Results 1 to 10 of 10
    Reputation: nauc's Avatar
    would my GT parts work with a Heckler frame
    i have a 2010 GT Avalanche Expert, thinking about buying a new Heckler frame. could i transfer my parts over to the Heckler. im not trying to make it an AM rig or anything like that (at least for now), just want to know if my stuff is compatible
    heres what i have
    Rockshox 335 130mm fork
    CaneCreek headset 11/8"
    Shimano FCM 542 cranks (3x9)
    Shimano Outboard 2 peice sealed bottom bracket
    GT threadless stem for 31.8mm
    GT bars
    GT post 31.6mm
    Juicy 3 brakes 7" front, 6" back
    SLX shifters and front de
    XT rear de
    WTB speed disc rims with Shimano Deore hubs and 2.1 Kenda Nevs
    thanks
    Reputation: Fix the Spade's Avatar
    Mostly yes.
    If my memory serves, the Avalanche uses a Zero Stack (ZS44) headset. The Heckler needs a normal (EC34) or if it's the very latest model a tapered (ZS44/EC49 I think).
    The other bit that may need replacing is the front mech.
    Other than that all the other parts should fit.
    whats the "front mech"
    and would it ride ok with a 5.11" travel fork. i think they come stock with a 5.9" travel fork
    thanks
    Front derailleur, the bit that shifts gear at the cranks.
    It won't be perfect with a 130mm fork, but it will ride fine. You won't find it suddenly hurling you forwards at random intervals.
    why wouldnt the front D might not work?
    The front mech is normally clamped onto the seat tube. The clamp's diameter has to match the frame or you can't fit it. However a lot of front mechs come with inserts that let them fit more than one size.
    I'm not sure what size the outer seat tube are for either frame, so I can't tell if the front mech you have will fit to the Heckler. It's not a huge deal though, the front mech's a pretty cheap part to replace if needs be.
    meow meow
    Reputation: b-kul's Avatar
    might need new brake adapters too but those are cheap.
    might need a new seat post as well. What size head tube on the GT and Santa Cruz? Need to make sure those are the same, if not you need to buy the right headset.
    Sep 2012
    Hey I just built a heckler but it was an 2011 or 2012 frame not sure I got it on their website on closeout. They have a bunch more I think too. But if it is a 13 frame they changed to a taper head set. So your fork and headset won't work and the seat post is 30.9 if you have any more questions.
    Quote Originally Posted by Dmac80sc View Post
    their site says the headtube is 1 1/8"
    Santa Cruz Bicycles
