Results 1 to 10 of 10
    Oct 2013
    Sunglasses with a foam strip?
    I hope I'm not the only one with this problem. Sweat runs down my face from my helmet and onto my sunglasses. Obviously it obscures vision. I also wear clear lenses during evening descents. So sweat rolls down my face and onto the lens. Can you recommend a brand of sunglasses with a foam strip on the top? Any other suggestions? A bandana under the helmet?
    Thanks,
    Jake
    Trailhead Poseur
    Reputation: jjaguar's Avatar
    Oct 2011
    I find Halo headbands to be pretty effective. They're a neoprene headband with a rubber strip that runs across the bottom, which does a good job of channeling sweat away from your eyes after the band itself becomes saturated.
    Speed solves all problems, except for those things it makes worse.
    Reputation: d365's Avatar
    +1 on the Halo sweatband, as the answer you seek.
    Reputation: Tim-ti's Avatar
    Oakley just re-released some 'retro' styles, and the Factory Pilot had a foam strip.
    That being said, I join d365 and jjaguar in recommending a sweatband or helmet liner. I prefer helmet liners over headbands.
    "...DirtBaggies may also be the best baggy mountain bike shorts on the market." Velonews - Click to check out other reviews.
    EDR
    Reputation: eatdrinkride's Avatar
    Jun 2005
    Re: Sunglasses with a foam strip?
    Halo. Carry a spare or two in hot weather and swap them out as you ride. I just tie them to the back of my pack and by the time I need it again it will be dry.
    A regular cycling cap moves the 'drip point' out far enough that it stays out of eyes. Sometimes it'll get blown or knocked onto my glasses but generally falls clear . The halo works well also, but i find that they leave a pink groove across my forehead for quite a while after so the cap is my preferred.
    now, if I could figure a way to keep my toxic sweat from staining my raw frame..
    Getting a little off topic, but toxic sweat can be a real problem - I've seen bikes break because the salt has eaten through the aluminum frame tubes. Rinsing your bike could actually be a safety step, Kark; and a painted frame will last longer (paint is protective as well as cosmetic).
    Quote Originally Posted by Tim-ti View Post
    True, and thanks for the cautionary tale. I'm pretty confident about keeping it to cosmetic, at least so far, but I can well appreciate the concern.
    I've never heard of failures from sweat myself but have heard accounts of damage caused by sport drinks around the pem-nuts for bottle cages.
    Mar 2013
    I had the Oakley factory pilots back in the day with the foam strip. Did nothing for me. I have a Sweat Buster on one of my helmets and it works really well. Tried a rubber gutter type headband years ago. Meh.
    Reputation: arphaxhad's Avatar
    Quote Originally Posted by d365 View Post
    Another halo lover. They come in lots of styles, sweatbands, skullcaps etc. I have a great one with ear flaps for winter. They wash up nicely too.
  1. Foam Grips?
    By kyle10bike in forum Weight Weenies
    Last Post: 01-11-2013, 05:21 AM
  2. Foam pit/Airbags in CO?
    By Super Bajones in forum Colorado - Front Range
    Last Post: 08-02-2012, 05:16 AM
  3. Where to buy new foam rings?
    By JonathanGennick in forum Shocks and Suspension
    Last Post: 04-20-2012, 06:02 AM
  4. foam pit
    By StonedEagle99 in forum General Discussion
    Last Post: 04-26-2011, 04:41 AM
