• 11-12-2012
    Tincup69
    Good deals on Merino Wool base layers?
    I'm looking to try some Merino wool for a base layer instead of the synthetic stuff I have been using. Where are some good places to get some deals on it? I've searched around a little bit and it seems like Serra Trading Post has some decent deals. Anyone have any other recommendations?
  • 11-12-2012
    shiggy
    STP is one of the best places to look.
    The Ibex site also has an Outlet page with closeouts
  • 11-12-2012
    Jwind
    Backcounrty. They have sorts fo great deals on stoic stuff. Merino rocks. Hard to wear synthetic after wearing it.
  • 11-13-2012
    beanbag
    Sports Basement has the Helly Hansen Wool / Hollow Polypropylene base layer for $48. Usually, the cheapest I see for wool is around $60.
  • 11-13-2012
    westin
    I'm a huge proponent of good quality Merino, and my closet/gear bag has Icebreaker, i/o bio, Smartwool, etc. from our local STP and places like backcountry.com And not to get off topic or be a Debbie Downer, but my favorite baselayer is a "dreaded" poly Craft t-shirt. For some reason it does not stink nor won't stink, and it dries about 10 times faster than my thinnest Merino. As for staying warm when wet, well, it never gets wet because it's so thin and wicks to the next layer.....which is always Merino (often a 260g item). Craft makes a cold weather base layer and a base layer for super hot weather (it's the layer you often see racers wearing even when their jerseys are unzipped. The Craft base layer is so good it almost gives polyester a good name. Nah, it's not that good. :D But it is good enough that I returned two smartwool base layers to backcountry.com last week. It's worth checking out if purchased from a place with a great return policy.
  • 11-13-2012
    sgtjim57
  • 11-13-2012
    abegold
    Be warned, while it works Stoic is not the quality of Ibex, Icebreaker, I/O Bio or Patagonia. My Patagonia merino base is even more comfortable than Ibex, though not quite as warm as it's thinner and generally a better weight for cycling unless it's below freezing. Own all 5 brands, 0% fleece, it all got given away but having dogs makes fleece and it's attraction to hair a very bad thing.
  • 11-13-2012
    Jwind
    Yaz, but you can often steal stoic jerseys for under 25 bucks. Might not be quite as nice as the likes of patagucci, ibex and ice breaker however that latter will run you 3x or more $$$.
  • 11-13-2012
    shiggy
    I have tried some of the wool blend base layers. Nowhere near as effective as 100% merino or as comfortable.
  • 11-13-2012
    Tincup69
    Thanks guys!
  • 11-13-2012
    lubes17319
    Goodwill has treated me well for the past 5 yrs.
    Now have collected 8 100% merinos for about $60 total.
  • 11-13-2012
    SDKmann
    Call all the local outdoors stores in your area and ask about their specials/coupons. Many stores send out coupons for a percentage off retail if you're part of their mailing list, have random sales over weekends, or have customer appreciation nights for those people on the mailing list where there is a discount. If the employee you talk to has worked at the store for a year or two (or longer) they will know when the sales typically happen and if you ask nicely they might share the inside info. There are also seasonal clearances for getting rid of that season's styles/colors in preparation for the new stuff. Unfortunately for you fall clearances rarely happen as the fall/holiday season is the best time for business at those stores and clearances are not needed. Also check the clearance racks, at the stores I have worked in it is not uncommon to find merino there.
    Also, if you buy at a local store, if you are buying a lot of stuff at once you can probably ask for a discount on your entire purchase. At the stores I have worked at if you're buying about $700+ in gear the store will give about 15-20% off the entire purchase. If you are personable and engage in conversation about outdoors stuff with the employees you are more likely to be treated well and given a good discount. So if you need some other winter gear or are buying holiday gifts you can save some money that way. Or you could just do a group buy with your friends and just send one person in to get everything on the list and then everyone gets a good deal.
  • 11-13-2012
    shiggy
    15-20% is not much when STP and the company outlet/closeout prices are 30-60% off. It does limit the selection, though.
  • 11-13-2012
    SDKmann
    No, its not much but when you're talking about 15-20% off an entire purchase for no reason other than buying things you were going to buy anyways its not a bad deal. You can get far more off the MSRP at outdoors stores through the other routes I mentioned.
  • 11-13-2012
    grandsalmon
    If you do the STP thang, go sign up for their daily deal, it will introduce you to additional % off by email. This may or may not apply to that smartwool base layer (their sleeveless are nice), or that ibex as examples, but in the last 3 weeks they both/many were applicable -one time or another. I try to never pay the straight percentage off at STP.
