Results 1 to 6 of 6
    the goose is loose!
    Reputation: rm_racer's Avatar
    Feb 2006
    x post: spoke lacing question
    i was looking at my wheels, and i noticed something. why, in a 3-cross spoke pattern, on the last cross, why does the spoke from the outside of the flange cross under the spoke from the inside of the flange, causing them to bend around each other? as you can see from the picture, the outside spoke (blue) crosses under the inside spoke (yellow) on the last cross. i would think the outside spoke would go on the outside, so the spokes wouldn't have to bend around each other at that 3rd cross. i did it with one spoke on my old wheelset, and there is a solid 2-3mm between the spokes with the outside spoke on the outside, the inner one on the inside. i've seen this on every wheel i've looked at in detail. anyone care to enlighten me on this?
    i posted this in the wheels forum but got no answer....
    It:s to keep tension on the spokes, and I:m sure there is alot more to it than meets the eye.
    Read Sheldon:s article on wheelbuilding, might find your answer!
    http://www.sheldonbrown.com/wheelbuild.html#torsion
    the goose is loose!
    Feb 2006
    ok, i guess that makes sense. it seems like the wheel would be stronger without the spokes bending, but the bend helps keep tension?. i looked at my motorcycle wheel then at the bike wheel and started wondering, so that's where this all came from. looks like it keeps the derailleur safer too.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Sheldon Brown told me to do it.
    Reputation: socalenduro's Avatar
    Nov 2006
    is so as the hub and rim is loaded and unloaded with torque (you pedaling or braking) the spokes press against each other and give each other strength. Thats why you do 3x is so much stronger.
    the goose is loose!
    Feb 2006
    yeah i get it now.
