Results 1 to 36 of 36
    Reputation: Kurious Oranj's Avatar
    Derailleur cleaning - an Arizona specific question (sort of)...
    I have a quick question on the cleaning of mtb derailleurs here in Arizona. I am new to the area (PHX) and to mountain biking after having lived in much colder and wetter climates most of my life where I have commuted on a bike for decades. I am used to cleaning all sorts of crud off the RD but this fine dust is new to me.
    I have noticed that the rear derailleur is getting a little sluggish in responding to shifts and it is quite dusty. I have asked a few people around here and gotten responses raging from "no lubricant - just brush off the dust" to oiling it up well with things such as Tri Flow or chain lube.
    Any suggestions for the newcomer? I tried the search function but did not come up with much. Also checked with Zinn's bible which recommended lubrication.
    Thx much!
    Reputation: mtnbiketodd's Avatar
    If anything I will use a little water to remove the dust. Check your cable housing to ensure the outer plastic (usually black) has not shrunk exposing the wires that can drag on the cable and make it hard to shift.
    Reputation: metalaficionado's Avatar
    When I wipe down the chain with lube, I pinch a der wheel and spin, need to shift up to expose the the der wheels. I get the some crud off and presto.
    Let the bikes in!
    Reputation: R2ana's Avatar
    Dec 2010
    Yeah, it's that easy!
    If the shifting is sluggish I might take a closer look at the housing/cable.
    SamuraiBunnyGuy
    Reputation: longhairmike's Avatar
    ^^ this
    i've yet to have a rock strike actually break my derailleur, but plenty of them have caused the cable to fray near the derailleur so badly that it turned the shifting to crap
    Black and Sticky
    Reputation: Bituman's Avatar
    If you have a compressor, blow the der down with air. What Metal said about pinching the der wheels is a good idea too. I also use the age old bike maintenance trick of using the edge of a rag between each gear of the cassette. That cleans off a lot of crap that would otherwise be available to gunk up the der. Use simple green, 409, or some other mild degreaser on the edge of the rag.
    Bob
    "Some people follow their dreams, others hunt them down and beat them mercilessly into submission." - Neil Kendall
    I keep an old toothbrush around for cleaning the gears out. Seems to work well
    "This fish who keeps on swimming, is the first to chill upstream" - 311
    Give it a crank
    Reputation: Mtn-Rider's Avatar
    May 2010
    After every ride, first wipe the chain clean with a rag. Then use a Park Tool GSC-1 GearClean Brush on the entire drivetrain.
    Reputation: GR1822's Avatar
    Quote Originally Posted by Mtn-Rider View Post
    I use the same tool, , but I only do it every other or third ride. I oil my chain after cleaning, and run it through a rag just before my next ride to let the oil get to where it needs to get.
    Reputation: Casual Observer's Avatar
    Quote Originally Posted by Kurious Oranj View Post
    Thx much!
    This is why dog invented single seeds
    Nobody gives a s#$t you singlespeed.
    Meatbomb
    Reputation: Phillbo's Avatar
    lube every 3rd ride
    Reputation: Tom93R1's Avatar
    Jan 2005
    For the derailleur and most of the rest of the bike I use a $2.50/32oz spray bottle of citrus degreaser from Home Depot every few rides. Just spray it on, let soak a minute or two then rinse off with water. Chain and gears require a little brushing.
    Reputation: cstem's Avatar
    I don't clean my bike, I just wait until something breaks. New parts are clean. For those that do, I recommend never using water. A little brake cleaner (non-clorinated and make sure it doesn't get on some painted wheels) on the derailluer pivots, followed by some compressed air to blow it dry and out of pivot points. Then dribble a lube of your choice- WD40 is not lube- into the pivot points and wipe the excess. I prefer chain lube, because it is what I have handy all the time and brake cleaner because you should also spray and wipe brake discs or rim brake surfaces after the whole cleaning process. Any old lube or dirt on those will cause squeals and decreased performance.