    When you have done your shopping (merino scrounges for me certainly), then I sign off their mailing list -deal notifier. ( I spent $28 - $38 on the SW, and Ibex. And yes their merino is nice;weave, construction.)
  • 11-13-2012
    Tincup69
    Great advice here guys, thank you! I ended up ordering a few things from STP, I can see myself spending a lot of money there.
  • 11-13-2012
    Spec7
    Depending on your location and whether or not there is one nearby, don't be above checking out a TJ Maxx store for this stuff too. My local TJ Maxx has supplied me with various wool products from Icebreakers, Helly Hansen, Bridgedale, and Smartwool; all at dirt cheap prices.
    My most recent purchase was Icebreakers merino wool cycling socks for $2.99 a pair and Keen merino wool liner socks for $2.99 a pair as well. I saw some merino layering tops last time I was there for something like $9.99, but I'm not in the market for them so I don't remember the brand. I've been buying cycling/outdoor gear from them for years, so I just keep checking back once a month or so to see whats new or marked down for fast closeout.
  • 11-14-2012
    Jinxy
    I have Smartwool & Ibex but prefer LL Bean merino as you can order "tall" sizing. Every bit as nice as the others and less $. The Smartwool tops feel short to me - especially on a bike.
  • 11-14-2012
    westin
    If you want really short-on-bike feel try Icebreaker. My favorite piece is a long sleeve 1/4 zip 260 weight Icebreaker and I feel like pulling it down to get a little more room. I'm under 6 feet with normal torso. But seeing as how it's my "90% garment" I must not care. :thumbsup:
  • 11-14-2012
    BatCountry
    Sierra Trading Post - Great Deals. Great Brands..
    Lots of closeout stuff, 2nds, and selection. Last week they had awesome sales on baselayer lines..
    Look for the coupon code.. they normally have 20% off..
  • 11-21-2012
    ferntree
    REI has sale right now. Got some smart wool. I love merino!
  • 11-23-2012
    ALBM
    You might want to check some web sites geared towards runners, lots of stuff out there if you know where to look.
  • 11-24-2012
    Travis Bickle
    I just picked up some long sleeve merino t shirts from Costco for $20 a piece. imported fabric but sewn in Canada! A rarity these days.
  • 11-24-2012
    jleeasc
    LL Bean looks good and gets good reviews. Offers lightweight and midweights. Tall size offering is also a plus. Can't beat their guarantee. 90$ for top and bottom with free shipping.
  • 12-02-2012
    Johnnydrz
    Check the On-One UK website. Last time I checked, they were having sale all most of their Merino stuff.
    Envoyé de mon iPad à l'aide de Tapatalk HD
  • 12-02-2012
    memi
    Costco.
  • 12-09-2012
    keepbalanced
    I completely agree. With 100% Merino Wool you really do get what you pay for. For most good quality 100% merino wool it is around $100. But I found a hunting company called Kuiu that sells exclusively online at wholesale prices. Their's is $80 dollars and it has worked so well for me. Really top of the line product, and at a good price. You should check them out.
  • 12-09-2012
    bapski
    +1 costco. its a merino layer base layer top by paragonoutdoors.com
  • 12-09-2012
    shiggy
    My mom bought one of those Costco "merino" shirts. They are polyester with 15 or 20% wool. Not enough wool to matter.
  • 12-10-2012
    bapski
    good enough for me. havent had to use arm warmers
  • 12-10-2012
    Jinxy
    Costco near me sells 1/4 zip merino tops for $24.99. Kirkland Signature brand, 100% extra fine merino wool. As nice as my Smartwool, might even be cut a tad longer. Nice stuff.
  • 12-10-2012
    shiggy
    Double check the labels
  • 12-10-2012
    limba
    These are very expensive but they're awesome. I don't think you will regret buying them. In fact I bet you will never want to wear any of your other gear because these are so nice.
    The finest 100% merino base layers made for cycling | Rapha
    Winter version.
    100% merino roll neck base layer for winter cycling | Rapha
    It's cheaper if you buy a bundle.
    Base Layer 3 pack | Rapha
  • 12-10-2012
    mattnmtns
    I recently bought the stoic 200 baselayer from backcounty. I got it on sale, its still on sale but looks like it has gone up $10.
    So far I have been happy with it. I have only ridden with it once and had to take it off not too far into the ride because it was so warm. I wore it with a t shirt yesterday while fishing. Did a great job, kept me plenty warm while standing in a high elevation stream on an overcast and damp day.
