Results 1 to 40 of 40
    Reputation: DRILLINDK's Avatar
    Mar 2012
    Cold Weather Bike Tights/Leggings
    I've been really happy with my padded Pearl Izumi bike shorts. Now that the weather is getting colder I'm looking for something similar to wear during the winter. I'm looking into what Peal has to offer, but just wondering if anyone has any recommnedations?
    I was hoping to get something to wear over/under the padded Pearl Izumi bike shorts I have. So that I could wear the legggings when I jog as well. This isn't a deal breaker though.
    MEC Roubaix Tights (Men's) - Mountain Equipment Co-op. Free Shipping Available
    These have worked well for me. Down to about -20C with tights underneath.
    Mar 2012
    Also, would you recommend buying tights with chamois/padding included or just wear my padded shorts underneath.
    Reputation: d365's Avatar
    I use leg warmers until it gets into the low 40s, then I use some full-on winter tights (over my bibs) below that. I recommend getting some without the chamois, and use regular lycra under it.. that way, you can get multiple uses, before you have to wash them.
    Quote Originally Posted by DRILLINDK View Post
    Wear the shorts underneath....you need the extra protection in that area to prevent dick freeze.
    One Gear
    Reputation: .40AET's Avatar
    Leg warmers are great down to 30 for me. If the temps warm up, they can easily be taken off. Once winter sets in I reach for thermal bib tights.
    Good luck
    Mar 2012
    Pearl Izumi makes some with chamois built in called elite. They are thermal and pretty warm. Im 6'1", 190 and wear a large in these (and an XL with every other bike shorts I have )
    Epic Flash Boris F65X + road bikes
    Mar 2012
    Ended up purchasing the PEARL IZUMI Men's AmFIB Tights. They are made out of a thicker material that should hold up well during falls, tears, etc. I'm planning on wearing my padded bike shorts underneath.
    Tights
    Reputation: beshannon's Avatar
    Oct 2012
    I bought the same Pearl Izumi tights myself, took them out yesterday, comfortable although a littl tough to get on and off
    Mar 2012
    Quote Originally Posted by beshannon View Post
    Yep, almost feel like a thinner wetsuit.
    Reputation: Arebee's Avatar
    Sep 2012
    I bought a pair of Novara Tempest Bike Tights - Men's for $80 at REI.
    My first ride with them started at 33 degrees and ended at 29 degrees and they performed amazingly well. They kept me warm for the entire 2-1/2 hour ride. I'm 6' 2" with a 35" inseam and although these claim to have a 30.5" inseam, they did go down to my ankles. Highly recommended.
    May 2010
    I have been using the same pair of Pearl Izumi Thermal Cycling Tights for some years now. I would highly recommend them. I also used them as liners for skiing/boarding. Don't get any with a chamois built in, since you have shorts you can wear underneath, and then you can use them comfortably for other sports.
    I live in Colorado and wear them when the temp is anywhere below 45 degrees and down to 25 degrees, colder than that...stay at home!
    I know you are asking about winter tights, but I would also recommend Performance Branded Ultra II Cycling shorts. They are very comfortable.
    I'm with stupid
    Reputation: hitechredneck's Avatar
    I got about 4 sets of underarmor winter weight tight thingys from work. I wear those all winter for running and for riding I just wear the diaper (padded butt shorts) under them.
    I quit e-MTBR
    Reputation: OldManBike's Avatar
    I don't much like tights. I very much like my Novara (REI) Headwind pants. One of the best REI-brand clothing items I've bought.
    Novara Headwind Bike Pants - Men's - Free Shipping at REI.com
    Reputation: The Highlander's Avatar
    2008 Specialized Stumpjumper fsr comp
    1998 Specialized Stumpjumper S2(Metal Matrix)
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    I wear shorts down to ~45 unless it is windy. I wear shorts with non-chamois tights (Louis Garneau nothing extravagant) down to the mid-low 30's and below there I wear tights w/ Chamois (Performance brand). I have long "pants" that I wear if it is snowing, raining or on blustery cold days.
    OldManBike,
    For the Novara Headwind pants, is the bottom of the leg able to go over a snow boot upper (I get cold feed easy)?
    Thanks,
    Dan (Turtle)
    I quit e-MTBR
    Quote Originally Posted by Turtle01 View Post
    OldManBike,
    Can't say, haven't ever tried that. But I went and measured for you, and the diameter of the leg opening is ~5.5" with the ankle zips all the way closed. The ankle zips are 10". So I would think you could wear them over your snow boots; depending on how big the uppers were, maybe you'd have to leave the ankle zips partway up. Hope that helps.
