Results 1 to 64 of 64
    bumble
    Reputation: bumble's Avatar
    Feb 2007
    Attempt at "Which tires" Question
    I have been searching the forums for a couple of weeks now. I did not really get a good answer, but with so many variables I did not expect it. I do, however, have some more experience on my present tires and if my observations make sense, maybe I can get some recommendations to think about? I ride SOMO mostly (Javelina, Mormon, National), also T100, Hawes, McDowell Mts. I am 150 lbs, I ride a Iron Horse Hollowpoint MK 3 with DW-Link that I like. Recently wore out Weirwolf tires, 2.35. I am running Weirwolfs, new ones, 2.1 size, and I have them at F/R 25psi/29psi, tubes. Now I am washing out constantly, front tire squirms, took off some skin on a curve that I would never have fallen on before. I am riding more aggressively now, but not at all racing level. Is it the new Weirwolfs, or the size change that may be causing my problems? They do not feel at all secure any more like the old ones. I want uphill traction, I am not very concerned about speed, but my speed on Desert Classic and McDowell Mt is causing me to gain scars. I don't do real DH, but I do like the downhills on Mormon and National, but I don't drop more than 1-2'. Help??
    To choose doubt as a philosophy of life is akin to choosing immobility as a means of transportation.
    Reputation: tmarkos's Avatar
    tire size. 2.35 is as small as I would go for where you ride. I like 2.5's better.
    Reputation: Casual Observer's Avatar
    Quote Originally Posted by bumble View Post
    Are you left handed, or right handed?
    Nobody gives a s#$t you singlespeed.
    bumble
    Feb 2007
    Sounds about right, tmarkos. I wonder if anyone has experience with the Geax tires, or Maxxis? Or should I just stick with larger Weirwofls? I think the larger Weirwolfs are pretty heavy, now.
    bumble
    Feb 2007
    I am ambidextrous, but I lean heavily toward right-handed.
    I've been riding maxxis for the last 10 years. No plan to change.
    Shovel Ready
    Reputation: Cycle64's Avatar
    I mostly ride the PMP area.
    2.4 PURGATORY GRID UST up front.
    2.3 ESKAR2 GRID UST out back.
    Great combo for me. Weight more than you. Ride a Specy Enduro tubeless.
    Currently at Mayo Clinic being tested for a kidney transplant. Donors welcome.
    bumble
    Feb 2007
    tmarkos, which Maxxis? so many models!
    bumble
    Feb 2007
    Cycle64, thanks. The pattern here looks like mine go back and I get larger size.
    Reputation: supermoto's Avatar
    Maxxis Ignitor 2.35 rear, Maxxis minion EXO front. I have yet to try a WTB or any other tire that stands up to the variety of our terrain (hawes ball bearings to SoMo chunk), as well as the Maxxis..
    Reputation: cstem's Avatar
    Sounds like the issue is the width. Rim width plays a part in how the tire will profile from edge to edge. I would measure your rim width at the inside of the beads (preferable if the tires are off-but outside is doable too) and compare that along with what tire size and style others recommend.
    Changing tire brand/tread pattern/volume/size etc also affects your suspenion settings too. You may want to play with that a little. I know it sounds hokey-but this is all taken from the motorcycle world where I learned a lot as a racing tire vendor a few years ago. Other factors to make your head spin is sidewall contruction/stiffness etc.
    My choice on every XC up to 4 inch bike I have ridden thus far is Maxxis Larsen TT, Ignitors (on front only for me) and High Rollers (especially on my old 29'r). I weigh anywhere from 140-155 over the years, ride pretty quick and technical, but am a "floater" and not a "basher" allowing me to run a 2.1 in the front and 2.0 in the rear without pinching or tearing on tubeless setups. If you can't tell- I kind of geek out on bike setup! Great setup can make a great rider awesome and overcome many of a bike or riders other shortcomings.
