by posting my 3 failed attempts.
    PS... the douchebag on a Jamis 29er that ran you over was Posh.
    Yep , old Ronnie------I have seen Gabe and Ronnie climb that baby .( Gabe has a real strange line on the outside edge 3' to the rt where Ronnie hits it at )
    They make it look easy , but as we all know its NOT what it looks like ,
    I can run it up to where you have to transition rt or left in the rut or to the rt like Ronnie did ----but I can't seem to have enough power to finnish the thing , -----and then that little rt hand turn at the top is really a power robber also.
    I ride with Ronnie sometimes and he is really amazing at all the really strange hard different lines all over that mountain that he rides , -------
    And that Astrix of his he rides is very heavy .
    EDR
    Jun 2005
    Quote Originally Posted by cesslinger
    I'm the OP: What was the result of the failed attempts? Video???
    The problem I see with that gap (as one who's never done it) is that the tranny is really steep, that's all well and good but it's just soooo washed out, basically sand at this point, plus the run out is very short. I did a few drops of 5' or so out at the pit but that looked easy in comparison. That tranny was really long with no need to ever stop.
    Anyhow I could see my front wheel flopping on that trail gap landing. It's spooky Not too mention the last thing you want to do is case the landing and hit the rear tire on the trails edge. That would be bad.
    The trick to the gap is speed, you need more speed than you think. Chuck was crashing on purpose, it's his MO.
    I will post the video later, but you don't need a lot of speed, just a straight shot off the rock. I messed up because I was trying to get around the chunky stuff and failed to correct myself in mid air quick enough. I didn't get hurt, but the third attempt taco'd my wheel.
    1st attempt
    2nd attempt
    &nbsp
    &nbsp
    http://vimeo.com/moogaloop.swf?clip_id=5404788&ampampserver=vimeo.com&ampampshow_title=1&ampampshow_byline=1&ampampshow_portrait=0&ampampcolor=&ampampfullscreen=1" type="application/x-shockwave-flash" allowfullscreen="true" allowscriptaccess="always" width="400" height="230">
    Chuck">http://vimeo.com/5404788">Chuck take 2 from SOMOhttp://vimeo.com/user1971252">SOMO on Vimeo.http://vimeo.com">Vimeo[/url].
    3rd one for the FAIL
    &nbsp
    &nbsp
    http://vimeo.com/moogaloop.swf?clip_id=5404872&ampampserver=vimeo.com&ampampshow_title=1&ampampshow_byline=1&ampampshow_portrait=0&ampampcolor=&ampampfullscreen=1[/url]" type="application/x-shockwave-flash" allowfullscreen="true" allowscriptaccess="always" width="400" height="230">
    Chuck">http://vimeo.com/5404872">Chuck take 3 from SOMOhttp://vimeo.com/user1971252">SOMO on Vimeo.http://vimeo.com">Vimeo.
    well, i can't figure out why the embedded code isnt working..
    attempt 1
    attempt 2
    final try... for now
    EDR
    Jun 2005
    attempt 1
    attempt 2
    That second attempt is exactly what I'm talking about. Flopping the wheel on the landing.
    Overall it looks really easy. Have enough speed. Don't go too fast. Don't turn the front wheel. Don't case the landing. Don't fall off the back by leaning too far rear-wards. Piece of cake
    ...Someday. I need to see this in person, and I have no armor besides knee guards, but that won't stop me, lol.
    parenting for gnarness
    Reputation: chollaball's Avatar
    Apr 2005
    attempt 1
    attempt 2
    giant heaving balls. going back 2 more times after crashing...
    Occidental Tourist
    Reputation: YuriB's Avatar
    Is this the section to which you refer?
    This is just need to know information: Am i supposed to enjoy the irony or pity the sincerity?
    EDR
    Jun 2005
    Quote Originally Posted by YuriB
    Yes. Si.
    The step up to the right to be exact. Now show me a pic of you cleaning it so I can paste my head on it
    Kathleen in AZ
    Reputation: DurtGurl's Avatar
    Dec 2001
    Yes. Si.
    This was a little tribute to duagla before he had knee surgery. I had another video of Chongobob bombing up the left line and arriving at the saddle with a hissing pinch flat but Youtube cut it due to my song choice and my iMac lost it upon crashing this past spring.
    from DurtGurl on Vimeo.
    Quote Originally Posted by chollaball
    LOL, much appreciated but it isn't too bad after the initial huck.
    EDR
    Jun 2005
    Quote Originally Posted by DurtGurl
    Nice. As always, video doesn't do it justice.
    edr this is so very true, the video just makes it look like a walk in the park, ------and its not.
    Thank for the video Kathleen
    Apr 2005
    Yes. Si.
    too funny. all along I thought you were talking about the rock steps exactly at the bottom on National right near the start. Can't get those either. Once like 5 yrs ago on a 4 inch bike I somehow managed to clean the steps into BV, never been able to do it since but I almost always try.
    EDR
    Jun 2005
    You know, I made that section once that I can remember. It's tough. Being at the very beginning of the trail you don't even have a chance to warm up to the tech stuff yet, I think I just fail to commit most of the time.
    Another once that gets me 90% of the time is the first rock step up when heading up Mormon. It's nothing fantastic, but it gets me almost every time.
