Results 1 to 26 of 26
    Dec 2013
    Good job! Lightweight and well vented full face helmet
    Hi. Im looking at a full face helmet for all mountain / single track riding.
    I want a well vented helmet, because i pedal up as well, and of course want it as light as possible.
    Practical things like removable padding and so on is also good.
    If the helmet is too heavy and warm, im afraid I wont use it as much as I should, and rather use my well vented XC helmet...
    Any advice?
    The first helmet that I found was the Urge Archi-Enduro helmet, but after i found out that the front "arch" at the mouth guard was just foam I became skeptical.
    Lightweight and well vented full face helmet-2012_mtb_helmet_archi_enduro_racing_white.jpg
    After some research, I now have found a couple of helmets I would like some feedback on.
    The following:
    The Urge Down-O-Matic Helmet:
    The 661 Evo Carbon
    The Giro Cipher:
    Lightweight and well vented full face helmet-giro_cypher_h_mtredblk_side.jpg
    All help appreciated!
    Reputation: Opinions's Avatar
    Sep 2012
    In all honesty, any one of those helmets will cook your head on a climb. What I like to do is climb with my XC helmet on and my fully strapped to my pack. But if that's a bit impractical for you, do check out Kali protectives. I use the Kali Avatar and it's super light weight, has great ventilation (as good as one can get with a fully) and great protection.
    http://kaliprotectives.com/bike/avatar
    I believe it weighs in around 800-900 grams.
    I bought a 661 evo for my brother as a Christmas gift. I put it on for a second. Its very light for a full face. No riding in it yet. Still snowed over here in Michigan.
    Dec 2013
    Thanks for the reply, guys.
    I will check out the Kali Avatar. It seems light, but it seems less vented than the Cipher?
    Im currently leaning most towards the Cipher and the Avatar 2.
    Judging by your choices, you seem to be looking at a certain price range, Have you checked out the TLD D2? that is comparable to prices of the choices you listed. I'd recommend the TLD D3, as it is lighter and more ventilated, but starting at $375 for the composite mode. Troy Lee DesignsŪ | Bicycle Helmets
    Sep 2012
    I can't really say on the ventilation of the Kali compared to the Cipher but from what I can see int eh pics of the Cipher they seem to have pretty close to the same ventilation. Another thing I will say about the Avatar is that your ears aren't smashed flat against your head like in so many helmets and it makes for a much cooler ride. Also if you are willing to spring for the Avatar 2 by all means go for it! The foam tech they have is incredible. I love how it transfers the energy of the impact around your head.
    I ended up with a Down O Matic, but haven't had a chance to try it in the heat.
    OG Ripley v2
    Carver 420 TI
    Dec 2013
    Any thoughts on the POC Cortex flow?
    Fra iPhone
    Quote Originally Posted by mykle View Post
    Fra iPhone
    Not if you're pedaling up, stay away, it's not well ventilated at all and runs hotter than other FF helmets. I have the Carbon version with MIPS and I love the fit, but I only use it for bike park/lift riding. I'd say it's too hot if you aren't moving fast.
    As I said I have the DownOMatic for my XC riding, it's pretty light and it seems like it will be well ventilated.
    OG Ripley v2
    Carver 420 TI
    Dec 2013
    Thank you. Very good input. Will stay clear of it then. Still the Avatar 2 on top.
    Dec 2010
    I have a Giro Remedy and a Specialized Deviant II. The Deviant has a lot more cutouts on top for heat to escape. I have no problem wearing it year round for trail riding in the SE US. Overheating has only been a problem for me if I'm wearing too much upper body armor and it is too hot/humid. I've looked into both of the POC helmets, supposedly the Flow breathes better than the DH. But looking at the vents compared to my Deviant I'm not sure it'd work for me on hotter days. I'm intrigued by the new Met Parachute coming out in the spring.
    Dec 2013
    The met parachute is very well vented, but looks awfull in my opinion... Maybe im shallow
    Fra iPhone
    Dec 2010
    Have you seen the 2014 version? Looks a lot better than the older one.
    Reputation: Dresdenlock's Avatar
    I used full face helmets for a long time for XC and it just does not work...its just too hot....believe me Ive tried....go and get a 1/2 helmet and it will be MUCH cooler...trust me.
    We Can't Stop Here...This Is Bat Country.
    Out Of Step.
    Quote Originally Posted by Dresdenlock View Post
    Until you land on your face and end up in the ER.
    OG Ripley v2
    Carver 420 TI
    Dec 2013
    The 2014 parachute looks very good. When will it be out and what will it cost?
    Fra iPhone
    Reputation: squareback's Avatar
    Fra iPhone
    April, and about 190 Euros (!!!)
    Quote Originally Posted by TwoTone View Post
    I use to think and say the exact same thing....full face helmets are just way too hot for xc..but try it and see.
    Out Of Step.
    Dec 2013
    Im going to try it out by buying a used helmet. Can anyone confirm that this is a kali avatar 2 and not 1? Seller wasnt sure as it had no labels that indicated the model. Good price at 105 usd.
    Fra iPhone
    Dec 2013
    last one
    Fra iPhone
    There are only so many color schemes, get on there website and check.
    OG Ripley v2
    Carver 420 TI
    Well having landed on my face and going to the ER, I have a little more incentive to deal with the heat. When I run my finger along the top of my eye socket I can still feel a bump, an inch lower and it could have taken my eye.
    Not taking that chance again.
    I'm the first to say, I'd love to try a MET Parachute, but I have to see that thing destroyed on video first before I trust it. Sort of like the Santa Cruz Carbon beating video.
    OG Ripley v2
    Carver 420 TI
    Dec 2013
    The schemes on their page was different, but it was the avatar 2. Asked them, and it was the 2012 model. Just bought it, and might try the parachute in a while when the price drops. It's overpriced in my opinion.
    Dec 2013
    Lightweight and well vented full face helmet-t28a2273.jpgCould just add a pic of the 2014 Met Parachute. Sure looks like everything i want.
    Seems like the chin guard is a 3D printed prototype though. Wonder what materials they will use...
ID:	859645Could just add a pic of the 2014 Met Parachute. Sure looks like everything i want.
    I sent them an email asking what kind of testing they did on the chin bar. If they respond I'll share it. It may be the angle of the pictures I've seen, but the chin bar seems to angle too far downward. Hopefully some reviews will be out soon.
    OG Ripley v2
    Carver 420 TI
    Dec 2005
    Fra iPhone
    That looks like an AVATAR 2
  1. full face helmet
    By Danielrg_usa in forum Arizona
    Last Post: 07-31-2012, 02:50 PM
  2. need help with full face helmet
    By ehigh in forum Apparel and Protection
    Last Post: 05-24-2011, 09:10 PM
  3. Convertible Full Face Helmet / XC helmet
    By Pimpride in forum Apparel and Protection
    Last Post: 04-15-2011, 08:42 PM
  4. full face DOT helmet?
    By RTM in forum Downhill - Freeride
    Last Post: 03-19-2011, 07:02 PM
  5. Best Vented Full Face?
    By loamranger in forum Downhill - Freeride
    Last Post: 03-14-2011, 01:17 PM
