Page 1 of 2 12 LastLast
Results 1 to 25 of 46
    Reputation: Tincup69's Avatar
    Sep 2012
    Good deals on Merino Wool base layers?
    I'm looking to try some Merino wool for a base layer instead of the synthetic stuff I have been using. Where are some good places to get some deals on it? I've searched around a little bit and it seems like Serra Trading Post has some decent deals. Anyone have any other recommendations?
    2011 Gary Fisher Advance
    2012 Salsa Mukluk 3
    http://tincup69.tumblr.com
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Tincup69 View Post
    STP is one of the best places to look.
    The Ibex site also has an Outlet page with closeouts
    mtbtires.com
    Paste eater
    Reputation: Jwind's Avatar
    Mar 2006
    Backcounrty. They have sorts fo great deals on stoic stuff. Merino rocks. Hard to wear synthetic after wearing it.
    Save Jesus
    Reputation: beanbag's Avatar
    Sports Basement has the Helly Hansen Wool / Hollow Polypropylene base layer for $48. Usually, the cheapest I see for wool is around $60.
    I'm a huge proponent of good quality Merino, and my closet/gear bag has Icebreaker, i/o bio, Smartwool, etc. from our local STP and places like backcountry.com And not to get off topic or be a Debbie Downer, but my favorite baselayer is a "dreaded" poly Craft t-shirt. For some reason it does not stink nor won't stink, and it dries about 10 times faster than my thinnest Merino. As for staying warm when wet, well, it never gets wet because it's so thin and wicks to the next layer.....which is always Merino (often a 260g item). Craft makes a cold weather base layer and a base layer for super hot weather (it's the layer you often see racers wearing even when their jerseys are unzipped. The Craft base layer is so good it almost gives polyester a good name. Nah, it's not that good. But it is good enough that I returned two smartwool base layers to backcountry.com last week. It's worth checking out if purchased from a place with a great return policy.
    Reputation: sgtjim57's Avatar
    2012 Specialized Camber Comp 29er
    2011 Specialized Stumpjumper Comp 29er
    Roll on, pedal hard
    Be warned, while it works Stoic is not the quality of Ibex, Icebreaker, I/O Bio or Patagonia. My Patagonia merino base is even more comfortable than Ibex, though not quite as warm as it's thinner and generally a better weight for cycling unless it's below freezing. Own all 5 brands, 0% fleece, it all got given away but having dogs makes fleece and it's attraction to hair a very bad thing.
    agmtb
    Paste eater
    Mar 2006
    Quote Originally Posted by abegold View Post
    Yaz, but you can often steal stoic jerseys for under 25 bucks. Might not be quite as nice as the likes of patagucci, ibex and ice breaker however that latter will run you 3x or more $$$.
    Dec 1998
    I have tried some of the wool blend base layers. Nowhere near as effective as 100% merino or as comfortable.
    mtbtires.com
    Sep 2012
    Thanks guys!
    2012 Salsa Mukluk 3
    Chronic 1st-timer
    Dec 2005
    Goodwill has treated me well for the past 5 yrs.
    Now have collected 8 100% merinos for about $60 total.
    Sold out
    Call all the local outdoors stores in your area and ask about their specials/coupons. Many stores send out coupons for a percentage off retail if you're part of their mailing list, have random sales over weekends, or have customer appreciation nights for those people on the mailing list where there is a discount. If the employee you talk to has worked at the store for a year or two (or longer) they will know when the sales typically happen and if you ask nicely they might share the inside info. There are also seasonal clearances for getting rid of that season's styles/colors in preparation for the new stuff. Unfortunately for you fall clearances rarely happen as the fall/holiday season is the best time for business at those stores and clearances are not needed. Also check the clearance racks, at the stores I have worked in it is not uncommon to find merino there.