  • 12-10-2012
    Jinxy
    Shiggy - I looked at the label as I typed it then - and again now. 100% extra fine merino wool. Made in China. Kirkland Signature label, $24.99 at Costco and nice. I've seen their blended stuff too - not for me. Gotta watch what you buy there.
  • 12-10-2012
    bapski
    Shiggy - I looked at the label as I typed it then - and again now. 100% extra fine merino wool. Made in Canada. Kirkland Signature label, $24.99 at Costco and nice. I've seen their blended stuff too - not for me. Gotta watch what you buy there.
    i dont seem to remember seeing a KIRKLAND branded merino wool there.. i did see the one from paradox outdoors ill check costco again and see if i can find the KIRKLAND brand.
    its paradoxoutdoors.com...and yup shiggy is right its 84% polyester, 11% merino wool, 5% spandex. . . thought its good enough though since i did not have to use my arm warmers as what i mentioned earlier.
  • 12-10-2012
    Von Gruber
    Cosco had some tops and bottoms for 20 and 25 each. I liked them for 45 bucks!
  • 01-16-2013
    abegold
    One of my 2 Stoic jerseys already has a hole in it and it's not even from getting poked. By far the thinnest merino shirt I
    own.
  • 01-16-2013
    mattnmtns
    own.
    I agree they are pretty thin, though they are really a base layer and not a jersey. Curious which did you get the 150 or 200. The 200 is tshirt thin, so not too bad IMO. All in all been happy with mine so far.
  • 01-16-2013
    abegold
    Think it's the merino bliss shirt. Doesn't even get worn much compaired to other merino shirts.
  • 01-16-2013
    keepbalanced
    Winter version.
    these look nice but one thing they are missing is a front zipper to dump heat when climbing, then zip it back up for the downhill. Or do they have a top with that but i just missed it?
  • 01-16-2013
    limba
    The links I posted were for base layers. They make merino jerseys with zippers. They don't have any base layers with zippers.
  • 02-11-2013
    parkyrides
    Subscribed loving Marino wool products
    this winter.
  • 02-17-2013
    Spec7
    Originally Posted by Abigailjpw View Post
    crock pot parts mp3 player cheap ..................senora proof reading courses
    Originally Posted by enanciaws View Post
    [isabelmarantsneaker............... arrange form
    Reported.
    The best thing to with spam? Slice it up into thin pieces and throw on the griddle searing both sides. Then throw it away.
  • 02-17-2013
    Gunnar-man
    I too have gone all merino and dumped my dri-fit/clima-dry/polyester jerseys and have found prices to be crazy expensive at most stores and online.
    I have bought some short sleeved off Jensons at ~40bucks each. Also have two long sleeved ones from Costco and the labels say 100% merino. They are branded "True North" and I think they were around $25 cdn.
    I also got burned by buying what I thought was a 100% merino long sleeved from MEC (Canada's REI) and couldnt figure out why it started to get funky after wearing it when all my other merino jerseys can go multiple days with no smell. Sure enough, it is a poly-wool blend. My Costco jerseys have remained funk-free after multiple days of wearing so I believe the label is correct at 100% merino.
    MEC does have other long sleeved 100% wool jerserys with a front zipper for around $65 cdn but that might be cost prohibitive if shipping into the US?
  • 02-17-2013
    grandsalmon
    The knit/weave and weight of a Merino garment makes a big difference too -whether you are looking for thin base or shirt, up to a thick jersey or sweater.
    If I can get Ibex, Smartwool, Icebreaker, Swobo, and many, many others on sale -then I jump on them (the wool, not sheep). Every weave is different -so actually hold-up & look , feel that particular weight. Quality Merino cared for, biked w and thrashed, will still last an incredibly LONG, LONG, time.
    As of latest: Ibis/Icebreaker -light to mid base, pocket&zip jerseys $40 -$60. You could probably find some quality light base, short&long sleeve for a wee bit less, Smartwools I see often on sale.
  • 10-23-2013
    Jinxy
    My local Costco has 100% Merino tops again: Kirkland Signature, 1/4 zip, 100% extra fine merino, woolmark certified, $19.99. I wore 3 of these through last winter and they're great. They've survived half a dozen gentle washings with Ivory Snow - same way I treat my other woolies. Flat dry. Mine still fit fine and show little wear. Good stuff & great price! Don't confuse with their blended tops - these are 100% Merino wool.
  • 10-24-2013
    Travis Bickle
    I just picked up a couple of long sleeved 100% merino T shirts. Nice and light, sewn in Canada and only $20 CDN. If it gets cooler I can double up. If I rip one I won't cry like I would with a $60+ jersey.
