Thread: Giro Xar vs Xen
    Oct 2010
    Giro Xar vs Xen
    Does anyone know if the coverage on the back of the helmet on the new Xar is as good or comes down as far as the Xen it is replacing?
    I fix choppers
    Reputation: HELLBELLY's Avatar
    They are pretty close...
    ...I ran the Xen for about 7 years +/- and the Xar feels and fits similarly. However, it is seemingly lighter weight and has better air flow. The fit does seem to cradle your noggin a wee bit better too.
    "Everything popular is wrong." -Oscar Wilde
    Bicyclochondriac.
    Quote Originally Posted by climnron View Post
    Should not be hard, as the Xen does not come down much in the rear to start with. It comes down in the back no lower then any xc or road helmet I've owned or tried on. The reason it LOOKS like it comes down far in the back is because it come down very little on the sides.
    Becuase of how little it comes down on the sides, and the fact that it is just about average down the back, the Xen is the LEAST overall coverage of the 5 helmets I have owned, and all were older "xc" lids.
    meow meow
    Reputation: b-kul's Avatar
    if you want max coverage id look at other lids like the giro feature or poc trabec or even the fox flux.
