Results 1 to 8 of 8
    Zoic Ether sizing
    Want to try out the Zoic Ethers, but I'm right between sizes and not sure if I should go medium or large.
    Any input on their sizing would be great.
    I'm 5'10" 171lbs with a 33 waist (probably more like 32.5). Losing weight still, maybe down to 165 in the next month or so.
    Reputation: chadalex78's Avatar
    Oct 2011
    Im a small 34 and got a large... They fit.. Have plenty of room to tighten with the adjust straps..
    Reputation: InvictaS1's Avatar
    Mar 2005
    get the size large shorts. i'm about your size and the large fit fine.
    Thanks for the fast replies :-)
    I'm ordering the large.
    As a follow up.
    The large was wayyy too big, exchanged for mediums and they fit much better. Had to tighten the waist adjustments most of the way even with the mediums.
    Yup - - mediums for sure. Ive got a 32/33 waist and the mediums fit me perfectly.
    May 2005
    Quote Originally Posted by moldau94 View Post
    Ditto here as well
    2013 Banshee Spitfire V2 650b
    Medium will work fine. Same size here.
