Results 1 to 3 of 3
    Reputation: fatmat71's Avatar
    Cracked SPD Shoes Soles
    The sole of my shoe has cracked and split on the plastic/carbon part. I think the only thing holding it in place is the rubber sole. It's ok but sometimes pops out and I have to put it back in. And it feels loose which is annoying and could even be dangerous because it's slow to pop out of the pedal.
    Has anyone fixed something like this? I was thinking of using epoxy. But not sure if it'll bond well enough. any opinions feedback appreciated.
    Cheers, Matt
    Shoes are DIADORA Hiker type.
    Riding free's the mind
    Suggestion
    No fix, you need new shoes- too much weight/torque/pressure down there for any king of epoxy or super glue to fix.
    I suggest NOT getting another pair of Diadora's, I've had similar problems of cracking near the cleat and had the SPD nut inside crack as well. I had the Diadora Gecko's, would not buy them again.
    Very happy with my Shimano 120's, curious about the new Pearl Izumi shoes and probably can't go wrong with Sidi's. If you can, get away from the hiker style- they weigh more and not as stiff as the racing style - if that matter to you.
    Question to a custom frame builder..."So what makes your bikes climb better?"....his answer, "Uh, your legs?"
    Quote Originally Posted by fatmat71
    Cheers, Matt
    How old are they? most shoe companies give a 1 year warranty. If it's outside of that than you are SOL and should definitely replace them.
  1. 8 spd. with 9 spd. shifters
    By dwnhillscreamin in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-06-2005, 08:05 PM
  2. Anyone dremel their shoes?
    By Chester in forum Apparel and Protection
    Last Post: 05-10-2005, 11:17 AM
  3. Crank Bros. Mallets, and Skate style shoes.
    By Plinkerton in forum Apparel and Protection
    Last Post: 02-13-2005, 10:48 PM
  4. 9 spd chain with 8 spd cassette?
    By top_ring in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-29-2005, 04:12 AM
  5. 9 spd chain on 8 spd crank
    By ttt in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-21-2004, 06:46 PM