    Vassago Cycles, Shadetree Bikes, Flat Tire Bikes, Galfer Brakes USA
    Maxxis are amazing tires.
    bumble
    Feb 2007
    supermoto,
    So the minion EXO is more of an all-mountain than a DH? I have been looking at the Ignitor. What size up front?
    bumble
    Feb 2007
    cstem,
    Geeking out on setup is what I want. Thanks! See, that is what gets me. You like the Ignitor up front, supermoto likes it on the rear. (Don't go there ). There are so many combos I could try, just not so much $$ to do it with!! I think I am more of a floater, but I also need a lot of work on getting better, too. More riding!! I will check out the Larsen, and the High Roller already has a great rep!!
    Break it, Fix it, Ride it
    Reputation: Dag Nabbit's Avatar
    Panaracer Rampage 2.3 up front always for me. I love that tire! Knobby and solid. You can hardly kill it doing XC. I can put about 1500 miles on one tire. For the rear, Exiwolf/Wolverine have been fine, but I also liked the GEAX Saguaro and Specialized Fast Track - they looked pretty similar, but wore much faster than the Rampage - probably only 800 miles or so. They climbed just fine for me. SoMo is my home mountain, and where I ride the most.
    Today's the day I eat bikes.
    I agree. But maybe that makes them safer?
    Try a 2.5 Maxxis Minion DHF EXO (60A durometer) up front, and a 2.35 Maxxis High Roller I in back. Maxxis tires are skinny(except for the Ardent), so don't worry about those big numbers.
    I've even seen recommendations to run two Minion DHF's. For where you ride, I would consider that. I'm in this camp:
    Shovel Ready
    A 2.5 Maxxis is like a 2.3 Specialized. I have yet to find a Maxxis tire that is the actual size they claim.
    Reputation: DonRastafari's Avatar
    Take all tire advice with a grain of salt. You have no idea if that person rides like you or has any idea what they're talking about. That said, I just started running Larsen 1.9 in the rear, switching over from Weirwolf 1.9. Been running Larsen 2.35 up front for a year, very good for me. For the record, the micrometer says the front is 2.29 and the rear is right around 1.80. So they are a little smaller than advertised. I ride a lot so I rarely pay over $30 for a tire. Buy some different ones on sale and try em out. Everyone I race motorcyles with loves Maxxis Desert IT's but I can't stand them on my bike. Don't know why, they just don't work for me. You never know til you try it for yourself.
    a real Dirkbag!
    Donrasti is right on there. Individual techinique is as big a factor as anything.
    No Clue Crew
    Apr 2005
    While it's true that tires are personal, I think you'll see a trend with riders on similar trails: Maxxis and/or Specialized. Personally, Maxxis Minion DHF 2.5 Exo 3c on the front; either Ignitor LUST 2.35 or High Roller LUST 2.35 on the rear.
    74 & 29 pilot
    Reputation: MTB Pilot's Avatar
    Oct 2010
    Quote Originally Posted by Cycle64 View Post
    +1...Couldn't agree more...EXACTLY...etc, etc.
    MTBP
    MTBP
    "GIVE ME LIBERTY OR GIVE ME DEATH!"
    Turn on the truth: http://www.ronpaulchannel.com/
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    I have to throw my $.02 in and suggest my current setup, selected for performance/cost/longevity. I run Kenda tires on all my bikes, main setup is a SB8 DH casing on back (2.35) with a Nexcavator up front (also 2.35). Hooks up amazingly well and the Nexcavator has saved me from more "oh crap" moments than I care to admit. FWIW, I got to try out the Weirwolf when the TCS casing was being released and I really liked it in the loose, gravelly stuff but it kinda suffered in the embedded rock sections. I think it's one of the best tires out there but not necessarily for our conditions here. Oh yeah, while my setup works great for me here in Phoenix it was downright scary in Flagstaff! Rear wheel needed something more aggressive (Excavators are my "Go To" tires for that)
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
    bumble
    Feb 2007
    Wow. This is all very helpful!! And I knew up front that different riding styles will get different results, but I kind of needed a place to start, and this is a great place to start! I am definitely ditching the 2.1's, as I did feel better with the 2.35, but I know things will change when I go to a new tire. I will be looking at sales for the next few days to pick up something new. Also, I want to go tubeless as I know I want to air my tires down, because that has worked well for me in the past. Just getting too many pinch flats with more aggressive riding. I think I may try some Maxxis tires, and look for some others on sale to try. Looks like a busy summer!
