Results 1 to 24 of 24
    Apr 2013
    Going to Sunrise Resort for first time. Any advice?
    I'm heading to Sunrise for the first time for some lift service trail riding.. This will be my first time at Sunrise, or any lift served trails for that matter. I was wondering if anyone had any advice on which trails are the best. Or just advice in general about the resort. I just finished building up a Canfield The One. I've seen some complaints about lifts marking up the frame. As this is a new frame I'd like to know if there is some area's on the frame it may help to protect from the lift with a protective film or something. I don't really care if it gets scratched up from me riding it, it would bother me if it was something I could have protected on the lift ride up though. Also would full face helmet be recommended or just standard bike helmet. I have both so either works
    Huffy Rider
    Reputation: motochick's Avatar
    Jun 2010
    Full face. There are only 2 or 3 DH trails all steep and loose. No comment on the bike getting scratched...
    PMP,TAN,LAUNDRY
    Reputation: azdog's Avatar
    3m clear tape if your concerned about the frame. This should minimize it.
    Bender to AZDog: I'm not the best person to give advice on not riding!
    "resort" ha! It's not really that. You might want to go ride the trails around Pinetop or other ones in the area if you are worried about your frame getting some scratches. Your body might get much worse "scratches" than your frame riding those trails with the current dry and loose conditions. Good luck! And.....please post some pictures of your adventure!
    The .05 percent
    Reputation: sinatorj's Avatar
    Feb 2006
    Drive a little further and go to angel fire, our pajarito. Well worth the extra drive.
    Make Flagstaff RAD Again.
    Oct 2011
    When are you heading up there. I will be there on july 6 th and can show you around if your going to be there that day. Bring body armor and a full face.
    Trails are closed on July 6th and 7th. Archery.
    Oct 2011
    Quote Originally Posted by seven1seven View Post
    Forgot all about that thank you.
    EDR
    Reputation: eatdrinkride's Avatar
    Jun 2005
    I've been there a few times on my 5.5'' bike that I ride everything on. Never ridden a true d/h bike. For me, standard protection was adequate as I was not blazing the trails like true d/h guys. My advice if riding your everyday trail rig...
    1) Be able to lower your seat down nearly all the way. If you can't, get a cheap seatpost and cut it short. If you have a dropper then no need.
    2) If you usually ride clipless maybe consider bringing some flats to try out.
    Apr 2013
    Thanks for the advice guys. I decided to wait until they get some rain. Seen some vids on YouTube and trails at sunrise look pretty sketchy. Add on top of that dry loose conditions and a bike I've only started tuning and riding today, makes sense to wait. I'm going to flagstaff to try out some trails there this weekend. Never been riding there so I thought a few shuttle rides would be nice to get a better feel for the bike and work on a suspension setup
    Apr 2013
    Quote Originally Posted by azdog View Post
    Were would be the best place to put the film. I have some on the bottom 1/3
    Of the downtube.
    Apr 2013
    Quote Originally Posted by sinatorj View Post
    Angelfire looks nice. Hadn't heard of it until your post. Bit of a drive though, but I noticed Gnar Gnar is going there may have to check it out on one of their trips
    The .05 percent
    Feb 2006
    Flag trails not going to be any easier. Really dry right now.
    Huffy Rider
    Jun 2010
    The trails up in Flag are just as sketchy right now, really, not even fun. Wait till they get some rain as well. Lots of rain!
    PMP,TAN,LAUNDRY
    Quote Originally Posted by JMSmitty View Post
    Of the downtube.
    Behind the seatube. They lean the bike against the rear holder, downtube and underneath top tube.
    May 2013
    I rode it a couple weeks ago, it was my first time doing downhill so I wore some Fox body armour and a full face. I would have probably broke my shoulder blade if I didn't have the upper armour on, I flipped over the side of a trail and bounced off some rocks. It was pretty awesome though because it barely hurt. I'm not very good so I stuck to the Fungus Trail. It's fun though unless you're into extreme riding, then I couldn't tell you. I saw some dudes with downhill specific bikes go down a double black diamond, I'm sure it was harder than fungus.
    The .05 percent
    Feb 2006
    sketchy, but still the best in the state. Get of your brakes, your ride will be better...
    Huffy Rider
    Jun 2010
    Quote Originally Posted by lobos82 View Post
    I took a guy who regularly rides Mammoth down that double black trail and he only made it about 100 ft before he turned around and pushed his bike back up, he wanted nothing to do with it. Fungus is more of a beginner trail, the only trail to ride if you aren't riding the blacks and double blacks. Your Canfield will handle every trail out there with no problem, mine does. Just gear up and hold on.
    May 2013
    Quote Originally Posted by motochick View Post
    Yeah I went down a blue section and it was practically straight down and through some trees, I can't imagine the double black! I still had a good time though
    Ow!
    Reputation: clydecrash's Avatar
    Apr 2005
    I was at Sunrise this weekend. Did the easy stuff (mainly Fungus), with a little of the blue mixed in. Lots of fun. I was expecting it to be loose, but it wasn't too bad and we had some rain. I had played on the "XC DH" trails at Snowmass and Vail many years ago, but this was only my second time at DH (or DH for me that is). Learned a lot, and ready to take a few more chances next time (but within limits--old means heal very slowly).
    I only went down once on Sunday's last run. Main reason was I was getting tired--and poor skills. I wore FF, hard shell knee/shin and elbow/forearm, and used them all. No injury, so well worth it to wear.
    Now making plans for Angel Fire. Doubt I will ever be a real DHer, but the bug did bite. I will be hitting Sunrise again this summer. And it was a whole lot better than being in the over 110's in Tucson this past weekend.
    Go go gadget bike!
    Reputation: timothyclaus's Avatar
    Sunrise is fun!! Beginners shouldn't stray too far from Fungus & Chutes n Ladders though... It will test your skills and make you a better rider for sure.
    GO TO ANGELFIRE WITH GNARGNAR!!!!!! Super fun trails, super cool dudes, you are literally sleeping 400 feet from the lift.
    Shred...it's the new drug
    Reputation: latedropbob's Avatar
    Thanks Timmy for the plug..we do have room for about 4 more for Angel Fire next weekend! They're getting rain now...trails will be epic!
    Huffy Rider
    Jun 2010
    +1 for going to AF with Gnar Gnar....you will have SO MUCH FUN!!
    Thread Killer
    Reputation: Hardluckhero's Avatar
    Jun 2010
    Snow Summit @ Big Bear is fun. Its a little further than Sunrise but worth it IMO.
    Cholla cactus=nature's guard rail.
  1. Any advice for the first time builder?
    By Simpledesign in forum Trail Building and Advocacy
    Last Post: 09-04-2013, 08:33 AM
  2. advice for first time buyer
    By Jmegt in forum Downhill - Freeride
    Last Post: 02-20-2012, 08:00 PM
  3. Long time rider - First time DJ'er needs some advice
    By woodyak in forum Urban/DJ/Park
    Last Post: 10-28-2011, 01:27 AM
  4. Suspension Advice needed - Setup for resort riding
    By CharacterZero in forum Knolly
    Last Post: 08-23-2011, 12:36 PM
  5. Q's on Sunrise Ski resort trails..
    By E30Evolution in forum Arizona
    Last Post: 08-10-2010, 07:32 PM
