Results 1 to 32 of 32
    XT vs Hone cranksets
    Hey guys,
    I used to have a set of XT hollowtechs (olderones without hollow BB) on my all mountain rig. I liked the cranks alot but when the chainrings needed replacement I found a great deal on a set of Hones (a friend of mine gave me a brand new set of hones with e-13 bash guard for 50 bucks).
    I love the hones, they feel so much stiffer than the XT's.
    Now that I am planning a build of a hardtail AM bike I'm looking around for some cranks.
    I still have my old XT's sitting around and I am thinking of just putting new rings on them and using them on the hardtail build. However, i would rather have the stiffness of the Hones.
    Are the new Hollowtech II XT's stiffer than the old ones I already have? How would they compare in stiffness to the Hones?
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    I own a set of XT and Hone HT2 cranksets... the only real difference is a bit of weight and aesthetics... I don't feel any difference in performance
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    They way I see it:
    Hone is the same as LX, except for the color and some steel components in the 2+bash Hone.
    LX is very close to XT (the HT2 models), except the look is different and XT is slightly lighter.
    Five is right out
    I'm with the other guys- if you can feel greater stiffness in the Hones, it's likely to be in the mind.
    FWIW, I have both the old and the new XTs. They feel the same. I also tried some RF Atlas cranks on the weekend. They also felt the same.
    I really believe there is a difference in the stiffness of the two cranks (XT vs Hone). When I first put on the Hones it felt alot different to me, coming off of drops was alot more solid and each pedal stroke felt more efficient.
    That said, I think I'll trust you guys and just buy new rings for my old XT's and put them on the hard tail. It will save me money and if you guys really are right and it is all purely placebo affect, then the XT's will be just fine.
    Quote Originally Posted by pedro_sandchez
    one thing... while I agree that new chainrings could be the most cost effective above.... my comments above referred to XT HT2 cranks and Hone HT2 cranks.... both are external bearing models... I do thing they are both a bit stiffer than previous iterations (octalink, square taper)... but it is not "night and day" different...
    Some of the comments in this thread disturb me (no offense) :
    "They way I see it:
    Hone is the same as LX, except for the color and some steel components in the 2+bash Hone...LX is very close to XT (the HT2 models), except the look is different and XT is slightly lighter."
    Wrong here...the Hone is totally different. The Hone has arms which resemble LX arms, but they use pressed in steel pedal inserts like the Saint group for strength. The spindle is also different...I believe the LX spindle is cromo whereas the Hone and Saint are Stainless.(again for strength)
    Hone cranks come standard with m760 rings. (that's XT level)
    "FWIW, I have both the old and the new XTs. They feel the same. I also tried some RF Atlas cranks on the weekend. They also felt the same."
    You must be a lightweight. (literally, not figuratively or offensively ) I can tell a great deal of flex in square taper, ISIS, and octalink cranksets. I'm 195lbs and when I stand up and "honk" on the pedals, I can get the chain to rub the front derailleur in outer gear ratios. If I adjust the derailleur "out" to compensate for it, then it rubs on the inside. It's all due to flex. With the outboard bearing style cranksets, the flex is greatly reduced. I still noted some flex with the LX Hollowtech II crankset, but when I switched to Saint and Hone cranksets...the flex COMPLETELY dissapeared.
    If you are a lighter rider, you won't notice this issue, but for a 195lb rider who has to have his bike working "perfectly" all the time...I definately appreciate the benefit of the stiffer spindle on the Hone vs. the LX. Now when comparing old XT to new XT...there's no comparison. New XT is much more rigid. XT Hollowtech I (3pc. with ISIS hollow BB) was fairly nice and adequate for XC'ish stuff...but the Hollowtech II is the only way to fly for an aggressive rider my size.
    Sooooooooooo...as far as I have researched, I have concluded that the Hone is it's own entity borrowing from LX, XT, and Saint.
    It has LX arms attached to a Saint spindle with Saint steel pedal inserts and XT rings. I believe the outboard bottom bracket bearings are LX. I don't know if XT bearings are any different. My main thing about the Hone's is this: I can get a crankset that is only 70g heavier than XT, yet has a stiffer spindle and steel pedal inserts for my aggressive riding style. 70g isn't worth the decrease in durability to me. I would buy a set of Hones again over LX or XT any day.
    Thanks for listening to my lengthy explanation.
    Quote Originally Posted by chelboed
    I have the 3-ring Hone and it is exactly the same as the LX.... the 2-ring-bash Hone has the pedal inserts and reinforced axle...correct...
    the 3-ring hone has the same rings as the LX (alu in the 2 bigger ones, steel in the granny), XT has 3 alu rings... minor difference though... I actually prefer to run a steel granny on my XTs
    local trails rider
    Aug 2005
    On Shimano's web pages the 3 ring Hone is almost identical with LX. The only differences I see is color and one gram of weight. The 2+bash Hone page mentions steel axle and pedal bushings.
    Dec 2004
    confused here
    Wow, that is a lot of interesting and slightly conflicting info.
    From looking at the two links, it would appear that both the 2 and 3 ring hones use a steel granny, and I seem to recall that my XT760s came that way as well.
    I checked the part numbers in the exploded view, and the chainrings are identical. The left arms are definitely different part numbers, and the "features" of the 2+bash reflects the steel spindle and steel pedal inserts.
    Kind of interesting that they don't list the right arm/spindle as one of the parts. I guess they won't sell that on its own?
