Results 1 to 21 of 21
    What are the stiffest flat shoes? Stiffer than 510's?
    Hi All - what are the stiffest flat shoes you know of?
    I like to ride flats - thats a whole story in itself because I have heard a 1000 times to get clipless.
    But anyway - i need stiffer flat shoes than the 510's I am riding with? Any suggestions?
    I have a foot pain that I think is called metatarsalgia where you get this pain in the forefoot and I think stiffer shoes would help more. I already wear a solid arch support with the current shoes
    any help is appreciated!
    Reputation: 'size's Avatar
    which model 5.10 are you using? they vary in stiffness for sure. my shimano am40's are pretty stiff and they come with an insert you can add or remove to change the stiffness.
    how old are your 5.10's?
    mine got softer after a couple of seasons...
    i looked around and couldnt find anything stiffer than the 5.10's and my new ones are substantially stiffer than the old ones...the karver's with the mud gaurd over the laces seem to be the stiffest.
    thanks so far
    I have the "impact" model right now and they are a little more than a year old or maybe 1500-1700 miles of riding
    Quote Originally Posted by surftime View Post
    thanks so far
    you might just need a new pair....did they bother you like this when they were new?
    i did an in store flex test against the shimano's and the 5'10's were noticeably stiffer.
    and perhaps a full length stiff insole with arch support like a 'super feet' or something.
    ya ill check into new shoes and somehow getting them stiffer. A stiff full length insert might be enough - i bet Spech makes one.
    the problem came up after picking up running in addition to riding and since has been hard to get rid of though its not really that bad now - i just want to get rid of it totally
    Reputation: Mr. 68 Hundred's Avatar
    I run and ride w/ Impact's as well. Finally starting to get a handle on some ongoing foot issues (metatarsal tendon issues on the left foot from fore-foot striking; plantar issue on the right foot from high milage on angled roads while heel striking). Getting better with mid-foot striking and foot massage. I roll my bare feet on a baseball to work out the sore spots. Doing this will probably hurt A LOT at first. Do 3 days on, rest 2 days, 3 days of massage, rest 2, etc. If you're having an issue similar to mine, it will get better (even though it hurts a lot at first).
    active dot com had the foot care article I got my information from.
    Steve
    Proponent for an Evidence Driven Life.
    Occupation: Disposable gene transfer machine
    Current HTFU status: 4/10; increasing
    Reputation: qbert2000's Avatar
    wooden clogs?
    Quote Originally Posted by qbert2000 View Post
    wooden clogs?
    they would be stiff....
    +1 on new 5.10's. They do soften up over time.
    Also, don't forget about your pedals, as larger pedals offer more support than smaller ones. I've been riding Spank Spike pedals for about a month now, and the supersized platform feels great underfoot.
    ill check it out, i emailed 510 to ask them but like most manufacturers have not gotten a response yet
    superfeet make some good stiff insoles...
    Superfeet Premium Insoles : Green : Insoles for all of your footwear and activities. Skiing, hiking, running, soccer and work.
    Quote Originally Posted by albeant View Post
    +1 on the big platforms... i rde the dmr vaults and they have a huge 115m squared platform.
    Carbon fiber insoles. I put them in a pair of Bogs for snow/ice riding. This is a wholesaler site, but most orthotics shops have access to them and will cut them to size...
    Atlas International Product Catalog
    Not saying you need these shoes for your application, but here are the Bogs I use for winter riding...
    Jamison - 52406 - Bogs Footwear - The Official Website
    Reputation: beer_coffee_water's Avatar
    Mar 2011
    Maybe you could get crazy and get a SPD compatiable flat shoe, it would seem they would be the stiffest thing you could get. 5.10's have Hellcats and Maltese Falcons, Shimano's AM45 also. Each of these shoes should have very rigid midsoles. The older Shimano MP-66's soles are a foam insole, plastic midsole, and rubber outsole. I can feel the pedals pretty well through mine I just wish I didn't pull the SPD cover off, its a one time deal. Just an idea to consider.
    Jan 2009
    you say your problem first appeard after you took up running,,, are you wearing a decent running shoe when you go out running,
    everyone has differant requirements from a shoe, as not all feet are the same, ideally you should see a shoe fitting expert to asses your individual needs,
    se info below.
    Choosing a Shoe: The Very Basics - Shoes - Runner's World
    Guide to Choosing the Best Running Shoes for you
    this info should give you a rough idea of what i am refaring to,,,, hopefully this will help to adress your problem, good luck, hope you get it sorted.
    thanks, yes i have good shoes and arch supports from a running only store that are made for my style and stride. What happened was during the summer i was riding, running barefoot in sand, surfing and skateboarding -it was like going 0-60 with my feet and thats what got it all started
    Quote Originally Posted by delirian View Post
    se info below.
    The 5.10 chase is quite a bit stiffer than the freeriders and line kings I have had in the past. They are much lighter than my impacts as well. For DH and riding in nasty conditions, I go with the impacts every time, but if I was going out on a long pedal and ultimate grip wasn't my biggest priority, the chase does great. If you put some green superfeet or a carbon insole in them, you would have a full on clipless stiff shoe. FWIW I wear a 10 in the impact, and a 10.5 in the chase. And yes, over the past few seasons I have had a pair of freeriders, line kings, impacts, and chases, so i have a perspective of the whole line.
    Thanks for the advice - i was looking for something a little lighter so I will check that model out with a set of insoles i should be good!
    Quote Originally Posted by 300hp View Post
    Reputation: walkertalker's Avatar
    Dec 2011
    Quote Originally Posted by beer_coffee_water View Post
    If you still have the inserts you could glue them back in with silicone glue or bathroom sealer. Or if you have ditched them you could fill the whole up with the said silcone. You can get it in any colur if you search.
    Dec 2011
  1. Big feet, need shoes
    By Ultra Magnus in forum Apparel and Protection
    Last Post: 02-25-2012, 08:00 PM