    Lot's a great advice here. personally, I ride minion DHF on front and rear. They're a bit heavy but I don't ever flat and that's more important to me.
    I love bike!
    Reputation: dsittman's Avatar
    Another +1 for Minion DHF. I actually use it for a rear tire and it hooks up nicely in our conditions. I run a Speshy Butcher in front which is pretty much a replica of the DHF. Seems like lots of manufacturers have a twin for the DHF and I think there's good reason for that...it works.
    bumble
    Feb 2007
    So even though Maxxis says to use the DHR on rear, you all use the DHF on the rear also? And 2.5 front, 2.35 rear? This may be a setup I can start from and see how it works for me.
    bumble
    Feb 2007
    What is the difference between using the Minion DHF or the Highroller on the rear? Or is it just riding style/preference?
    I think HR are a bit lighter. I doubt you would notice a difference in traction.
    bumble
    Feb 2007
    They seem to be the same weight from their web site, but the tread patterns are different between the DHF and DHR.
    I accidentally mounted a High Roller backwards on the rear on my 29'r SS. It was slightly used as a front and it handled great until you trailbraked into flat granite turns. Then it would step out which was kind of cool-like backing it in on a supermoto- but only if you wanted it to/were ready for it! (Let me edit this before I get flamed for skidding-not locking up the tire at all, it would just step out in a little slide which still probably is not great for trails) Personally I did not like it on the front at all for my style of riding.
    Shred...it's the new drug
    Reputation: latedropbob's Avatar
    Just mounted two brand new DHF's on my DH bike...so stoked on new rubber...so stoked. I see a lot of tires and tire fails...My best bet is DHF #1, High Roller #2, Ardent #3, Nevegal/Nexcavator/excavator #4. Go tubeless as well...
    bumble
    Feb 2007
    cstem, sounds like fun. Just one more way to optimize the experience!
    bumble
    Feb 2007
    latedropbob, it is very interesting to me that the recommendations for an all-mountain tire is actually a downhill tire. I am also interested in the Ardent, and I still wonder with all the awards and recommendations, why the Nevegal comes up so few times in my searches, for our conditions?
    Reputation: woahey's Avatar
    Quote Originally Posted by tmarkos View Post
    Going from Highrollers to DHF front and back, there is a noticeable difference in traction. The Highroller is great in a downhill setting if you really throw your bike into corners but don't try to take a corner half @$$ed because they wont- they like it all or nothing. If you ride a lot of off-camber stuff the highroller may not be for you. I've heard this has changed with the new HR 2. The DHF's are a phenomenal tire and offer great, even traction. The only downfall is that they are a little slow going uphill, but 2 seconds after you've pointed downhill and its all worth it. I ride them tubeless at around 18-20 psi.
    The secret to mountain biking is pretty simple. The slower you go the more likely it is you’ll crash.
    - Julie Furtado
    Oct 2010
    I have two wheel set ups that I have used in all the locations you listed. One is a Trail King 2.4 both wheels on Flows. I have the back tire reversed for traction. Love them and this is my favorite wheel set. I also have Trail King 2.2's on both with Mavic 819's for my lighter trail/XC runs. I run the rear in the normal position for this one (although I will change it when I wear the tire out). I love the Trail Kings. I have done long XC, AM, and DH with the tires and am very happy. I run both sets tubeless with the UST Trail King tires and would never go back to tubes.