    Empirically, I still think my 752 cranks felt smoother and spin more easily, but they definitely are not as stiff or as nice for maintenance as the new ones are.
    Thanks for the enlightenment, fellows, I think the 2+bash Hone is a great choice for bigger dudes like me when the time comes. Plus black is cooler for its non-XC connotations...
    Interlectchewal
    Reputation: tvrbob86's Avatar
    Aug 2005
    Quote Originally Posted by perttime
    There was a similar thread a while back and someone pointed out that the spider also has a slightly different shape on the LX vs. the Hone.
    Quote Originally Posted by heavyg
    I actually replaced my worn alu granny on my XT 760s with the steel one from the Hones (since I run the Hones as SS)... they looked the same... but the XT one weighs a lot less than the Hone one... the steels granny lasts a lot longer, so I prefer it...
    Dec 2004
    short term memory abuse
    You may be right, my XT might have come with Al but I didn't remember that.
    I destroy Al grannys in no time, so it got s-canned right off the bat. I put Ti rings on almost two years ago and they are STILL going strong and shifting beautifully. I highly recommend them- Cycle Dynamics out in BC. ($30-40 each ring, I don't think they sell big rings, but I don't use one of those).
    cool..that could be a nice option.. I'll check them out for sure
    Quote Originally Posted by crisillo
    Ahhhhhhh...now we're getting somewhere. I have the 22/32/bg.
    My LBS at one point said that the Generation #1 Hone was a "black LX".
    I wonder if it's changed.
    The picture of the Hone / LX comparison shows a different spider and pedal inserts on the 3 ring model. The spindle looks different from the outside of the drive side than mine also. My spindle looks like the Saint spindle.
    that is just the recess for the pedal spindle..maybe the light in the photo plays a role in that too.. as said, I have the 3-ring Hone cranks and there is no insert on mine
    the pedal inserts look a bit more "prominent" in the 2-ring picture
    Quote Originally Posted by tvrbob86
    See...they are different. Hmm...
    I can't quite tell if the XT has a similar looking spindle (from the outside of the drive side) as the Saint and Hone-BG models...similar, but maybe even different yet.
    thanks for your comment, it has been about the most helpful so far.
    It definitely confirms that I was correct in noticing the difference since I am about your weight (180 lbs).
    I'm beginning to think that my idea of just getting new rings will not be adequate.
    hmm...after the first two or three replies I felt like I had made a pointless post, but now that things are starting to heat up, it seems I had a pretty valid question.
    Good eye. No insert on the 3 ring model. It DOES appear to be a "black LX" with maybe a reverse beveled spider. I called a pretty good shop nearby to ask them...they'll lemme know this afternoon.
    Dec 2004
    more questions
    The 2 ring+bash Hone shows and lists a "pedal washer", and the 3 ring does not. I'm guessing the insert is not as thick as the arm and needs the washer mainly for a "spacer"?
    As I said, I have the 2 ring model and it is an actual Steel insert that the pedal screws into. It's got a washer on the pedal side and threads on the inside. I'ts designed to handle the fatigue of the All Mountain Jumping/dropping. It's really not much of a spacer b/c it's recessed into the arm a bit.
    Lemme throw you for another loop (just for fun)
    Dec 2004
    hahaha
    Nice, I've checked those DXRs out as well.
    I am too much of a wimp to give up my granny, but that chrome look is pretty hawt...
    WOW, those things are $400 bucks at Pricepoint. I had no idea.
    Interlectchewal
    Aug 2005
    It makes no sense. They're basically polished, one-ring Saints. BMX stuff is usually less expensive since the market is skewed more towards kids.
    I find it interesting that Shimano doesn't publish their weight on the website.
    If I were going to spend that kind of money on BMX cranks, it would be for these.
    Oh, So Interesting!
    Reputation: davec113's Avatar
    Don't get new rings for an isis or octalink crankset.
    I went from RF Turbine cranks with a 4 bearing dh isis bb to Saints and there is a huge difference in stiffness and smoothness. External bb cranks are far superior, imo. I'd go with 2 ring/bash Hones or Saints. The biggest difference is the Saint crankarms are much beefier but Saints also weigh about 200g more. I'm not sure whats a good deal now, but I paid $130 for my Saint cranks last year.
    Yup...it's a shame they're not that cheap anymore. I got a set for $120, and Universalcycles was blowing them out for $125 for a long time.
    Lots of places were.
    Okay, I got off the phone with the Mech at the shop I had mentioned...he said that the Hone triple is actually even different than the Hone 22/32/bg. The 22/32/44 has an aluminum spindle and no pedal inserts. The BG version has a Stainless Spindle and steel pedal inserts.
    So...if'n you're a big dude or rougher on crap, get the 22/32/bg. If you're riding aggressive XC then just get the LX b/c there's not much difference between that and the Hone Triple besides color, price, and XT rings..
    told ya' or one just might Hone instead of LX because it was cheaper and looks cooler
    Hone's cheaper?
    I got my LX on sale for $109
    I got my Hone set on sale for $135
    I'd definately go Hone over LX if Hone was cheaper...snazzy!
    Hone's cheaper?
    here it was for almost a year.. the 3-ring Hone, 80 EUR.. LX, 100... I bought my Hones and some weeks later, they went back to being the same price..
    now the 3-ring Hone and LX are about 90-95 EUR and the XT 760 is now 100 EUR, while the 08 XT 770 is about 160 EUR
    Nice...I'd definately go 3 ring Hone over LX just to be different if nothing else. The added bonus of XT rings and the schweet black finish...fo shizzle.
