Results 1 to 3 of 3
    UFO Bike Commander
    Reputation: K'Tesh's Avatar
    NiteRider SolMate Helmet Mount problem
    Last week, I bought the new helmet mount for my MiNewt X2 (its the same mount as you get in the SolMate). It was difficult to adjust the light as the O ring was so tight, and when I opted to take it off, the O ring got sliced. I returned the mount immediatly.
    I wish that NR would create a MiNewt/TriNewt adapter so I could use the older Universal style mounts
    NR did send me a replacement O ring.
    Cya out there.
    K'Tesh
    beam(dot)to/ufobike
    Quote Originally Posted by K'Tesh
    Cya out there.
    K'Tesh
    I found it extremely hard to work with as well.
    ballbuster
    Reputation: pimpbot's Avatar
    So...
    Cya out there.
    K'Tesh
    ... Can this cannot be mounted with the regular NR mount? At least is the base removable with a 10/32 screw like the other ones? I'm thinking maybe a base transplant to use the NR mount.
