Results 1 to 17 of 17
Thread: Hope Brakes
    Reputation: KavuRider's Avatar
    Sep 2004
    Hope Brakes
    Can anyone recommend a good place for service on Hope brakes? I have a set of M4's that need to be bled and possibly have a line replaced.
    Quote Originally Posted by azdog View Post
    I think he was born around the time of the Chernobyl fallout which would explain a lot.
    sixsixtysix
    Guest
    Quote Originally Posted by KavuRider
    Um... I would say Performance Bike for sure...
    Tip: Find a place that sells pads and lines for Hopes, and they can probably do the service, its not rocket science.
    PMP,TAN,LAUNDRY
    Reputation: azdog's Avatar
    Rage...that's pretty much the only brakes they carry and service.
    Bender to AZDog: I'm not the best person to give advice on not riding!
    sixsixtysix
    Guest
    Yup, Rage sells a lot of Hopes and probably can fix them up. Cactus doesn't sell the brake sets, but sells the pads and Goodridge lines for them.
    Too many Sedonuts...
    Reputation: CactusJoe's Avatar
    Aug 2005
    +1 for Rage. Slippery Pig will service them too.
    Funny, my M4's just started barely leaking. Time for a seal replacement...because you can do that on Hopes...
    When the world slips you a Jeffrey, stroke the furry wall.
    Sep 2004
    Cool, thanks. That's the answer I was looking for.
    Shovel Ready
    Reputation: Cycle64's Avatar
    Just a note there are Hope M4's and Mono M4's. Told Curley I needed some pads for my M4's and got the wrong pads, as I have the Mono M4's. Nothing special to bleed these brakes. DOT3 in the cylinder and break the bleed fitting loose while pulling in on the lever. Tighten before releasing the lever. Don't let the reserve get low on fluid and you should be fine. I actually have the Hope bleed kit and have never used it. The bottle is nice to catch the fluid coming out the Zerk, but a large rag works also. You do want to be careful not to get the fluid on the frame or any other painted item.
    Rage does have lots of Hope items. Even the little clips to hold in the brake pad retaining pin, as I always drop one on the floor and can never find it again.
    Currently at Mayo Clinic being tested for a kidney transplant. Donors welcome.
    Sep 2004
    Quote Originally Posted by trb2929
    What is the difference between the M4 and Mono M4?
    These came stock on my GT.
    It was stolen, then recovered from a tweaker. Not sure what he did, but there is no fluid in the rear brake anymore. Didn't notice any leaks or paint damage, which you would expect from that big a leak. The front brake is fine.
    The spec's for my bike just say "Hope M4 brakes".
    Shovel Ready
    Older M4 pads
    Newer Mono M4
    sixsixtysix
    Guest
    Mono just refers to the caliper being one piece, which yours are with the gold outboard piston caps.
    Sep 2004
    Quote Originally Posted by sixsixtysix
    So mine are the Mono's.
    Ok, good to know.
    On a side note, the GT was fun this weekend.
    Except for switchbacks. Its like a Greyhound bus, its so long.
    But they are still doable. Very stable in the air.
    caninus xerophilous
    Reputation: SunDog's Avatar
    The Hope bleed kit makes bleeding a breeze as its pressurized.
    Sep 2004
    Quote Originally Posted by SunDog
    I was considering getting the bleed kit. But since I'm not exactly sure what is wrong with the brake, I need to bring it to Rage anyways.
    Thanks for the info!
    caninus xerophilous
    Thats how I learned.
    When I rehosed to Goodridge. An excellent and DIYish upgrade.
    my knees hurt
    Reputation: singlespeedsycip's Avatar
    Jan 2005
    I have Hopes bore cap removal tool if anyone ever needs to borow it for a bore cap seal replacement....Iknow it works on the mono caps, not sure about the previous models though....
    BELIEVE
    Imagine what you could achieve if you knew you would not fail.
    Dec 2005
    these are one of the easiest to work on, sure you don't want to try yourself? no bleed kit needed
    mx
    Dec 2005
    mx
