Results 1 to 28 of 28
    Camel Back MULE vs MULE N.V. vs Vaude Hyper Air
    Getting a new Camelback for longer rides / hotter days and was considering the Mule.
    The NV has an improved ventilation system but weighs more and costs more than the standard Mule
    Anyone been able to feel an improvement in ventilation with the NV? e.g. a cooler back?
    Dan
    UPDATE 2013
    Update: I bought the Vaude Hyper Air 14+3 Pack Black/Grey, 14 plus 3. Almost 2 years later I am still loving it. Very cool vent system in the back that. I have yet to find anything better.
    I rotate through different bladders. Slight preference to the camelback bladder due to mouthpiece flowing better.
    Dec 2005
    I just got the NV and I think it does help the ventilation somewhat....i would recommend it.
    Ahhh the pain....
    Reputation: Raybum's Avatar
    Old ROMPer, I have a Hawg NV that I am looking to sell. It's in great shape and I have a brand new 100oz bladder (never used) that I'll sell with it. PM me if you're interested.
    Looks like the Mule N V is twice the weight. 1lb versus 2.4lbs according the REI website.
    FYI the Hawg NV is 2.9lbs
    Reputation: twowheelsdown2002's Avatar
    Also take a look at the Vaude packs. The packs that say "air" like the Hyper "Air" have a mesh back panel and they actually have airflow behind the back that does work. They also have a fairly substantial waste belt. Downsides are the bladder is not insulated, and no phone/MP3 pocket, but one of the cooler packs in hot weather.
    I also tried some of the Deuter packs that have a similar design, but their waste belts were thin afterthoughts, and they had pressure spots.
    Reputation: dunerinaz's Avatar
    Performance has the MULE on sale for 39.99. Smokin deal.
    http://www.performancebike.com/bikes..._1025137_-1___
    Get Some!
    Reputation: Theycallmebrown's Avatar
    i have the mule. i have no complaints. for 39.99... id jump on it in a heart beat
    Great input so far!!!
    Thanks for market research as well.
    I noticed on the clearance priced Mules they have the older 100oz OMEGA HydroTanium reservoir. The newer ones have the
    100 fl. oz. Antidote™ reservoir equipped with the Quick Link™ connection system for hassle-free removal of the drinking tube
    Is the new bladder that big of a deal? REI has the new ones on sale for $60ish
    Quote Originally Posted by twowheelsdown2002
    Thanks- I like the price of these. Do you know if anyone stocks them locally?
    Bloodied but Unbowed
    Reputation: DesertCrawler's Avatar
    Quote Originally Posted by Old ROMPer
    The newer bladders are nce but not $40 worth of nice. I realize that is an individual value judgement but it is coming from someone who has one of each. A Mule at $40 is a great deal on a great pack. I may order one as a spare.
    Reputation: supermoto's Avatar
    NV has better strap system, sealed electronics pocket and the ventilation makes a huge difference. Worth the $$ IMO.
    Here's an alternative, its made in salt lake city, Utah.
    http://www.lonepeakpacks.com/
    Meatbomb
    Reputation: Phillbo's Avatar
    hard to fit a spare tube, pump, 100oz bladder and an oil can in one of those.
    DepartmentofGoods.com has the Vaude Hyper Air and Deuter Race X Air for $37.58. I own a new Hyper Air and an older Deuter, MUCH cooler than a Camelbak, lighter but not as many pockets. I like both but the Vaude is the perfect cycling pack as it's 14 liters that expand to 17 liters. The Deuter I have is larger (AC lite 20 Liter) than the Race X so I use it in winter.
    The only thing I use that's Camelbak is their bite valves. Mule is a 14 liter pack.
    agmtb
    Thanks for everyones feedback!!!
    I decided to try the Vaude. Ordered thru Amazon from Department of Goods.com.
    I did buy a Camelback mule at the Bass Pro sale for $59 last week but got looking at it and realized it had the old bladder so it going back. So that and the REI sale started this whole rethink... If I don't like the Vaude I don't know which way I will go next....