    Shovel Ready
    Interesting so many seem to like the Highroller. I thought it totally sucked on the loose shale at PMP.
    N/A
    Bob & Ken - which casing Kenda tires are you using? I've had extremely bad luck with single-ply Kendas. As in, I get about 3 rides out of them before slicing a sidewall. And their older tubeless casing used to separate when using sealant and was also unreliable for me. Are the newer casings more tolerant of mounting tubeless with sealant?
    I've had much better luck with Specialized tires. I've really been liking the 2.3" Clutch. It's a little slow rolling as a rear tire but great as a front. Haven't had one die prematurely yet. Planning to try the Butcher but still burning through my tire stash. The 2.2" Purgatory was OK as a rear tire when new but after the tread starts wearing a bit it started breaking free with no warning on high-speed braking in loose over hardpack.
    How much further ???
    Reputation: Douger-1's Avatar
    Anybody try out the new Hutchinson Cobra? Supposed to be designed for dry conditions, comes in Tubeless ready and had "hardskin" puncture protection. Im wondering how this tire would work for a rear paired up with a DHF exo on the front for a good AM setup.
    Hutchinson Tire : COBRA - HARDSKIN
    “Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did." Mark Twain
    Reputation: JoePAz's Avatar
    May 2012
    Hey I have tire question. I need tires for my 26" hardtail XC bike. I run tubes and wore down on old Hutchinson scorpion airlight . Tire worked, but wore the tread down. I put on some 10 year old IRC mythos XC. I had these stored up for years. Like the grip and the weight, but I have beebread ripping lugs off the rear like crazy. I have done about 45 miles and have ripped off 20% of the rear lug on toe rides. On here in north phx and another in flag yesterday. Now clearly some of this could be just tat the tires are old. However I can't replace tires every 50 miles. I was running 35 psi and I am only 155 lbs.
    My bike is light at 23lbs so I want to keep to 500-600g tire in 2.0 to maybe 2.2. My Hutchinson were 2.0 and the mythos ar 2.1. Kenda small block 8 maybe?
    Joe
    '12 Santa Cruz Highball 29", '13 Santa Cruz Solo 27.5",Vassago Verhauen SS 29" XC, AM, blah blah blah.. I just ride.
    No Clue Crew
    Apr 2005
    I've got a set of Schwalbe Nobby Nic takeoffs you might be interested in. 26x2.25, less than 600grams per tire. Send me a PM for details.
    74 & 29 pilot
    Oct 2010
    Quote Originally Posted by mtnbkaz View Post
    The Butcher is AWESOME and like all special ed tires, they measure to advertised size. I love the Purgatory 2.4 on the front for my AM. I've got Maxxis DHF and HRs on back-up with some use, if anyone wants to buy...
    MTBP
    MTBP
    74 & 29 pilot
    Oct 2010
    Quote Originally Posted by Douger-1 View Post
    Have one on the back now for about 25 miles. Like the traction for climbing and cornering, but doesn't come close to advertised size.
    MTBP
    Attached Thumbnails Attached Thumbnails Attempt at "Which tires" Question-img_0765.jpg
    MTBP
    Reputation: Bones2's Avatar
    Trail King 2.2 UST with Black Chili compound. Run tubeless. On Stan Flow rims until last month now on easton haven carbons.
    They are at least as big as my friends 2.35 nevgals. I have used these tires since the purchase of my bike in August (Mojo HD) and on my second set of tires. They have given me great traction on everything from Trail 100, National, Moab, BCT and Sedona. I like them better then my Captain Controls on my old bike. I really dont have alot of exprerience with other tires, but traction has never been a problem either in technical climbing or turns. and in 10 months of riding I have NEVER once had to stop on the trail for tire issues. They mounted easily onto the flows and havens (bike shop tried a set of the current non TRL protection TK and they had problems mounting them on the flow rims, so went back to UST) They like low pressures. I have sometimes wished I had some lighter true cross country tires for days that I am out on the BCT but I am afraid I will compromise traction or have tire problems on the trail. So I got a pair of used Carbon wheels and kept the heavy tires.
