Results 1 to 29 of 29
    Reputation: broncbuster's Avatar
    How much and often do you add Stan's during the summer?
    Also same question during the rest of the year?
    I add 2 oz of Stan's about every 3 months. Doesn't matter what time of year. I'm in Prescott, so the temps may be different. I'm also putting about 500 miles on the tires during that 3 months.
    Reputation: RajunCajun44's Avatar
    If you have a good seal/seat, then 2 oz per 6-8 weeks is good, if you have a poor seating and you have to pump up your tires often, then your stans will evaporate completely every two weeks (or more often)...
    Reputation: mtnbiketodd's Avatar
    ~The same for me 6-8 weeks in the Valley year round.
    Jul 2013
    If you have lots of money then put a calender reminder on your smart phone at what ever time period you think is correct. If you are a more frugal person buy the four ounce bottle of Stans and make up your own home brew for about $10 a gallon. You carry the 4 oz. bottle in your pack to recharge your tire or friends having leak issues. Refill the 4 oz. bottle up when you get home.
    When your tire starts losing air either over night or during a ride squirt in 2-3 oz. in the valve stem and proceed on your ride.
    I actually had the rear tire going flat on my car yesterday and squirted in about 5 oz. and the leak sealed instantly. I have about 10,000 miles left on the tread and rather than pay for a flat fix I am going the drive the car until December and buy a new set of tires for winter driving in the snow.
    Hope that helps
    Attached Thumbnails Attached Thumbnails How much and often do you add Stan's during the summer?-getto-stans.jpg
    Quote Originally Posted by RenegadeMtnBiker View Post
    Hope that helps
    So how do you make the home brew?
    As mentioned I probably need to add sealant more often since my tires are not tubeless even though I am running them tubeless and have to pump them up about once a week.
    Thanks for the advice all ...
    Meatbomb
    Reputation: Phillbo's Avatar
    search home brew, there are MANY threads on the subject.
    Good deal Phillbo think I'll just try adding the tubeless slime for now since I just recharged the Stan's today so as not to waste it.
    Reputation: GR1822's Avatar
    32 oz water
    24 oz Atv slime - 1 bottle
    16 oz latex mold builder - 1 jar from Michaels
    Search WSS in the 29er forum for a gazillion page thread on it.
    Apr 2013
    I live in Phoenix area. Im running maxxis ardents. They last about 3 months. I add new Stan's when I replace the tires typically. I have Enve hoops and they don't leak out any Stan's that I can tell. My old wheels that came with my bike sucked and leaked really bad.
    SamuraiBunnyGuy
    Reputation: longhairmike's Avatar
    Quote Originally Posted by GR1822 View Post
    32 oz water
    i tried that but it was impossible to get out of my camelbak afterwards
    Jul 2013
    When you change to the new tire do you pour the sealant into the new tire and add a little new or do you try and see if you can get by on what's left in the old tire?
    Reputation: Skeeter97's Avatar
    Feb 2012
    Ok dumb question but I'd like to get this straight. . How much air loss would be considered enough to make me want to add sealant?? I typically will lose 3-5 psi in between rides (4-5 days) Is that normal? 2013 stumpy fsr comp with stock wheels/tires.
    Sent from my SCH-I545 using Tapatalk 4
    32 oz water
    Perfect I'll try that when the Stan's is gone.
    Quote Originally Posted by Skeeter97 View Post
    I think 3-5 psi between rides is about normal. The Maxxis ignitors that didn't hold air well, also would loose sealant fast.
    Honestly, now that I think about it, it may have been seepage at the rim edges and not losing air that caused the loss of sealant...
    Ahhh the pain....
    Reputation: Raybum's Avatar
    two things...
    1. Keep you bikes in the house.
    2. Ride more...I never add stans after the initial install; tires are worn out in 6 weeks. (rear tire at least)
    ┌∩┐(◣_◢)┌∩┐
    http://onegear-ray.blogspot.com/
    Quote Originally Posted by Raybum View Post
    two things...
    Impossible, and impossible.
    I envy you though on both points
    I love bike!
    Reputation: dsittman's Avatar
    Take tire/rim combo off bike every so often and shake. If you hear liquid sloshing around then you're ok. Probably don't have to worry for about the first month after a refresh, then check weekly or so. If no slosh you need to refresh sealant. I've had sealant last months or just weeks. Too many variables to nail down a refresh schedule IMO.
