Results 1 to 19 of 19
    I Like Bicycles
    Reputation: Thimk's Avatar
    X-Fusion Hilo: Is This "Normal"?
    Just installed my Hilo 125 straight from the box, and it's giving approx 10mm of vertical movement at full extension. Small issue, but quite annoying as it sorta feels like a suspension seatpost now.
    X-Fusion Hilo: Is This "Normal"?-945535_132140663652604_1227899175_n.jpg
    Is this something that would go away after some breaking in?
    #1 Norco Aurum LE
    #2 Yeti SB-66
    #3 Evil Sovereign
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Thimk View Post
    Not normal but also not uncommon. You may need to contact customer service.
    mtbtires.com
    Reputation: zahgurim's Avatar
    Aug 2005
    Cycle it up and down a few times, and see if the problem goes away.
    I Like Bicycles
    Quote Originally Posted by zahgurim View Post
    Done that. PSI is good too. Also have done the "pull and suck" method... lol
    #1 Norco Aurum LE
    #2 Yeti SB-66
    #3 Evil Sovereign
    Just A Mountain Biker.
    Reputation: blaklabl's Avatar
    Mar 2011
    I have a HiLo and it has been back to warranty 3x, and is about to go back for a 4th as it just starting pissing oil (again) from around the collar. What a POS.
    MTBR: Your dad's online mountain bike forum.
    I Like Bicycles
    I've fixed this issue by refunding the the damn thing.
    I'll stick to my rigid Thomson post until there's a reliable, not ugly and affordable dropper.
    #1 Norco Aurum LE
    #2 Yeti SB-66
    #3 Evil Sovereign
    Inrideo est vita
    Reputation: SSteel's Avatar
    Quote Originally Posted by Think View Post
    Not normal, sounds like it does not have enough oil. A service center can fix it for you, or you could top it up yourself. Probably ~10cc by the sound of it.
    Canadian distribution: X-Fusion Shox, Rand Momentum lube and Canadian Shield fenders.
    TheRide.ca
    Facebook
    MTB B'dos
    Reputation: LyNx's Avatar
    Have you checked that you don't have the quick release seat colar clamped too tight? I've had my 100mm HiLo for 2 months now and no issues like that. There's a shrader valve at the bottom of the post, check to see that it has in the right amount of air which is 25 PSI, go to their site and download the manual if you don't have it as it requires having the post upside down and holding the release lever down while doing it.
    Reputation: Fix the Spade's Avatar
    Gravity Dropper.
    It works, ugly... maybe to some, but do you really look down there when you're riding?
    Initial reports on the Thomson post are glowing too, although give it six months to be sure.
    Apr 2013
    Quote Originally Posted by Fix the Spade View Post
    Gravity Dropper.
    I agree with the Gravity Dropper. It has a spring and a retaining pin and it securely locks in place every time. Some may find it ugly, but that is all in the eye of the beholder.
    I agree with you spade, I don't look at my seat post when I'm riding either since I think that would cause me to wreck. For this reason, I don't care what it looks like.
    Not sure if this is still relevant, but my newly bought Hilo did exhibit the same behavior after first run or two. I just topped-up with oil fork (wt5) problem solved (takes 5 minutes).
    Reputation: CrozCountry's Avatar
    Mar 2011
    There is, specialized.
    Reputation: MarinCRO's Avatar
    Jul 2013
    HiLo is not a bad post at all, but they don't come with enough oil in them.
    You can just flush the oil, add more of the same, or add heavier oil to tune it to your liking.
    After that, it works pretty well.
    my new bike came with this in 125mm drop length. it drops a couple mm initially and than stays where its meant to. just takes a few cycles. what I dont like is the noticeable saddle movement while riding - ive ridden reverbs (via demo), KS lev, Giant Switch and CB krono and none have so much that its always noticable as this - will see if it s simple tighten etc...
    Reputation: weeksy950's Avatar
    If any of you guys (or others with the same post) can give me a few pointers on filling with oil it would be appreciated. I've got a stealth version on a new bike and have that sag too.
    MTB B'dos
    Quote Originally Posted by weeksy950 View Post
    Well that isn't happening with a post that's 2 weeks old..
    It can go for warranty.
    how heavy are you ??
    Reputation: Scottay5150's Avatar
    What I want to know is did you replace the quick release clamp with a standard clamp?
    Sent from the UnderWorld via Nexus 6P 😜
    What does Marsellus Wallace look like, A BIT*H?
    Reputation: Coal-Cracker's Avatar
    May 2010
    You guys know the OP's original post was from 2013, right?
    Sent from my SM-G920V using Tapatalk
  1. Replies: 3
    Last Post: 02-10-2013, 12:37 AM
  2. normal for lefty to "unload" when wheel comes up.
    By machine4321 in forum Cannondale
    Last Post: 05-23-2012, 08:55 PM
  3. 29er's Look "Normal" To Me!
    By Moonshine in forum General Discussion
    Last Post: 04-24-2012, 06:40 PM
  4. odd ball x-fusion 7"x1.6" rear shock upgrade question
    By KMAGRIZZ in forum Shocks and Suspension
    Last Post: 07-23-2011, 08:54 PM
  5. Replies: 12
    Last Post: 02-22-2011, 11:43 PM
Members who have read this thread: 8