    EDR
    Reputation: eatdrinkride's Avatar
    Jun 2005
    Quote Originally Posted by Bones2 View Post
    Trail King 2.2 UST with Black Chili compound. :
    I'm always looking for the next tire.
    I've searched but everything I've found states that Black Chili is only availble with the 2.4ust, not 2.2. Are you sure about the size of your tire?
    From Comp Cyclist website:
    The 2.4 version uses Black Chili rubber compound on the tread, with carbon black rubber sidewalls
    The Trail King UST 2.2 does NOT have Black Chili rubber on the tread and the APEX sidewall.
    Quote Originally Posted by eatdrinkride View Post
    Yes, since about last August. It's on the box.
    bumble
    Feb 2007
    This has turned into a great thread! I am still trying to choose, maybe the Trail Kings or the Minions. Still wondering that many have the DHF on front and rear, but don't have the DHR on the rear.
    Needless to say the DHR wasn't the best tire. The DHR II has been released and the tread pattern has been totally re-worked. The complaint's I read about the DHR is that it was a little squirrely under heavy braking and didn't provide good traction when climbing.
    The DHF has been a great tire for me front and back. It has great traction all-around and is predictable.
    - Julie Furtado
    bumble
    Feb 2007
    woahey,
    Thanks for the clarification. That helps a lot.Then I am leaning toward trying the DHF front and rear. So many like it. I hope it is not too slow for XC and uphill, but really I am not racing, so slow is ok as long as I stop falling off the bike in sandy/hardpack sweeper turns.
    EDR
    Jun 2005
    Just ordered a 2.2 ust TK. No idea if it's Black Chili or not, we'll see. It'll be for the rear so a little smaller is ok...I've heard it's "a large volume 2.2". I now see they list an ETRTO of 55mm, now I'm concerned it's too narrow.
    If you have nothing better to do with your evening and you happen to have digital calipers/micrometer could you take a measurement of the casing only and a measurement at the widest point of knob to knob?
    thanks
    EDR
    Jun 2005
    Got my TK 2.2 UST today. It is indeed a Black Chili. thanks.
    Please let me know what you think compared to what you have ridden before.
    EDR
    Jun 2005
    Will do. Not sure I'll mount it today or let my Fat Albert run it's course first. I really hate the 2.35 FA's for riding out here so maybe I'll ditch it today and keep it as a backup.
    I just mounted my first 2.5 Minion DHF on the front(60a durometer). It was a bear to get it to seal with a floor pump. It's the first tire I've mounted that I could get to inflate to 20 lbs, i.e. it was holding air, but then would not seal up. I thought there must be a hole in the sidewall, but the air was leaking out of the bead in one spot. After several attempts and lots of sweat I finally got it to inflate to 40lbs.
    Then what I do is, I deflate the tire while being careful not to knock the bead off the edge of the rim, remove the valve core, add Stan's, replace the valve core, then reinflate. Usually, it's really easy to reinflate the tire because the bead is already in place on the edge of the rim. But not with the DHF. It was like starting from scratch again. After a lot of tire lever work, and many attempts at inflating the tire, I finally got it to hold air. What a work out.
    I did some requisite shaking, then I went for a ride. The tire didn't feel heavy compared to other tires I've been using on the front, e.g. 2.4 Conti Mountain King, 2.35 Maxxis High Roller, 2.35 Kenda Nevegal, so it felt fine climbing. And the tire doesn't look especially fat up there.
    bumble
    Feb 2007
    happyriding,
    That was very informative for me. I have ordered a set of Maxxis Minions.
