Results 1 to 6 of 6
    Low Pressure Shock/Fork Pump ...
    Hey, I'm in search of a low pressure shock/fork pump for a Rockshox WC. I end up putting in less than 50 pounds and would like something more accurate with small increments on the dial. Anybody know who makes one?
    Kathleen in AZ
    Reputation: DurtGurl's Avatar
    Dec 2001
    I found one on-line a few years ago for use on my White Bros forks which needed about 15 lbs of air pressure. I will look it up when I get home. If it goes up to 50, you are welcome to it as I have gotten ride of those forks and no longer need to pump.
    Quote Originally Posted by DurtGurl View Post
    That would be awesome!!
    I'm doing a fork service tonight and would love to scoop it up to get an accurate reading of where I need to be for the right sag.
    Muchas Gracias!!
    ....just cruisin through
    Reputation: dfrazm's Avatar
    Oct 2007
    If DG can't find that pump, Fish at Cactus bike has one (probably not for sale). I think he made it. It is basically a syringe with a pressure gauge on it. He pumped me up for free
    Here are just a few of the key ingredients: dynamite, pole vaulting, laughing gas, choppers.....
    You can just use a nice low pressure gage on any fork/shock pump, I used a nice 3" 50 psi gage in 1/4 lbs incriments and used a Y fitting I made and added it to my pump, ....now I have two gages on my suspension pump , I added a gate valve and just chose which one I am going to use at the time .
    I had the gage , but you can get them at Granger and or off the internet .
    Sport Chalet had two diff ones taht would do pressures under 50lb. PB has their version that Ive used a couple times and its got better markings than the topeak if I remember right.. I wheeled my bike right in Sport Chalet once and pumped pressure in and then left.. You gotta test em
  1. replacing shock pump pressure gauges
    By da_eddio in forum Tooltime
    Last Post: 02-25-2010, 07:53 PM
  2. Low Pressure Shock Pump?
    By Call_me_Clyde in forum Shocks and Suspension
    Last Post: 03-15-2006, 05:35 AM
  3. Low pressure shock pump?
    By Call_me_Clyde in forum Where are the Best Deals?
    Last Post: 02-18-2006, 01:54 PM
  4. Compact Low Pressure Shock Pump
    By ahimanic in forum Shocks and Suspension
    Last Post: 02-15-2006, 08:12 PM
  5. Low pressure shock pump recommendation?
    By SinglePivot in forum Shocks and Suspension
    Last Post: 02-20-2005, 08:31 PM