    If you don't like the Vaude you could try the Ergon BC2. I haven't tried it or even seen it on the trail but they are feature rich and Competative Cyclist has the best price seen at $69. Usually well over $140. They swivel with your body. Weight unknown, cadillac pack.
    agmtb
    Quote Originally Posted by abegold
    I had an Ergon BC2 before the Vaude. I did not like how it swung around.
    You could make adjustments to the Ergon to set how far off the back it carried. But with a full bladder in it, it would contact my back(and therefore make me sweat) If I adjusted it so it had air space with a full bladder, then it felt akward. It felt like you had a plank stuck 2 feet behind you with a bowling ball sitting on the end of it, so when you moved around you could really feel the weight out away from your body.
    The Vaude keeps it's air space even with a full bladder, but the weight feels like it is much closer to the body than the Ergon. The Ergon felt really weird in technical terrain where you use a lot of body english. Not so with the Vaude.
    jimfab
    Guest
    Also look into the osprey talon series packs. You can get a 6L MSR bladder in most of them. In my experience, the mule is a great pack for smaller guys on short rides ( <3 hrs). I find the mule sits up way to high on my back and caused back pains. It is also limited on space if you ever plan to pack a lunch or something. I also found that the shoulder straps cut off blood flow to my arms. Osprey and wingnut are good packs to look at if you have the same issues i have had. I have since threw in the towel and started making my own packs.
    Meatbomb
    H.A.W.G. ... does not weigh much more and you are not limited
    Closekids.com
    Reputation: BoomingSooner's Avatar
    I own both
    Bought a NV to replace my old CB. I didn't realize the weight difference. Loaded up, I bet it weighs 10-14 lbs anyway. But you can definitely tell the difference with the air circulation around your back. I believe the lack of circulation from previous models contributed to bonking, which led them to make improvements.
    I could be wrong and am sure there are other great packs out there.
    Me to my riding buddy, "Want to ride this afternoon?"
    Him, "I can't. I have to chop this guys foot off at 2".
    Meatbomb
    wow.. a 14lb MULE must have a lot of stuff in it.
    Closekids.com
    Quote Originally Posted by Phillbo View Post
    Well I didn't weigh it, but 6.5 lbs of water plus 2 lbs for the bag was my starting point. Didn't seem to have far to go.
    Tucson, AZ
    Reputation: azepicriderandrunner's Avatar
    Quote Originally Posted by jimfab View Post
    +1 Osprey packs are the best.
    Rhino
    Reputation: urbanseeds's Avatar
    Osprey (manta series) gets my vote. Love my Osprey. I carry it nearly empty and packed full and it's the most versatile pack I own.
    Wait, what!?
    Reputation: Enduroblood's Avatar
    Nov 2007
    I know this thread is probably close to dyeing out, but I wanted to ad this. Its awesome, and I use it with my Mule NV
    http://www.camelbak.com/Sports-Recre...rsion-Kit.aspx
    Follow up-
    I have been running with this for a month + and thought I would give some feedback
    I really like the pack. The ventilation system is good. It holds plenty of gear and grub. The mouthpiece/bite valve seems a little weak and I may try and switch it out with a camelback.
    I really like how light it is compared to anything else I found and ventilation seems superior to any of the newer or older Camelbacks when comparing in the field with a few guys I ride with.
    Thanks again for the all the input and feedback
    Dan
    Reputation: woahey's Avatar
    Quote Originally Posted by Raybum View Post
    I may be interested in this...
    The secret to mountain biking is pretty simple. The slower you go the more likely it is you’ll crash.
    - Julie Furtado
    Reputation: cstem's Avatar
    Quote Originally Posted by Old ROMPer View Post
    Follow up-
    Dan
    Which one- the Vaude? And which model?
    I am a slim build guy- and I find that many of the packs I have to take in all of the slack to get any fit then they feel a bit weird- anyone else like me? (If you are too much like me I am sooooo sorry for you!)
    Vassago Cycles, Shadetree Bikes, Flat Tire Bikes, Galfer Brakes USA