    That is great. I just spent like 5 hours converting my old Weirwolfs to tubeless, and had a similar experience. They absolutely would not seat, and one even has a cut n the sidewall. I will be playing with them near my house today, then take them for a ride Wednesday on Desert Classic. Then I will be on vacation for two weeks, then I will immediately change over to the Minions.
    happyriding,
    If you use an air compressor with the valve core pulled out and a little soapy water, you should be able to get it to seat pretty easy.
    - Julie Furtado
    No Clue Crew
    Apr 2005
    Yep, I set up a bunch of Maxxis tires (Minions, High Rollers, Ardents, Ignitors) on a variety of rims and never had any issue getting a tire to seat except for one tire that had a defective bead. I soap 'em up, hit 'em with the air compressor and they pop right on.
    Sissies!
    Hey, I forgot to mention this...The DHF says the maximum load is 198 lbs. on the sidewall. What the??
    The DHF held air over night, so Stan's sealed up the tire fine.
    May 2012
    Quote Originally Posted by happyriding View Post
    Sissies!
    Are you 350lbs? No then you are fine. 198lbs spread between two tires or 396lbs for the bike and rider.
    Joe
    EDR
    Jun 2005
    Re: the TK 2.2 ust. I have never been more frustrated trying to mount a tire in my life. I've been running UST or tubeless since '05, all on UST rims and have never had true UST tire that did not inflate in seconds flat. I can't get this TK to even start to inflate even with the valve core removed and full blast with air compressor. Yes, rim is fine and bead area is clean. Like I said, I'm no newbie with tubeless/UST.
    I'm about done
    I'm about done
    Sorry to hear that, they have seated up easily on both my Stans Flows and my carbon Havens. Bad batch? The old protections did not. My LBS said that they have had tires they have sent back because the bead was bad.
    EDR
    Jun 2005
    I got it now....and calmed down some, lol.
    For anyone who cares the casing is wider than the tread. It initially measured 2.1 at the casing and smaller at the widest tread area. After sitting in the sun for a few hours the casing now measures 2.21 and the tread 2.11. Pretty darn true to size on my 819.
    I like the adjacent double row of knobs running down the middle. I've had tires (like the Chunder, Minion for example) that hook up really well on our terrain. Seems to me tires with a more abstract middle row design don't grab the rocks when climbing as well.
    Hope to get a ride in this weekend, gotta work tomorrow.
    EDR
    Jun 2005
    Update on the TK 2.2
    Got a ride in tonight before the sun set out at Hawes. First impressions of the Trail King are great. Super grip on all the loose and steepest climbs out there. The tire just felt great for our terrain.
    After a few days and ride it measures 2.23 at the casing, 2.12 at the tread. Thanks for heads up on this tire. So far I'm loving it. Much much more so than the Fat Albert UST it replaced. That tire never hooked up super well on climbs despite it's knobby look. For reference my 2.4 ust Purgatory in front measures 2.35 at the knobs and 2.25 at the casing.
    If anybody is interested Bike Bling had them in 2.2 and 2.4 UST for $46. I had Jenson price match it since they were cheaper in shipping, I bought a Halo and they dropped any shipping charges even though their policy doesn't include free shipping over 50 bucks with a price match. Love that place.
    Wizza wizza wu-tang...
    Reputation: silentG's Avatar
    Is the BikeBling Trail King 2.2 tire Black Chili compound or regular compound?
    Good price but sometimes online resellers are peddling older tires and not much detail on the BikeBling site about the 2.2 as far as BC goes.
    EDR
    Jun 2005
    Quote Originally Posted by silentG View Post
    Look again, I see it in the 2.2 description:
    Continental Trail King Kevlar Tire from Bike Bling
    "Special blend of extra soft and tacky Black Chili compound. Apex reinforced sidewall protects and stabilizes at heavy lean angles. Additional material placed above the bead to reduce pinch-flats and stiffen the sidewall. 2.2 version for demanding trail riders"
    I now see that the UST description does not mention black chili for the 2.2, I'd call them. FWIW Jenson didn't mention black chili but that's what I got from them.
