Results 1 to 16 of 16
Thread: juicy five
    juicy five
    my juicy five rear brake gets stock and i allready bleed them any help
    My other ride is your mom
    Reputation: Maadjurguer's Avatar
    Let me translate for you: "My Avid Juicy 5's, specifically the rear caliper, gets stuck. I have already bled them to no avail. Do you have any help for me? Thank you in advance."
    You could try the brake forum here, http://forums.mtbr.com/brake-time/ , and do a search on stuck calipers.
    Good luck.
    Meatbomb
    Reputation: Phillbo's Avatar
    It's not the calipers, it's the levers.
    Reputation: MattyBoyR6's Avatar
    Sep 2004
    Had exact same issue. The seals inside are swollen. You need to either buy a piston rebuild kit about $20 shipped off ebay each lever. Or take it to your LBS for replacement under warranty. Cactus took care of me like rock stars.
    If you do the work yourself you will need C clamp pliers. real small ones or some other sharp tools to get into the lever.
    Got Daytons on the Motha Ship - Cube
    Quote Originally Posted by Phillbo View Post
    forgive me....my drunken 3'rd grader l33t translation skills from Klingon to English sometimes backfire.....
    Meatbomb
    was not pointed at you.. i had the same issue and it was the lever that needed a rebuild... they would not return.
    I bet the problem started when it got hot.
    Philbo....I'm not baggin' on you....I'm baggin' on the OP whose first post is almost intelligible. This drivel might be the parlance of our times...but I still believe in the concept of clear communication.....especially....when you're making first impressions....on a forum....where intent means nothing and perception means everything....to wit...I am not impressed....but who the hell am I anyways? So disregard......
    Meatbomb
    "intelligible"
    guilty.. i had to look that one up.
    I just assumed he was foreign.
    Kathleen in AZ
    Reputation: DurtGurl's Avatar
    Dec 2001
    I recently did a complete overhaul on several of my Juicy 7s - both levers and capiers. The 5s and codes are not much different but each requires their own specific kits and you need to know what year your levers were made.
    Here are some directions for 2005s and 2007s:
    http://www.sram.com/_media/techdocs/...TechManual.pdf
    http://www.sram.com/_media/techdocs/...04-000RevA.pdf
    I'm guessing SRAM will have these directions in Spanish which might help
    You'll most likely need a pushrod kit for your brake lever to fix it. I suggest you take the lever apart following the directions in the links above before ordering a kit. Most likely it will be SRAM part # 11.5311.567.000. Do a google search on that number and find a retail site where the items in the kits have pictures so that you can match it up to what you took out of your current lever. Order and then rebuild. Then bleed, and hopefully you'll be good.
    Or bring it to your local bike shop and have them do the rebuild
    Good luck!!
    I had the stuck lever issue on my juicy 5's. SRAM replaced lever internals under warranty with only change for 2 rides then kept getting stuck. They were rebuilt again under warranty that lasted approx 2 months. They have excellent customer service and when the bike warranty was for a while I called them trying to buy a new set of brakes at a possible discount since all my issues with the 5's and the sent me a full set(front and rear, levers, calipers, disc, hoses) of elixers free. I think they are basically the juicy 5 just newer but havent had any issues yet with the brakes.
    Eroding into the trail
    Reputation: DustyBones's Avatar
    Jun 2010
    Wow! That is rockin' customer service!
    Reputation: BIGHORN LEW's Avatar
    Quote Originally Posted by Maadjurguer View Post
    Let me translate for you: "My Avid Juicy 5's, specifically the rear caliper, gets stuck. I have already bleed them to no avail. Do you have any help for me? Thank you in advance."
    You could try the brake forum here, http://forums.mtbr.com/forumdisplay.php?f=51 , and do a search on stuck calipers.
    Good luck.
    Umm Maad, that should be BLED them, not BLEED.
    RAM speed: UP, UP, and away....!
    drink coffee, ride.
    Reputation: cookiedough's Avatar
    Nov 2006
    Yep, same experience here, once it gets warm out they start to stick. Was in REI and they had a whole front kit for $35, granted it was the 3.5 but it's basically the same. I'll get to rebuilding them this fall once it's cool in the garage.
    Quote Originally Posted by BIGHORN LEW View Post
    facepalm!
    Meatbomb
    Quote Originally Posted by EPDP99 View Post
    You were lucky... Mine were out of warranty so after 2 rebuilds, I had to replace.
    thanks for your help
    regards
    regio1
  1. Avid Juicy 5 Vs. Juicy 7 & Rotor size
    By sperlingjf in forum Beginner's Corner
    Last Post: 01-06-2009, 10:37 PM
  2. Replies: 9
    Last Post: 07-22-2008, 05:08 AM
  3. Avid Juicy Carbon vs. Juicy Ultimate
    By WindWalker in forum Brake Time
    Last Post: 08-16-2006, 05:39 AM
  4. Replies: 1
    Last Post: 08-06-2006, 02:30 PM
  5. Juicy Carbon cheaper than Juicy 7 (Jenson)
    By mp29k in forum Brake Time
    Last Post: 06-02-2006, 01:26 PM
