Results 1 to 30 of 30
    Alive and Lurkin'
    Reputation: Jibro's Avatar
    Dot 5.1 in the North Valley
    Other than buying the Avid brake fluid from a bike shop, are there any Motorcycle/Auto stores that carry DOT 5.1 brake fluid in the North Valley? I've tried Checker, CycleGear, and RideNow PowerSports in the Hwy 51 area with no luck.
    Any Suggestions?
    Pumpin & Pimpin
    Reputation: Casual Observer's Avatar
    Quote Originally Posted by Jibro View Post
    Any Suggestions?
    Do you need DOT 5.1? I believe I got the fuild I have in the brakes now at Checker.
    Nobody gives a s#$t you singlespeed.
    No Clue Crew
    Apr 2005
    I sub Dot 4 for Dot 5.1 in my Hopes.
    Shovel Ready
    Reputation: Cycle64's Avatar
    Jibro. Some Mercedes use it. Worse case check a dealer.
    Currently at Mayo Clinic being tested for a kidney transplant. Donors welcome.
    Kathleen in AZ
    Reputation: DurtGurl's Avatar
    Dec 2001
    I'd be curious to know too! I put some Dot 5 into someone's new Codes but was told by some shop guys that was a big no-no. Something about synthetic vs. nonsynthetic? So if we cannot find 5.1 anywhere, would substituting Dot 4 for Dot 5.1 be better than using Dot 5? I'm hoping someone in the know will spout some wisdom on the subject...
    Dot 3 , 4 , 5.1 is all compatible .....but if you really want a good brake fluid that will not fade use Motul high temp racing fluid , its rated as a 600 degree fluid but I see temps in excess of 1400 degrees come off superbike systems and 900 to 1200 come of moto systems and the Motul does not fade or change at all.
    I was easily fading the standard 5.1 in my avids ...went to Motul and no more problem
    I just picked up some 5.1 from NAPA two weeks ago or so ago for a truck I was overhauling the braking system on ........just make sure you do not ever use 5.0 silicone fluid ....this stuff is some of the worst fluid I have ever tried to use
    Reputation: woahey's Avatar
    I think most NAPA or Checker stores carry it. If not, Checker could probably have it in a day or two if you ordered it. You can buy the Motul- .5 liter for $8 on amazon.
    The secret to mountain biking is pretty simple. The slower you go the more likely it is you’ll crash.
    - Julie Furtado
    No Clue Crew
    Apr 2005
    KK: You CANNOT sub 5.0 for 5.1. Most manufacturers allow DOT 4 as a 5.1 sub.
    Quote Originally Posted by DurtGurl View Post
    The dot 5 silicone fluid came around for hot rod guys that did not want the fluid to eat the paint if they ever got any on the paint , -----stupid i know but that was its claim to fame .
    oils come in some different base categories ,....the quick and dirty explanation is --------you have "Petroleum" ......"Caster"..........".Vegetable"........".Mineral "
    Brake fluid in most "English / American systems are "Vegetable fluid only systems .
    The dot 3,4,5.1 are all Vegetable base brake fluids and are all compatible.
    The strange dot 5.0 is a hybird design silicone base that is supposed to work with in a vegetable base system .......but it DOES NOT and really should not ever be used as a brake fluid at all .
    Now this is just a down and dirty simple explanation .......I could right a book on oils , fluids and the like but it gets really boring really quick .
    And do not ever mix ---Petroleum ...Caster.....Vegetable.....Mineral ever in any form other than salad dressing ......
    Reputation: 'size's Avatar
    i believe horizon motorsports on 20th ave and rose garden carries motul dot 5.1. at least they did last time i bought a bottle.
    Alive and Lurkin'
    Quote Originally Posted by kelstr View Post
    I think the Motul RBF600 is the stuff I'm looking for. Brand new Codes and they're as soft as Doo-doo. Fade like Doo-doo too. If all the 5.1 stuff is the same a racing DOT 4 is probably the way to go. I've been gaining some more mass these days and need all the help I can get to keep the brake power firm and even.