    Reputation: PhxBenK's Avatar
    Jan 2011
    I keep my bikes inside but I replace every 2 months or so depending on if I had a puncture or not. Ride about 200mi/mo.
    Feb 2012
    Cool thanks for the info, glad to hear all is well
    Reputation: In2falling's Avatar
    Jan 2005
    Quote Originally Posted by longhairmike View Post
    Add 12oz of Jack Daniels
    Reputation: Evil Patrick's Avatar
    Sep 2004
    The drying isn't so easily associated with time, though time is a factor. Think about this: how long does it take a bottle of liquid latex to dry if it's statically sitting on the shelf?
    From what I can tell, I believe that the drying rate for liquid latex is a combination of wheel revolutions and time; and for wheel revolutions, let's use miles. The latex "paints" the inside of the tire on each revolution and the air within the tire begins to dry the thin layers on the inside during this process.
    What I've seen as a ROM is one oz every 300 miles and about a month. Two months and 600 miles and my bike's tires are pretty much dry inside.
    -- Evil Patrick
    Some of my Music
    My Videos
    The trail...shall set you free.
    Reputation: dorse's Avatar
    Quote Originally Posted by In2falling View Post
    The real answer to this question is you don't have to recharge your sealant until you get a flat or your tire gets soft. Stan's will dry out at different rates, depending what tire your using. With schawbe tubeless ready tires. It does not last that long as I run really low pressures,and the side walls are very thin and with the low pressures the side wall get pinch flatted all the time. I have little wet spots all over a 3 month old tire. I have another bike with UST nevegals. I have not put sealant in them for over a year. I'm sure it has dried out but the tire stays just as hard as if it did have sealant. For flat repair. I carry a stan's syringe and a vale core remover tool, and a two ounce bottle of stan's. I pump up the tire listen for the leak. Once I find the leak I remove the valve core and inject the two ounces of stan's with the syringe. I then let the stan's sealant cover the hole by moving the hole to the lowest part of the tire. Sometimes you may have to shake the tire a little. Once the tire seals I pump it up to the desired pressure and ride on. I don't even have to take off my wheel.
    Mar 2011
    There's an old guy in Sedona; TRAIL DOC, that has a secret formula. He asseerts that its the best; but he only gives the formula in the hot tub....so bring a pen!
    Clean, smooth surfaces, and no lumps help;;;;as well as 1 oz of Canadian club per 1/2 gal of potion. TS
    Always use new sealant when you change tires. I save the old sealant and use it when I need to replace dried out sealant.
    UST does not require sealant, because the tires are so thick and heavy. I have my slowest leaking with UST even slower than tubes.
    You do not need to worry about your sealant drying out unless your riding somewhere like Arizona with all the pokey things. Even there you could wait till you flat to add more sealant.
    I carry a Stan's syringe and valve core remover. I have a two once bottle off Stan's sealant I carry as well. The Last time I flatted I didn't even need to take my wheel off to fix it.
    SamuraiBunnyGuy
    dude, do you know what forum you are in?
    Why do you ask?
    Reputation: chipolopolo's Avatar
    Dec 2008
    two things...
    That right there is some sage advice. Bikes in the garage? would you make your wife stay in the garage?
    I never add Stan's between tires either, unless removing to un-install a trail mounted tube. Another thing I try to do is wire brush all the dried up Stan's off, just extra rotational weight for zero reason.
    Drinkin the S-Works Kool-aid
  1. Happy Summer! What's Your Favorite Summer Tunes Thread?
    By cyclelicious in forum Off Camber (off topic)
    Last Post: 08-14-2013, 09:45 PM
  2. Replies: 1
    Last Post: 07-23-2013, 05:08 AM
  3. Stan's wheels ad
    By Mojo Maestro in forum General Discussion
    Last Post: 06-13-2013, 08:10 AM
  4. New Stan ZTR Hub vs. CK and I9
    By OriginalDonk in forum Wheels and Tires
    Last Post: 02-25-2011, 02:04 PM
  5. Stan got a new website
    By meltingfeather in forum Wheels and Tires
    Last Post: 02-24-2011, 01:19 PM
