Results 1 to 13 of 13
    Reputation: Dusty Trails's Avatar
    Clipless issues, looking for input.
    I just received my second pair of clipless shoes and I'm having an issues getting them release from the pedals. My first pair I had to grind away a lot of the tread to get them to clip. These clip just fine, I guess, but getting them to release is a major battle. It looks like I'm going to need to do some work on the the bottom of this pair as well.
    Is this normal or am I missing something?
    Armature speller
    Sep 2004
    What pedals?
    Quote Originally Posted by NordieBoy View Post
    What pedals?
    Shimano XT M785
    The shoes are Mavic Rush
    Reputation: RossJamis's Avatar
    Aug 2013
    Have you tried adjusting the tension so they release easier? Also there are two types of shimano cleats the silver ones allow you to pull back to release, the black ones only release under side pressure. I use the silver ones because I can get out much quicker when I really need to.
    When you've seen someone rupture their scrotum on a bike you won't take the standards for top tube clearance lightly!
    The tension is as loose as it can be, worked fine with my old shoes. I'm using the black cleat.
    Reputation: rogbie's Avatar
    With the tension set so loose the cleat has more room to move before it will disengage. This means you'll have to rotate your heel out further to unclip.
    Another problem arises if the cleat is offset to to close to the tread. However, this would make engaging the cleat difficult.
    Using a door frame to balance, practice uncilpping at different tensions to find the one that works best for you.
    I passed the shoes off to my son, they fit him much better since I have a freakishly high instep, and he tried them out on my old clipless pedals. They worked much better with the old then the new. Which makes me wonder if it's just not the combo of new cleats and new pedals.
    Sent from my SCH-I605 using Tapatalk
    Reputation: Reelchef67's Avatar
    New cleats are definitely stiff and need time to break in. I have Mavic Scree shoes they have the same tread as yours, I use 1 spacer and multi release sm56 cleats and it works fantastic ...
    I picked up a pair of Diadora X-Trail 2 Carbons, (a true high volume shoe even though it's not advertised that way) coupled with a set of the multi directional cleats works great. No breaking in needed. Now if the trails would stop resembling chunky peanut butter maybe I could get some riding in.
    Armature speller
    Sep 2004
    They look quite nice...
    Quote Originally Posted by anglenasalt View Post
    I have a freakishly high instep, and he tried them out on my old clipless pedals. They worked much better with the old then the new. What pedals?
    I thought I responded to this earlier. I guess it didn't go through. Sorry.
    To answer your question, Shimano PD-M530.
    Yeah, I dig'em, just wish they had more of toe cap like the Mavics. I can just see myself finishing a ride with my to sticking out of the end of my shoe.
  1. Replies: 24
    Last Post: 09-07-2013, 06:10 AM
  2. Flash 29er input on shifting issues needed.....
    By ChiRho in forum Cannondale
    Last Post: 05-10-2013, 06:00 AM
  3. Platform vs clipless vs platform/clipless hybrid?
    By Chad A in forum All Mountain
    Last Post: 06-08-2012, 09:04 PM
  4. Beginner clipless shoes and pedals, input please...
    By madsedan in forum Beginner's Corner
    Last Post: 06-11-2011, 06:44 PM
  5. Replies: 17
    Last Post: 03-11-2011, 06:47 PM