    (And its REI, so you could try them and if they don't work for you, return them.)
    If you're not using merino wool you're doing it wrong, nothing other than merino should be considered for tights/baselayer. Icebreaker is my favorite brand for performance merino, I think its the softest and best fit for clothing (Fits brand is softer but they only make socks at the moment). This is what I use- Bodyfit 260 Legless - Icebreaker (US)
    Merino is nice for tops where you sweat a lot and can easily smell your own funk, but synthetics are fine for the lower body. If smell doesn't matter, then it doesn't matter much.
    Quote Originally Posted by leaftye View Post
    Totally wrong. First off smell does matter. Over time you won't be able to wash stink out of synthetics, they start to permanently carry the smell and it gets BAD. Unless you're not using your leggings for more than a season or two then it is a factor, Im sure many others who have used synthetics over a sustained period of time know what Im talking about. All that bacteria synthetics hold on to is pretty gross too, something you don't have to worry about with the naturally anti-microbial merino. Secondly merino is temperature regulating, meaning warm in cool weather and cool in warm weather, synthetic can't do that. A merino piece in the same weight as a synthetic can be used in a wider range of temperatures. Merino wicks moisture away while its still in the vapor form while synthetics can't, meaning you stay dry and don't get that clammy feeling, that one aspect alone makes merino worth it. And finally merino is just more durable than synthetics, over time merino ends up costing you less money as you get many more uses out of it.
    Quote Originally Posted by SDKmann View Post
    Dude, smell doesn't matter if you can't smell it. Well, unless you're trying to smell pretty for your bros.
    Temperature regulation of merino wool works until it's saturated. Wicking like a synthetic while also the core to get soaked is what provides that temperature regulation, and once soaked, that benefit is gone. That's fine if you're doing short rides, and not touring. It's something that definitely needs more thought on longer rides. And no, merino is definitely not more durable.
    Well I won't argue with you since you have your mind made up, and but in terms of smell it varies from person to person, my last pair of synthetics was the only pair that I was using and after a years worth of use I couldn't keep them in my drawer because the stink that wouldn't wash out filled up the room. And I will say that there is a reason that all the large outdoor manufacturers are starting to phase out their synthetic lines in favor of a merino line.
    That still jives with what I'm saying. If you smell your leggings, then by all means replace them. If you can't wash the smell out of your synthetics, by all means replace them. Personally, I don't smell my synthetic bottoms, and they pass the sniff test after washing, so there's no point in my replacing them for short trips. So yeah, it depends on the person or persons smelling it. I will note that I'm phasing out my polyester backpacking shirts because I can't stand the smell after hiking in them for just a few hours, which is a big problem if I'm several days away from laundered clothing. It should be noted that nylon doesn't stink nearly so much as polyester.
    I have a differing opinion, or rather, an additional reason for why they're switching. The Starter and Champion brands at Target and Walmart, respectively, aren't worth fighting. The quality is close, and the price difference is huge. There's also the matter of how it's easy for most synthetic materials to be acquired, even by someone willing to sew their own gear. I've looked hard for merino wool fabrics, but it's nigh impossible to find and buy in small quantities. Backpackinglight is a prime example. They had a line on a very thin merino wool fabric, and even though customers constantly experienced rapid wear under their shoulder straps, the reason gear made with that fabric disappeared is because they could no longer acquire that fabric. So for the companies that can get the fabric they need, they can charge very high prices for their apparel.
    Reputation: parkyrides's Avatar
    Dec 2010
    a. I have recently tried PEARL IZUMI Men's AmFIB Tight Bibs with a light weight padded bike shorts in 30 degree temps and were toasty warm! Bibs keep the back nice and warm and no drafts. ++ Got them on Amazon for $75
    b. Was using PEARL IZUMI Elite mens winter pants w/ chamois, but got to drafty.
    Mar 2012
    I've been very happy with my AmFib tights so far. The do keep me warm!
    I have a pair of fox 3/4 nicker tights with chamois and fleece interior. I wear those, ankle high wool socks, a fleece base layer. That keeps me fine in the low 30's. I live in GA so no need for super warm gear. Doesn't get all that cold.
    I like turtles
    Reputation: TiGeo's Avatar
    Am I the only one who likes my tights padded? I hate wearing shorts under them..more layers, more bulk.
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro are #@$%
    Dec 2010
    Quote Originally Posted by TiGeo View Post
    I prefer all biking pants to be padded w/ chamois, but the AM Bibs don't have them. On plus side you can recycle them between washes. I have a pair of Volar ultra light shorts w/ chamois that I wear under the AM bibs.
