Results 1 to 5 of 5
    May 2013
    WTB laserdisc freeride rim. Valve stem won't fit.
    Hi, I just picked up a new wheel today to replace a very badly damaged one, and my old tube stem won't fit through the second hole through the rim.
    Is this rim designed perhaps for a smaller stem or am I missing something?
    Thank you in advance. (all items other than this rim are from my stock 2008 GT Avalanch 1.0)
    I have no real aspirations to switch to presta valves, and honestly, it looks wider than those anyway, just not wide enough for the schraeder. Should I carefully drill it a little wider? It's not a particularly thin rim.
    If so, is there perhaps a manual tool that can do this a little less heavy handedly than my Dewalt will?
    My concern is rim integrity, or lack thereof created by me enlarging that hole a little.
    Rob.
    May 2013
    And I grew tired of waiting and enlarged it. Seems fine.
    My drill has an incremental speed trigger, so i just took it super slow, switching up drill sizes one at a time until the size was right. Cleaned up the hole and it inflated fine. The hole is still nowhere near the edges of the rim.
    meow meow
    Reputation: b-kul's Avatar
    should be fine. most mtg rims are presta but drilling them out some doesnt hurt.
    Downhill fan
    Reputation: #Cyclelife's Avatar
    I have the same rim and did the same thing. Just make sure to remove all the burrs on the valve stem hole so it don't kill your tube. That rim takes a beating!!!!!
    I'm thinking about shreddin' it up right now!
    Giant Glory DH (custom)
    K2 Evo 4.0 FS XC (custom)
    May 2013
    Quote Originally Posted by #Cyclelife View Post
    Many thanks for the moral support.
    I had an old countersink drill bit that cleaned up the edge perfectly when I ran it super slowly. It looks like a nicer job than the original.
  1. Different valve stem???
    By stonemxfan369 in forum General Discussion
    Last Post: 04-01-2013, 08:34 PM
  2. Replies: 13
    Last Post: 11-27-2012, 12:22 AM
  3. Valve stem leak
    By ryguy135 in forum 29er Bikes
    Last Post: 08-22-2012, 10:45 PM
  4. Broken Valve Stem
    By knumbskull in forum Shocks and Suspension
    Last Post: 06-20-2012, 07:04 AM
  5. WTB TCS Valve Stem
    By Inuitbiker in forum Wheels and Tires
    Last Post: 09-11-2011, 08:35 AM
