    Padded Liner AND Compression wear?
    Is it ok to wear compression wear as underwear, then a padded liner on top of that (then finally baggies on top)?
    Reputation: junior1210's Avatar
    If you're comfortable riding like that, then yes it's fine. Just be forewarned that you may find that set up to be binding, as well as causing overheating.
    The ridiculousness of cycling clothes increase exponentially in relation to the distance from your bicycle.
    Trailhead Poseur
    Reputation: jjaguar's Avatar
    Oct 2011
    I agree, try it and see if it's comfortable for you. I'd think all those layers would be too hot, but then again I'm a Florida rider. Don't know what sort of climate you ride in.
    Ok, so I tried out this combination on a 10hr hillclimb/descent. Halfway up the hill, I took the padded liner off from over my compression wear. The compression wear does a great job keeping you cool and your legs breathing, and I think the liner inhibited this. So my legs felt better, but my backside got sore because of the lack of padding afterwards.
    I think the next upgrade for me will be a softer saddle
  1. 661 padded compression short review?
    By MTBCanuck in forum Apparel and Protection
    Last Post: 01-03-2013, 03:30 PM
  2. Everyday wear compression shorts w/o chamois - Suggestions?
    By Bobby12many in forum Apparel and Protection
    Last Post: 07-25-2012, 05:08 PM
  3. Padded compression shirts
    By stevehollx in forum Apparel and Protection
    Last Post: 05-20-2012, 01:40 PM
  4. Unobtrussive compression shirt/padded shirt
    By MTBCanuck in forum Arizona
    Last Post: 05-19-2012, 09:23 AM
  5. found a solid pair of padded compression shorts
    By hanklr in forum Apparel and Protection
    Last Post: 04-16-2012, 01:20 AM