    The other day I used a middleweight LLBean Marino wool under my fleece lined shell and more than warm enough in 28 degree temps.
    2012 SC Tallboy LTc X9 Talas Build in '13
    Prior bikes: 2012 Camber Comp 29er, 2010 RIP9, 2005 D'ale Prophet/Jekyll
    May 2012
    For a less expensive albeit fruity option: I wear padded shorts and leggings, and found the leggings still allow a touch too much wind to penetrate. My wife happened to have a pair of black yoga/stretchy pants sitting around, so I tried them on. They work great. Having the yoga pants and leggings allows me to strip down throughout the ride without getting too dang hot.I think they cost about 10 bucks at the box stores.
    Reputation: t0pcat's Avatar
    May 2012
    Was wondering if anyone has tried these LDComfort - Getting to the Bottom of Rider Comfort - Motorcycle Underwear i think they work pretty good on the motorcycle and so far on the bike too!
    “An adventure is misery and discomfort, relived in the safety of reminiscence.” Marco Polo
    I dont like wearing tights.. Do you have any suggestions for looser (not necessarily baggy) pants for the winter? Something that fits like a normal pant. This is my first time biking in Colorado Snow and I would love to hear suggestions of brands/ pants, etc
    I wear Castelli winter bib pants with a great chamois and I wear my regular MTB shorts shell over them. Looks like I'm just wearing leg warmers.
    May 2012
    I wear insulated tights and these Tech-Pant Overtrousers they do a great job stopping the wind and are waterproof! You could wear anything under them.
    Dec 2004
    Interesting thread.
    I love wool for socks. Even ride with them in the summer. I got an expensive merino wool top after hearing about how great they were. OK, but once it gets soaked, not so much so. Certainly not rushing out to buy more wool tops at this point. My thermal long sleeve jersey over a poly base layer works much better in my opinion. Over that I use a thin breathable wind breaker for cooler weather.
    I used to use regular non padded tights over a padded short but the seam in the tights bothered me. I bought two pair of Pearl Izumi padded thermal tights and I really like them. My favorite though is the Pearl Izumi padded thermal knickers. Like another poster does, I wear long wool socks that tuck in under the lower part of their leg. Unlike leggings they stay in place and don't drop down. I never liked legging for this reason. Even in summer I wear thinner knickers because I don't notice them being too warm and I get more sun protection and brush protection.
    I have a pair of Pearl Izumi water resistant biking shoes that work great in the summer and winter. In the winter I run a full shoe cover and that works great for keeping the feet warm. I am not a big fan of mesh cycling shoes. Too cold in the winter and in the summer they let in too much of the fine dust. But that is just me.
    I also wear a long sleeve poly top or long sleeve jersey in the summer. They breath well and keep the sun off the arms. I also don't like to wear a pack since it makes my back sweat too much.
    As far as stink goes, I have never had a poly top or bottom where once through the wash still stink. I think some people are bigger stinkers than others!
    Temperature regulation is the key and the worst conditions are where you go from sweating to freezing. You really have to spend more time layering and unlayering before things get out of hand. Really slows down the flow of the ride for sure.
    "Life is really simple, but we insist on making it complicated"
    "When you seek revenge, be prepared to dig 2 graves"
    Kitty! Kitty! Kitty!
    Reputation: GelatiCruiser's Avatar
    Oct 2012
    +1 for the Headwind pants. On sale now from $79.50 down the %54.93. Yoink!
    Reputation: cob4lt!'s Avatar
    Tights + pi leg Warner's
    Been wearing tights/long underwear plus pearl Izumi leg warmers over in 25-35 degree weather and the setup is working just fine. Note, this setup is for dry rides not wet. Did have to pick up some Mavic drift shoes to help with the cold toes.
    Bandersnatch
    Quote Originally Posted by GelatiCruiser View Post
    Bummer......xl only
    Bandersnatch
    I remember odor retention and amplification was really noticeable with the early wicking fabrics back in 85 or so, like polypropylene. Newer fabrics do not have the same problem at least to me. Maybe my nose is in permanent olfactory fatigue
    I have a couple of winter weight Merino wool polyester mix jerseys that are my first choice for the coldest riding i do (25F down to 0F).
    urmb
    “Nothing compares to the simple pleasure of riding a \mountain or fat/ bike.” ~ John F. Kennedy
    Oct 2012
    Quote Originally Posted by cob4lt! View Post
    Bummer......xl only
    Yea. Sucks big time. I went into rei and they only had xl... And online. Dagger!
