    > /dev/null 2&>1
    Reputation: Procter's Avatar
    Feb 2012
    Neck Braces: Moto vs. MTB
    Is there any reason not to use a Moto neck brace for MTB?
    I checked as many of the 'neck brace' threads I could find. One guy suggested an MTB neck brace is lower in back allowing the head to tilt back a little further, for better visibility on steep downhills. Makes sense, but I wouldn't mind some extra protection from rearward rotation anyways, I think I could live with it being less than ideal on steeps.
    Also, aren't moto helmets generally higher volume than MTB helmets? Therefore, higher back on a moto neck brace, combined with smaller volume on the back of an MTB helmet, might net out to the same angle for maximum head tilt-back.
    Anyone have any experience with this?
    Thanks & Reps!
    Reputation: Swissam's Avatar
    Moto braces are unsafe for the same reason you mentioned above. You cant tilt your head back. Can you really live with not seeing the trail? I had one of the first leatt braces before they made a MTB brace I can say from personal experience they are completely unsafe.
    > /dev/null 2&>1
    Feb 2012
    Re: Neck Braces: Moto vs. MTB
    Ah, so you're saying that the fact that the head can't tilt back as much with a moto brace is more than just inconvenient, it's dangerous because it limits visibility significantly. I see your point, thanks for the advice.
    Is it that bad though? Does the smaller volume mtb helmet counter that at all?
    I used mine with a MTB helmet and sometimes you can only see a few feet in front of you. There's not enough time to react. My advice I'd to get a MTB brace and helmet.
  1. neck braces (again!)
    By stepchow in forum Apparel and Protection
    Last Post: 02-05-2014, 07:17 AM
  2. Neck Braces
    By hwangnyc in forum Beginner's Corner
    Last Post: 10-23-2012, 01:33 PM
  3. Neck Braces
    By cyclelicious in forum Downhill - Freeride
    Last Post: 08-24-2011, 08:06 AM
  4. Neck Braces
    By srebeccan in forum Apparel and Protection
    Last Post: 07-26-2011, 04:32 PM
  5. neck braces.............
    By SHIVER ME TIMBERS in forum Downhill - Freeride
    Last Post: 07-18-2011, 09:55 PM