    Also, if you buy at a local store, if you are buying a lot of stuff at once you can probably ask for a discount on your entire purchase. At the stores I have worked at if you're buying about $700+ in gear the store will give about 15-20% off the entire purchase. If you are personable and engage in conversation about outdoors stuff with the employees you are more likely to be treated well and given a good discount. So if you need some other winter gear or are buying holiday gifts you can save some money that way. Or you could just do a group buy with your friends and just send one person in to get everything on the list and then everyone gets a good deal.
    Dec 1998
    Quote Originally Posted by SDKmann View Post
    15-20% is not much when STP and the company outlet/closeout prices are 30-60% off. It does limit the selection, though.
    mtbtires.com
    No, its not much but when you're talking about 15-20% off an entire purchase for no reason other than buying things you were going to buy anyways its not a bad deal. You can get far more off the MSRP at outdoors stores through the other routes I mentioned.
    Reputation: grandsalmon's Avatar
    If you do the STP thang, go sign up for their daily deal, it will introduce you to additional % off by email. This may or may not apply to that smartwool base layer (their sleeveless are nice), or that ibex as examples, but in the last 3 weeks they both/many were applicable -one time or another. I try to never pay the straight percentage off at STP.
    When you have done your shopping (merino scrounges for me certainly), then I sign off their mailing list -deal notifier. ( I spent $28 - $38 on the SW, and Ibex. And yes their merino is nice;weave, construction.)
    Sep 2012
    Great advice here guys, thank you! I ended up ordering a few things from STP, I can see myself spending a lot of money there.
    2012 Salsa Mukluk 3
    High Gravity Haze
    Reputation: Spec7's Avatar
    May 2000
    Depending on your location and whether or not there is one nearby, don't be above checking out a TJ Maxx store for this stuff too. My local TJ Maxx has supplied me with various wool products from Icebreakers, Helly Hansen, Bridgedale, and Smartwool; all at dirt cheap prices.
    My most recent purchase was Icebreakers merino wool cycling socks for $2.99 a pair and Keen merino wool liner socks for $2.99 a pair as well. I saw some merino layering tops last time I was there for something like $9.99, but I'm not in the market for them so I don't remember the brand. I've been buying cycling/outdoor gear from them for years, so I just keep checking back once a month or so to see whats new or marked down for fast closeout.
    Aug 2010
    I have Smartwool & Ibex but prefer LL Bean merino as you can order "tall" sizing. Every bit as nice as the others and less $. The Smartwool tops feel short to me - especially on a bike.
    If you want really short-on-bike feel try Icebreaker. My favorite piece is a long sleeve 1/4 zip 260 weight Icebreaker and I feel like pulling it down to get a little more room. I'm under 6 feet with normal torso. But seeing as how it's my "90% garment" I must not care.
    Quote Originally Posted by Jinxy View Post
    Talk to me, Goose.
    Reputation: BatCountry's Avatar
    Jun 2012
    Sierra Trading Post - Great Deals. Great Brands..
    Lots of closeout stuff, 2nds, and selection. Last week they had awesome sales on baselayer lines..
    Look for the coupon code.. they normally have 20% off..
    We can't stop here, this is bat country..
    Nov 2012
    REI has sale right now. Got some smart wool. I love merino!
    You might want to check some web sites geared towards runners, lots of stuff out there if you know where to look.
    Anytime. Anywhere.
    Reputation: Travis Bickle's Avatar
    I just picked up some long sleeve merino t shirts from Costco for $20 a piece. imported fabric but sewn in Canada! A rarity these days.
    I got some bad ideas in my head.
    Nov 2012
    LL Bean looks good and gets good reviews. Offers lightweight and midweights. Tall size offering is also a plus. Can't beat their guarantee. 90$ for top and bottom with free shipping.
    Check the On-One UK website. Last time I checked, they were having sale all most of their Merino stuff.
    Envoyé de mon iPad à l'aide de Tapatalk HD
Hot Deals
Contests
Latest Mountain Bike Articles
