Results 1 to 13 of 13
    Meatbomb
    Reputation: Phillbo's Avatar
    Do Cleats Wear Out?
    I've developed a lot of slop in my right foot and it releases a lot easier than it use too. I tightened the adjustment on the pedal with no change.
    Cleat or Pedal issue?
    No issue with the left but it does not get engaged and released as often.
    parenting for gnarness
    Reputation: chollaball's Avatar
    Apr 2005
    rubbing metal on metal, sand and rocks will have no effect whatsoever on its shape. Replacement cleats are a marketing gimmick.
    Reputation: Casual Observer's Avatar
    Quote Originally Posted by chollaball View Post
    Cholla speaks the truth. Same with toothbrushes and underware. No need to ever replace them.
    Nobody gives a s#$t you singlespeed.
    Reputation: mtnbiketodd's Avatar
    Same with drive trains and tires no need to every replace.....
    Sorry had to fall inline with the other posts.
    Yes, they wear out. I usually replace when I replace shoes which is about once a year or so.
    dru
    dru is offline
    I've already given Cholla secret +rep for mocking the OP, now I have to give some to you two. Hell, I'll even give the OP some for being a dumbass!
    Drew
    occasional cyclist
    dru
    dru is offline
    OP, what pedals? I've heard that as big S cleats wear out the pedal gets harder to get out of. Certainly the pedal mechanism will wear too.
    Drew
    occasional cyclist
    SamuraiBunnyGuy
    Reputation: longhairmike's Avatar
    Quote Originally Posted by Casual Observer View Post
    it totally pays to clean your underwear with your toothbrush
    Meatbomb
    LOL.. fell in to that pile of flaming poo
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Which by the way, never goes bad either!
    To be cereal, brass crack brother's cleats wear much faster than anything else. This is one reason they are "smooth", as brass is self-lubricating to some extent, but you'll start getting unplanned exists and will start slamming your knee into the handlebar/levers, which really hurts BTW. Shimano cleats go much longer, but they do wear out eventually. My shoe usually wears out before those cleats do though.
    Reputation: az3075's Avatar
    Yes they do. I speak from personal experience.
    Always in the wrong gear
    Reputation: Coondog#77's Avatar
    Cleats? If you ride flats you never have to worry about this minor detail.
    slower than you
    Reputation: rockychrysler's Avatar
    Aug 2003
    i leave my shoes engaged with my pedals at all times and merely slip my feet into them and ratchet-up as i coast down the driveway.
    i never replace cleats.
    "May your trails be winding, lonesome, dangerous, leading to the most amazing view." - Ed Abbey
    http://rockychrysler.com/
    dru
    dru is offline
    I do the same, but every time I fall my pedals unclip. Then I have to take the shoes off, put them back on the pedals and then put my feet back in them which is a pain being I'm now in the bush and not in the driveway.
    There has to be a better way.
    occasional cyclist
  1. Replies: 16
    Last Post: 12-13-2013, 10:30 AM
  2. change cleats?
    By jgutz71 in forum Tooltime
    Last Post: 06-08-2013, 07:47 PM
  3. cleats
    By imcastock in forum Beginner's Corner
    Last Post: 12-29-2012, 07:11 AM
  4. SPD cleats are SPD cleats are SPD cleats or are they?
    By far raider in forum General Discussion
    Last Post: 11-03-2012, 12:49 PM
  5. When to replace cleats ?
    By rickcin in forum General Discussion
    Last Post: 08-28-2011, 07:58 AM