    Vassago Cycles, Shadetree Bikes, Flat Tire Bikes, Galfer Brakes USA
    Thanks guys! I have been known to overthink things. Need to check those cables. Too old to convert to single speed...
    Reputation: tysonnemb's Avatar
    Why would anyone convert to single speed when it's much more fun to enjoy riding your bike?
    Yeah I over think things too much as well. Like when I moved here, I didn't know what chain lube to run. The kinds I used out east cake on the dust here.
    “Think of bicycles as rideable art that can just about save the world.”
-Grant Petersen
    No Clue Crew
    Reputation: big0mike's Avatar
    Jun 2010
    Quote Originally Posted by cstem View Post
    THIS. I don't think I've had a derailleur last more than 6 months. They don't get dirty enough to worry about in that time.
    Quote Originally Posted by tysonnemb View Post
    Word. Every time I think I may want to try it I stick my bike in a gear and try to leave it there. Have yet to make it 10 minutes in one gear. Making the task at hand HARDER is never a good idea. Nor fun.
    Reputation: In2falling's Avatar
    Jan 2005
    Thx much!
    "DuPont Teflon Chain Saver" I have found is the best drive-train (chain/derailleurs) lube for the dusty dry conditions here in AZ.
    Its a dry wax formula and does not collect much dust/grim and lasts a while (lube chain about every 3 rides and hit derailleur every now and then).
    For me it has done a great job of keeping dust/grim down to a minimum and extending life of drive-train components.
    Tri-Flow is a nightmare here and so are other oil based lubes.
    My other ride is your mom
    Reputation: Maadjurguer's Avatar
    Quote Originally Posted by In2falling View Post
    I agree a little, and disagree a little: If you don't ride much, then wax lubes are great....but get messy over the long haul and create crazy gunk buildup on parts. If you ride a lot, you need to switch to an oil based lube like Dumond Tech Lite, otherwise your lube won't last the ride....think bikepacking or endurance rides.
    Of course YMMV....bit I find your mileage dictates how and when you need to lube....just food for thought.
    Jan 2005
    Quote Originally Posted by Maadjurguer View Post
    I agree a little, and disagree a lot .
    I agree wax based and dry lubes don't last as long and have used some brands that would barely last a ride.
    But the Dupont Chain Saver I having been using for a little over a year now is working great for me. I am getting about 30 to 50 miles before I have to re-lube my chain and there is very little buildup with it. Its also fairly cheap and can pick up at Lowes and other hardware stores.
    I am with Maad on the Dumonde Tech Lite. Been using it for about four years now on geared and SS bikes. I like it because it cleans off easily.
    I love bike!
    Reputation: dsittman's Avatar
    I must have got the wrong Dumonde Tech as mine is blue which looks like is the 'original formula'. That stuff doesn't seem to get any less gunky than others I've used and I've not experienced any other noticeable benefits. Guess I didn't think the 'light' version was right since it says it's recommended for road bikes. If anyone has experience using both...Is there a noticeable difference b/w the two?
    Dave...I used the blue dumonde once...it's a lot heavier and far too gunky for my preferences. I think it would be a better lube choice for wet environments. The lite stuff works for about 70 or so dry miles for me before the chain gets squeaky again.
    Added bonus....it smells like pina colada....
    I love bike!
    Well...I guess I just can't go wrong then. At least if the lube doesn't work I can then use it as an air freshener. SCORE!!!
    I love my Squirt.
    No Clue Crew
    Jun 2010
    I've yet to meet a "wet" lube I didn't hate. They all collect dirt like white trash collects tattoos. I used to use Triflow because it's a great lube for many things. But not bikes that are dirt magnets. I currently use Finish Line Dry and I'm perfectly happy with it. If I had to relube after every two rides I'd be pissed. That's a worthless lube IMO. I don't want to do more maintenance on my bike. I don't want to do ANY maintenance on my bike.