    Pumpin & Pimpin
    Kathleen in AZ
    Dec 2001
    So.... would flushing the 5.1 from the lines with 4 clean it out enough or should I disassemble everything thing and really wash all the rubber bits in the levers and calipers? And if I did that, what do I wash with? Geeez, for being a scientist and a self-proclaimed good bike mechanic, I sure am a dolt about hydraulic brakes! But my moto has always been "live and learn" Sometimes the learning comes with a price
    Yes the Motul 600 is what you are looking for , I have some if you can't find some soon enough .
    I generally get mine from "SouthWest Dist" in PHX , I have seen it at "Cycle Gear "
    and the Apache Honda stores , ......and you can order it from "RockyMountain Cycle"
    No Clue Crew
    Reputation: big0mike's Avatar
    Jun 2010
    It's been so long since I had my CBRs fluid changed I can't remember for sure but I'm pretty sure that's what I had put in my lines. Hadn't thought about putting it in a bicycle's lines but next time I need anything done with my brakes I'll have that fluid swapped and bled.
    Alive and Lurkin'
    No, you do not have to breakdown all the pieces and parts. Yes, you do have to remove as much of the old fluid as possible, otherwise the new bleed will only be as good as the old fluid's temp rating. All cleaning and clean-up should be done with 90% Rubbing Alcohol.
    Pumpin & Pimpin
    Eroding into the trail
    Reputation: DustyBones's Avatar
    Jun 2010
    You can also order online from lots of MX stores, here is a couple of links.
    http://www.locox.com/Motorcycle-Gear/Brake-Chemicals/
    and another
    http://www.motorcycle-superstore.com...0-0-0-24-1-3-1
    Dirt is Fun
    What is the life span of Motul 600 in the bottle after being opened? According to Avid DOT fluid lasts only 48 hours after a bottle being opened before it absorbs to much moisture thus breaking down the fluid. If you create a good secondary seal can store it for maybe 2 weeks.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    I've never had a problem finding it up in hickville Prescott, so I doubt you would in the valley. Yes, it has a shelf-life. If I don't use the entire bottle at once, I throw it away. It absorbs moisture from the atmosphere, doesn't necessarily "break it down", but it lowers the boiling point significantly.
    Reputation: Chalkpaw's Avatar
    I'm off to the moto store today to replace the "factory" fluid in my Avid Exclir's. I'm having major brake fade in and fade out on most longer descents. Originally, these brakes worked just fine, but now it sure seems like most of the new Avid's need a brake fluid flush within 6 months of use.
    I will give a report on the prognosis. I have a trip to the Alps coming up and I have been warned to have my bike's brakes in best ever working condition. We are talking many thousands of meters of descents (and some major climbing too) per day. I'm also taking an extra set of brake pads. I'm skeered!
    There is a big difference between ripping and skidding.
    Quote Originally Posted by dirtyknobbies View Post
    Any brake fluid should only be opened before using and any left in the bottle should be discarded and not used at all.
    Brake fluid should be changed very often , I change mine in my trucks cars and bicycles every 6 months .
    In my race vehicles or race moto bikes I change it out all the time
    "No Clue Crew"
    Reputation: Cenobite39's Avatar
    Victory Big Dog Motorcycles in Mesa has it.
    Quote Originally Posted by Chalkpaw View Post
    You are correct , about the 6 month mark the old brake fluid just looses any of its tempature threshold, ....nothing like new fresh high temp fluid with fresh pads .....its something thats is really overlooked by most people on their vehicles , and it sure can get your attention when it starts to go !!
    Alive and Lurkin'
    Went back to Cyclegear 20mins ago and no good stuff (out of stock)...
    I'm tired of chasing this stuff down locally. Found it online for $14.99 ordered 3!
    Pumpin & Pimpin
    "No Clue Crew"
    $11 at Victory!
    Reputation: supermoto's Avatar
    Hmm. I've been bleeding my juicies with the silicone stuff for a while. Its pretty (pink), doesnt take on air and doesnt burn my hands. Seems to be working fine, although I have one sticky rear brake on the f-bird.
    Reputation: dunerinaz's Avatar
    What about brake systems that use mineral oil. Is the shelf life any different? I'm using Pentosin in my shimano brakes and it works great. It's labeled as a mineral based hydraulic fluid. I bought the big can since it was cheaper than one tiny little bottle of shimano mineral oil. I'll never use it in my lifetime but it works well.
