Results 1 to 19 of 19
    Reputation: Rollin'in'Zona's Avatar
    Caution;  Merge;  Workers Ahead! Flagstaff GEM about to be lost - AZ Trail - SF Peaks
    EDIT: Communication with the people structuring the forest thinning has confirmed that the person in uniform who told us on the trail that all the painted tree would be cut down is wrong. The painted trees stay.
    Apologies. Very happy
    Reputation: rockman's Avatar
    Rollin', you had your chance to vote for or against the Four Forest Restoration Initiative as a city bond last year (that is, if you are a resident). Not only that but it's largely funded by the city of Flagstaff so you are paying for it as well. Forest Initiative Plan Unveiled | Flagstaff Business & Online News | Northern Arizona Local Newspaper
    The comment period on the draft EIS ended on May 29th. For those interested more info can be found here: Four Forest Restoration Initiative - Planning Documents
    The information I posted above is not entirely correct. The 10 million dollar bond passed by the city of Flagstaff is the Forest Health and Water Supply Protection Project.
    Project at a Glance | Flagstaff Watershed Protection Project
    It's a more focused effort on the Schultz Creek and Rio De Flag watersheds. It will treat new areas (mainly on Elden and Dry Lake Hills) as well as accelerate plans for other area that were already part of the Four Forest Restoration Initiative (4FRI).
    To the OP, I'm not sure what you are so fired up about. More than 90% of the AZ trail between Snowbowl Rd and Schultz Pass was routed on areas that have already been thinned. The big impact will be to Dry Lake Hills on trails like L. Gnarly, Schultz, upper Brookbank and Sunset. And it's a done deal and if you are so upset about it maybe you should go talk to some of your fellow Flagstaff neighbors who live downstream of the Schultz burn area.
    Reputation: Eazy_E's Avatar
    Hey, at least the snow will melt faster.
    Gotta pacify all those people that had to build their homes in the forest and now worry about a forest fire taking their homes.
    The .05 percent
    Reputation: sinatorj's Avatar
    Feb 2006
    Quote Originally Posted by Azpilot View Post
    Or someone like me who lives in the area across from the peaks and does not want their house flooded because some valley dweller could not extinguish their camp fire and burns our forest down.
    Make Flagstaff RAD Again.
    Meatbomb
    Reputation: Phillbo's Avatar
    Those damn valley dwellers..
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    More people will solve everything!
    That's a pretty hubristic statement, to be mild. Calling it outright ignorant wouldn't be a stretch.
    Fire has always been, and will always be part of the normal, safe northern woods ecosystem. The problem is, the fires we see now don't have historical precedent. Back in the day, there were 5-10x less trees per acre, and they were big trees for the most part. There'd be regular under story fires which clean out the forest floor, but that was no problem since Ponderosa Pine has thick bark, deep roots, and it's foliage is high up.
    Now, we have 500-1000 trees per acre, of all sizes, and we're in a period of drought. Years and years of heavy handed fire suppression have left a lot of fuel on the ground. A fire starts, it burns hotter than it normally would, and it uses all those small, tightly packed trees to ladder up into the forest crown and there you go, a run away wildfire.
    Used to be, you'd only see that every hundred years or so, not the frequent crown fires we see today.
    Good news is, we now understand where we went wrong with forest management and with the correct amount of thinning and prescribed burns, the forest should go back to acting like it did pre-European settlement. And since the forest will be acting normal again, you won't see the massive fires and accompanying erosion and water quality issues that follow a hard burn.
    SamuraiBunnyGuy
    Reputation: longhairmike's Avatar
    this is bob barker reminding you to have your trees spayed or neutered.
    Oh, if anybody is interested in some reading, Nature Conservancy had a good article about this:
    Nature Conservancy Magazine - Catching Fire
    My other ride is your mom
    Reputation: Maadjurguer's Avatar
    To the OP....another thread a week back or so clarified via the FS that those trees which are marked, are the ones to NOT be cut. I repeat....the orange slashes you see on the trees....mark those trees which are healthy and will be saved.
    Give it a crank
    Reputation: Mtn-Rider's Avatar
    May 2010
    We all need haircuts once in a while, forests too.
    parenting for gnarness
    Reputation: chollaball's Avatar
    Apr 2005
    Quote Originally Posted by Eazy_E View Post
    why am I seeing cleavage shots of Jennifer Lawrence?
    Research has shown that thinning does not help to stop wildfires, but actually causes them to spread. When a forest is thinned, the decrease in shade allows much more sunlight to reach the forest floor, causing the foliage and small trees to dry out, creating entire forests full of tinder.
    A 2003 study of another large blaze, the Hayman fire in Colorado in 2002, published as a case study by the Forest Service, showed that fires killed 50 percent of the trees in a natural, unthinned forest but killed 90 percent in a thinned forest, because the fire on the ground was hotter.
    Studies Find Danger to Forests in Thinning Without Burning | Bark
    SamuraiBunnyGuy
    Quote Originally Posted by chollaball View Post
    more importantly,, why am i not?
    You're missing a key point here....and it's listed in the first line of the article: "Thinning forests without also burning accumulated brush and deadwood may increase forest fire damage rather than reduce it, researchers at the Forest Service reported in two recent studies."
    On the Coco, they are both thinning and burning accumulated brush/deadwood....and have been for a while now.
    Quote Originally Posted by Maadjurguer View Post
    Good to know.
  1. Flagstaff GEM about to be lost - AZ Trail - SF Peaks
    By Rollin'in'Zona in forum Passion
    Last Post: 08-15-2013, 09:19 PM
  2. Flagstaff GEM about to be lost - AZ Trail - SF Peaks
    By Rollin'in'Zona in forum Trail Building and Advocacy
    Last Post: 08-15-2013, 09:17 PM
  3. Peaks Trail
    By hinchmant in forum Colorado - Front Range
    Last Post: 06-30-2012, 11:25 PM
  4. 4 peaks trail help
    By JonLeeGreen in forum Arizona
    Last Post: 05-14-2012, 05:31 PM
  5. Peaks Connecetor trail
    By speedier racer in forum Colorado - Front Range
    Last Post: 07-31-2011, 07:38 PM