    But that's just the opinion of a lazy guy who just wants to ride and not worry about how many miles I have on my lube job. TiFWiW...
    Reputation: XCRiderAZ's Avatar
    Ive found in AZ dry lube works the best. Alot less crap clogs up the drivetrain that way. Generally speaking you should use dry lube in dry climates and wet in wet climates.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Dumonde tech is not an oil based lube, it's actually a polymer based lube. It's "in between" oil lubes and waxes, which makes it a good compromise. I've been using the "lite" version for years without complaints. In really nasty/wet situations nothing is better than re-oiling your chain mid-ride with something like ATF fluid. If you want to do the oil thing, just buy some ATF fluid at the auto store, far better than the little bottles of "chain oil" at the bike shop. I'm currently looking for a little tiny bottle to use for this, because it's excellent "mid-ride" lubrication, if needed. Otherwise, dumonde tech for me. You do have to give it some time for the carrier to dry off, like waxes, but the carrier isn't totally worthless, like it is with waxes.
    http://www.dumondetech.com/dumonde/w...13.10-edit.pdf
    No Clue Crew
    Jun 2010
    Quote Originally Posted by XCRiderAZ View Post
    After I got tired cleaning up a Triflow mess that's what I learned and it makes sense to me. Especially, since I don't have to clean a mess very often now. Maybe I'll have to give this Dumonde stuff a looksie...
    That just sounds nuts to me. How pissed would be all be if we had to re-air our tires mid ride? But, then again, there are guys that can tell the difference between 27# and 28# of air in a tire. I'll never be that good...
    parenting for gnarness
    Reputation: chollaball's Avatar
    Apr 2005
    Purple Extreme. about every 6 hrs of spinning. bring some in your pack for long rides.
    i have peed on mt drivetrain. not because it needed it. because i could. vacuum
    Quote Originally Posted by big0mike View Post
    Death mud. 'nuff said there.
    Riding in a real wet nasty environment can wash away the lube and after a while the mud will start to make the bike miss-shift, auto-shift, etc. A little bottle of ATF can be a godsend. Now that I think about it, those real small bottles of eye-drops are the perfect size, so I'll go buy one of those sometime soon and replace the saline stuff with ATF.
    No Clue Crew
    Jun 2010
    Certainly a scenario I've not considered. If it's raining THAT hard I'm unlikely to be riding but definitely something to think about. For a while I had an small bottle of the Finish Line Dry in my pack but I think I took it out after never using it.
    bland
    Reputation: m77ranger's Avatar
    Jan 2009
    Lies. It smells like blue cheese. Get the yellow stuff it works great. Stay away from the dumond tech bio-green.
    Apr 2005
    those bottles are exactly what i use.
    BigO - its not something i ever thought of til i started do 5+ hr rides. Or times when you are on a road trip and needs something for day 2, at least you have it.
    No Clue Crew
    Jun 2010
    Quote Originally Posted by chollaball View Post
    Road trips would certainly be another exception. But, I still think the longevity of your lube should be rated in weeks, not hours.
    Quote Originally Posted by m77ranger View Post
    You just ruined it for me....just like a bartender back in 97 did when I was drinking a Fat Tire and he asked, " Don't you think that's tastes like a sour apple jolly rancher?"
  1. Sram-Specialized 29er specific front derailleur
    By Davidcopperfield in forum 29er Bikes
    Last Post: 12-25-2013, 06:57 PM
  2. Arizona Specific Tires
    By bazooka_beard in forum Arizona
    Last Post: 11-30-2012, 05:41 AM
  3. Cleaning question
    By JerB in forum General Discussion
    Last Post: 08-09-2012, 07:54 AM
  4. Frame cleaning question
    Last Post: 08-05-2012, 11:05 PM
  5. Derailleur cable routing ? on SS specific frames?
    By Ike Turner in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-16-2010, 08:24 AM