    PS....If anyone local with shimano brakes needs to bleed them, I'll hook you up with some oil.
    And for the 5.1 stuff, these guys are usually cheapest and ship fast. I've been buying from them for years and never a problem.....http://www.rockymountainatvmc.com/ty...29&webCatId=23
    Quote Originally Posted by supermoto View Post
    Yep the silicone fluid is really only made for the hot rod guys that really do not use their vehicles at all , I have had to rebuild many systems where guys were trying to run the 5.0 in a hard use system .
    Its really not what you want to be running , it can cause sticking and bloating of the seals and it does not hold moisture in suspension and causes corrosion in the calipers where the moisture settles .
    Kathleen in AZ
    Dec 2001
    Supermoto - Cenobuns is buying the store out of their dot 5.1 for the codes and I already have dot 4 for Juicies. There will be a bleeding party in my garage tomorrow (I'm taking Fri off work) if you wanna bring your bikes on over. I also have two spare kits to repair floppy Juicy 7 lever syndrome.
    Kathleen in AZ
    Dec 2001
    ok... here's the poop on 5 vs 5.1...
    Dot 5 is silicone based, hydroscopic (does not absorb water or air), non-toxic, non-corrosive, non-irritating. It is always PURPLE.
    Dot 3, 4, and 5.1 are glycol based, hygroscopic (does absorb water and air), toxic, corrosive, and irritating. These are always clear to light yellow.
    Use of Dot 5 in our bike brakes will cause poor performance due to it's inability to absorb air and moisture. Air pockets will form and that leads to iffy fading brakes. Because it does not absorb water and is lighter than water, any moisture that gets into the system will pool at the lowest point (oil and vinegar theory) and may cause internal metal corrosion, especially in your caliper if you always leave the bike wheels-side-down. I have not found any evidence that says Dot 5 will cause corrosion of rubber seals, but anecdotal evidence says this can happen.
    So... the general rule for us is.... Do not use Purple Dot 5 Silicon brake fluid!!
    On the positive side, turns out I've been using purple Dot 5 for a while in my Avid Juicies with no adverse effects (that I know of). Today I shall bleed all my Juicy 7s with Dot 4 and will bleed Cenobuns' Codes with Dot 5.1 and we will wish for the best!
    Also, know that Dots 3, 4, and 5.1 have a shelf life due to their hygroscopic nature. One on-line reference stated said that the color of Dot 4 will change from light yellow to darker straw yellow with age, but here is a pic of a brand new bottle of Dot 4 (left), a 2+ year old bottle of Dot 4 (middle), and Dot 5 Silicone (right). Looks like the old Dot 4 is lighter yellow than the new bottle, so perhaps color is not a good guideline. The stuff is cheap - best advice is to buy a new bottle when it's time to bleed your brakes!
    O'Reilly's Auto Shop in the Gold's Gym complex at 52nd at Elliot said they'd start carrying 5.1 on the shelf within about a week just for us.
    http://www.gabma.us/docs/dot5.pdf
    Attached Thumbnails Attached Thumbnails Dot 5.1 in the North Valley-dot-4-5-brake-fluids.jpeg
    Yes the color really is not a good guideline of age or contamination , there are so many different shades of even the same makers fluid , some makers have a real dark red/brown color (Motul) and some are almost clear .
    The best bet is to just keep it changed out and clean in all your vehicles and you will never have any problem , and run from the 5.0 silicone .
  1. Squaw Valley / North Tahoe
    By Kenrow in forum California - Norcal
    Last Post: 08-10-2010, 09:36 PM
  2. North Fork Happy Valley
    By TheoBend in forum Oregon
    Last Post: 07-04-2010, 05:08 PM
  3. BCT carpool from north PHX/I-17/Happy Valley
    By RobZona in forum Arizona
    Last Post: 03-14-2010, 07:22 AM
  4. Help with North West Valley trails?
    By fiveo in forum Arizona
    Last Post: 03-15-2007, 08:43 PM
  5. Trail on 51st ave north of Happy Valley
    By CactusJoe in forum Arizona
    Last Post: 01-30-2006, 04:08 PM
