Cygolite Trion 600
Anyone here in AZ using the Trion 600 from Cygo.
There is some but not alot of review data out there
I like the all in one design and guess that 600 lumens will be adequate when combined with a helmet light.
Anyone seen or using this?
I have seen one and know someone that has one. It is close to 600 lumens, and the beam pattern is ok. The all in one design is nice, however the runtime is pretty short on high, and the cost is very high! You can get one of the nicer chinese lights (the Titans) for a 3rd the cost, with a longer runtime, and lighter weight. The batteries can mount on the stem in most cases.
For the money you save buy going that route over the Cygo, you could also purchase a helmet light, and have money for a weeks worth of gas...
You may have better luck getting feedback in the lights forum. Dunno if you looked or posted there.
yes i did
there is not so much info on this light and I like to get feedback from those in my riding area as I believe this has an effect on ones opinion of a product.
True that. When I went ghetto tubeless, I wanted local input primarily due to the high heat., and it's effect on the goop.
I can't comment on the 600, but I've been running a TridenX LED Li-Ion Xtra 600 for two years now and it's still going strong. Couple of decent get-offs and it's still good. I use it 3-4 times a week once the temps are above about 90 or so during the year, so I've got alot of hours on it. I'm very satisfied with it to where I'm keeping an eye on the Centauri 1000 for next summer...
 Originally Posted by Phillbo
magicshine ..... boom
Literally.
Magicshines 900 is nice, but the beam isn't wide enough for a bar mount solution unless you know the trail well. Head mounted it's fantastic! It's fan-freakin-tastic on a road bike.
Much like Godwins law for Nazi refrences, I will declare a new law named Law's law in respect to how soon Magicshine lights are mentioned.
- You may not post replies
- You may not edit your posts
Forum Rules
