• 12-27-2012
    TiGeo
    Favorite winter gloves...not bulky
    What is everyone's favorite? Was thinking something from Specy or maybe the Pearl Cyclones.
  • 12-27-2012
    limba
    You should give us a temperature. Your winter might be different from ours.
  • 12-27-2012
    TiGeo
    Mid-Atlantic..cold is in the 30s-low 40s. I don't ride in the rain/snow.
  • 12-27-2012
    limba
    At those temperatures you'll have lots of options. It's when you ride in worse weather things get tricky.
    I wear these at the low end of your scale. Hot Paws
    or Pearl Izumi Amfib or Lobster style gloves.
    Gloves
    and I wear Rapha gloves at the upper end of your weather. They're not on their website right now. I think those Cyclones will work for you unless other guys say they suck.
    Like this guy. :D
    Review: Pearl Izumi Cyclone Gloves | Fearless Gearless
  • 12-27-2012
    supersedona
    I was pleasantly surprised with my new gloves from Sports Authority. I used to consider my old Pearl Izumi snow gloves to be the best, well they still are, but they cost a bit. The Slalom snowboard/ski gloves from SA are actually pretty close and only $19. No extra around the fingertips to mess with the shifters and still plenty warm in a 33 degree ride home in the wind today.
  • 12-27-2012
    Hutch3637
    Usually I can get away with my regular gloves *Spec. LoDown* at those temps but sometimes I use these if the wind chill makes it below freezing or if it gets really cold out 25F and below.
    http://forums.mtbr.com/9912763-post29.html
  • 12-28-2012
    monzie
    I love my Hestra Windstopper Tracker gloves. They are not bulky at all and have good bar feel while still being exceptionally warm in your temperature range.
  • 12-28-2012
    bad andy
    What I find works for me is layering. My hands sweat like crazy during the summer, so I use the lightest gloves possible then. In winter, though cold at first, once my hands warm up they're pretty good. That being said I usually wear my regular summer gloves, which are very thin and not bulky, with another glove as a shell on top. Generally a knit-style glove. Often, I'll even remove the shell glove mid-ride if hands are warm enough - to avoid sweating. Moisture not good in winter rinding. I use something like these as outer shells: Castelli | An Unfair Advantage - Country selector though there are lots of other options out there besides Ca$telli
  • 12-28-2012
    BigHit-Maniac
    Best gloves EVER. :thumbsup:
  • 12-28-2012
    knoob
    What model & can you find them here local?
    The 12/21/12 nite ride was a little chilly @22.
  • 12-28-2012
    BigHit-Maniac
    If you're riding in the 20's, you may need additional neoprene glove liners. However, I've found that in the mid 30's and 40's they're fantastic.
    I've absolutely loved every article I've ever purchased from Pearl. They make top notch stuff.
    Pearl Izumi P.R.O. Softshell Lite Gloves - Competitive Cyclist
  • 12-28-2012
    Thiel
    At 30-40 degrees I'd recommend the soft shell lite glove above until you are warmed up, then switch to something uninsulated.
    NEVER ride in the cold with just one pair of gloves... And best to switch before you start sweating so you can keep the warmer pair in reserve.
  • 01-07-2013
    Backyard Pro
    i wear grenade snow board gloves
