Results 1 to 27 of 27
Thread: Bib question
    Bib question
    Ok guys I am not ragging on any of you that wear bibs I was just woundering what is the point like are they more comfortable than regular shorts, do they benefit ur riding in anyway cause I am lookin to getting into some xc racing this year and was woundering what the benifits were from them and weather or not I should get some and how do u go about sizing them
    Thnks
    2011 Kona Unit 29er
    In the words bike company Niner
    Pedal damn it
    Reputation: jerry68's Avatar
    I have always found bibs to be more comfortable. They stay in place better, and if the seat nose does grab the pad, they pop back to where they should be.
    Pisgah Area SORBA
    Quote Originally Posted by kjlued View Post
    ... your idea of technical may be much different than other peoples idea of technical.
    LightJunction.com
    Reputation: lightjunction's Avatar
    They seemed ridiculous to me too, but once you switch to bibs, you'll never go back. They hold the chamois in the perfect place, no matter how much you move around, and the bib straps eliminate the need for an elastic waistband that can irritate you on long rides. The bib straps also provide extra surface area for moisture management. Try a pair. Especially if you're racing. You'll wish you'd switched long ago.
    We sell quality bike headlights and flashlights.
    www.LightJunction.com
    poser Administrator
    Reputation: rockcrusher's Avatar
    Aug 2003
    Another bonus is that the tail piece that attaches to the strap covers your lower back where the some of the muscles responsible for stabilizing your pelvis reside. These can get stiff and sore easily especially with the chill of air that flows around the body. Not a huge difference but it is a nice perk on top of the above mentioned reasons.
    Try this: HTFU
    Ok thank you guys I will def look into getting a pair and see how they work
    2011 Kona Unit 29er
    Pedal damn it
    jct
    jct is offline
    Reputation: jct's Avatar
    i switched to bibs a while ago when i started to get serious about racing CX. i still have an arsenal of nice baggies that I wear, but if i know i'm going on a 4-5+ hr ride, the bibs come out and i may throw some baggies on top of them.
    try on as many different pairs as you can. i have bibs from castelli, PI, craft and rapha and the sizing/fit is different across the board.
    Feb 2012
    Switched to bibs while training for my first race and now won't go back. The extra expense was worth it for a more comfortable ride.
    Reputation: Puffy Tacos's Avatar
    They do a great job controlling your beer gut so it doesn't flop over your waistband.
    Reputation: dmboarder's Avatar
    Jan 2011
    They are excellent at controlling plumber's butt and grossing out those behind you.
    Reputation: DBLDEE20's Avatar
    Feb 2012
    I'd get a bib without a pad for winter riding
    Huffy Rider
    Reputation: motochick's Avatar
    Jun 2010
    Please wear the bibs under your shirt, they are not meant to look like you're wearing suspenders! (I only mention this, cuz I've seen it too many times before)
    Quote Originally Posted by rockcrusher View Post
    To expand on this "coverage" back there............
    If it's wet, you don't get cold water spray directly on your back if you are leaned forward at all.
    Unless I'm actually in a race, I wear bibs under by baggies. The baggies are an extra layer of protection. Plus, if you go down hard, you don't want to rip you nice $100 bib on a fun ride.
    Lead by my Lefty............... right down the trail, no brakes.
    Quote Originally Posted by motochick View Post
    I have seen a roadie with just the bib and HR monitor (no jersey) on a hot day. I turned on a side street went a different way home I was so embarrassed.
    Quote Originally Posted by DBLDEE20 View Post
    Or just get actual Winter Bibs.
    If you are riding in the right way and like to make babies later in life the pad has its value(s).
    I ride Mavic winter bibs all winter even at -15 this year. Downside to winter bibs is the fabric that keeps you warmer tends to be a bit thicker. Sort of like having a wet suit resistance when riding (no biggie really).
    On side note and more human levels of outdoor heat the bib will rub less, fit better, and just be like nothing on. Quality and fit matters!
    Feb 2012
    I've tried both types. with crotch pad and without. for me the ones without padding were much more comfortable. the padding stays where you need it better in a pair of shorts compared to a full bib, so I'd just wear my short tights w crotch pad underneath the bib. No need to wash the bib after unless you're really sweating. Bontrager makes a very nice thermal bib with windfront material that sells for about $105. It has kept me warm while winter riding in Pgh area
    just my opinion, YMMV
    Reputation: Tystevens's Avatar
    All salient points covered. For me, 1) more comfortable , ie always in the right spot, 2) no elastic cutting into my belly, 3) don't fall down, 4) avoid showing crack. If you're gonna wear lycra, may as well do it right and get the bibs (I seldom wear mine on the trail, and if I do, it's under baggies, but they're great on the road).
    '11 Specialized Enduro Expert for the trails
    '13 Felt Z4 for the road
    Reputation: 53119's Avatar
    Nov 2008
    it's ok if you have to wear bib straps on the outside cuz it's "conversational".
    Well I went and got a pair of bibs after reading all ur guys post and u guys were right super comfortable thanks for all the input
    2011 Kona Unit 29er
    Pedal damn it
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    So what if we look like Flying Trapeze Artists....those things have built-in suspenders, and is the best thing since sliced bread. The mesh sides keep tearing from pee runs, so I sewed a zipper on mine...problem solved!
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    Best things about tights:
    If they look bad on you then you need to bike more. Get the super legs of steel and bike 1000KM a month and it won't matter.
    Quote Originally Posted by (807) Recordings View Post
    Well, I'm not so sure they look good on anyone, of the male gender at least. But the benefits of the function outweigh the drawbacks of the form IMO.
    Reputation: rogbie's Avatar
    Quote Originally Posted by 53119 View Post
    Correct. The key to this statement, though, is, <i>if you have to</i>. Which, implies, <i>don't do it if you don't have to</i>.
    The "conversational" part is spot on!
    I wear 3/4 pants over my winter bibs (mostly to tuck a wool sweater into) and shorts over my bib-shorts on the trail. Bibs are far superior to shorts for already mentioned reasons.
    "Padded crotch" is called a chamois. Use chamois cream. Shea butter, makes a great chamois cream. Use generous amounts of chamois cream, applied directly to chamois. Don't think about it, just do it. The comfort is worth the self-exploration.
    The most commonly asked questions about my bib-straps:
    Are you wearing a wrestling singlet?
    What are those?
    ::quizzical look::
    Is that a wet-suit?
    These are usually followed by questions about my neoprene booties.
    Reputation: SeaBass_'s Avatar
    I became a bib convert after getting a pair on sale from performance. They've definitely become my preferred attire (with the shirt over the straps!)
    Jan 2011
    Hell, I love wearing my bibs. They're like wearing male spanx. Makes my gut look a tiny bit less guttish. I wear them when I'm going out!
    Reputation: Tim-ti's Avatar
    Since a waistband only squeezes around your body, if your shorts slide down the chamois pad will migrate away from your crotch, that allows chaffing to begin and feels like a full diaper.
    Bib straps keep your chamois pulled upward in close contact with your crotch, thus no chaffing and increased ease of motion while hiking and moving on the saddle.
    I'm not going to make a habit of spamming the boards, but I've written more about the benefits of bibs for mountain bikers here: F.A.Q. - dirtbaggies
    Reputation: bikerjohn64's Avatar
    Feb 2012
    Too funny; oh the image that is ingrained in my mind; life will never be the same again!
    I agree with all the other posters for bibs; gut control, comfort, plumber's butt. It's just very nice IMO.
    Jun 2010
    Quote Originally Posted by dmboarder View Post
    However, this could be a good race strategy.
    I prefer bids over shorts as well for all the prior mentioned reasons.
